Martin Welker
104
230,310
John Deere 435 535 Round Balers Operators Manual OME87614
Download this document, you need 200 Gallons
Brand: John Deere
Type of Machine: Round Balers
Model: John Deere 435 535 Round Balers
Serial Number: 990001-
Part Number: OME87614
Number of Pages: 196 Pages
Safety
Safety Signs
Preparing the Tractor
Adjusting the Drawbar
Adjusting Tractor Wheels
Checking Ballast, Wheel Spacing and
Tire Inflation
Setting Hydraulic Outlets
Tractor Electrical Hookup
Install BALE-TRAK Monitor Console
Using Heavy-Duty Tractor Drawbar
Using Drawbar Shield
Making Drawbar Shield
Preparing the Baler
Selecting Twine
Loading Twine Boxes
Tying Sheet Bend Knot—Plastic Twine
Tying Modified Square Knot—Sisal Twine
Routing Twine From Right-Hand Twine
Box (Rear Arm)
Routing Twine From Left-Hand Twine
Box (Front Arm)
Adjusting Twine Spacing
Selecting Proper Tire Inflation
Attaching and Detaching
Connecting Baler to Tractor Drawbar
Connecting PTO Driveline
Assembling Splined Telescoping
Members
Installing Orifice in Tractors With Low
Hydraulic Flow
Connecting Hydraulic Lines
Connecting Wiring Harness
Storing Jackstand
Connecting Twine Wrap Recycle Rope
Removing PTO Driveline
Page
Removing Baler from Tractor Hitch
Transporting
Handling Round Bales
Operating the Baler
BALE-TRAK Monitor
How the Baler Forms a Bale
Crop Preparation
Breaking-In
Adjusting Bale Size
Bale Density Gauge
Adjusting
Bale Density
Pickup Height
Hydraulic Pickup Lift
Converging Wheel Height
Forming a Bale
Checking Baler Performance in the Field
Gate Lock Valve
Using Manual Twine-Trip Rope
Twine Arm
Operating With Empty Baler
Avoid Cycling While Servicing Baler
Rotating Baler By Hand
Unplugging Baler Under Power
Unplugging Baler With Hydraulic Pickup
Lift
Compressor Rack Assembly
Removing
Installing
Adjusting
Starting a Bale in Difficult Conditions
Baling
Short, Dry, Slick Crops
Cornstalks
Wet Hay
Long, Stiff, Cane-Type Crops
Extinguishing a Fire
Bale Push Bar (Optional)
Operation
Operating
Engaging
Locking Out
Variable Core Valve (Optional)
Operation
Operating
Adjusting Gauge Wheels—435 With Wide
Pickup
Adjusting Wheel Spindles—435 With
Wide Pickup
Lubrication and Maintenance
Grease
Hydraulic Oil
Gear Case Oil
Multiluber Grease
Alternative Lubricants
Observe Lubrication Symbols
Perform Lubrication and Maintenance
Chains
Every 10 Hours
Every 30 Hours
Every 50 Hours
Every 100 Hours
Annually
Troubleshooting
Automatic Twine Wrap
BALE-TRAK Monitor Difficulties
Feeding Difficulties
Pickup Difficulties
Bale Quality
General Baler Difficulties
Push Bar Difficulties
Silage Bundle Difficulties
Service
Practice Safety
Service Tires Safely
BALE-TRAK Monitor and Baler Wiring
Diagram
Bale Tension and Gate Hydraulic System
Diagram
Adjusting Chains
Adjusting Upper Drive Roll Chain
Page
Servicing Upper Chain and Idler
Adjusting Drive Slip Clutch
Checking Belt Tracking
Adjusting
Belt Tracking
Lower Feed Roll Scraper
Starter Roll Scraper
Auger Scrapers (435 With Wide
Pickup)
Take-Up Arm Compression Spring
Bale Size Indicator
Replacing Tension Wear Channel
Checking Twine Trip Rod and Valve
Latch Clearance
Checking Maximum Size Bale Adjustment
Adjusting Twine Trip Rope
Checking Knife Register
Adjusting Twine Cutter Anvil
Twine Arm Timing
Adjusting Twine Cutter Tension
435 Baler
535 Baler
Adjusting Number of Twine Wraps on RH
End of Bale
435 Baler
535 Baler
Adjusting Twine Distance From RH End
of Bale (435)
Adjusting Twine Arm Travel To Shift
Valve (535)
Adjusting Twine Cylinder Installation
Dimensions
435 Baler
535 Baler
Adjusting
Gate Latch Stop
Gate Latch Linkage
Twine Indicator Retaining Strap
Checking Microswitches
Adjusting
Pump Idler Switch
Gate Latch Switch (Green Light)
Twine Arm Switch (Solid Yellow Light)
Flashing Yellow Light Switch
Oversize Bale Switch (Red Light)
Variable Core Switch
Bale Shape Senders
Adjusting Pickup Float Springs
435 Standard Pickup and 535
435 Wide Pickup
Adjusting Pickup Belt Idler
Removing Center and Rear Tension Arm
Rolls
Removing Front Tension Arm Roll
Twine Hydraulic Pump
Priming
Cleaning Pump Screen
Raising Gate With Hoist
Checking Belt Pins
Removal of All Belts or Spring Rods
Installing Belts
Repairing Belts
Belts Eligible for Warranty Replacement
Belts Not Eligible for Warranty
Replacement
Storage
Specifications
Machine Specifications
435 Baler
535 Baler
Record Product Identification Number
Bolt and Cap Screw Torque Value Charts
Metric
Inch
Crime Prevention Tips
Index
