John Deere 466 Silage Special Round Baler Operators Manual OME92599
- Download this document, you need 300 Gallons
Brand: John Deere
Type of Machine: Round Baler
Model: John Deere 466 Silage Special Round Baler
Serial Number: 115501-
Part Number: OME92599
Number of Pages: 344 Pages
Safety
Safety Signs
Preparing the Tractor
Adjusting the Drawbar
Using Heavy-Duty Tractor Drawbar
Using Drawbar Shield
Making Drawbar Shield
Three-Point Hitch Position
Adjusting Tractor Wheels
Checking Ballast, Wheel Spacing and
Tire Inflation
Setting Hydraulic Outlets
Tractor Convenience Outlet
Installing BaleTrak® PLUS
Monitor-Controller on Tractor
Open-Station
ComfortGard™ Cab
SOUND-GARD® Cab
Using Extended Rear-View Mirror
Preparing the Baler
Checking Oversize Bale Switch
Selecting Twine
Loading Twine Boxes
Routing Twine from Left-Hand Twine Box
(Front Arm)
Routing Twine from Right-Hand Twine
Box (Rear Arm)
Wheel Spindle Positions
Mega Pickup
Wide Pickup
Adjusting Wheel Spindles
Tire Inflation
Checking Wheel Nut Torque
Preparing Baler for Net Wrap
Selecting Net Wrap Material
Care of Net Wrap Material
Page
Additional Net Wrap Storage
Opening and Closing Net Wrap Cover
Using Net Wrap After Extended Storage
Manually Releasing Net Wrap Brake
Threading Net Wrap and Routing
Through Rolls
Attaching and Detaching
Attaching Baler to Tractor Drawbar
PTO Driveline
Assembling (If Necessary)
Connecting
Attaching to Tractor Hydraulic Systems
Using Tractor Convenience Outlet
Connecting Baler Wiring Harness to
Tractor
Connecting Warning Light Wiring Harness
to Tractor
Detaching Baler from Tractor
Transporting
Handling Round Bales
Operating the Baler
How the Baler Forms a Bale
Crop Preparation
Breaking In Baler
Keep Riders Off Machine
Rotating Output Shaft by Hand
BaleTrak® PLUS Monitor-Controller
Introduction
Description
Keys and Switches
Displays and Indicators
Setup Values and Initial Settings
Diagnostic and Setup Modes
Diagnostic and Setup Channels
Operating
Resetting to Initial Settings (Channel 01)
Activating Alarms
Adjusting Audible Alarm Volume
Setting Bale Diameter
Adjusting Bale Diameter Display
Understanding Variable Core Feature
Adjusting Variable Core Diameter
Understanding Twine Wrap Terms and
Settings
Setting Twine Spacing
Setting Number of Twine End Wraps
Setting Twine End Wrap Distance
Setting Number of Net Wraps (If
Equipped)
Recommended Baling Guidelines
Interpreting Bale Shape Bars
Weaving in the Windrow
Viewing and Resetting Bale Counters
Using Manual Actuator, Wrap, and
By-Pass Switches
Using By-Pass Switch (Twine Wrap)
Advanced Operational Information
Using Dry Straw Twine Wrap Program
(Channel 17)
Adjusting Bale Shape Sensitivity
(Channel 24)
Adjusting Near-Full Indicator Set Point
(Channel 25)
Adjusting New Wrap Delay (Channel
26)
Adjusting Bale Shape Bars (Channel
28)
Changing Monitor-Controller Display to
Metric or English Units
Changing Baler Model Program
Bale Density Gauge
Adjusting
Bale Density
Twine Tension
Pickup Height
Gauge Wheels—Mega Pickup
Gauge Wheels—Wide Pickup
Gathering Wheel Height
Checking Baler Performance in the Field
Locking the Gate
Unplugging Baler With Hydraulic Pickup
Lift (If Equipped)
Unplugging Baler Under Power
Page
Compressor Rack Assembly
Removing
Installing
Adjusting (Mega Pickup)
Adjusting Channel (Mega Pickup)
Setting Pickup Feeder Forks (Wide
Pickup)
Starting a Bale in Difficult Conditions
Baling
Short, Dry, Slick Crops
Cornstalks
Long, Stiff, Cane-Type Crops
Wet Hay
Fire Prevention
Extinguishing a Fire
Bale Push Bar (If Equipped)
Operation
Operating
Locking Out
Engaging
Lubrication and Maintenance
Grease
Gear Case Oil
Observe Lubrication Symbols
Perform Lubrication and Maintenance
Fire Prevention
Belt Pins
Every 10 Hours
Every 30 Hours
Every 50 Hours
Every 100 Hours
Annually
Troubleshooting
PTO Driveline Difficulties
Main Drive Slip-Clutch Difficulties
Drive Chain Difficulties
Gear Case Difficulties
Diagnosing Hydraulic Functions
Automatic Twine Wrap
Difficulties
Feeding Difficulties
Pickup Difficulties
Bale Quality
General Baler Difficulties
Push Bar Difficulties
Silage Baling Difficulties
Net Wrap Difficulties
Service—Baler
Practice Safe Service Procedures
Fire Prevention
Keep Service Area Clean
Service Tires Safely
BaleTrak® PLUS Component Locations
Wiring Diagrams
BaleTrak® PLUS Control System
Warning Light
Replacing Monitor Fuses and Relays
Hydraulic System Diagram
Installing Orifice in Tractors With Low
Hydraulic Flow
Adjusting
Pickup Drive Chains—Mega Pickup
Pickup Drive Chains—Wide Pickup
Lower Belt and Cleaning Auger Drive
Roll Chain
Upper Drive Roll Chain
Servicing Upper Chain and Idler
Replacing Chain Idler Bushing
Adjusting
Slipping
Checking Pickup Slip-Clutch Torque
Belt Tracking
Checking
Adjusting
Adjusting Scrapers
Lower Feed Roll
Starter Roll
Idler Roll
Auger Scrapers (Wide Pickup)
Cleaning Auger
Adjusting
Take-Up Arm Compression Spring
Twine Indicator Retaining Strap
Twine Cutter Tension
Cutter Link Support and Twine Arm
Clearance
Twine Arm Distance from Right
Sidesheet
Front Twine Arm
Twine Cutter to Twine Arm
Checking Knife Adjustment
Page
Twine Electric Actuator Installation
Adjustment
Adjusting Twine Arm to Starter Roll and
Twine Arm Stop
Adjusting Pickup Float Springs
Mega Pickup
Wide Pickup
Adjusting Pickup Lift Crank Stop Nuts
(Wide Pickup)
Hydraulic Pickup Lift Cylinder Dimension
Checking Pickup Tooth End Play
Adjusting Gate Latch Stop
Adjusting Gate Latch Linkage
Replacing Sensors
Twine Wrap
Bale Diameter
Bale Shape
Adjusting Switches
Twine Wrap Sensor (Channel 03—With
Sound)
Bale Diameter Sensor (Channel
05—With Sound)
Bale Shape Bar Display (Channels 07
and 09)
Bale Shape Sensor (Channels 07 and
09—With Sound)
Testing
Gate Latch and Oversize Bale
Switches (Channels 11-12-13)
Twine Wrap Actuator Current (Channel
14)
Tractor Convenience Outlet Voltage
(Channel 15)
Lighted Crystal Display (LCD) Panel
(Channel 16)
Oversize Bale
Adjusting Gate Latch Switches
Checking Microswitches
Raising Gate With Hoist
Checking Belt Pins
Correct Belt Lacing and Pin Installation
Incorrect Belt Lacing and Pin Installation
Installing Belts
Repairing Belts
Belts Not Eligible for Warranty
Replacement
Service—Net Wrap
Releasing Feed Roll Brake
Correcting Net Wrap Feeding Problems
Repairing Cuts On Feed Roll
Brake Bar Tension
Decreasing
Increasing
Adjusting Knife Arm Stop
Checking Feed Roll Brake
Adjusting Feed Roll Pressure
Net Wrap Switch
Testing (Channel 10)
Adjusting
Checking Cutoff Indicator Channel Travel
Knife
Removing and Installing
Sharpening
Actuator
Testing Current (Channel 14)
Removing
Installing
Removing and Installing Net Wrap V-Belt
Net Wrap V-Belt Idler Arm
Checking Adjustment
Adjusting Net Wrap Roll Support Brackets
Checking and Adjusting Lower Net Wrap
Guide
Storage
Specifications
Machine Specifications
Machine
Record Product Identification Numbers
Bolt and Cap Screw Torque Value Charts
Metric
Inch
Crime Prevention Tips
Index
Brand: John Deere
Safety
Safety Signs
Tire Inflation
Open-Station
ComfortGard™ Cab
SOUND-GARD® Cab
Preparing the Baler
Selecting Twine
Loading Twine Boxes
(Front Arm)
Box (Rear Arm)
Mega Pickup
Wide Pickup
Tire Inflation
Page
Through Rolls
PTO Driveline
Connecting
Tractor
to Tractor
Transporting
Operating the Baler
Crop Preparation
Breaking In Baler
Introduction
Description
Keys and Switches
Operating
Activating Alarms
Settings
Equipped)
By-Pass Switches
(Channel 17)
(Channel 24)
(Channel 25)
26)
28)
Bale Density Gauge
Adjusting
Bale Density
Twine Tension
Pickup Height
Locking the Gate
Lift (If Equipped)
Page
Removing
Installing
Pickup)
Baling
Cornstalks
Wet Hay
Fire Prevention
Operation
Operating
Locking Out
Engaging
Grease
Gear Case Oil
Fire Prevention
Belt Pins
Every 10 Hours
Every 30 Hours
Every 50 Hours
Every 100 Hours
Annually
Troubleshooting
Difficulties
Pickup Difficulties
Bale Quality
Service—Baler
Fire Prevention
Wiring Diagrams
Warning Light
Hydraulic Flow
Adjusting
Roll Chain
Adjusting
Slipping
Belt Tracking
Checking
Adjusting
Adjusting Scrapers
Lower Feed Roll
Starter Roll
Idler Roll
Cleaning Auger
Adjusting
Clearance
Sidesheet
Front Twine Arm
Page
Adjustment
Twine Arm Stop
Mega Pickup
Wide Pickup
(Wide Pickup)
Replacing Sensors
Twine Wrap
Bale Diameter
Bale Shape
Adjusting Switches
Sound)
05—With Sound)
and 09)
09—With Sound)
Testing
14)
(Channel 15)
(Channel 16)
Oversize Bale
Checking Belt Pins
Installing Belts
Repairing Belts
Replacement
Service—Net Wrap
Brake Bar Tension
Decreasing
Increasing
Net Wrap Switch
Adjusting
Knife
Sharpening
Actuator
Removing
Installing
Checking Adjustment
Guide
Storage
Specifications
Machine
Metric
Inch
Index
- JOHN DEERE CODE DTC LIST
