Martin Welker
104
230,310
John Deere 4210 4310 4410 Compact Utility Tractor Technical Manual TM1985
Brand: John Deere
Type of Machine: Compact Utility Tractor
Type of Manual: Technical Manual
Model: John Deere 4210 4310 4410 Compact Utility Tractor
Part Number: TM1985
Publication Date: 2002
Number of Pages: 838 Pages
JOHN DEERE MODELS 4210 4310 4410 COMPACT UTILITY TRACTORS
INTRODUCTION
SAFETY
Recognize Safety Information
Understand Signal Words
Replace Safety Signs
Handle Fluids Safely - Avoid Fires
Use Care In Handling And Servicing Batteries
Prevent Battery Explosions
Prevent Acid Burns
Wear Protective Clothing
Use Care Around High-pressure Fluid Lines
Service Machines Safely
Use Proper Tools
Park Machine Safely
Support Machine Properly And Use Proper Lifting Equipment
Work In Clean Area
Using High Pressure Washers
Illuminate Work Area Safely
Work In Ventilated Area
Warning: California Proposition 65 Warning
Remove Paint Before Welding Or Heating
Avoid Harmful Asbestos Dust
Service Tires Safely
Avoid Injury From Rotating Blades, Augers And PTO Shafts
Service Cooling System Safely
Dispose Of Waste Properly
Live With Safety
SPECIFICATIONS & INFORMATION
Table of Contents
General Specifications
Metric Fastener Torque Values
Metric Fastener Torque Values—Grade 7
Inch Fastener Torque Values
Gasket Sealant Application
O-Ring Seal Service Recommendations
Face Seal Fittings with Inch Stud Ends Torque
Face Seal Fittings with Metric Stud Ends Torque
O-Ring Face Seal Fittings
O-Ring Boss Fittings
Fuels and Lubricants
Diesel Fuel Specifications
Diesel Fuel Lubricity
Diesel Fuel Storage
Engine Oil
Engine Break–in Oil
Alternative Lubricants
Synthetic Lubricants
Lubricant Storage
Mixing Of Lubricants
Chassis Grease
Transaxle Oil
Coolant Specifications
Engine Coolant
Engine Coolant Drain Interval
Serial Number Locations
Machine Product Identification Number
Engine Serial Number
Transaxle Serial Number
Interlock System
Interlock System
ENGINE - DIESEL
Table of Contents
Specifications
Repair Specifications
Tests and Adjustment Specifications
Operational Tests
Torque Values, Non-Standard Fasteners
Special Tools
Other Materials
Theory of Operation
Fuel and Air System Operation
Cooling System Operation
Lubrication System Operation
Diagnostics
Diagnostic
Tests and Adjustments
Cylinder Compression Test
Slow Idle Adjustment
Valve Clearance Adjustment
Connecting Rod Side Play Check
Connecting Rod Bearing Clearance Check
Crankshaft End Play Check
Crankshaft Main Bearing Clearance Check
Valve Lift Check
Camshaft End Play Check
Timing Gear Backlash Check
Fuel Injection Nozzle Test
Thermostat Opening Test
Injection Pump Static Timing Adjustment
Injection Pump Timing Adjustment (EPA Engines)
Fan/Alternator Drive Belt Adjustment
Radiator Bubble Test
Cooling System Pressure Test
Radiator Pressure Cap Test
Engine Oil Pressure Test
Fuel Transfer Pump Tests
Fuel System Leakage Test
Bleed Fuel System
Repair
Engine Removal
Rocker Cover Removal and Installation
Rocker Arm Assembly
Cylinder Head and Valves Removal and Installation
Cylinder Head and Valves Disassembly and Assembly
Valve Seats
Valve Recession
Valve Guides
Valve Springs
Exhaust Manifold
Intake Manifold
Grind Valve Seats
Lap Valves
Measure Piston-To-Cylinder Head Clearance
Piston and Connecting Rod
Piston Inspection
Cylinder Bore
Crankshaft Rear Oil Seal
Crankshaft Front Oil Seal
Crankshaft and Main Bearings
Flywheel and Coupling
Camshaft
Camshaft Followers
Timing Gear Cover
Idler Gear
Timing Gear Cover Mounting Plate
Oil Pan and Strainer
Oil Pump
Thermostat and Water Pump
Fuel Filter Assembly
Component Location Fuel Supply
Fuel Injection Pump
Fuel Injection Nozzles
Starting Motor Removal and Installation
Starting Motor Disassembly and Assembly
Starting Motor Inspection/Test
Starting Motor Gear Train
Starting Motor Solenoid
Alternator Removal and Installation
Alternator Disassembly
Alternator Components
ELECTRICAL
Table of Contents
Reading Electrical Schematics
Theory Of Operation Information
Diagnostic Information
Wire Color Abbreviation Chart
Common Circuit Tests
Conductors For 12 Volt Circuits
Specifications
System Specifications
Component Location
Instrument Panel
Machine Front Section
Machine Rear Section
Load Center
System Schematics
Schematic and Wiring Harness Legend
W1 Main Electrical Schematic
W2 SST and W3 ePowrReverser Electrical Schematic
W4 eHydro and Cruise Control Electrical Schematic
W1 Main Wiring Harness
W2 SST Jumper Plug Wiring Harness
W3 ePowrReverser Wiring Harness
W4 eHydro Wiring Harness
W5 Cruise Control Wiring Harness (standard)
W6 Cruise Control Wiring Harness (optional)
W1 Main Wiring Harness Color Codes
W2 SST Jumper Wiring Harness Color Codes
W3 ePowrReverser Wiring Harness Color Codes
W4 eHydro Wiring Harness Color Codes
W5 eHydro Cruise Control Wiring Harness Color Codes (standard)
W6 eHydro Cruise Control Wiring Harness Color Codes (optional)
S13 Brake Switch - eHydro
T1 Flywheel Speed Sensor - eHydro
T2 MFWD Speed Sensor - eHydro
Y2 Fuel Shutoff Solenoid
Troubleshooting
eHydro Electronic Operating System Troubleshooting Flowchart
ePowrReverser Electronic Operating System Fault Codes
ePowrReverser Electronic Operating System Fault Code Chart
eHydro Electronic Operating System Fault Codes
eHydro Electronic Operating System Fault Code Chart
Theory and Diagnosis
ePowrReverser - e MatchOS Electronic Operating System
eHydro - e MatchOS Electronic Operating System
Power Circuit Operation
Power Circuit Electrical Schematic
Power Circuit Diagnosis
Cranking Circuit Operation
Cranking Circuit Electrical Schematic
Cranking Circuit Diagnosis
Manifold Heater and Light Circuit Operation
Manifold Heater and Light Circuit Electrical Schematic
Manifold Heater and Light Circuit Diagnosis
Fuel Supply Circuit Operation
Fuel Supply Circuit Electrical Schematic - W1 Main with W2 SST and W3 ePowrReverser
Fuel Supply Circuit Electrical Schematic - W1 Main with W4 eHydro
Fuel Supply Circuit Diagnosis
Engine Shutoff Circuit Operation
Engine Shutoff Circuit Electrical Schematic - W1 Main with W2 SST and W3 ePowrReverser
Engine Shutoff Circuit Electrical Schematic - W1 Main with W4 eHydro
Engine Shutoff Circuit Diagnosis
Charging Circuit Operation
Tachometer Circuit Operation
Hour Meter Circuit Operation
Charging, Tachometer and Hour Meter Circuit Electrical Schematic
Charging, Tachometer and Hour Meter Circuit Diagnosis
ePowrReverser - Forward Drive Circuit Operation
ePowrReverser - Forward Drive Circuit Electrical Schematic
ePowrReverser - Forward Drive Circuit Diagnosis
ePowrReverser - Reverse Drive Circuit Operation
ePowrReverser - Reverse Drive Circuit Electrical Schematic
ePowrReverser - Reverse Drive Circuit Diagnosis
eHydro - Forward Drive Circuit Operation
eHydro - Forward Drive Circuit Electrical Schematic
eHydro - Forward Drive Circuit Diagnosis
eHydro - Reverse Drive Circuit Operation
eHydro - Reverse Drive Circuit Electrical Schematic
eHydro - Reverse Drive Circuit Diagnosis
eHydro - Cruise Control Circuit Operation (standard)
eHydro - Cruise Control Circuit Electrical Schematic (standard)
eHydro - Cruise Control Circuit Diagnosis (standard)
eHydro - Cruise Control Circuit Operation (optional)
eHydro - Cruise Control Circuit Electrical Schematic (optional)
eHydro - Cruise Control Circuit Diagnosis (optional)
eHydro - Load Match and Motion Match Circuit Operation
eHydro - Load Match and Motion Match Circuit Electrical Schematic
eHydro - Load Match and Motion Match Control Circuit Diagnosis
Rear PTO Circuit Operation
Rear PTO Circuit Electrical Schematic
Rear PTO Circuit Diagnosis
Mid PTO Circuit Operation
Mid PTO Circuit Electrical Schematic
Mid PTO Circuit Diagnosis
MFWD Circuit Operation
MFWD Circuit Electrical Schematic
MFWD Circuit Diagnosis
Instrument Panel Lights Circuit Operation
Instrument Panel Lights Circuit Electrical Schematic
Instrument Panel Lights Circuit Diagnosis
Turn Signal Lights Circuit Operation
Turn Signal Lights Circuit Electrical Schematic
Turn Signal Lights Circuit Diagnosis
Diverter Valve Circuit Operation (optional)
Diverter Valve Circuit Electrical Schematic (optional)
Diverter Valve Circuit Diagnosis (optional)
Ground Circuit Test
Battery Voltage and Specific Gravity Test
Battery - Charge
Battery - Load Test
Unregulated Amperage Test
Regulated Amperage and Voltage Test
Starting Motor Solenoid Test
Starting Motor Amperage Draw Test
No-Load Amperage Draw and RPM Test
Relay Test
Engine Oil Pressure Switch Test
Engine Coolant Temperature Sensor Test
Manifold Heater Test
Key Switch Test
Fuse Test
Control Panel Light Test
Diode Block Test
Light Switch Test
Seat Switch Test
Transmission Neutral Switch Test - SST and ePowrReverser
Turn Signal Switch Test
Rear PTO Switch Test
Mid PTO Switch Test
MFWD, Rear PTO and Mid PTO Solenoid Test
Cruise Control Switch Test - eHydro
Res/+, Set/- Switch Test - eHydro
Brake Switch Test and Adjustment - eHydro
Park Brake Switch Test and Adjustment
Fuel Gauge Sensor Test
Fuel Shutoff Solenoid Test
Bottom of Clutch Switch Test and Adjustment - ePowrReverser
MFWD Switch Test
Load Match Switch Test - eHydro
Motion Match Switch Test
Diverter Valve Solenoid Test
Proportional Drive Solenoid Test - ePowrReverser
Proportional Drive Solenoid Test - eHydro
F-N-R Switch Test - ePowrReverser
Test and Calibration Kit
ePowrReverser - Clutch Position Potentiometer Test
ePowrReverser - Clutch Position Potentiometer Adjustment
ePowrReverser - Pressure Transducer Test
ePowrReverser - Proportional Solenoid Test
eHydro - Throttle Position Potentiometer Test
eHydro - Throttle Position Potentiometer Adjustment and Calibration
eHydro - Drive Pedal Potentiometer Test
eHydro - Drive Pedal Potentiometer Adjustment and Calibration
eHydro - Flywheel Speed Sensor Test
eHydro - MFWD Speed Sensor Test
eHydro - Proportional Solenoid Test
eHydro - Electronic Operating System Automatic Calibration
ELECTRICAL EUROPEAN
European Electrical Section
European Electrical Theory
Component Location
Instrument Panel
Load Center
System Schematics
Troubleshooting
Front PTO Clutch Circuit Operation
Front PTO Clutch Circuit Electrical Schematic
Front PTO Clutch Circuit Diagnosis
2-Speed PTO Lights
Brake Lights Operation
Hazard Switch Operation
Turn Signal and Hazard Lights Circuit Electrical Schematic
POWER TRAIN - GEAR
Table of Contents
Specifications
Torque Specifications
Special or Essential Tools
Other Materials
Component Location
Traction Clutch (SST)
Pinion Shaft and Drive Shaft (SST)
3 Speed Synchro Transmission (SST)
Clutch Pedal and Linkage
Clutch Adjustment
Repair
Machine Splitting (Front)
Traction Clutch Removal
Clutch Regulator Removal and Installation
Traction Clutch Disassembly
Input Shaft Disassembly
Traction Clutch Installation
Clutch Shimming Procedure
Snubber Shimming Procedure
Clutch Shaft Removal and Installation
3-Speed Transmission Removal
3 Speed Synchronized Transmission
POWER TRAIN - HYDROSTATIC
Table of Contents
Specifications:General: Power Train:Hydrostatic;Hydrostatic System:Specifications;Power Train:Hydros
General
Hydrostatic Pump/Motor Assembly: Hydrostatic Pump
Hydrostatic Motor
Torque Specifications:Hydrostatic Power Train (eHydro)
Other Materials
Component Location
Component Location:Hydrostatic Hoses and Lines;Hydrostatic System:Component Location
Hydrostatic System Schematic
Hydrostatic System Schematic (continued)
Diagnosis:Hydrostatic Power Train (eHydro);Hydrostatic System:Diagnosis
Symptom Table
Theory of Operation
eHydro Transmission Operation
Tests and Adjustments:Hydrostatic Power Train
Hydrostatic Pump Pressure Test
Charge Pump Pressure Test
Hydraulic System Bleed Procedure
Repair:Hydrostatic Power Train
Forward and Reverse Potentiometers
Forward and Reverse Pedals Assembly
Hydrostatic Transmission Removal and Installation
POWER TRAIN EPOWRREVERSER
Table of Contents
Specifications
Other Materials
Component Location
Clutch Housing
ePowrReverser Clutch
4-Speed Transmission
Theory of Operation
ePowrReverser Control Valve Operation
ePowrReverser Clutch Operation – Forward and Reverse
Proportional Solenoid Valve Operation
4-Speed Transmission Operation
ePowrReverser System Pressure Test
ePowrReverser Clutch Pressure Test
ePowrReverser Lube Pressure Test
Repair
ePowrReverser Traction Clutch Removal
ePowrReverser Traction Clutch Disassembly
ePowrReverser Traction Clutch Assembly
Input Shaft Disassembly and Assembly
ePowrReverser Traction Clutch Installation
Clutch Cover Disassembly
Clutch Cover Assembly
4-Speed Transmission Removal
4-Speed Transmission Disassembly
4-Speed Transmission Assembly
Shift Cap Disassembly and Assembly
MFWD Cylinder Disassembly/Assembly
Valve Manifold Disassembly/Assembly
Connector Disassembly/Assembly
4-Speed Transmission Installation
POWER TRAIN - FINAL DRIVE
Table of Contents
Specifications
Front Axle MFWD
Other Materials
Component Location
Range Shift Transmission
Axle Shaft and Brake - Right
Axle Shaft and Brake - Left
Differential Lock
MFWD Drive Shaft (SST)
MFWD Drive Shaft (ePowrReverser and eHydro)
MFWD Axle Component Location
MFWD Final Drive Component Location
MFWD Differential Component Location
Theory of Operation
Power Transmission - Range Transmission
MFWD Drive Shaft
MFWD Front Axle
Diagnostics
Final Drive System Diagnosis
Final Drive
Differential Backlash Adjustment
Main Shifter Adjustment
Repair
MFWD Output Shaft Removal and Installation
MFWD Drive Shaft Removal and Installation
MFWD Removal
MFWD Final Drive Cover Removal and Inspection
MFWD Spindle Shaft
MFWD Final Drive Housing
MFWD Spindle Housing
MFWD Differential
Pinion Depth Setup and Adjustment
Machine Splitting (Rear)
Range Transmission Removal and Installation
Final Drive Removal
Final Drive Installation
Final Drive Disassembly, Inspection and Assembly
Differential Lock Removal and Installation
PTO Component Location
PTO Assembly
PTO Clutch and Brake
Rear PTO
2-Speed PTO (European)
Mid PTO
Mid PTO Drive Shaft
PTO Theory of Operation
Power Transmission - PTO Clutch and Brake
Power Transmission - Rear PTO
Power Transmission - 2-Speed PTO (European)
Power Transmission - Mid PTO
PTO Troubleshooting
Troubleshooting Table
PTO Repair
Rear PTO Removal and Installation
Rear PTO Shafts and Gears Disassembly and Assembly
2-Speed PTO Shafts and Gears Disassembly
2-Speed PTO Shafts and Gears Assembly
PTO Clutch and Brake Removal and Installation
PTO Input Hub Disassembly and Assembly
PTO Clutch and Brake Disassembly and Assembly
Mid PTO Removal and Installation
Mid PTO Disassembly and Assembly
HYDRAULICS
Table of Contents
Specifications
Hydraulic Specifications
Component Location and Schematics
Steering Pump Components, SST
Steering Pump Schematic, SST
Steering System Components, ePowrReverser
Steering System Schematics, ePowrReverser
Steering System Components, eHydro
Steering System Schematics, eHydro
SCV and Rockshaft System Components
SCV and Rockshaft System Schematics
Manifold Block Schematics
Single SCV Schematics
Diverter Valve Schematic
Theory of Operation
SST Hydraulic Operation
ePowrReverser Hydraulic Operation
eHydro Hydraulic Operation
PTO and MFWD Hydraulic Operation
Main PTO Clutch Operation
Rockshaft Operation
Troubleshooting
Hydrostatic (eHydro) Troubleshooting
Diagnostics
Hydraulics
Rate of Drop/Stop Valve Adjustment
Lift Arms Adjustment
System Pressure/Flow Test
System Pressure Adjustment
Steering Pressure Test
Lube Pressure Test - ePowrReverser
Charge Pressure Test - eHydro
Main PTO Clutch Pressure Test
Rockshaft Lift Cycle Test
Rockshaft Leakage Test
Rockshaft Position Feedback Linkage Adjustment
Repair
Rockshaft Filter Replacement
Hydraulic Gear Pump
Rockshaft Removal and Installation
Rockshaft Disassembly and Assembly
Rockshaft Lift Arms Removal and Installation
Dual SCV Linkage
Dual SCV Disassembly and Assembly:
Hydraulic Cylinder Repair
STEERING
Table of Contents
Specifications
Steering Specifications
Component Location
Steering Components - eHydro
Theory of Operation
All Models:
Hydrostatic Model:
SST or ePowrReverser Models:
Diagnostics
Steering Operation
Component Diagnosis
Steering System Test
Toe-in Adjustment MFWD
Toe-in Adjustment 2-WD
Repair
Steering Cylinder Removal and Installation MFWD
Steering Cylinder Removal and Installation 2- WD
Steering Wheel Removal and Installation
Tilt Steering Mechanism Removal and Installation
Steering Control Unit (SCU) Removal and Installation
Tie Rod Removal and Installation 2-WD
Tie Rod Disassembly and Assembly 2-WD
Tie Rod Removal and Installation MFWD
BRAKES
Table of Contents
Specifications
Brakes:
Transaxle Oil:
Additional Materials:
Component Location
Brake Housing
Parking Brake (Side Mount)
Brake Pedals and Linkage (SST North American)
Brake Pedals and Linkage (SST European)
Brake Pedals and Linkage (ePowrReverser North American)
Brake Pedals and Linkage (ePowrReverser European)
Brake Pedals and Linkage (eHydro North American)
Theory of Operation
Brakes
Diagnostics
Brakes
Brake Pedal Adjustment
Parking Brake Adjustment - Side Mount
Parking Brake Adjustment - Console Mount
Repair
Brake Disassembly and Inspection
Brake Assembly
Brake Pedal Removal and Installation - eHydro
Brake Pedal Removal and Installation - SST and ePowrReverser
Parking Brake Linkage Removal and Installation
MISCELLANEOUS
Table of Contents
Repair
3-Point Hitch
Seat and Seat Support
Seat Close Out Panel
Rear Fenders
Roll Over Protection System (ROPS)
Front Wheels
Floor Mat
Side Panels
Operators Platform
Steering Wheel
Control Panel
Fuse Panel Cover
Grille
Battery
Key Switch Panel
Cowl Panel
Engine Hood
INDEX
