Martin Welker
104
230,310
John Deere 4560 4760 4960 Tractor Operators Manual OMAR112280
Brand: John Deere
Model: John Deere 4560 4760 4960 Tractor
Part Number: OMAR112280
Number of Pages: 302 Pages
Safety
Safety Signs
Controls and Instruments
Control Location
Instrument Location
Indicator Description
Tachometer
Performance Monitor
Radar
Lighting and Signals
Switch
Lamps
Electrical Outlets
Operator Station
SOUND-GARD® Body Temperature
Controls
Window Wipers and Washers
Windows
Radio
Tape Player
Seat Belt
Steering Wheel
Engine Break-in
Prestarting Checks
Operating the Engine
Start-up Procedure
Cold Weather Starting
Starting Aids
Booster Battery
Warm-Up and Operation
Stopping the Engine
Page
Operating the Tractor
Brakes
Differential Lock
Power Shift Transmission
QUAD-RANGE™ Transmission
Mechanical Front-Wheel Drive (MFWD)
Rockshaft and Three-Point Hitch
Component Identification
Rockshaft Controls
Rockshaft Control Lever
Rate-of-Drop
Rockshaft Raise/Lower Limit Switch
Rockshaft System Troubleshooting
Sway Blocks
Hitch Conversion
Attaching Implement Hitch
Adjusting Implement Level
Removing Implement
Remote Hydraulic Cylinders
Hose Tips
Identifying SCV
Connecting Cylinder Hoses
Operating SCV
Setting Remote Cylinder Stroke
Disconnecting Cylinder Hoses
Adjusting SCV Linkage
Drawbar and PTO
Drawbar Adjustments
Power Take-Off (PTO)
Ballast
Guidelines
Measuring Wheel Slip
Determining Ballast
Liquid Weight
Rear Cast Iron Weights
Implement Codes
Quik-Tatch Weights
Wheels, Tires and Treads
Guidelines
Implement-To-Tire Clearance
Inflation Pressures
MFWD Tire Combinations
Tightening Wheel and Axle Bolts
MFWD Wheels
Front Axle, Wheels, Tread Settings
Adjusting
Check Toe-In
Adjustable
MFWD
MFWD Tread Settings
Steering Stops
Adjust Front Fenders
Adjusting Rear Wheels
Rear Tread Settings
Dual Wheel Hub Extensions
Transporting
Driving
Carrier
Towing
Fuels, Lubricants and Coolant
Fuel
Engine Oil
Engine Coolant
Transmission-Hydraulic Oil
Lubricants
Lubrication and Maintenance
First 100 Hours
Lubrication and Maintenance/10 Hour
Lubrication and Maintenance/250 Hour
Lubrication and Maintenance/750 Hour
Lubrication and Maintenance/1000 Hour
Lubrication and Maintenance/1500 Hour
Lubrication and Maintenance/Annual
Page
Lubrication and Maintenance/2 Year
Lubrication and Maintenance/As
Required
Troubleshooting
Brakes
Rockshaft 3-Point Hitch
Electrical
SOUND-GARD Body
Service
Access
Air Cleaner
Belts
Fuel System
Electrical
Fuses
Lighting
Starter
Brakes
Tires
Heating and Air Conditioner
ROPS
Storage
Placing Tractor in Storage
Short-Term Idle Periods
Removing Tractor From Storage
Crime Prevention Tips
Specifications
General
Ground Speeds
Identification Numbers
Lubrication and Maintenance Records
Index
