Martin Welker
106
232,697
John Deere 4600 4611 4620 4640 4670 4680 4691 Row-Crop Cultivators Parts Catalog PC0495
Download this document, you need 250 Gallons
Brand: John Deere
Type of Machine: Row-Crop Cultivators
Model: John Deere 4600 4611 4620 4640 4670 4680 4691 Row-Crop Cultivators
Part Number: PC0495
Number of Pages: 47 Pages
ALPHABETICAL INDEX
B
Bar-type Center Rear Rig
Bar-type Rear Rig
C
Centering Brace for Bar-type Rear Rig
Crossheads
Center Rear Rig Lift Parts
Double Spring Tooth Shank
F
Frame on Tractor Equipped with Wide Adjustable Front Axle (40T Tractors Prior to Serial No. 100,000) (Used on 4620)
Frame on Tractor Equipped with Wide Adjustable Front Axle (40T Serial No. 100,000 and Up, 430T, and 420T) (Used on 4620)
Friction Trip Shank, 1-3/8-inch Shank
Front Frame Bar (Used on 4600 and 4611)
Front Frame Bar (Used on 4640, 4670, 4680, 4691 Cultivators)
Front Frame Bar (Used on 4670)
Front Frame Bar (Used on 4620)
Front Frame Stand
Front Rig Lift Parts (Used on 4600 and 4620)
Front Rig Lift Parts (Used on 4611, 4680, and 4691)
Front Rig Lift Parts (Used on 4640 and 4670)
Front Rig Lift Pipe (Used on 4600, 4611, and 4620)
Front Rig Lift Pipe (Used on 4640, 4670, 4680, and 4691)
Front Rigs (Position No. 1 on 4600, 4611, 4620, 4640, 4670, and 4691)
Front Rigs (Positions No. 3 Through No. 8 on 4600, 4620, 4640, and 4670) (Positions No. 3 Through No. 6 on 4611 and 4691)
Front Rigs (Position No. 2 on 4600, 4611, 4620, 4640, and 4670)
I
ID VIEW
O
Outer Rear Rig Lift Parts
P
Parallel Center Rear Rigs
Parallel Outer Rear Rigs
Q
Quick-adjustable Spring-trip Shank, 1-3/8-inch Shank
Quik-tatch Frame (Used on 4600 and 4611)
Quik-tatch Frame (Used on 4640, 4670, 4680, 4691 Cultivators)
Quik-tatch Frame (Used on 4620 Cultivator)
R
Rear Tool Frames (Used on 4680 Cultivator)
Rubber Tire Gauge Wheel, Castering Type
Rubber Tire Gauge Wheel, Rigid Type
S
Safety Reflector and Brackets
Shank Standard for Bar-type Rear Rig
Shield
Solid Shield
Square Bars and Clamps for Vegetable Cultivator (Used on 4600, 4640, and 4670)
Steel Gauge Wheel, Casterin g Type
Straight Center Rear Rigs
Straight and Offset Outer Rear Rigs
Stub Beam and Single Spring-tooth Shank (No. 1 Attachment)
T
Tool Frame and Rig (Positions No. 1 Through No. 4 on 4680 Cultivators)
Tractor Frame (4670 Cultivator Only)
Tractor Frame (Used on 4640, 4680, and 4691)
Truss Rods (Used on 4600 Series)
Truss Rods (Used on 4611)
Truss Rods (Used on 4620, 4640, 4670, 4680, 4691)
