Martin Welker
104
230,310
John Deere 459 459S 559 559S Round Baler Operators Manual OMFH313138
Format: HTML
Brand: John Deere
Type of Machine: Round Baler
Model: John Deere 459 459S 559 559S Round Baler
Parts Number: OMFH313138
Foreword
Dealers Record
Predelivery
Delivery
After-Sale
Section 05 - Safety Features
Machine Safety Features
Section 10 - Safety
Recognize Safety Information
Follow Safety Instructions
Protect Bystanders
Operate Baler Safely
Operate Safely on Slopes
Handle Round Bales Safely
Prepare For Emergencies
Fire Prevention
In Case of Fire
Wear Protective Clothing
Stay Clear of Rotating Drivelines
Use Safety Lights and Devices
Use a Safety Chain
Tow Loads Safely
Practice Safe Maintenance
Avoid High-Pressure Fluids
Section 15 - Safety Sign Location
Replace Safety Signs
Safety Signs
Section 16 - In Case of Fire
In the Case of Fire—Supplemental Information
Section 20 - Preparing the Tractor
Adjust Drawbar
Tractor Drawbar (Heavy-Duty)
Three-Point Hitch Position
Adjust Tractor Wheels
Check Ballast, Wheel Spacing, and Tire Inflation
Adjust Tractor Hydraulic Outlets
Tractor Convenience Outlet
Right-Hand Rear-View Mirror
Extended Rear-View Mirror
Section 21 - Preparing the Tractor for BaleTrak™ Pro
Install BaleTrak™ Pro Monitor-Controller on Open-Station Tractor
Install BaleTrak™ Pro Monitor-Controller in ComfortGard™ Cab
Install BaleTrak™ Pro Monitor-Controller In SOUND-GARD™ Cab
Section 25 - Preparing the Baler
Select Twine
Load Twine Boxes
Route Twine—Right-Hand Side (Rear Arm)
Route Twine—Left-Hand Side (Front Arm)
Adjust Baler Hitch
Adjust Wheel Spindles
Wheel Spindle Positions on 459 Baler with Regular Pickup and 11L-14 Tires
Wheel Spindle Positions on 459 and 559 Balers with Regular Pickup and 14L x 16.1 Tires
Wheel Spindle Positions on 459, 459S, and 559 Balers with MegaWide™ Plus Pickup and 14L x 16.1 Tires
Wheel Spindle Positions on 459, 459S, 559, and 559S Balers with MegaWide™ Plus Pickup and 21.5L x 16.1 Tires
Tire Inflation Pressures
Tire Installation and Wheel Nut Torque
Check Gate Lock Valve Interlock Lever Adjustment
Section 26 - Preparing Baler for Net or B-Wrap
Select Net Wrap Material
Care of Net Wrap Material
Open and Close Net Wrap Cover
Load B-Wrap Material
Wrap Material Storage
Release Net Wrap Feed Roll Brake
Thread and Route Net Wrap Material
Section 30 - Attaching and Detaching
Assemble Main PTO Driveline (If Necessary)
Attach Baler to Tractor Drawbar
Install Drawbar Shield
Connect PTO Driveline
Attach to Tractor Hydraulic System
Connect Baler Wire Harness to Tractor (BaleTrak™ Pro System)
Connect Tail or Warning Light Plug to Tractor
Detach Baler From Tractor
Section 35 - Transporting
Prepare Baler for Transport
Follow Safe Transport Procedures
Light Enhancement Module Operation
Section 36 - Break-In Period
Break-In Baler
After the First 10 Hours—Wheel Nut Torque
After the First 50 Hours—Gear Case
After the First 50 Hours—Wheel Nut Torque
Section 40 - Operating the Baler
Before Each Use of the Baler
Handle Round Bales
Handle Round Bales with Net Wrap
Handle Round Bales With B-Wrap
Feed Round Bales
Crop Preparation
BaleTrak™ Pro Monitor-Controller System Introduction
BaleTrak™ Pro Monitor-Controller Description
BaleTrak™ Pro Monitor-Controller Keys and Switches
BaleTrak™ Pro Monitor-Controller Displays and Indicators
BaleTrak™ Pro Monitor-Controller Setup Values and Initial Settings
BaleTrak™ Pro Monitor-Controller Customer and Setup Channels
BaleTrak™ Pro Monitor-Controller Channels
BaleTrak™ Pro Monitor-Controller Operation
Activate BaleTrak™ Pro Monitor-Controller Alarms
Adjust Audible Alarm Volume
Operation of Pickup Slip Clutch
(MegaWide™ Plus Pickup)
Slip Clutch Alert
Set Bale Diameter
Adjust Bale Diameter Display
Optional Variable Core Feature
Adjust Variable Core Diameter (If Equipped)
Twine Wrap Terms and Settings
Set Twine Spacing
Set Number of Twine End Wraps
Set Twine End Wrap Distance
Set Number of Net Wraps (If Equipped)
Net Switch Indicator
Monitor Display for B-Wrap Baling
Recommended Baling Guidelines
Interpret Bale Shape Indicators
Weave in the Windrow
View and Reset Bale Counter
Manual Actuator, Wrap, and Bypass Switches
Bypass Switch (Twine Wrap Only)
Reset BaleTrak™ Pro Monitor-Controller To Initial Settings (Channel 001)
Dry Straw Twine Wrap Program (Channel 002)
Set Twine Re-Extension (Channel 003)
Set Cinch Wrap (Channel 004)
Adjust Bale Diameter Sensor
(Channel 005)
Adjust Net Wrap Delay (Channel 006)
Adjust Bale Shape Sensor
(Channels 007 and 009)
Monitor-Controller Display, Metric or English Units (Setting) (Channel 008)
Set Near-Full Indicator Set Point
(Channel 010)
Set Bale Shape Sensitivity (Channel 011)
Test Net Switch (Channel 012)
Test Gate Close and Oversize Bale Switches—Monitor-Controller Assisted Test (Channels 013 and 014)
Check PTO and Lower Drive Roll Speed (Channels 016 and 017)
Test Twine or Net Wrap Actuator Current (Channel 018)
Test Tractor Convenience Outlet Voltage (Channel 019)
Test Liquid Crystal Display (LCD) Panel (Channel 020)
Twine Arm Calibration (Channel 029)
Adjust Delay of Twine Eject (Channel 033)
Adjust Cut Position (Channel 034)
Adjust Bale Orientation (Channel 035)
Baler Model Program (Channel 201)
Twine Feature (Channel 202)
(Turning On and Off)
Net Wrap and B-Wrap Feature (Channel 203)
Slip Clutch Alert PTO Speed Sensor
(Channel 204) (Turning On and Off)
Slip Clutch Alert Pickup RPM Sensor
(Channel 205) (Turning On and Off)
Calibrate Slip Clutch Alert PTO and Pickup RPM Sensors
(Channels 206 and 207)
Activate Optional Variable Core Operation (Channel 208)
Adjust Twine Tension
Adjust Pickup Height
Adjust Gauge Wheels
Adjust B-Wrap Sensor
Adjust Gathering Wheel Height (If Equipped)
Baler Performance in the Field
Lock the Gate
Unplug Pickup
Start a Bale in Difficult Conditions
Bale Short, Dry, Slick Crops
Bale Cornstalks
Bale Long, Stiff, Cane-Type Crops
Bale Wet Hay
Operate Baler With Bale Ramp (If Equipped)
Understand Bale Ramp Regulator (Relief) Valve
Adjust Bale Ramp (If Equipped)
Section 45 - Attachments
Pickup Gauge Wheels (459 and 559 with Regular Pickup)
Gathering Wheels
Hi-Flotation Tires
High-Moisture Kit (459 and 559)
Hydraulic Pickup Lift
Hydraulic Bale Ramp
Adjustable Twine Guides
Belt Lacing Tool
Skiving Tool
Electrical Outlet Socket
Variable Core Valve—BaleTrak™ Pro System
COVER-EDGE™ Surface Wrap Unit
BaleTrak™ Pro Monitor-Controller (If Equipped)
BaleTrak™ Pro Monitor-Controller Mounting Brackets
Mounting Kit for Open Station 6000 and 7000 Series Tractors
Crop Deflector Kit
Fire Extinguisher
Silage Auger Kit
Cornstalk Feeding Enhancement Kit
(559 and 559S Only)
Pickup Filler Plates for Cornstalks
(MegaWide™ Plus Pickup Only)
Allied Equipment
Section 50 - Lubrication and Maintenance
Lubricating and Maintaining Machine Safely
Grease
Gear Case Oil
Observe Lubrication Symbols
Perform Lubrication and Maintenance
Fire Prevention
As Required - Belt Pins
As Required - Tension Arm Wear Channels
First 50 Hours
Every 10 Hours
Every 30 Hours
Every 100 Hours
Annually
Section 55 - Troubleshooting
PTO Driveline Difficulties
Main Drive Friction Slip Clutch
Drive Chain Difficulties
Gear Case Difficulties
Diagnose Hydraulic Functions
Twine Wrap Difficulties—BaleTrak™ Pro System
BaleTrak™ Pro Monitor-Controller Difficulties
Slip Clutch Alert
Feed Difficulties
Feed Difficulties With Roller Baffle
Pickup Difficulties
Bale Quality—BaleTrak™ Pro System
General Baler Difficulties—BaleTrak™ Pro System
Bale Ramp Difficulties
High-Moisture Kit (Silage Baling) Difficulties
Net Wrap Difficulties
BaleTrak™ Pro Monitor-Controller Error Codes
Section 60 - Service—Baler
Detailed Service Information
Practice Safe Service Procedures
Fire Prevention
Keep Service Area Clean
Service Tires Safely
Hydraulic System Diagram
Rotate Output Shaft By Hand
Adjust Lower Drive Roll Chain
Adjust Upper Roll Drive Chain
Replace Drive Roll Bearings or Left-Hand Sprockets
Install Left-Hand Upper Drive Roll Bearing
Replace Left-Hand Lower Drive Roll Bearing
Replace Right-Hand Lower Drive Roll Bearing
Install Upper Right-Hand Drive Roll Bearing
Remove Compressor Rack (Regular Pickup)
Install Compressor Rack (Regular Pickup)
Adjust Compressor Rack (Regular Pickup)
Remove Compressor Rack (MegaWide™ Plus)
Install Compressor Rack (MegaWide™ Plus)
Adjust Compressor Rods (MegaWide™ Plus)
Remove and Install Roller Baffle
Adjust Roller Baffle Height
Adjust Roller Baffle Float Tension
Balance Roller Baffle
Replace Teeth (Pickup Installed)
Adjust Main PTO Driveline Slip Clutch
Slip Main PTO Driveline Slip Clutch
Adjust Initial Length of Pickup Drive Belt Idler Spring—Regular Pickup (459 and 559)
Adjust Pickup Drive Belt Idler—Regular Pickup (459 and 559)
Adjust Pickup Drive Chains (MegaWide™ Plus Pickup)
Check Pickup Slip Clutch Torque (MegaWide™ Plus)
Adjust PTO and Drive Roll Slip Clutch Alert Sensors (MegaWide™ Plus Pickup)
Net Wrap, Slip Clutch Alert, and Variable Core Features (Turn On and Off)
Adjust Pickup Float Springs—Regular Pickup (459 and 559)
Adjust Pickup Float Springs—MegaWide™ Plus Pickup
Adjust Initial Length of Hydraulic Lift Cylinder (If Equipped)
Check Pickup Tooth Rotational Play
Adjust Clearance Between Cutter Link Support and Twine Arm
Adjust Front Twine Arm
Adjust Twine Cutter-to-Twine Arm
Twine Arm Timing (559 and 559S)
Check and Adjust Twine Cutter Knife
Adjust Twine Arm-to-Starter Roll, Cutter Link Support, and Twine Arm Stop
Adjust Lower Feed Roll Scraper
Adjust Starter Roll Scraper (If Equipped)
Adjust Auger Scrapers (MegaWide™ Plus Pickup)
Check and Adjust Clearance Between Cleaning Auger and Staggered Belt Roll (459S and 559S)
Adjust Twine Indicator Retaining Strap
Adjust Bale Size Indicator
Adjust Take-Up Arm Compression Spring
Adjust Upper Tension (Take-Up) Arm Cylinder
Check Microswitches
Raise Gate With Hoist
Remove and Install Bale Ramp
(If Equipped)
Check Belt Pins
Check Belt Tracking
Adjust Belt Tracking
Correct Belt Lacing and Pin Installation
Incorrect Belt Lacing and Pin Installation
Install Belts
Repair Belts
Belts Eligible for Warranty Replacement
Belts Not Eligible for Warranty Replacement
Section 61 - Service—Net Wrap
Net Wrap Use After Extended Storage
Net Wraps on Rubber Drive Roll
Correct Net Wrap Feeding Problems
Check For Looped Net Material
Check and Adjust Net Wrap Feed Roll Brake
Check Front Sheet-to-Rubber Roll Clearance
Repair Cuts on Rubber Feed Roll
Adjust Net Wrap Counterknife
Sharpen Net Wrap Knife
Install and Adjust Net Wrap Brush
Check and Adjust Net Pan Pressure
Check and Straighten Net Pan Angle
Check and Adjust Net Pan Pressure without Leaf Spring
Check For Bent Rubber Crop Deflectors
Check and Adjust Net Wrap V-Belt Idler Tension
Check For Left-Hand Side Counterknife Contact
Check Hole Wear in Surface Wrap Side Panel
Check and Adjust Net Wrap Feed Roll Brake Spring
Adjust Net Wrap Feed Roll Pressure
Test Net Wrap Switch—Monitor-Controller Assisted Test (Channel 012)
Check and Adjust Net Wrap Switch
Final Adjustment of Net Wrap Switch—In Field
Remove and Install Knife
Test Net Wrap Actuator Current (Channel 018)
Remove Net Wrap Actuator
Install Net Wrap Actuator
Remove and Install Net Wrap V-Belt
Check and Adjust Lower Net Wrap Guide
Adjust Net Wrap Stretch
Section 62 - Service—BaleTrak™ Pro System
BaleTrak™ Pro System Component Locations
Wire Diagram—BaleTrak™ Pro Monitor-Controller Control System
Wire Harness Diagram—BaleTrak™ Pro Monitor-Controller
Wire Harness Diagram—Baler
Adjust Twine Arm Distance From Right Sidesheet —(459 and 459S) (Electric)
Twine Electric Actuator Installation Adjustment
Adjust Twine Cutter Tension (Electric)
Replace Bale Diameter Sensor
Replace Bale Shape Sensor
Replace Gate Close Switch
Replace Oversize Bale Switch
Replace and Adjust Bale Diameter Sensor Mounting Bracket
Adjust Bale Diameter Sensor (Channel 005)
Adjust Bale Shape Sensor—Field Procedure (Channels 007 and 009)
Adjust Bale Shape Sensor—In Shop Procedure (Channels 007 and 009)
Adjust Oversize Bale Switch
Adjust Bale Size Link For Maximum Bale Size (Oversize Warning)
Adjust Gate Close Switch
Section 65 - Storage
End of Season
Start of Season
Section 70 - Assembly
Perform Predelivery Service Safely
Install Jack
Install PTO Slip Clutch Alert Sensor and Driveline
Adjust Baler Hitch
Install Hitch Pin and Safety Chain
Prepare to Install Wheel Spindles and Tires
Install Wheel Spindles on 459 Baler with Regular Pickup and 11L-14 Tires
Install Wheel Spindles on 459 and 559 Baler with Regular Pickup and 14L x 16.1 Tires
Install Wheel Spindles on 459, 459S, and 559 Balers with MegaWide™ Plus Pickup and 14L x 16.1 Tires
Install Wheel Spindles on 459, 459S, 559, and 559S Balers with MegaWide™ Plus Pickup and 21.5L x 16.1 Tires
Check Wheel Nut Torque
Check Tire Inflation Pressures
Install Gauge Wheels (Regular Pickup)
Install Gauge Wheel Arms
Install Gauge Wheels (MegaWide™ Plus Pickup)
Install Slow Moving Vehicle (SMV) Sign in Operating Position
Install Fire Extinguisher—459 and 559
Install Fire Extinguisher—459S and 559S
Apply Powder to Belts
Section 75 - Specifications
459 Round Baler Specifications
459 Silage Special Round Baler Specifications
559 Round Baler Specifications
559 Silage Special Round Baler Specifications
BaleTrak™ Pro Monitor-Controller Specifications
Tractor Compatibility
Hitch Weights
Section 80 - Serial Numbers
Serial Number Plate
Serial Number Plate Description
Record Baler Serial Number
Keep Proof of Ownership
Keep Machines Secure
Section SERVLIT - John Deere Service Literature Available
Technical Information
Section IBC - John Deere Service Keeps You On The Job
John Deere Is At Your Service
