John Deere 45 Series Self-Propelled Combines Parts Catalog PC0433
Brand: John Deere
Type of Machine: Self-Propelled Combines
Model: John Deere 45 Series Self-Propelled Combines
Part Number: PC0433
Number of Pages: 317 Pages
ALPHABETICAL INDEX
A
Adjustable Long Divider (Special)
Air Cleaner (Engine)
Arm, Reel
Arms, Reel Support, R.H. and L.H.
Auger, Clean Grain And Housing
Auger, Grain Tank, Hinged Unloading
Auger, Grain Tank Loading
Auger, Lower Tailings
Auger, Weed Seed and Housing for Hart ScourKleen Model "N" (Grain Tank)
Axle, Extensions, Front (Special)
Axle, Rear
Axle, Support
B
Bar, Cylinder Stripper
Bar, Rasp
Bar, Weed (Special)
Battery Clamp and Cables
Bearings, Connecting Rod (Engine)
Bearings, Main (Engine)
Bearings, Wood (For Straw Walker Crnakshaft)
Beater Behind Cylinder
Bell Housing (Engine)
Blade Assembly, Cooling Fan
Blade, Fan (For Straw Spreader)
Blade, Straw Chopper
Block, Cylinder and Head (Engine)
Bottom, Grain Conveyor
Brace, at Front of Separator to Axle
Brake and Clutch Controls on Operator's Platform
Brake, Main Wheel and Linings
Brake, Parking, Controls
C
Cables, Starter and Gound (For Battery)
Camshaft and Bearings (Engine)
Carburetor
Chaffer Frame, Seals and Rear Support
Chaffers and Finger Bar
Choke and Throttle Controls
Chopper, Straw
Chute, Sack
Clean Grain Auger
Clean Grain Elevator
Clutch and Brake Controls on Operator's Platform
Clutch, Main Wheel
Coil (Engine)
Concave Teeth
Concaves and Grate, Rasp-Bar Cylinder
Concaves Snap-On Covers (Special)
Concaves, Spike-Tooth
Connecting Rod and Piston (Engine)
Control, Hydraulic, for Platform Lift
Control, Hydraulic for Selective Ground Speed
Control Rod, Separator Belt Tightener Lever
Controls, Gear Shift
Controls, Steering, on Operator's Platform
Controls, Valve (LP-Gas)
Conveyor Bottom, Grain
Conveyor Chain, Grain
Conveyor in Feeder House
Crank, Shoe Pitman
Crankshaft (Engine)
Crankshafts and Bearings, Straw Walker
Cutter Bar Extension (Special)
Cutting Platform Support Stand (Special)
Cylinder Block and Head
Cylinder, Hydraulic Selective Ground Speed Control
Cylinder, Rasp-Bar
Cylinder, Spike-Tooth
Cylinder Sprockets
Cylinder Stripper Bar
Cylinder Tooth
Decalcomania Set
Differential and Transmission
Distributor
Divider, Adjustable Long (Special)
Divider, Platform End, Sheet L.H. and R.H.
Drive Gears and Housing, Main Wheel Final
Drive, Clean Grain Auger
Drive, Cooling Fan and Generator
Drive, Cylinder
Drive, Feed Rolls
Drive, Feeder Conveyor
Drive, Grain Conveyor
Drive, Grain Tank Loading Auger
Drive, Grain Tank Unloading Auger (Belt)
Drive, Grain Tank Unloading Auger (Chain)
Drive, Hydraulic Unit
Drive, Main Wheels
Drive, Platform Auger
Drive, Reel
Drive, Rotor, Hart ScourKleen Model "N"
Drive, Separator Drive Belt and Tightener
Drive, Sickle and Auger on L.H. Side Feeder House
Drive, Straw Chopper
Drive, Straw Spreader
Drive, Straw Walker, Shoe and Fan
Drive, Tailings Auger, Lower
Drive, Tailings Auger, Upper
Drive, Weed Seed Auger, Hart ScourKleen Model "N"
E
Elevator, Clean Grain and Tailings
End Sheet Extensions, Platform (Special)
End Sheet, Platform, L.H. and R.H.
Engine, John Deere HA-145 - See Parts Catalog, PC-537
Engine, Hercules JX-4C-3, Bearings, Connecting Rod
Engine, Hercules JX-4C-3, Bearings, Main
Engine, Hercules JX-4C-3, Bell Housing
Engine, Hercules JX-4C-3, Camshaft and Bearings
Engine, Hercules JX-4C-3, Crankshaft
Engine, Hercules JX-4C-3, Cylinder Block and Head
Engine, Hercules JX-4C-3, Flywheel
Engine, Hercules JX-4C-3, Fuel Pump and Filter
Engine, Hercules JX-4C-3, Gasoline Tank and Supports
Engine, Hercules JX-4C-3, Gear Cover, Breather Tube
Engine, Hercules JX-4C-3, Generator
Engine, Hercules JX-4C-3, Governor
Engine, Hercules JX-4C-3, Oil Filter
Engine, Hercules JX-4C-3, Oil Pan
Engine, Hercules JX-4C-3, Oil Pump
Engine, Hercules JX-4C-3, Piston and Connecting Rod
Engine, Hercules JX-4C-3, Piston Rings
Engine, Hercules JX-4C-3, Powershaft
Engine, Hercules JX-4C-3, Radiator and Screen
Engine, Hercules JX-4C-3, Spark Plug
Engine, Hercules JX-4C-3, Starting Motor
Engine, Hercules JX-4C-3, Valves and Valve Cover
Engine, Hercules JX-4C-3, Voltage Regulator on Generator
Engine, Hercules JX-4C-3, Water Pump
Engine Support
Exhaust Pipe and Manifold
Extension, Cutter Bar (Special)
Extension Divider
Extensions for Platform End Sheets (Special)
Extensions, Front Axle (Special)
F
Fan, Cooling (Engine)
Fan Housing (Cleaning) and Shields
Fan Shaft (Cleaning) and Bearings
Feed Rolls and Housing
Feeder House
Feeder House Conveyor Chain
Filter, Oil (Purolator)
Final Drive
Fingers, Grain Grate
Fingers, Platform Auger
Floorboard, Sacking Platform
Flywheel (Engine)
Fuel Tanks and Support (Gasoline and LP-Gas)
G
Gaskets, Bell Housing
Gaskets, Carburetor
Gaskets, Cooling Fan
Gaskets, Cylinder Block and Head (Engine)
Gaskets, Distributor
Gaskets, Exhaust Pipe and Manifold
Gaskets, Fuel Pump and Filter
Gaskets, Gasoline Tank and Fuel Filter
Gaskets, Gear Cover, Breather Tube
Gaskets, Generator
Gaskets, Governor
Gaskets, Hydraulic Pump
Gaskets, Oil Filter
Gaskets, Oil Pan (Engine)
Gaskets, Oil Pump
Gaskets, Valve Cover (Engine)
Gaskets, Voltage Regulator
Gaskets, Water Outlet (Radiator)
Gaskets, Water Pump
Gaskets, Water Pump Inlet (Radiator)
Gear Shift Controls
Gear, Steering
Generator
Governor
Grain Conveyor Bottom
Grain Conveyor Chain with Shafts
Grain Grate and Concaves
Grain Grate Fingers
Grain Pan
Grain Tank
Grain Tank Hinged Unloading Auger
Grate and Concaves
Guard for Clean Grain and Tailings Auger Drive Chain
Guard for Transmission Sheave
Guards and Sickle
Handrails, Sacking Platform
Hangers and Rocker Arms for Shoe, and Chaffer Frame
Hangers and Shaft at Front of Grain Pan
Hinged Ladder on Operator's Platform
Holders, Sack and Sacking Spout
Hood, Rear
Hose Connection, Radiator
Housing for Clean Grain Hinged Unloading Auger
Housing for Fan (Cleaning)
Housing for Feed Rolls
Housing for Flywheel with Ring Gear (Engine)
Housing for Grain Tank Loading Auger
Housing for ScouKleen, Hart, Weed Seed Auger
Housing for Upper Tailings Auger
Hydraulic Controls for Platform Lift
Hydraulic Controls for Selective Ground Speed
Hydraulic Cylinders, Platform Lift
Hydraulic Cylinders, Selective Gound Speed Control
Hydraulic Hoses, Hydraulic Oil Reservoir
Hydraulic Hoses, Platform Lift
Hydraulic Oil Lines
Hydraulic Unit Drive
Hydraulic Unit Drive Shaft
Hydraulic Valve
I
ID VIEW
Intake Pipe, Air Cleaner
K
Knife Sections (For Straw Chopper)
L
Ladder on Separator
Ladder, Operator's Platform
Lever, Gear Shift
Lever, Grain Tank Unloading
Lever, Platform Hydraulic
Lever, Selective Ground Speed Control
Lever, Separator Belt Tightener
Lifting Guards (For Sickle)
Lighting Attachment
Lighting, Implement Warning
Lines, Oil
Linings, Brake, Main Wheel
Lower Tailings Auger
M
Main Bearings (Engine)
Main Wheel
Main Wheel Brake and Linings
Main Wheel Clutch
Main Wheel Transmission Gears and Case
Manifold and Exhaust Pipe
Motor Starting
O
Oil Filter (Purolator)
Oil Lines
Oil Pan
Oil Pump
Oil Reservoir, Hydraulic
Operator's Platform
Operator's Platform Ladder
Operator's Platform Seat
Operator's Seat, Sacking Platform
P
Paddles, Elevator
Pan, Oil
Pipe, Intake, Air Cleaner
Pipe, Reel
Piston and Connecting Rod (Engine)
Pitman, Sickle
Platform Auger
Platform Bottom Shields
Platform End Sheet Extensions (Special)
Platform End Sheet, L.H., and Divider
Platform End Sheet, R.H., and Divider
Platform Extension Divider
Platform, Operator's
Platform, Sacking, Support Angles and Handrails
Powershaft on Engine
Pre-Cleaner (Engine)
Pump, Fuel and Filter
Pump, Hydraulic
Pump, Oil
Pump, Water
R
Radiator, Radiator Screen, and Water Line
Rasp Bar
Rear Axle
Rear Hood
Rear Wheels and Stub Axle
Reel Arm, Pipe, and Slat
Reel Slats End Shield (Special)
Reel Support Arms, LH. and R.H.
Reflective Tap, Safety
Regulator, Voltage
Rings, Piston Compression (Engine)
Rods, Connecting (Engine)
Rotor Drive, Hart ScourKleen, Model "N"
S
Sack Chute and Supports
Sack Holders
Sack Shelf
Sacking Platform Floorboard and Operator's Seat
Sacking Platform Side Sheets
Sacking Platform, Support Angle, and Handrails
Sacking Spout
ScouKleen, Hart, Model "N"
Screen, Radiator
Screens, Hart ScourKleen, Model "N"
Seat, Operator's Platform
Seat, Operator's Sacking Platform
Section, Sickle
Separator Belt Tightener Control
Separator Front End Sheets
Shield, End Reel Slats (Special)
Shield for Upper Tailings Auger Drive (Special)
Shields, Cleaning Fan Housing
Shields, Feeder Conveyor Drive
Shields, Platform Bottom
Shoe, Seals, Tail Board and Door
Shoe Pitman and Crank
Sickle
Sickle and Auger Drie Shaft ant Rear of Platform
Sickle Pitman
Sieves, Chaffer and Finger Bar
Slat, Reel
Spacer, Rear of Separatpr
Spark Plug Wires and Coil
Spark Plugs
Spike-Tooth Concaves and Cylinder
Spout, Hinged Unloading Auger
Spout, Sacking
Spout, Weed Seed (Sacker)
Spouts, ScourKleen Discharge (Sacker)
Spreader, Straw
Starting Motor
Starting Switch
Steering Arms and Tie Rods
Steering Controls on Operator's Platform
Steering Gear
Stand, Support, Cutting Platform (Special)
Straw Chopper
Straw Chopper Housing, with Fins and Shields
Sraw Spreader
Straw Walkers, Crankshaft and Bearings
Support, Axle
Support Stand, Cutting Platform (Special)
Switch Box, Wire, and Cables
Switch, Starting
T
Tailings Auger Drive, Lower
Tailings Auger Drive, Upper
Tailings, Elevator
Tank, Fuel, and Supports (Lp-Gas)
Tank, Gasoline, and Supports
Tank, Grain
Tape, Reflective Safety
Tappets (Engine)
Throttle and Choke Controls
Tie Rods and Steering Arms
Tire and Tube, Main Wheel
Tooth, Concave and Cylinder
Transmission Sheave Guard
Tube, Breather
U
Upper Tailings Auger and Housing
Upper Tailings Auger Drive Shield (Special)
V
Valve Controls (LP-Gas)
Valves and Valve Coer (Engine)
Voltage Regulator
W
Walkers, Straw
Warning Lighting
Weed Bar (Special)
Weed Seed Auger and Housing for Hart ScourKleen, Model "N"
Weed Seed Spout and Box for Hart ScourKleen, Model "N"
Weed Seed Spout (Sacker)
Wheel, Main
Wheel, Rear
Wires, Cables and Switch Box
Wires, Spark Plug
Wrench, Wheel
Brand: John Deere
Part Number: PC0433
ALPHABETICAL INDEX
A
Arm, Reel
Axle, Rear
Axle, Support
B
Bar, Rasp
Bar, Weed (Special)
C
Carburetor
Chopper, Straw
Chute, Sack
Clean Grain Auger
Clutch, Main Wheel
Coil (Engine)
Concave Teeth
Crank, Shoe Pitman
Crankshaft (Engine)
Cylinder, Rasp-Bar
Cylinder Sprockets
Cylinder Tooth
Decalcomania Set
Distributor
Drive, Cylinder
Drive, Feed Rolls
Drive, Main Wheels
Drive, Reel
E
Engine Support
Extension Divider
F
Feeder House
Final Drive
Flywheel (Engine)
G
Gaskets, Carburetor
Gaskets, Generator
Gaskets, Governor
Gaskets, Oil Filter
Gaskets, Oil Pump
Gaskets, Water Pump
Gear Shift Controls
Gear, Steering
Generator
Governor
Grain Grate Fingers
Grain Pan
Grain Tank
Grate and Concaves
Guards and Sickle
Hood, Rear
Hydraulic Oil Lines
Hydraulic Valve
I
ID VIEW
K
L
Ladder on Separator
Lever, Gear Shift
Lighting Attachment
Lines, Oil
M
Main Wheel
Main Wheel Clutch
Motor Starting
O
Oil Lines
Oil Pan
Oil Pump
Operator's Platform
P
Paddles, Elevator
Pan, Oil
Pipe, Reel
Pitman, Sickle
Platform Auger
Pump, Hydraulic
Pump, Oil
Pump, Water
R
Rasp Bar
Rear Axle
Rear Hood
Regulator, Voltage
S
Sack Holders
Sack Shelf
Sacking Spout
Screen, Radiator
Section, Sickle
Sickle
Sickle Pitman
Slat, Reel
Spark Plugs
Spout, Sacking
Spreader, Straw
Starting Motor
Starting Switch
Steering Gear
Straw Chopper
Sraw Spreader
Support, Axle
Switch, Starting
T
Tailings, Elevator
Tank, Grain
Tappets (Engine)
Tube, Breather
U
V
Voltage Regulator
W
Walkers, Straw
Warning Lighting
Weed Bar (Special)
Wheel, Main
Wheel, Rear
Wires, Spark Plug
Wrench, Wheel
- JOHN DEERE CODE DTC LIST
