Martin Welker
104
230,792
John Deere 420 And 430 Tractors Parts Catalog PC0505
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 420 And 430 Tractors
Part Number: PC0505
Number of Pages: 416 Pages
ALPHABETICAL INDEX
A
Adjustable Front Axle (H)
Adjustable Front Axle (S)
Adjustable Front Axle (48"-80") (T)
Adjustable Front Axle (68"-88") (T)
Adjustable Front Axle (U)
Adjustable Front Axle (V)
Adjustable Front Axle (48"-80" and 56"-88") (W)
Adjustable Front Axle, Swept-back (56"-80") (W)
Air Cleaner
All-fuel Attachment
All-fuel Selector Lever
All-fuel Starter Tank
Ammeter
Anchor Yoke (C and U)
Anchor Yoke (H)
Anchor Yoke (I and W)
Anchor Yoke (S)
Anchor Yoke (S with Dual Touch-o-matic)
Anchor Yoke (T and V)
Armature, Generator
Armature, Starter, Heavy-duty
Armature, Starter, Regular
Arm, Steering (H, S, U, and V)
Arm, Steering (I and W)
Arm, Steering (T)
Arm, Steering (W) (Swept-back Axle)
Auxiliary Light Socket (C)
Auxiliary Light Socket (H, I, T, V, and W) (S with Dual Touch-o-matic)
Auxiliary Light Socket (S and U)
Axle, Front (I)
B
Baffle, Heat
Battery Box and Mounting (80001-139999)
Battery Box and Mounting (140000-up)
Battery Cable
Battery Ground Strap
Bayonet Oil Gauge
Bearing, Clutch Throw-out ( -100000)
Bearing, Clutch Throw-out (C) (131309-up)
Bearing, Clutch Throw-out (C and I) (100001-131308)
Bearing, Clutch Throw-out (H, S, T, U, V, and W) (100001-up)
Bearing, Clutch Throw-out, Continuous-running PTO (H, S, T, U, V, and W) (100001-up)
Bearing, Clutch Throw-out Direction Reverser (S, T, U, and W) (131309-up)
Bearing, Connecting Rod
Bearing, Engine Main
Bearing, Steering Clutch Throw-out (C)
Belt, Fan
Belt, Generator
Belt Pulley
Blade, Fan
Block, Cylinder
Bottom Guard (C)
Box, Tool, and Mounting
Bracket, Implement Mounting (H, S, T, U, V, and W) ( -100000)
Brake Band (C)
Brake Pedal (C) ( -100000)
Brake Pedal (C) (100001-131308)
Brake Pedal (C) (131309-up)
Brake Pedals (H, S, U, and V)
Brake Pedals (I, T, and W)
Brakes (C)
Brakes (H, S, U, and V)
Brakes (I, T, and W)
Breakaway Coupling and Coupling Bracket
Breather Cap, Air Cleaner
Breather Cap, Engine
Breather Cap, Oil Reservoir (C)
Breather Cap, Touch-o-matic (H, T, and V)
Breather Cap, Touch-o-matic (I and W)
Breather Cap, Touch-o-matic (S and U)
Breather Cap, Touch-o-matic (S with Dual Touch-o-matic)
Brushes, Generator
Brushes, Starter, Heavy-duty
Brushes, Starter, Regular
Bumper Attachment (C)
Bumper, Attachment (C)
Bumper, 90 Loader
C
Cable, Battery
Cable, Coil
Cable, Spark Plug
Cable, Speed-hour Meter
Calks, Snow (C)
Camshaft
Carburetor, Gasoline and All-fuel
Carburetor, LP-gas
Carrier, Enginer Throw-out Bearing ( -100000)
Carrier, Engine Throw-out Bearing (100001-up)
Carrier, Engine Throw-out Bearing, Continuous-running PTO (H, I, S, T, U, V, and W) (100001-up)
Carrier, Steering Clutch Throw-out Bearing (C)
Center Frame (C) ( -100000)
Center Frame (C) (100001-131308)
Center Frame (C) (131309-up)
Center Frame (H) (100001-up)
Center Frame (H, S, T, U, V, and W) ( -100000)
Center Frame (I, S, T, U, V, and W) (100001-up)
Center Frame, Direction Reverser (S, T, U, and W) (131309-up)
Choke Control (80001-139999)
Choke Control (140000-up)
Cigarette Lighter
Cleaner, Air
Clutch, Driven Disk (C) ( -100000)
Clutch, Driven Disk (C) (100001-131308)
Clutch, Driven Disk (C) (131309-up)
Clutch, Driven Disk, Continuous-running PTO (H, I, S, T, U, V, and W) (100001-up)
Clutch Pedal (C) ( -100000)
Clutch Pedal (C) (100001-131308)
Clutch Pedal (C) (131309-up)
Clutch Pedal (H, S, T, U, V, and W) ( -100000)
Clutch Pedal (H) (100001-up)
Clutch Pedal (I, S, T, U, V, and W) (100001-up)
Clutch Pedal, Direction Reverser (S, T, U, and W) (131309-up)
Clutch Pilot Bearing
Clutch, Steering
Coil, Ignition
Coil, Lead Wire
Condenser, Distributor
Connecting Rods
Control, Starter (80001-139999)
Control, Starter (140000-up)
Control, Throttle (800001-139999)
Control, Throttle (140000-up)
Control Valve, Controls and Linkage (H, I, S, T, U, and W)
Control Valve, Power Steering (H, S, T, U, and W) (133665-up)
Control Valve, Power Steering (I and U) (80001-133664) (H, S, T, V, and W) (125001-133664)
Controls and Linkage for Control Valve (H, I, S, T, U, and W)
Converter, LP-gas
Coupling, Breakaway
Cover, Muffler Exhaust
Cover, Tappet
Crank, Starting
Cross Members (C)
Current-voltage Regulator
Cylinder and Valve Housing, Touch-o-matic (H, T, and V)
Cylinder and Valve Housing, Touch-o-matic (I and W)
Cylinder and Valve Housing, Touch-o-matic (S and U)
Cylinder and Valve Housing, Touch-o-matic (S with Dual Touch-o-matic)
Cylinder, Remote Control
Cylinder, Remote, Power Steering (I and U) (80001-125000)
Decalcomania Kits
Decalcomanias
Deflector, Exhaust
Deluxe Seat (C)
Differential (H, S, U, and V)
Differential (I, T, and W)
Dip Stick, Oil
Direction Reverser ( -100000)
Direction Reverser (100001-131308)
Direction Reverser (131309- )
Direction Reverser Assembly (131309-up)
Direction Reverser Cover and Shifting Parts (131309-up)
Distributor
Distributor Condenser
Double Remote Control Lever (C)
Double Remote Control Oil Lines (C) (80001-139999)
Double Remote Control Oil Lines (C) (140000-up)
Double Remote Control Valve (C)
Drawbar (C)
Drawbar (H)
Drawbar (I and W)
Drawbar (S)
Drawbar (T)
Drawbar (U) ( -100000)
Drawbar (U) (100001-up)
Drawbar (V)
Drive, Planter (S, U, and V)
Drive Shaft, Clutch ( -100000)
Drive Shaft, Clutch (C) (131309-up)
Drive Shaft, Clutch, with Continuous-running PTO (100001-up)
Drive Shaft, Clutch, without Continuous-running PTO (100001-up)
Drive Shaft, Clutch, with Direction Reverser (S, T, U, and W) (131309-up)
Drive Sprocket, Five Roller (C)
Drive Sprocket, Four Roller (C)
Dual Front Wheel (T)
E
Elbow, Water Inlet
Electrical Gauges
Element, Oil Filter
Engine Breather Cap
Engine Overhaul Gasket Set
Engine Tune-up Gasket Set
Exhaust Pipe Attachment
F
Fan
Fan Belt
Fan Drive Pulley
Fender Attachment, Heavy-duty (I, T, and W)
Fenders (C)
Fenders, Regular (I, T, and W)
Fenders (S)
Fenders (U)
Fenders (V)
Filler Valve, LP-gas
Filter, Fuel, Gasoline and All-fuel
Filter, Fuel, LP-gas
Filter, Oil
Final Drive (C)
Final Drive (H)
Final Drive (I and W)
Final Drive (S, U, and V)
Final Drive (T)
Final Drive Gasket Set (C)
Final Drive Gasket Set (I, V, and W)
Five-roller Drive Sprocket (C)
Five-roller, Hydraulic Track Tension Adjuster
Five-roller Idler (C)
Five-roller Rock Guards (C)
Five-roller Sprocket Shield (C)
Five-roller Track Frame (C)
Five-roller Track Roller (C)
Float Gauge, LP-gas
Float Ride Seat (T and W)
Flow Divider Valve (I and U) (80001-131817) (H, S, T, V, and W) (125001-131817)
Flywheel ( -100000)
Flywheel (100001-up)
Flywheel, Continuous-running PTO (H, I, S, T, U, V, and W) (100001-up)
Foot-operated Governor Control
Footrests (C)
Footrests (H)
Footrests (I, T, and W)
Footrests (S)
Footrests (U)
Footrests (V)
Four-roller Drive Sprocket (C)
Four-roller, Hydraulic Track Tension Adjuster
Four-roller Idler (C)
Four-roller Rock Guards (C)
Four-roller Sprocket Shields (C)
Four-roller Track Frame (C)
Four-roller Track Roller (C)
Frame, Center (C) ( -100000)
Frame, Center (C) (100001-131308)
Frame, Center (C) (131309-up)
Frame Center (H, S, T, U, V, and W) ( -100000)
Frame, Center (H) (100001-up)
Frame, Center (I, S, T, U, V, and W) (100001-up)
Frame, center, with Direction Reverser (S, T, U, and W) (131309-up)
Frame, Seat (C)
Frame, Seat (H, T, and V)
Frame, Seat (I and W)
Frame, Seat (S and U)
Frame, Seat, Wide (C, I, T, and W)
Frame, Side (C)
Frame, Spacer (H)
Frame, Track, Five-roller (C)
Frame, Track, Four-roller (C)
Frame, Track, Hydraulic Adjuster (C)
Front, Axle (I)
Front Axle, Adjustable (H)
Front Axle, Adjustable (S)
Front Axle, Adjustable (48"-80") (T)
Front Axle, Adjustable (68"-88") (T)
Front Axle, Adjustable (U)
Front Axle, Adjustable (V)
Front Axle, Adjustable (48"-80" and 56"-88") (W)
Front Axle, Adjustable Swept-back (56"-80") (W)
Front Cover, Touch-o-matic (H, T, and V)
Front Cover, Touch-o-matic (I and W)
Front Cover, Touch-o-matic (S and U)
Front Cover, Touch-o-matic (S with Dual Touch-o-matic)
Front End Support (C)
Front End Support (H, S, U, and V)
Front End Support (I and W)
Front End Support (T)
Front End Support (W) (Swept-back Axle)
Front End Support, 90 Loader (C)
Front End Weight (H, S, U, and V)
Front End Weight (I and W)
Front End Weight (T)
Front Lights
Front Wheel, Single (T)
Front Wheel, Dual (T)
Front Wheels
Front Wiring Harness
Fuel Filter, Gasoline and All-fuel
Fuel Filter, LP-gas
Fuel Lines, All-fuel
Fuel Lines, Gasoline
Fuel Lines, LP-gas
Fuel Strainer, LP-gas
Fuel Tank Filler Cap
Fuel Tank, Gasoline and All-fuel
Fuel Tank, LP-gas
Fuse
G
Gasket Set, Engine Overhaul
Gasket Set, Engine Tune-up
Gasket Set, Final Drive (C)
Gasket Set, Final Drive (I, V, and W)
Gasket Set, Transmission (C)
Gasket Set, Transmission (I, V, and W)
Gasoline Carburetor
Gauge, Bayonet, Oil
Gauge, Bayonet, Oil Reservoir (C)
Gauges, Electrical
Gauges, LP-gas
Gauges, Oil Pressure
Gauges, Water Temperature
Generator
Generator Belt
Governor
Governor Control, Foot-operated
Grille
Grille, 90 Loader (C)
Grille Guard (C)
Grille Guard (U)
Grille Guard, 90 Loader (C)
Guard, Bottom (C)
Guard, Grille (C)
Guard, Grille (U)
Guard, Grille, Heavy-duty (C)
Guard, Light (C)
Guard, Light (U)
Guard, Powershaft
Guide, Valve
Hand Crank
Head, Cylinder
Heat Indicator
Heavy-duty Protective Equipment (C)
Hitch, 3-point (C)
Hitch, 3-point (H, I, S, T, U, V, and W)
Hood (Gasoline and All-fuel)
Hood, Heavy-duty Protective Equipment
Hood, LP-gas
Hose, Air Cleaner
Hose, LP-gas
Hose, Power Steering (80001-131817)
Hose, Power Steering (131818-158074)
Hose, Power Steering (158075-up)
Hose, Radiator
Hose, Remote Hydraulic Cylinder
Hose, Water Inlet
I
Idler, Five-roller (C)
Idler, Four-roller (C)
Idler, Upper, Five-roller (C)
ID VIEW
Ignition Coil
Ignition Switch
Implement Mounting Bracket (H, S, T, U, V, and W) ( -100000)
Indicator, Heat
Inner Sprocket Shield (C)
Instrument Panel (C) (80001-139999)
Instrument Panel (C) (140000-up)
Instrument Panel (H) (80001-139999)
Instrument Panel (H, S, T, U, V, and W) (140000-up)
Instrument Panel (I, S, T, U, V, and W) (80000-125000)
Instrument Panel (I, S, T, U, V, and W) (125001-139999)
Instrument Panel, LP-gas (C, S, T, U, and W) (140000-up)
Instrument Panel Light
Instrument Panel, LP-gas, (125000-139999)
J
Jaw, Starting Crank
Jets, Carburetor, Gasoling and All-fuel
K
Key, Switch
L
Lamp, Warning (H, I, S, T, U, V, and W)
Leveling Crank (C)
Leveling Crank (H, I, S, T, U, V, and W)
Lever, Double Remote Control (C)
Lever, Powershaft Shifter (C, H, S, U, and V)
Lever, Powershaft Shifter (I, T, and W)
Lever, Remote Control Valve
Lever, Shaft, Power Steering
Lever, Shaft, Steering (H, S, U, and V)
Lever, Shaft, Steering (T)
Lever, Shaft, Steering (I and W)
Lever, Single Remote Control (80001-139999)
Lever, Single Remote Control (140000-up)
Lever, Starting Control (80001-139999)
Lever, Starting Control (140000-up)
Lever, Steering (C)
Light Guard (C)
Light, Guard (U)
Light, Instrument Panel
Light, Rear (C)
Light, Rear (H, I, T, V, and W) (S with Dual Touch-o-matic)
Light, Rear (S and U)
Lighter, Cigarette
Lights, Front
Lines, LP-gas
Link, Mounting (H)
Links, Track (C) (Four Bolt)
LInks, Track (C) (Two Bolt)
Liquid Level Gauge, LP-gas
Liquid Withdrawal Valve, LP-gas
LP-gas Carburetor
LP-gas Converter
LP-gas Fuel Strainer
LP-gas Fuel Tank
LP-gas Gauges
LP-gas Hood
LP-gas Instrument Panel
LP-gas LInes
LP-gas Valves
M
Main Bearing Insert
Manifold, Engine Exhaust
Manifold, Underneath and Side Exhaust
Manifold, Water Outlet
Meter, Speed-hour
Motor, Starting, Heavy-duty
Motor, Starting, Regular
Muffler
Muffler Attachment
O
Oil Filter
Oil Fiilter Element
Oil Lines, Double Remote Control (C) (80001-139999)
Oil Lines, Power Steering (H, S, T, U, and W) (131818-158074)
Oil LInes, Power Steering (H, S, T, U, and W) (158075-up)
Oil LInes, Power Steering (I and U) (80001-131817) ( H, S, T, V, and W) (125001-131817)
Oil LInes, Remote Control Hydraulic (H)
Oil LInes, Remote Control Hydraulic (I and W)
Oil Lines, Remote Control Hydraulic (S and U)
Oil Lines, Remote Control Hydraulic (T)
Oil LInes, Single and Double Remote Control (140000-up)
Oil Lines, Single Remote Control(C) (80001-139999)
Oil Lines, Touch-o-matic, Gasoline (H, I, S, T, U, V, and W)
Oil Lines, Touch-o-matic, LP-gas (I, S, T, U, and W)
Oil Pan
Oil Pressure Gauge
Oil Pump
Oil Reservoir (C)
P
Pan, Crankcase Oil
Panel, Instrument (C) (80001-139999)
Panel, Instrument (C) (140000-up)
Panel, Instrument (H) (80001-139999)
Panel, Instrument (H, S, T, U, V, and W) (140000-up)
Panel, Instrument (I, S, T, U, V, and W) (80001-125000)
Panel, Instrument (I, S, T, U, V, and W) (125001-139999)
Panel, Instrument, LP-gas (125001-139999)
Panel, Instrument, LP-gas (140000-up)
Parts for Crawler Tractor Equipped with 90 Loader
Pedal, Brake (C) ( -100000)
Pedal, Brake (C) (100001-131308)
Pedals, Brake (H, S, U, and V)
Pedals, Brake (I, T, and W)
Pedal, Clutch (C) ( -100000)
Pedal, Clutch (C) (100001-131308)
Pedal, Clutch (C) (131309-up)
Pedal, Clutch (H) (100001-up)
Pedal, Clutch (H, S, T, U, V, and W) ( -100000)
Pedal, Clutch (I, S, T, U, V, and W) (100001-up)
Pedal, Clutch, with Direction Reverser (S, T, U,and W) (131309-up)
Pins, Track (C) (Four Bolt)
Pins, Track (C) (Two Bolt)
Piston
Piston Rings
Planter Drive (S, U, and V)
Plate, Pressure ( -100000)
Plate, Pressure (100001-up)
Plate, Pressure (C) (131309-up)
Plate, Pressure, Continuous-running PTO (H, I, S, T, U, V, and W) (100001-up)
Plate, Pressure, with Direction Reverser (S, T, U, and W) (131309-up)
Point Set, Ignition
Power Adjusted Rear Wheels (I, T, and W)
Power Adjusted Rear Wheels (S and U)
Powershaft, Five-speed (100001-125000)
Powershaft, Five-speed (125001-up)
Powershaft, Five-speed with Continuous-running PTO (100001-up)
Powershaft, Five-speed with Continuous-running PTO (125001-up)
Powershaft, Four-speed ( -100000)
Powershaft, Four-speed (100001-125000)
Powershaft, Four-speed (125001-up)
Powershaft Attachment (C, H, I, U, and W)
Powershaft Guard
Powershaft Shield
Powershaft Shifter Lever (C, H, S, U, and V)
Powershaft Shifter Lever (I, T, and W)
Power Steering Control Valve (H, S, T, U, and W) (133665-up)
Power Steering Control Valve (I and U) (80001-133664) (H, S, T, V, and W) (125001-131817)
Power Steering Flow Divider Valve (I and U) (80001-131817) (h, S, T, U, and W) (125001-131817)
Power Steering Gear and Support (H, I, S, T, U, V, and W) (125001-up)
Power Steering Oil Lines (H, S, T, U, and W) (131818-158074)
Power Steering Oil Lines (H, S, T, U, and W) (158075-up)
Power Steering Oil Lines (I and U) (80001-131817) (H, S, T, V, and W) (125001-131817)
Power Steering Rack and Pinion (H,, I, S, T, U, V, and W) (125001-up)
Power Steering Tie Rod (I and U) (80001-up)
Pre-cleaner
Pressure Plate ( -100000)
Pressure Plate (100001-up)
Pressure Plate (C) (131309-up)
Pressure Plate, Continuous-running PTO (H, I, S, T, U, V, and W) (100001-up)
Pressure Plate, with Direction Reverser (S, T, U, and W) (131309-up)
Propeller Shaft ( -100000)
Propeller Shaft (100001-up)
Propeller Shaft (C) (131309-up)
Propeller Shaft, Continuous-running PTO (H, I, S, T, U, V, and W) (100001-up)
Propeller Shaft, with Direction Reverser (S, T, U, and W) (131309-up)
Protective Equipment, Heavy-duty (C)
Pulley, Belt
Pulley, Fan Drive
Pump, Hydraulic
Pump, Lubricating Oil
Pump, Power Steering (131818-158074)
Pump, Power Steering (158075-up)
Pump, Water
Q
Quadrant, Touch-o-matic (H, T, and V)
Quadrant, Touch-o-matic (I and W)
Quadrant, Touch-o-matic (S)
Quadrant, Touch-o-matic (S with Dual Touch-o-matic)
Quadrant, Touch-o-matic (U)
R
Rack and Pinion, Power Steering (H, I, S, T, U, V, and W) (125001-up)
Rear Light (C)
Rear Light (H, I, T, V, and W) (S with Dual Touch-o-matic)
Rear Light (S and U)
Rear Wheel and Wheel Weight for 56-1/2" Special Tread (U)
Rear Wheel Weights (H)
Rear Wheel Weights (I, T, V, and W)
Rear Wheel Weights (S and U)
Rear Wheels (H)
Rear Wheesl (I, T, V, and W)
Rear Wheels, Power Adjusted (I, T, and W)
Rear Wheels, Power Adjusted (S and U)
Rear Wheels, Regular (S and U)
Rear Wiring Harness (C)
Rear Wiring Harness (H, I, T, V, and W) (S with Dual Touch-o-maitc)
Rear Wiring Harness (S and U)
Regular Rear Wheels (I, T, V, and W)
Regular Rear Wheels (S and U)
Regulator, Current-voltage
Remote Control Cylinder
Remote Control Hydraulic Oil Lines (H)
Remote Control Hydraulic Oil Lines (I and W)
Remote Control Hydraulic Oil Lines (S and U)
Remote Control Hydraulic Oil Lines (T)
Remote Control Levers, Double (C)
Remote Control Lever, Single (C) (80001-139999)
Remote Control Lever, Single (C) (140000-up)
Remote Control Oil Lines, Double (C) (80001-139999)
Remote Control Oil Lines, Single (C) (80001-139999)
Remote Control Oil Lines, Single and Double (C) (140000-up)
Remote Control Valve (H, I, S, T, U, and W)
Remote Control Valve, Double (C)
Remote Control Valve, Single (C) (80001-139999)
Remote Control Valve, Single (C) (140000-up)
Remote Cylinder, Power Steering (I and U) (80001-up)
Remote Power Steering Cylinder
Repair Kit, Carburetor, Gasoline and All-fuel
Reservoir, Oil (C)
Reverser, Direction ( -100000)
Reverser, Direction (100001-131308)
Ring Gear and Pinion (C)
Ring Gear and Pinion (H, S, U, and V)
Ring Gear and Pinion (I, T, and W)
Rings, Piston
Rock Guards, Five-roller (C)
Rock Guards, Four-roller (C)
Rocker Arms, Valve
Rockshaft Housing Assembly (C)
Rockshaft, Touch-o-matic (H, T, and V)
Rockshaft, Touch-o-matic (I and W)
Rockshaft, Touch-o-matic (S)
Rockshaft, Touch-o-matic (S with Dual Touch-o-matic)
Rockshaft, Touch-o-matic (U)
Rod Bearings
Rod, Carburetor Connecting (80001-139999)
Rod, Carburetor Connecting (140000-up)
Rod, Connecting
Rod, Governor Connecting (80001-139999)
Rod, Governor Connecting (140000-up)
Rod, Valve Push
S
Safety Block (C)
Safety Relief Valve, LP-gas
Seat (C)
Seat (H, T, and V)
Seat (I and W)
Seat (S and U)
Seat, Deluxe (C)
Seat, Float Ride (T and W)
Seat Frame (C)
Seat Frame (H, T, and V)
Seat Frame (I and W)
Seat Frame (S and U)
Seat Frame, Wide (C, I, T, and W)
Shaft, Clutch (C) ( -100000)
Shaft, Clutch (C) (100001-131308)
Shaft, Clutch (H, S, T, U, V, and W) ( -100000)
Shaft, Clutch (H) (100001-up)
Shaft, Clutch (I, S, T, U, V, and W)(100001-up)
Shaft, Power Steering (I and U) (80001-131817) (H, S, T, V, and W) (125001-131817)
Shaft, Power Steering (H, S, T, U, and W) (131818-158074)
Shaft, Propeller ( -100000)
Shaft, Propeller (100001-up)
Shaft, Propeller, with Continuous-running PTO (100001-up)
Shaft, Propeller (C) (131309-up)
Shaft, Propeller, with Direction Reverser (S, T, U, and W) (131309-up)
Shaft, Steering (H) (80001-139999)
Shaft, Steering (H, S, T, U, V, and W) (140000-up)
Shaft, Steering (I, S, T, U, V, and W) (80001-125000)
Shaft, Steering (I, S, T, U, V, and W) (125001-139999)
Shaft, Steering, LP-gas (C, S, T, U, and W) (140000-up)
Shield, Powershaft
Shield, Sprocket, Five-roller (C)
Shield, Sprocket, Four-roller (C)
Shifting Parts, Five-speed (100001-108921)
Shifting Parts, Five-speed (108922- )
Shifting Parts, Four-speed (80001-108921)
Shifting Parts, Four-speed (108922- )
Shoes, Track (C) (Four Bolt)
Shoes, Track (C) (Two Bolt)
Shroud, Radiator
Side Frames (C)
Side Weight (T)
Single and Double Remote Control Oil Lines (C) (140000-up)
Single Front Wheel (T)
Single Remote Control Lever (C) (80001-139999)
Single Remote Control Oil Lines (C) (80001-139999)
Single Remote Control Valve (C) (80001-139999)
Single Remote Control Valve (C) (140000-up)
Sleeve, Engine Throw-out Bearing Carrier ( -100000)
Sleeve, Engine Throw-out Bearing Carrier (100001-up)
Sleeve, Engine Throw-out Bearing Carrier (C) (131309-up)
Sleeve, Engine Throw-out Bearing Carrier, Continuous-running PTO (H, I, S, T, U, V, and W) (100001-up)
Sleeve, Engine Throw-out Bearing Carrier, with Direction Reverser (S, T, I, and W) (131309-up)
Sleeve, Steering Clutch Throw-out Bearing Carrier (C)
Snow Calks (C) (Two Bolt)
Snow Shoes (C) (Four Bolt)
Snow Shoes (C) (Two Bolt)
Socket, Auxiliary Light (C)
Socket, Auxiliary Light (H, I, T, V, and W) (S with Dual Touch-o-matic)
Socket, Auxiliary Light (S and U)
Sod Pan
Spark Plug
Spark Plug Cable
Spark Plug Coil
Speed-hour Meter
Spindle, Dual Front Wheel (T)
Sprocket, Drive, Five-roller (C)
Sprocket, Drive, Four-roller (C)
Sprocket Shield, Five-roller (C)
Sprocket Shield, Four-roller (C)
Starter Control Lever (80001-139999)
Starter Control Lever (140000-up)
Starter Tank, All-Fuel
Starting Motor, Heavy-duty
Starting Motor, Regular
Steering Clutch (C)
Steering Clutch Housing (C)
Steering Gear (H, S, U, and V)
Steering Gear (I and W)
Steering Gear (T)
Steering Gear and Support, Power Steering (H, I, S, T, U, V, and W) (125001-up)
Steering Levers (C)
Steering Wheel (H) (80001-139999)
Steering Wheel (H, S, T, U, V, and W) (140000-up)
Steering Wheel (I, S, T, U, V, and W) (80001-125000)
Steering Wheel (I, S, T, U, V, and W) (125001-139999)
Steering Wheel, LP-gas (S, T, U, and W) (140000-up)
Strainer, Fuel, LP-gas
Strap, Battery Ground (80001-139999)
Strap, Battery Ground (140000-up)
Support, Front End (C)
Support, Front End (H, S, U, and V)
Support, Front End (I and W)
Support, Front End (T)
Support, Front End (W) (Swept-back Axle)
Switch, Ignition
Switch, Key
T
Tachometer
Tank, Fuel, Gasoline and All-fuel
Tank, Fuel, LP-gas
Tank, Starting All-fuel
Tappet Cover
Tappet, Valve
Thermostat
3-point Hitch (C)
3-point Hitch (H, I, S, T, U, V, and W)
Throttle, Control Rod (80001-139999)
Throttle, Control Rod (140000-up)
Throttle, Foot-operated
Throw-out Bearing and Carrier, Engine ( -100000)
Throw-out Bearing and Carrier, Engine (100001-up)
Throw-out Bearing and Carrier, Engine (C) (131309-up)
Throw-out Bearing and Carrier, Engine Continuous-running PTO (H, I, S, T, U, V, and W) (100001-up)
Throw-out Bearing and Carrier, Engine with Direction Reverser (S, T, U, and W) (131309-up)
Throw-out Bearing and Carrier, Steering Clutch (C)
Tie Rod, Power Steering (I and W) (80001-up)
Tool Box and Mounting
Touch-o-matic Cylinder and Valve Housing (H, T, and V)
Touch-o-matic Cylinder and Valve Housing (I and W)
Touch-o-matic Cylinder and Valve Housing (S and U)
Touch-o-matic Cylinder and Valve Housing (S with Dual Touch-o-matic)
Touch-o-matic Front Cover (H, T, and V)
Touch-o-matic Front Cover (I and W)
Touch-o-matic Front Cover (S and U)
Touch-o-matic Front Cover (S with Dual Touch-o-matic)
Touch-o-matic Oil Lines, Gasoline (H, I, S, T, U, V, and W)
Touch-o-matic Oil Lines, LP-gas (I, S, T, U, and W)
Touch-o-matic Quadrant (H, T, and V)
Touch-o-matic Quadrant (I and W)
Touch-o-matic Quadrant (S)
Touch-o-matic Quadrant (S with Dual Touch-o-matic)
Touch-o-matic Quadrant (U)
Touch-o-matic Rockshaft (H, T, and V)
Touch-o-matic Rockshaft (I and W)
Touch-o-matic Rockshaft (S)
Touch-o-matic Rockshaft (S with Dual Touch-o-matic)
Touch-o-matic Rockshaft (U)
Track Frames, Five-roller (C)
Track Frames, Four-roller (C)
Track Links (C) (Four Bolt)
Track Links (C) (Two Bolt)
Track Pins (C) (Four Bolt)
Track Pins (C) (Two Bolt)
Track Roller, Five-roller (C)
Track Roller, Four-roller (C)
Track Shoes (C) (Four Bolt)
Track Shoes (C) (Two Bolt)
Track Tension Adjuster (C)
Transmission Case (C, H, S, U, and V)
Transmission Case (I, T, and W)
Transmisison Gasket Set (C)
Transmission Gasket Set (I, V, and W)
Transmission Gears, Continuous-running PTO, Five-speed (100001-125000)
Transmission Gears, Continuous-running PTO, Five-speed (125001-up)
Transmission Gears, Five-speed, for Auburn Trencher (C and W) (125001-up)
Transmission Gears, Five-speed, without Continuous-running PTO (100001-125000)
Transmission Gears, Five-speed, without Continuous-running PTO (125001-up)
Transmission Gears, Four-speed ( -100000)
Transmission Gears, Four-speed (100001-125000)
Transmission Gears, Four-speed (125001-up)
Transmission Rear Cover (C and U)
Transmission Rear Cover (H)
Transmission Rear Cover (I and W)
Transmission Rear Cover (S)
Transmission Rear Cover (S with Dual Touch-o-matic)
Transmission Rear cover (T and V)
Transmission Rear Cover, for Auburn Trencher (C and W)
Transmission Shafts, Continuous-running PTO, Five-speed (100000-125000)
Transmission Shafts, Continuous-running PTO, Five-speed (125001-up)
Transmission Shafts, Five-speed, for Auburn Trencher (C and W) (125001-up)
Transmission Shafts, Five-speed, without Continuous-running PTO (100001-125000)
Transmission Shafts, Five-speed, without Continuous-running PTO (125001-up)
Transmission Shafts, Four-speed ( -100000)
Transmission Shafts, Four-speed (100001-125000)
Transmission Shafts, Four-speed (125001-up)
Transmission Top Cover, Five-speed (100001-108921)
Transmission Top Cover, Five-speed (108922-up)
Transmission Top Cover, Four-speed (80001-108921)
Transmission Top Cover, Four-speed (108922-up)
V
Valve, Control, Double Remote (C)
Valve, Control, Remote (H, I, S, T, U, and W)
Valve, Control, Single Remote (C) (80001-139999)
Valve, Control, Single Remote (C) (140000-up)
Valves, Exhaust
Valve, Flow Divider (I and U) (80001-131817) (H, S, T, V, and W) (125001-131817)
Valve, Intake
Valves, LP-gas
Vapor Return Valve, LP-gas
Vapor Withdrawal Valve, LP-gas
Vent Valve, LP-gas
W
Warning Lamp (H, I, S, T, U, V, and W)
Water Manifold
Water Temperature Gauge
Weight, Front End (H, S, U, and V)
Weight, Front End (I and W)
Weight, Front End (T)
Weight, Front End (U)
Weight, Side (T)
Weights, Rear Wheel (H)
Weights, Rear Wheel (I, T, V, and W)
Weights, Rear Wheel (S and U)
Wheel, Front
Wheel, Front, Single
Wheel, Rear (H)
Wheel, Rear, Power-adjusted (I, T, and W)
Wheel, Rear, Power-adjusted (S and U)
Wheel, Rear, Regular (I, T, V, and W)
Wheel, Rear, Regular (S and U)
Wheel, Rear, 56-1/2" Special Tread (U)
Wheel, Steering (H) (80001-139999)
Wheel, Steering (H, S, T, U, V, and W) (140000-up)
Wheel, Steering (I, S, T, U, V, and W) (80001-125000)
Wheel, Steering (I, S, T, U, V, and W) (125001-139999)
Wheel, Steering, LP-gas (140000-up)
Wheel, Weight, Rear (U)
Wide Seat (C, I, T, and W)
Wide Seat Frame (C, I, T, and W)
Wire, Lead, Coil
Wiring Harness, Front
Wiring Harness, Rear (C)
Wiring Harness, Rear (H, I, T, V, and W) (S with Dual Touch-o-matic)
Wiring Harness, Rear (S and U)
Worm Power Steering (125001-up)
Worm, Steering (H, S, U, and V)
Worm, Steering (I and W)
Worm, Steering (T)
