John Deere 45 Series Combine Parts Catalog PC0652
Brand: John Deere
Type of Machine: Combine
Model: John Deere 45 Series Combine
Part Number: PC0652
Number of Pages: 352 Pages
ALPHABETICAL INDEX
A
Adjustable Long Divider
Ammeter ( -35000)
Ammeter (35001-43000)
Ammeter (43001-46000)
Arm, Hanger, Shoe ( -43000)
Arm, Hanger, Shoe (43001- )
Arm, Rocker, Shoe ( -43000)
Arm, Rocker, Shoe (43001- )
Arms, Steering ( -35000)
Arms, Steering (35001- )
Arms, Support, Reel
Auger, Clean Grain ( -35000)
Auger, Clean Grain (35001- )
Auger, Drive Shaft, Platform
Auger, Fingers and Shafts
Auger, Flight Extensions, Platform
Auger, Grain Tank Loading
Auger, Grain Tank Unloading ( -35000)
Auger, Grain Tank Unloading (35001- )
Auger, Platform
Auger, Tailings, Lower
Auger, Tailings, Upper ( -35000)
Auger, Tailings, Upper (35001- )
Auger, Weed Seed, ScourKleen
Auger Drive, Grain Tank Loading ( -35000)
Auger Drive, Grian Tank Loading (35001- )
Auger Drive, Grain Tank Loading, ScourKleen ( -35000)
Auger Drive, Grain Tank Loading, ScourKleen (25001- )
Auger Drive, Grain Tank Unloading (35001- )
Auger Drive, Grain Tank Unloading, Front ( -35000)
Auger Drive, Grain Tank Unloading, Middle and Rear ( -35000)
Auger Drive, Platform
Auger Drive, Platform (On Feeder House)
Auger Drive, Tailings, Upper ( -35000)
Auger Drive, Tailings, Upper (35001- )
Auger Drive, Weed Seed, ScourKleen ( -35000)
Auger Drive, Weed Seed, ScourKleen (35001- )
Axle, Drive Wheel
Axle, Main Drive (Grain) ( -35000)
Axle, Main Drive (Grain) (35001- )
Axle, Main Drive (Rice)
Axle, Rear
Axle, Rear, Two Position and Wide Tread ( -35000)
Axle Spacers (2-3/8")
Axle Spacers (12")
Axle Supports
B
Bar, Finger, Chaffer
Beater Behind Cylinder, Drum-Type
Beater Behind Cylinder, Wing-Type
Blade, Cleaning Fan
Blade, Straw Chopper
Blade, Straw Spreader
Block, Guard and Knife Repair
Box, Tool
Brake, Controls, Pedal, and Parking ( -27900)
Brake, Controls, Pedal, and Parking (27901-35000)
Brake, Controls, Pedal, and Parking (35001- )
Brakes, Drive Wheel
Breaker, Circuit
C
Cable, Hydraulic Lift Reel
Cable, Variable Speed Reel
Chaffer and Sieves
Chaffer Frame, Shoe, and Seals ( -43000)
Chaffer Frame, Shoe, and Seals (43001- )
Choke and Throttle Controls, Gasoline ( -24700)
Choke and Throttle Controls, Gasoline (24701-35000)
Choke and Throttle Controls, Gasoline (35001- )
Choke and Throttle Controls, LP-Gas ( -24700)
Choke and Throttle Controls, LP-Gas (24701-35000)
Chopper, Straw, Blades and Shafts
Chopper, Straw, Drive, Front
Chopper, Straw, Drive, Rear
Chopper, Straw, Housing, Fins, and Shields
Chute, Sack, and Supports
Chute, ScourKleen Discharge, Grain Tank
Chute, ScourKleen Discharge, Sacker
Circuit Breaker
Clean Grain Auger ( -35000)
Clean Grain Auger (35001- )
Clean Grain Elevator, Grain Tank ( -35000)
Clean Grain Elevator, Grain Tank (35001- )
Clean Grain Elevator, Sacker ( -35000)
Clean Grain Elevator, Sacker (35001- )
Clean Grain Elevator Drive, Grain Tank ( -35000), Bottom
Clean Grain Elevator Drive, Grain Tank ( -35000), Top
Clean Grain Elevator Drive, Grain Tank (35001- )
Clean Grain Elevator Drive, Sacker ( -35000)
Clean Grain Elevator Drive, Sacker (35001-46000)
Clean Grain Elevator Extension Drives
Cleaning Fan Blade
Cleaning Fan Drive
Cleaning Fan Shafts and Bearings ( -43000)
Cleaning Fan Shafts and Bearings (43001- )
Cleaning Fan Shield, Air Intake ( -43000)
Cleaning Fan Shield, Air Intake (43001- )
Cleaning Fan Shield, Housing
Cleaning Shoe ( -43000)
Cleaning Shoe (43001- )
Cleaning Shoe Drive
Cleaning Shoe Hangers ( -43000)
Cleaning Shoe Hangers (43001- )
Cleaning Shoe Pitman and Crank
Cleaning Shoe Rocker Arms ( -43000)
Cleaning Shoe Rocker Arms (43001- )
Clutch, Drive Wheel
Clutch, Slip, Clean Grain Elevator ( -35000)
Clutch, Slip, Clean Grain Elevator (35001- )
Clutch, Slip, Grain Conveyor
Clutch, Slip, Reel
Clutch, Slip, Reel Drive Countershaft
Clutch, Slip, Tailings Elevator ( -35000)
Clutch, Slip, Tailings Elevator (35001- )
Clutch Controls and Pedal ( -27900)
Clutch Controls and Pedal (27901-35000)
Clutch Controls and Pedal (35001- )
Clutch Finger Gauge, Drive Wheel
Concave, Open Bar
Concave, Spike-Tooth
Concave Adjusting Controls ( -35000)
Concave Adjusting Controls (35001- )
Concave Cover Plates
Concave Extension, Cell-Type, Open Bar
Concave Extension, Cell-Type, Spike-Tooth
Concave Extension, Finger-Type, Open Bar
Concave Extension, Finger-Type, Spike-Tooth
Console, Instrument
Controls, Brake and Clutch ( -27900)
Controls, Brake and Clutch (27901-35000)
Controls, Brake and Clutch (35001- )
Controls, Choke and Throttle, Gasoline ( -24700)
Controls, Choke and Throttle, Gasoline (24701-35000)
Controls, Choke and Throttle, Gasoline (35001- )
Controls, Choke and Throttle, LP-Gas ( -24700)
Controls, Choke and Throttle, LP-Gas (24701-35000)
Controls, Concave Adjusting ( -35000)
Controls, Concave Adjusting (35001- )
Controls, Gearshift ( -35000)
Controls, Gearshift (35001- )
Controls, Grain Tank Unloading Auger ( -35000)
Controls, Grain Tank Unloading Auger (35001- )
Controls, Hydraulic Lift Reel ( -35000)
Controls, Hydraulic Lift Reel (35001- )
Controls, Platform Lift ( -35000)
Controls, Platform Lift (35001- )
Controls, Platform Throw-Out ( -46000)
Controls, Platform Throw-Out (46001- )
Controls, Selective Ground Speed ( -35000)
Controls, Selective Ground Speed (35001- )
Controls, Separator Throw-Out ( -46000)
Controls, Separator Throw-Out (46001- )
Controls, Steering ( -35000), on Operator's Platform
Controls, Steering ( -35000), on Side of Separator
Controls, Steering ( -35000), Cylinder and Valve
Controls, Steering ( -35000), Flow Divider ( -28584)
Controls, Steering (35001- ), Control Pump
Controls, Steering (35001- ), Control Valve
Controls, Steering (35001- ), Cylinder
Controls, Steering (35001- ), Wheel
Controls, Throttle (Diesel) ( -24700)
Controls, Throttle (Diesel) (24701-35000)
Controls, Throttle (Diesel) (35001-46000)
Controls, Variable Speed Reel
Conveyor, Clean Grain Elevator, Grain Tank ( -35000)
Conveyor, Clean Grain Elevator, Grain Tank (35001- )
Conveyor, Clean Grain Elevator, Sacker ( -35000)
Conveyor, Clean Grain Elevator, Sacker (35001-46000)
Conveyor, Clean Grain Elevator Extension
Conveyor, Feeder House
Conveyor, Grain
Conveyor, Tailings Elevator ( -35000)
Conveyor, Tailings Elevator (35001- )
Corn Attachment Seals
Countershaft, Elevator
Countershaft, Reel Drive
Countershaft, Reel Drive, Varibale Speed
Countershaft, Straw Chopper
Cover, Engine
Cover, Open Bar Concave Snap-On
Crank, Shoe
Crankshaft, Straw Walker
Cutter Bar
Cutter Bar Extension
Cylinder, Hydraulic, Platform Lift ( -35000)
Cylinder, Hydraulic, Platform Lift (35001- )
Cylinder, Hydraulic, Reel Lift
Cylinder, Hydraulic, Selective Ground Speed
Cylinder, Hydraulic, Steering ( -35000)
Cylinder, Hydraulic, Steering (35001- )
Cylinder, Separator, Drive, 3/4" Roller Chain
Cylinder, Separator, Drive, 1" Roller Chain
Cylinder, Separator, Rasp-Bar
Cylinder, Separator, Shear Hub Sprocket
Cylinder, Separator, Spike-Tooth
Decalcomania, Slow moving Vehicle
Decalcomania Set
Differential and Transmission
Differential and Transmission Case
Discharge Chute, ScourKleen, Grain Tank
Discharge Chute, ScourKleen, Sacker
Divider, Chaffer
Divider, Platform, Adjustable Long
Divider, Platform, L.H.
Divider, Platform, R.H.
Divider Extension
Door, Inspection
Drive, Clean Grain Elevator, Grain Tank ( -35000), Bottom
Drive, Clean Grain Elevator, Grain Tank ( -35000), Top
Drive, Clean Grain Elevator, Grain Tank (35001- )
Drive, Clean Grain Elevator, Grain TankScourKleen ( -35000), Top
Drive, Clean Grain Elevator, Grain Tank, ScourKleen (35001- )
Drive, Clean Grain Elevator, Sacker ( -35000)
Drive, Clean Grain Elevator, Sacker (35001-46000)
Drive, Clean Grain Elevator Extension
Drive, Cleaning Fan
Drive, Countershaft, Elevator (35001- )
Drive, Cylinder ( -35000)
Drive, Cylinder (35001-49000)
Drive, Cylinder (49001- )
Drive, Feed Roll, Lower
Drive, Feed Roll, Upper
Drive, Feeder Conveyor
Drive, Final, Grain ( -35000)
Drive, Final, Grain (35001- )
Drive, Final, Rice
Drive, Grain Conveyor
Drive, Grain Tank Loading Auger ( -35000)
Drive, Grain Tank Loading Auger (35001- )
Drive, Grain Tank Loading Auger (ScourKleen) ( -35000)
Drive, Grain Tank Loading Auger (ScourKleen) (35001- )
Drive, Grain Tank Unloading Auger ( -35000), Front
Drive, Grain Tank Unloading Auger ( -35000), Middle and Rear
Drive, Grain Tank Unloading Auger (35001- )
Drive, Hydraulic Pump
Drive, Platform Auger
Drive, Reel, Front
Drive, Reel, Middle
Drive, Reel, Rear
Drive, Reel, Variable Speed
Drive, Rotor, ScourKleen
Drive, Separator ( -46000)
Drive, Separator (46001- )
Drive, Shoe
Drive, Straw Chopper, Front
Drive, Straw Chopper, Rear
Drive, Straw Spreader
Drive, Straw Walker
Drive, Tailings Auger, Upper ( -35000)
Drive, Tailings Auger, Upper (35001- )
Drive, Tailings Elevator ( -35000)
Drive, Tailings Elevator (35001- )
Drive, Transmission
Drive, Weed Seed Auger, ScourKleen ( -35000)
Drive, Weed Seed Auger, ScourKleen (35001- )
E
Eccentric Pickup Reel ( -PF 49000)
Eccentric Pickup Reel (PF 49001- )
Elevator, Clean Grain, Grain Tank ( -35000)
Elevator, Clean Grain, Grain Tank (35001- )
Elevator, Clean Grain, Sacker ( -35000)
Elevator, Clean Grain, Sacker (35001- )
Elevator, Clean Grain (Grain Tank), Drive ( -35000), Bottom
Elevator, Clean Grain (Grain Tank), Drive ( -35000), Top
Elevator, Clean Grain (Grain Tank), Drive (35001- )
Elevator, Clean Grain (Grain Tank) (ScourKleen), Drive ( -35000), Top
Elevator, Clean Grain (Grain Tank) (ScourKleen), Drive (35001- )
Elevator, Clean Grain (Sacker), Drive ( -35000)
Elevator, Clean Grain (Sacker), Drive (35001- )
Elevator, Clean Grain, Extension
Elevator, Tailings ( -35000)
Elevator, Tailings (35001- )
Elevator, Tailings, Drive ( -35000)
Elevator, Tailings, Drive (35001- )
End Sheets, Platform, L.H.
End Sheets, Platform, R.H.
Engine Catalogues
Engine Cover
Engine Powershaft
Extension, Concave
Extension, Cutter Bar
Extension, Divider
Extension, Elevator
Extension, Elevator, ScourKleen
Extension, Feed Rolls
Extension, Feeder Conveyor Shield
Extension, Grain Tank ( -35000)
Extension, Ladder
F
Fan, Cleaning ( -43000)
Fan, Cleaning (43001- )
Fan, Cleaning, Drive
Fan, Cleaning, Shaft and Bearings ( -43000)
Fan, Cleaning, Shaft and Bearings (43001- )
Fan, Cleaning, Shields, Housing
Fan Spinning Screen ( -43000)
Feed Rolls
Feed Rolls Drive, Lower
Feed Rolls Drive, Upper
Feed Rolls Housing
Feeder Conveyor Chain
Feeder Conveyor Drive
Feeder Conveyor Drive Shaft
Feeder Conveyor Idler Shaft
Feeder House
Field Lights ( -43000)
Field Lights (43001- )
Filter, Fuel (Diesel) ( -16000)
Filter, Fuel (Gasoline)
Filter, Oil Reservoir (28585- )
Final Drive, Grain ( -35000)
Final Drive, Grain (35001- )
Final Drive, Rice
Finger, Pickup Reel ( -PF 49000)
Finger, Pickup Reel (PF 49001- )
Finger, Pickup Reel, Polygon and Double Eccentric ( -PF 49000)
Finger, Pickup Reel, Polygon and Double Eccentric (PF 49001- )
Finger, Pickup Reel, Plain Polygon ( -PF 49000)
Finger, Pickup Reel, Spoke Polygon ( -PF 49000)
Finger, Platform Auger
Finger Bar, Chaffer
Float, Platform
Float Indicator, Platform
Forks, Transmission
Fuel Tank and Lines, Diesel ( -46000)
Fuel Tank and Lines, Gasoline
Fuel Tank and Supports, LP-Gas ( -35000)
G
Gauge, Clutch Finger, Drive Wheel
Gauge, Oil Pressure ( -35000)
Gauge, Oil Pressure (35001-43000)
Gauge, Oil Pressure (43001-46000)
Gauge, Oil Pressure (46001- )
Gauge, Water Pressure ( -35000)
Gauge, Water Pressure (35001-43000)
Gauge, Water Pressure (43001-46000)
Gauge, Water Pressure (46001- )
Gear, Differential and Transmission
Gear, Steering, on Operator's Platform ( -35000)
Gear, Steering, on Side of Separator ( -35000)
Gearshift Controls ( -35000)
Gearshift Controls (35001- )
Gearshift Housing ( -35000)
Gearshift Housing (35001- )
Grain Conveyor Bottoms ( -27900)
Grain Conveyor Bottoms (27901- )
Grain Conveyor Chain
Grain Conveyor Shafts
Grain Tank
Grain Tank Extension ( -35000)
Grain Tank Unloading Auger Controls ( -35000)
Grain Tank Unloading Auger Controls (35001- )
Grain Tank Unloading Auger Drive Shaft ( -35000)
Grain Tank Unloading Auger Drive Shaft (35001- )
Grain Tank Unloading Auger Drive Sheave ( -35000), Front
Grain Tank Unloading Auger Drive Sheave ( -35000), Middle and Rear
Grain Tank Unloading Auger Drive Sheave (35001- )
Grain Tank Unloading Auger Housing ( -35000)
Grain Tank Unloading Auger Housing (35001- )
Guard, Knife
Guard, Lifting
Guard, Straw Spreader
Guard, Transmission Sheave
Guard Repair Block
Hand Rail, Engine
Hand Rail, Hinged Ladder ( -35000)
Hand Rail, Hinged Ladder (35001- )
Hand Rail, Operator's Platform ( -35000)
Hand Rail, Operator's Platform (35001- )
Hand Rail, Rigid Ladder ( -43000)
Hart ScourKleen
Hart ScourKleen Discharge Chute, Grain Tank
Hart ScourKleen Discharge Chute, Sacker ( -46000)
Hart ScourKleen Drive, Rotor
Hart ScourKleen Mounting Parts
Hart ScourKleen Weed Seed Spout Drive ( -35000), Bottom
Hart ScourKleen Weed Seed Spout Drive ( -35000), Top
Hart ScourKleen Weed Seed Spout Drive (35001- )
Hood, Rear
Horns, Signal
Horns, Signal, Switch
Hour Meter
Housing, Brake
Housing, Clean Grain Auger ( -35000)
Housing, Clean Grain Auger (35001- )
Housing, Clutch
Housing, Clutch Input Shaft
Housing, Differential and Transmission
Housing, Feed Rolls ( -46000)
Housing, Final Drive, Grain ( -35000)
Housing, Final Drive, Grain (35001- )
Housing, Final Drive, Rice
Housing, Gearshift ( -35000)
Housing, Gearshift (35001- )
Housing, Grain Tank Unloading Auger ( -35000)
Housing, Grain Tank Unloading Auger (35001- )
Housing, Steering Gear ( -35000)
Housing, Straw Chopper
Housing, Tailings Auger, Lower
Housing, Tailings Auger, Upper ( -35000)
Housing, Tailings Auger, Upper (35001- )
Hydraulic Cylinders, Platform Lift ( -35000)
Hydraulic Cylinders, Platform Lift (35001- )
Hydraulic Cylinders, Reel Lift
Hydraulic Cylinders, Selective Ground Speed
Hydraulic Cylinders, Steering ( -35000)
Hydraulic Cylinders, Steering (35001- )
Hydraulic Lift Reel Cables and Sheaves
Hydraulic Lift Reel Controls ( -35000)
Hydraulic Lift Reel Controls (35001- )
Hydraulic Lift Reel Cylinder
Hydraulic Lift Reel Oil Hose ( -35000)
Hydraulic Lift Reel Oil Hose (35001- )
Hydraulic Oil Lines, Platform Lift ( -35000)
Hydraulic Oil Lines, Platform Lift (35001- )
Hydraulic Oil Lines, Pump ( -35000)
Hydraulic Oil LInes, Pump (35001-46000)
Hydraulic Oil Lines, Pump (46001- )
Hydraulic Oil Lines, Selective Ground Speed ( -35000)
Hydraulic Oil Lines, Selective Ground Speed (35001- )
Hydraulic Oil Lines, Steering ( -28584)
Hydraulic Oil Lines, Steering (28585-35000)
Hydraulic Oil Lines, Steering (35001- )
Hydraulic Oil Lines, Steering Control Pump (35001- )
Hydraulic Pump, Manual Steering ( -26036)
Hydraulic Pump, Manual Steering (26037-35000)
Hydraulic Pump, Power Steering ( -28584)
Hydraulic Pump, Power Steering (28585-35000)
Hydraulic Pump, Power Steering (35001-46000)
Hydraulic Pump, Power Steering (46001- )
Hydraulic Pump Drive
Hydraulic Pump Drive Shaft and Mountings ( -46000)
Hydraulic Pump Drive Shaft and Mountings (46001- )
Hydraulic Pump Oil Lines ( -35000)
Hydraulic Pump Oil Lines (35001-46000)
Hydraulic Pump Oil LInes (46001- )
Hydraulic Oil Reservoir ( -28584)
Hydraulic Oil Reservoir (28585- )
Hydraulic Valve, Platform Lift ( -35000)
Hydraulic Valve, Platform Lift (35001-46000)
Hydraulic Valve, Platform Lift (46001- )
Hydraulic Valve, Reel Lift ( -35000)
Hydraulic Valve, Reel Lift (35001-46000)
Hydraulic Valve, Reel Lift (46001- )
Hydraulic Valve, Selective Ground Speed ( -35000)
Hydraulic Valve, Selective Ground Speed (35001-46000)
Hydraulic Valve, Selective Ground Speed (46001- )
Hydraulic Valve, Steering ( -35000)
Hydraulic Valve, Steering (35001- )
I
ID VIEW
Ignition Switch ( -35000)
Ignition Switch (35001-43000)
Ignition Switch (43001-46000)
Ignition Switch (46001- )
Implement Warning Lights
Indicator, Platform Float
Instrument Panel ( -35000)
Instrument Panel (35001- )
K
Knife
Knife Drive (On Feeder House)
Knife Drive Pitman
Knife Drive Shaft
Knife Drive Shaft (Variable Speed Reel)
Knife Repair Block
L
Ladder, Operator's Platform, Hinged ( -35000)
Ladder, Operator's Platform, Hinged (35001- )
Ladder, Operator's Platform, Rigid ( -43000)
Ladder, Separator (Grain Tank)
Ladder, Separator (Sacker) ( -46000)
Lifting Guards
Lights, Field ( -43000)
Lights, Field (43001- )
Lights, Implement Warning
Light, Tail
Light Switch (35001-43000)
Light Switch (43001-46000)
Light Switch (46001- )
Lines, Fuel, Diesel
Lines, Fuel, Gasoline
Lines, Oil, Hydraulic Pump ( -35000)
Lines, Oil, Hydraulic Pump (35001-46000)
Lines, Oil, Hydraulic Pump (46001- )
Lines, Oil, Platform Lift ( -35000)
Lines, Oil, Platform Lift (35001- )
Lines, Oil, Selective Ground Speed ( -35000)
Lines, Oil, Selective Ground Speed (35001- )
Lines, Oil, Steering ( -28584)
Lines, Oil, Steering (28585-35000)
Lines, Oil, Steering (35001- )
Lines, Oil, Steering Control Pump (35001- )
Linings, Brake
Linings, Clutch
Loading Auger, Grain Tank
M
Meter, Tach-Hour
O
Oil Pressure Gauge ( -35000)
Oil Pressure Gauge (35001-43000)
Oil Pressure Gauge (43001-46000)
Oil Pressure Gauge (46001- )
Operator's Platform Ladder, Hinged ( -35000)
Operator's Platform Ladder, Hinged (35001- )
Operator's Platform Ladder, Rigid ( -43000)
Operator's Platform Supports ( -35000)
Operator's Platform Supports (35001- )
P
Panel, Instrument ( -35000)
Panel, Instrument (35001- )
Parking Brake Controls ( -27900)
Parking Brake Controls (27901-35000)
Parking Brake Controls (35001- )
Pedals, Brake and Clutch ( -27900)
Pedals, Brake and Clutch (27901-35000)
Pedals, Brake and Clutch (35001- )
Pickup Reel, Polygon, Double Eccentric ( -PF 49000)
Pickup Reel, Polygon, Double Eccentric (PF 49001- )
Pickup Reel, Polygon, Plain ( -PF 49000)
Pickup Reel, Polygon, Spoke ( -PF 49000)
Pickup Reel Drive, Front
Pickup Reel Drive, Middle
Pickup Reel Drive, Rear
Pickup Reel Drive, Variable Speed
Pickup Reel Drive Shaft
Pickup Reel Drive Weed Shield
Pickup Reel Shafts and Sprocket
Pitman, Cleaning Shoe
Pitman, Knife
Plate, Clutch, Drive Wheel
Plate, Concave, Cover
Plate, Cylinder Filler
Platform, Operator's ( -35000)
Platform, Operator's (35001- )
Platform and Feeder House
Platform Angles and Braces
Platform Attaching Parts
Platform Auger
Platform Auger Fingers and Shafts
Platform Auger Flight Extensions
Platform Bottom Protective Wear Plates
Platform Divider, Adjustable Long
Platform Divider, L.H.
Platform Divider, R.H.
Platform Drive
Platform Float Attachment
Platform Lift Control Valve ( -35000)
Platform Lift Control Valve (35001-46000)
Platform Lift Control Valve (46001- )
Platform Lift Control (35001- )
Platform Lift Cylinders ( -35000)
Platform Lift Cylinders (35001- )
Platform Lift Oil Lines ( -35000)
Platform Lift Oil Lines (35001- )
Platform Support Stand ( -46000)
Platform Support Stand (46001- )
Platform Sheets, End, L.H.
Platform Sheets, End, R.H.
Platform Throw-Out Control ( -46000)
Platform Throw-Out Control (46001- )
Power Steering Control Pump ( -28584)
Power Steering Control Pump (28585-35000)
Power Steering Control Pump (35001- )
Power Steering Control Valve ( -35000)
Power Steering Control Valve (35001- )
Power Steering Cylinder ( -35000)
Power Steering Cylinder (35001- )
Power Steering Oil Lines ( -28584)
Power Steering Oil Lines (28585-35000)
Power Steering Oil Lines (35001- )
Power Steering Oil Lines, Steering Control Pump (35001- )
Power Steering Wheel ( -35000)
Power Steering Wheel (35001- )
Powershaft, Engine
Pump, Hydraulic, Drive Shaft and Mounting ( -46000)
Pump, Hydraulic, Drive Shaft and Mounting (46001- )
Pump, Hydraulic, Manual Steering ( -26036)
Pump, Hydraulic, Manual Steering (26037-35000)
Pump, Hydraulic, Power Steering ( -28584)
Pump, Hydraulic, Power Steering (28585-35000)
Pump, Hydraulic, Power Steering (35001-46000)
Pump, Hydraulic, Power Steering (46001- )
Pump, Hydraulic, Steering Control (35001- )
R
Rail, Hand, Engine
Rail, Hand, Hinged Ladder ( -35000)
Rail, Hand, Hinged Ladder (35001- )
Rail, Hand, Operator's Platform ( -35000)
Rail, Hand, Operator's Platform (35001- )
Rail, Hand, Rigid Ladder ( -43000)
Rail, Shifter, Transmission
Rasp-Bar Cylinder
Rear Hood
Rear Wheel and Spindle
Reel, Pickup ( -PF 49000)
Reel, Pickup (PF 49001- )
Reel Drive, Front
Reel Drive, Middle
Reel Drive, Rear
Reel Drive Countershaft (Not Variable Speed)
Reel Drive Countershaft (Variable Speed)
Reel Drive Shaft
Reel End Shields
Reel Shafts and Sprocket ( -PF 49000)
Reel Shafts and Sprocket (PF 49001- )
Reel Slat
Reel Support Arms
Reel Truss Rods ( -PF 49000)
Regulator, Voltage
Repair Block, Guard and Knife
Rocker Arms, Shoe ( -43000)
Rocker Arms, Shoe (43001- )
Rolls, Feed
Rotor Drive, ScourKleen
S
Sacker ( -46000)
Sacker Chute
Sacker Control, Chute Gate
Sacker Floorboard, Platform
Sacker Handrails, Platform
Sacker Holders, Sack
Sacker Platform
Sacker Seat, Operator's
Sacker Shelf, Sack
Sacker Side Sheets, Platform
Sacker Soput
Sacker Supports, Chute
Sacket Supports, Platform
ScourKleen
ScourKleen Discharge Spout, Sacker ( -46000)
ScourKleen Drive
ScourKleen Weed Seed Spout ( -35000), Bottom
ScourKleen Weed Seed Spout ( -35000), Top
ScourKleen Weed Seed Spout (35001- )
Screen, Fan Spinning ( -43000)
Seat ( -35000)
Seat (35001- )
Seat, Sacker ( -46000)
Sections, Knife
Sections, Straw Chopper
Selective Ground Speed Controls ( -35000)
Selective Ground Speed Controls (35001- )
Selective Ground Speed Control Valve ( -35000)
Selective Ground Speed Control Valve (35001-46000)
Selective Ground Speed Control Valve (46001- )
Selective Ground Speed Cylinder
Selective Ground Speed Drive Yoke and Sheaves
Selective Ground Speed Oil Lines ( -35000)
Selective Ground Speed Oil Lines (35001- )
Sensing Unit, Straw Walker
Separator Cross Brace
Separator Door, Inspection
Separator Drive ( -46000)
Separator Drive (46001- )
Separator Drive Shield, L.H. (35001- )
Separator Drive Shield, R.H. ( -35000)
Separator Drive Shield, R.H. (35001- )
Separator Front Sheets
Separator Ladder (Grain Tank)
Separator Ladder (Sacker) ( -46000)
Separator Throw-Out Control ( -46000)
Separator Throw-Out Control (46001- )
Separator Top Sheets
Shear Hub Sprockets, Cylinder
Sheaves, Cable, Hydraulic Lift Reel
Sheets, Platform End, L.H.
Sheets, Platform End, R.H.
Sheets, Separator, Front
Sheets, Separator, Top
Shields, Cleaning Fan ( -43000)
Shields, Cleaning Fan (43001- )
Shields, Cleaning Fan and Clean Grain Auger Housing ( -43000)
Shields, Cleaning Fan and Clean Grain Auger Housing (43001- )
Shields, Clean Grain Elevator Extension
Shields, Clean Grain Elevator Top Drive
Shields, Clean Grain and Tailings Elevator Bottom Drive ( -35000)
Shields, Feeder Conveyor
Shields, Feeder Conveyor Drive
Shields, Grain Conveyor Chain
Shields, Hart ScourKleen and Clean Grain Elevator Drive ( -35000)
Shields, Hart ScourKleen Weed Seed Auger Drive ( -35000)
Shields, Hart ScourKleen Weed Seed Auger Drive (35001- )
Shields, Hart ScourKleen Weed Seed Spout ( -35000)
Shields, Platform Auger Drive
Shields, Reel Front Drive
Shields, Reel Middle Drive
Shields, Selective Ground Speed Sheave
Shields, Separator Drive, L.H. (35001- )
Shields, Separator Drive, R.H. ( -35000)
Shields, Separator Drive, R.H. (35001- )
Shields, Slat Reel, End
Shields, Straw Chopper Rear Drive
Shields, Transmission Sheave
Shields, Upper Tailings Auger Drive ( -35000)
Shields, Valve Control, LP-Gas
Shifter Forks and Rails
Shoe, Cleaning ( -43000)
Shoe, Cleaning (43001- )
Shoe Drive
Sidehill Dividers, Shoe
Sieves and Chaffers
Signal Horns
Signal Horns Switch (43001- )
Slat, Reel
Slow Moving Vehicle Decalcomania
Spacers, Axle (2-3/8")
Spacers, Axle (12")
Spacer, Separator
Spike-Tooth Concave
Spike-Tooth Cylinder
Spindle, Rear Wheel
Spout, Grain Tank Unloading ( -35000)
Spout, Grain Tank Unloading (35001- )
Spout, Weed Seed, ScourKleen ( -35000)
Spout, Weed Seed, ScourKleen (35001- )
Spreader, Straw
Spreader, Straw, Guard
Spring, Platform Float
Stand, Platform Support ( -46000)
Stand, Platform Support (46001- )
Steering Arms and Tie Rods ( -35000)
Steering Arms and Tie Rods (35001- )
Steering Column ( -35000)
Steering Column (35001- )
Steering Flow Divider ( -28584)
Steering Valve ( -35000)
Steering Valve (35001- )
Stone Trap, Rod-Type
Stone Trap, Trough-Type
Straw Chopper Blades and Shafts
Straw Chopper Drive, Front
Straw Chopper Drive, Rear
Straw Chopper Housing, Fins, and Shields
Straw Spreader
Straw Spreader Guard
Straw Walkers
Straw Walkers Crankshafts and Bearings
Straw Walkers Drive
Straw Walkers Sensing Unit
Switch, Horn (43001- )
Switch, Ignition ( -35000)
Switch, Ignition (35001-43000)
Switch, Ignition (43001-46000)
Switch, Ignition (46001- )
Switch, Light (35001-43000)
Switch, Light (43001-46000)
Switch, Light (46001- )
T
Tach-Hour Meter
Tailings Auger Drive, Upper ( -35000)
Tailings Auger Drive, Upper (35001- )
Taillight
Tank, Fuel, and Lines, Diesel ( -46000)
Tank, Fuel, and Lines, Gasoline
Tank, Grain
Throttle Controls, Diesel ( -24700)
Throttle Controls, Diesel (24701-35000)
Throttle Controls, Diesel (35001-46000)
Tie Rods, Steering ( -35000)
Tie Rods, Steering (35001- )
Tool Box
Tooth, Beater, Drum-Type
Tooth, Concave, Spike-Tooth
Tooth, Cylinder, Spike-Tooth
Transmission and Differential
Transmission and Differential Case
Transmission and Differential Drive
Transmission and Differential Sheave Guards
Trap, Stone, Rod-Type
Trap, Stone, Trough-Type
U
V
Valve, Hydraulic, Platform Lift ( -35000)
Valve, Hydraulic, Platform Lift (35001-46000)
Valve, Hydraulic, Platform Lift (46001- )
Valve, Hydraulic, Reel Lift ( -35000)
Valve, Hydraulic, Reel Lift (35001-46000)
Valve, Hydraulic, Reel Lift (46001- )
Valve, Hydraulic, Selective Ground Speed ( -35000)
Valve, Hydraulic, Selective Ground Speed (35001-46000)
Valve, Hydraulic, Selective Ground Speed (46001- )
Valve, Hydraulic, Steering ( -35000)
Valve, Hydraulic, Steering (35001- )
Variable Speed Reel Control
Variable Speed Reel Countershaft
Variable Speed Reel Drive
Voltage Regulator
W
Walkers, Straw
Warning Lights, Implement
Water Temperature Gauge ( -35000)
Water Temperature Gauge (35001-43000)
Water Temperature Gauge (43001-46000)
Water Temperature Gauge (46001- )
Wear Plates, Platform Bottom, Protective
Weed Seed Spout, ScourKleen ( -35000)
Weed Seed Spout, ScourKleen (35001- )
Weed Shield, Reel Drive
Wheel, Drive
Wheel, Rear
Wheel, Steering ( -35000)
Wheel, Steering (35001- )
Wheel Wrench
Wiring, Instrument ( -35000)
Wiring, Instrument (35001-43000)
Wiring, Instrument (43001-46000)
Wiring, Instrument (46001- )
Y
Yoke, Selective Ground Speed
Brand: John Deere
Part Number: PC0652
ALPHABETICAL INDEX
A
Ammeter ( -35000)
Arms, Support, Reel
Auger, Platform
Axle, Drive Wheel
Axle, Rear
Axle Spacers (12")
Axle Supports
B
Blade, Cleaning Fan
Box, Tool
Brakes, Drive Wheel
Breaker, Circuit
C
Chaffer and Sieves
Circuit Breaker
Cleaning Fan Blade
Cleaning Fan Drive
Cleaning Shoe Drive
Clutch, Drive Wheel
Clutch, Slip, Reel
Concave, Open Bar
Console, Instrument
Conveyor, Grain
Cover, Engine
Crank, Shoe
Cutter Bar
Decalcomania Set
Divider, Chaffer
Divider Extension
Door, Inspection
Drive, Cleaning Fan
Drive, Final, Rice
Drive, Reel, Front
Drive, Reel, Middle
Drive, Reel, Rear
Drive, Shoe
Drive, Straw Walker
Drive, Transmission
E
Engine Catalogues
Engine Cover
Engine Powershaft
Extension, Concave
Extension, Divider
Extension, Elevator
Extension, Ladder
F
Feed Rolls
Feed Rolls Housing
Feeder House
Final Drive, Rice
Finger Bar, Chaffer
Float, Platform
Forks, Transmission
G
Grain Tank
Guard, Knife
Guard, Lifting
Guard Repair Block
Hand Rail, Engine
Hart ScourKleen
Hood, Rear
Horns, Signal
Hour Meter
Housing, Brake
Housing, Clutch
I
ID VIEW
K
Knife
Knife Drive Pitman
Knife Drive Shaft
Knife Repair Block
L
Lifting Guards
Light, Tail
Lines, Fuel, Diesel
Linings, Brake
Linings, Clutch
M
Meter, Tach-Hour
O
P
Pitman, Knife
Platform Auger
Platform Drive
Powershaft, Engine
R
Rail, Hand, Engine
Rasp-Bar Cylinder
Rear Hood
Reel Drive, Front
Reel Drive, Middle
Reel Drive, Rear
Reel Drive Shaft
Reel End Shields
Reel Slat
Reel Support Arms
Regulator, Voltage
Rolls, Feed
S
Sacker ( -46000)
Sacker Chute
Sacker Platform
Sacker Shelf, Sack
Sacker Soput
ScourKleen
ScourKleen Drive
Seat ( -35000)
Seat (35001- )
Sections, Knife
Shoe Drive
Sieves and Chaffers
Signal Horns
Slat, Reel
Spacers, Axle (12")
Spacer, Separator
Spike-Tooth Concave
Spindle, Rear Wheel
Spreader, Straw
Straw Spreader
Straw Walkers
Straw Walkers Drive
T
Tach-Hour Meter
Taillight
Tank, Grain
Tool Box
U
V
Voltage Regulator
W
Walkers, Straw
Wheel, Drive
Wheel, Rear
Wheel Wrench
Y
- JOHN DEERE CODE DTC LIST
