John Deere 435 535 Round Balers Operators Manual OME82417
- Download this document, you need 200 Gallons
Brand: John Deere
Type of Machine: Round Balers
Model: John Deere 435 535 Round Balers
Serial Number: 943001-
Part Number: OME82417
Number of Pages: 178 Pages
Safety
Preparing the Tractor
Adjusting the Drawbar
Adjusting Tractor Wheels
Checking Ballast, Wheel Spacing, and
Tire Inflation
Setting Hydraulic Outlets
Tractor Electrical Hookup
Install BALE-TRAK Monitor Console
Using Heavy-Duty Tractor Drawbar
Using Drawbar Shield
Making Drawbar Shield
Preparing the Baler
Selecting Twine
Loading Twine Boxes
Tying Sheet Bend Knot—Plastic Twine
Tying Modified Square Knot—Sisal Twine
Routing Twine From Right-Hand Twine
Box (Rear Arm)
Routing Twine From Left-Hand Twine
Box (Front Arm)
Adjusting Twine Spacing
Tire Inflation
Attaching and Detaching
Transporting
Handling Round Bales
Operating the Baler
BALE-TRAK Monitor
How the Baler Forms a Bale
Crop Preparation
Breaking-In
Adjusting Bale Size
Bale Density Gauge
Page
Adjusting:
Bale Density
Pickup Height
Converging Wheel Height
Forming a Bale
Checking Baler Performance in the Field
Gate Lock Valve
Using Manual Twine Trip Rope
Twine Arm:
Operating With Empty Baler
Avoid Cycling While Servicing Baler
Rotating Baler By Hand
Unplugging Baler Under Power
Unplugging Baler With Hydraulic Pickup
Lift
Compressor Rack Assembly:
Removing
Installing
Adjusting
Starting a Bale in Difficult Conditions
Baling Short, Dry, Slick Crops
Baling Cornstalks
Baling Wet Hay
Extinguishing a Fire
Bale Push Bar Operation (Optional)
Operating Baler With Push Bar (Optional)
Engaging Bale Push Bar (Optional)
Locking Out Bale Push Bar (Optional)
Variable Core Operation (Optional)
Operating Variable Core (Optional)
Lubrication and Maintenance
Perform Lubrication and Maintenance
Alternative Lubricants
Hydraulic Pump Oil
Chains
Extreme Pressure Grease
Gear Case Oil
Lubrication and Maintenance:
Every 10 Hours
Every 30 Hours
Every 50 Hours
Every 100 Hours
Annually
Troubleshooting
Automatic Twine Wrap
BALE-TRAK Monitor Difficulties
Feeding Difficulties
Pickup Difficulties
Bale Quality
General Baler Difficulties
Push Bar Difficulties
Silage Bundle Difficulties
Service
Practice Safety
Mounting Tires
BALE-TRAK Monitor and Baler Wiring
Diagram
Bale Tension and Gate Hydraulic System
Adjusting Chains
Adjusting Upper Drive Roll Chain
Servicing Upper Chain and Idler
Adjusting Drive Slip Clutch
Checking Belt Tracking
Adjusting:
Belt Tracking
Lower Feed Roll Scraper
Compression Spring Rod Stop Nuts
Bale Size Indicator
Replacing Tension Wear Channel
Checking Twine Trip Rod and Valve
Latch Clearance
Checking Maximum Size Bale Adjustment
Adjusting Twine Trip Rope
Checking Knife Register
Adjusting Twine Cutter Anvil
Twine Arm Timing (435)
Twine Arm Timing (535)
Adjusting:
Twine Cutter Tension (435)
Number of Twine Wraps on R-H End
of Bale (435)
Twine Distance From R-H End of Bale
(435)
Page
Twine Cylinder Installation Dimensions
(435)
Adjusting:
Twine Cutter Tension (535)
of Bale (535)
Twine Arm Travel To Shift Valve (535)
(535)
Adjusting:
Gate Latch Stop
Gate Latch Linkage
Twine Indicator Retaining Strap
Checking Microswitches
Adjusting:
Pump Idler Switch
Gate Latch Switch (Green Light)
Twine Arm Switch (Solid Yellow Light)
Flashing Yellow Light Switch
Oversize Bale Switch (Red Light)
Variable Core Switch
Bale Shape Senders
Pickup Float Springs
Pickup Belt Idler
Removing Center and Rear Tension Arm
Rolls
Removing Front Tension Arm Roll
Installing Orifice in Tractors With Low
Hydraulic Flow
Priming Twine Hydraulic Pump
Cleaning Pump Screen
Raising Gate With Hoist
Checking Belt Pins
Removal of All Belts or Spring Rods
Installing Belts
Repairing Belts
Belts Eligible for Warranty Replacement
Belts Not Eligible for Warranty
Replacement
Storage
Crime Prevention Tips
Specifications
Index
Brand: John Deere
Safety
Tire Inflation
Preparing the Baler
Selecting Twine
Loading Twine Boxes
Box (Rear Arm)
Box (Front Arm)
Tire Inflation
Transporting
Operating the Baler
BALE-TRAK Monitor
Crop Preparation
Breaking-In
Adjusting Bale Size
Bale Density Gauge
Page
Adjusting:
Bale Density
Pickup Height
Forming a Bale
Gate Lock Valve
Twine Arm:
Lift
Removing
Installing
Adjusting
Baling Cornstalks
Baling Wet Hay
Hydraulic Pump Oil
Chains
Gear Case Oil
Every 10 Hours
Every 30 Hours
Every 50 Hours
Every 100 Hours
Annually
Troubleshooting
Pickup Difficulties
Bale Quality
Service
Practice Safety
Mounting Tires
Diagram
Adjusting Chains
Adjusting:
Belt Tracking
Bale Size Indicator
Latch Clearance
Adjusting:
of Bale (435)
(435)
Page
(435)
Adjusting:
of Bale (535)
(535)
Adjusting:
Gate Latch Stop
Gate Latch Linkage
Adjusting:
Pump Idler Switch
Bale Shape Senders
Pickup Belt Idler
Rolls
Hydraulic Flow
Checking Belt Pins
Installing Belts
Repairing Belts
Replacement
Storage
Specifications
Index
- JOHN DEERE CODE DTC LIST
