John Deere 4555 4755 4955 4560 4760 4960 Tractor Repair Technical Manual TM1460
Brand: John Deere
Model: John Deere 4555 4755 4955 4560 4760 4960 Tractor
Part Number: TM1460
Publication Date: 2001
Number of Pages: 906 Pages
SECTION 05—SAFETY
Group 05—Safety Information
SECTION 10—GENERAL INFORMATION
Group 05—Machine Specifications
Group IO—Predelivery Service
Group 15—Tune-up
Group 20—Lubrication
SECTION 15—SEPARATION
Group 05—Front Axle
Group 10—Front End
Group 15—Front End and Engine
Group 20—Engine
Group 25—SOUND-GARD Body
Group 30—Power Shift Clutch Housing
Group 31—OUAD-RANGE Clutch Housing
Group 35—Transmission
Group 40—Final Drive
SECTION 20—ENGINE
Group 05—Service
Group 10—Cooling System
SECTION 30—FUEL AND AIR
Group 05—Air Intake System
Group 10—Diesel Fuel System
SECTION 40—ELECTRICAL REPAIR
Group 05—Connector Repair
Group 10—Harness Replacement
Group 15—Alternator
Group 20—Starting Circuit
Group 25—Lighting Circuit Repair
Group 30—INTELLITRAK Monitoring System
Group 35—Accessory Components
Group 40—Hitch Electronic Control Components
Group 45—Electronic Governor Control Components
Group 50—Auxiliary Lighting and Electrical Components (European)
SECTION 50—POWER TRAIN QUAD-RANGE TRANSMISSION
Group 05—Clutch Oil Pressure Regulating Valve Housing
Group 10—Clutch Operating Piston Housing
Group 15—Perma-Clutch
Group 20—Quad-Range Planetary
Group 25—Quad-Range Transmission and Charge Pump
Group IBC—Shift Lever Assembly
Group 35—PTO Gear Train
Group 40—Adjust PTO Clutch Rod
SECTION 55—POWER TRAIN—POWER SHIFT TRANSMISSION
Group 05—Remove and Install Traction Clutch Valve Housing
Group 10—Traction Clutch Valve Housing
Group 15—Remove and Install Transmission
Control Valve Housing
Group 20—Transmission Control Valves and Accumulators
Group 25—Remove and Install Traction Clutch
Group 30—Traction Clutch and Drive Shafts
Group 35—Input Planetary
Group 40—Reduction Gear Train
Group 45—Output Planetary
Group 50—Speed Selector Assembly
Group 55—Charge Pump Assembly
Group 60—PTO Gear Train WITH MFWD
Group 65—PTO Gear Train WITHOUT MFWD
Group 70—PTO Clutch Rod
Group 75—MFWD Gear Train
Group 80—MFWD Clutch
SECTION 56—DIFFERENTIAL AND FINAL DRIVE
Group 05—Differential
Group 10—Differential Lock Valve
Group 15—Final Drive
SECTION 60—STEERING AND BRAKES
Group 05—Remove and Install Power Steering Components
Group 10—Steering Column
Group 15—Metering Pump
Group 20—Steering Valve
Group 25—Steering Motor
Group 30—Remove and Install Brake Valve and Brake Accumulator
Group 35—Brake Valve
Group 40—Brake Accumulator
Group 45—Bleeding Brakes and Testing Brake Accumulator
Group 50—Brake Pistons, Plates and Disks
Group 55—Auxiliary Trailer Brake (European)
Group 60—Secondary Brake (European)
Group 65—Auxiliary Steering System (European)
SECTION 70—HYDRAULICS
Group 05—Hydraulic System Repair
Group 10—Main Hydraulic Pump
Group 15—Oil Filter Relief Valve and Return Manifold
Group 20—Hydraulic Oil Cooler and Bypass Valve
Group 25—Rock shalt‚ Draft Control and Lift Assist Cylinders
Group 30—Hitch Control Valve
Group 35—Control Valves
Group 40—Selective Control Valves and Breakaway Couplers
Group 45—Remote Cylinder
Group 50—Transmission-Hydraulic Cleanup
SECTION 80—MISCELLANEOUS
Group 05—Rear Wheels
Group 10—Front Axle
SECTION 90—OPERATOR STATION REPAIR
Group 05—Air Conditioning System
Group 10—Air Conditioning System Service
Group 15—Heating System
Group 20—Seat
Group 25—ROPS and SOUND-GARD Body
SECTION 99—DEALER FABRICATED TOOLS
Group 05—Fabricated Tools
Index
Brand: John Deere
Part Number: TM1460
SECTION 05—SAFETY
Group 15—Tune-up
Group 05—Front Axle
Group 10—Front End
Group 20—Engine
SECTION 20—ENGINE
Group 05—Service
Group 15—Alternator
Group 10—Front Axle
Group 20—Seat
Index
- JOHN DEERE CODE DTC LIST
