Martin Welker
104
230,310
John Deere 4555 4755 4955 Tractor Operators Manual OMRW25630
Brand: John Deere
Model: John Deere 4555 4755 4955 Tractor
Part Number: OMRW25630
Number of Pages: 290 Pages
Safety
Safety Signs
Controls and Instruments
Control Location
Instrument Location
Indicator Description
Tachometer
Performance Monitor
Radar
Lighting and Signals
Switch
Lamps
Electrical Outlets
Operator’s Station
SOUND-GARD® Body Temperature
Controls
Window Wipers and Washers
Windows
Radio
Tape Player
Seat Belt
Steering Wheel
Engine Break-in
Prestarting Checks
Operating the Engine
Start-up Procedure
Cold Weather Starting
Starting Aids
Booster Battery
Warm-Up and Operation
Stopping the Engine
Page
Operating the Tractor
Brakes
Differential Lock
Power Shift Transmission
QUAD-RANGE™ Transmission
Mechanical Front-Wheel Drive (MFWD)
Rockshaft and Three-Point Hitch
Component Identification
Rockshaft Controls
Rockshaft Control Lever
Rate-of-Drop
Rockshaft Raise/Lower Limit Switch
Rockshaft System Troubleshooting
Sway Blocks
Hitch Conversion
Attaching Implement Hitch
Adjusting Implement Level
Removing Implement
Remote Hydraulic Cylinders
Hose Tips
Identifying SCV
Connecting Cylinder Hoses
Operating SCV
Setting Remote Cylinder Stroke
Disconnecting Cylinder Hoses
Adjusting SCV Linkage
Drawbar and PTO
Drawbar Adjustments
ower Take-Off (PTO)
Ballast
Importance of Ballast
Measuring Wheel Slip
Rear Ballast
Front Ballast
Installing QUIK-TATCH™ Weights
Wheels, Tires and Treads
Wheel Tightening
Front Wheel Tread Settings
Toe-in
Toe-in (MFWD)
Rear Wheel Spacing
Dual Wheels
Hub Extensions
Bolt-on Duals
Tire Pressures
MFWD Wheel Spacing
Steering Stops
Front Fender Adjustment
Tire Combinations
Transporting
Driving
Carrier
Towing
Fuels, Lubricants and Coolant
Fuel
Engine Oil
Engine Coolant
Transmission-Hydraulic Oil
Lubricants
Lubrication and Maintenance
First 100 Hours
Lubrication and Maintenance/10 Hour
Lubrication and Maintenance/250 Hour
Lubrication and Maintenance/750 Hour
Lubrication and Maintenance/1500 Hour
Lubrication and Maintenance/Annual
Lubrication and Maintenance/2 Year
Lubrication and Maintenance/As
Required
Troubleshooting
Page
Brakes
Rockshaft 3-Point Hitch
Electrical
SOUND-GARD Body
Service
Access
Air Cleaner
Belts
Fuel System
Electrical
Fuses
Lighting
Starter
Brakes
Tires
Heating and Air Conditioner
ROPS
Storage
Placing Tractor in Storage
Short-Term Idle Periods
Removing Tractor From Storage
Crime Prevention Tips
Specifications
General
Ground Speeds
Identification Numbers
Daily Maintenance
Lubrication and Maintenance Records
Index
