John Deere 4520 Tractor Technical Manual TM1007
- Download this document, you need 300 Gallons
Brand: John Deere
Type of Manual: Technical Manual
Model: John Deere 4520 Tractor
Part Number: TM1007
Number of Pages: 322 Pages
SECTION 10 - GENERAL
Group 5 — Specifications
Group 10 - Predelivery, Delivery, and After-Sale Services
Group 15 - Tune-Up
Group 20 - Lubrication
Group 25 - Separation
SECTIONZO — ENGINE
Group 5 — General Information,Diagnosis, and Tests
Group 10 — Cylinder Head, Valve Train, and Camshaft
Group 15 - Cylinder Block, Liners, Pistons, and Rods
Group 20 — Crankshaft, Main Bearings, and Flywheel
Group 25 — Lubrication System
Group 30 - Cooling System
SECTION 30 - FUEL SYSTEM
Group 5 - Diagnosing Malfunctions
Group 10 - Fuel Injection System
Group 15 - Air Intake System
Group 20 - Speed Control Linkage
SECTION 40 - ELECTRICAL SYSTEM
Group 5 - Information and Wiring Diagram
Group 10 - Charging Circuit
Group 15 - Starting Circuit
Group 20 - Lighting and Accessory Circuits
SECTION 50 - POWER TRAIN
Group 5 - Clutches for Syncro-Range Transmission and PTO
Group 10 - Syncro-Range Transmission
Group 15 - Engine Disconnect Clutch
Group 20 - Power Shift Transmission
Group 25 - Differential
Group 30 — Final Drive
Group 35 - Syncro-Range PTO
Group 40 - Power Shift PTO
Group 45 - Power Front Wheel Drive
SECTION 60 - STEERING AND BRAKES
Group 5 - General Information
SECTION 70 — HYDRAULIC SYSTEM
Group 5 - General Information, Diagnosis, and Tests
Group 10 - Main Reservoir, Filters,Valves, Oil Cooler, and Oil Reservoir
Group 15 - Hydraulic Pumps
Group 20 - Power Steering
Group 25 - Power Brakes
Group 30 — Rockshaft, 3-Point Hitch, and Quik-Coupler
Group 35 — Selective Control Valve, Break away Couplers, and Remote Cylinders
SECTION 80 - MISCELLANEOUS
Group 5 - Conventional Front Axle
Group 10 - Power Front Wheel Drive Axle
Brand: John Deere
Part Number: TM1007
Group 15 - Tune-Up
SECTIONZO — ENGINE
- JOHN DEERE CODE DTC LIST
