John Deere 42 Series Combine Parts Catalog PC0745
Brand: John Deere
Type of Machine: Combine
Model: John Deere 42 Series Combine
Part Number: PC0745
Number of Pages: 160 Pages
ALPHABETICAL INDEX
A
Adjustable Long Divider (Special)
Adjustable Parking Stand
Arm, Reel
Arms, Reel Support
Auger, Clean Grain
Auger, Grain Tank Hinged Unloading
Auger, Grain Tank Loading
Auger, Lower Tailings
Auger, Platform
Auger, Upper Tailings
Auger, Weed Seed Auger (Hart ScourKleen)
Axle Frame and Tractor Hitch
B
Bar, Cylinder Stripper
Bar, Rasp
Bar, Weed (Special)
Bearings, Wood (Straw Walker Crankshaft)
Beater
Blade, Straw Chopper
Blade, Straw Spreader
Blades, Cleaning Fan
Bottoms, Grain Conveyor
C
Cell - type Separating Grate
Chaffers and Finger Bar
Chopper, Straw
Clean Grain Auger
Clean Grain Elevator
Clean Grain Elevator Extension (Special)
Clutch, Safety
Concave Extension
Concaves and Grate, Rasp - bar Cylinder
Concaves Snap - on Covers (Special)
Concaves, Spike - tooth
Control Levers and Linkages
Conveyor Bottoms
Conveyor Chain, Feeder House
Conveyor Chain, Grain
Crank, Shoe Pitman
Crankshafts, Straw Walker
Cutting Platform Support Stand (Special)
Cylinder, Rasp - bar
Cylinder, Spike - tooth
Cylinder Sprockets
Cylinder Stripper Bar
Cylinder Tooth
Decalcomania Set
Discharge Chute (Hart ScourKleen)
Divider, Extension
Divider, Long, Adjustable (Special)
Dividers, Platform End Sheets
Drives for, Clean Grain and Tailings Auger
Drives for, Clean Grain Elevator
Drives for, Clean Grain Elevator Top Drive
Drives for, Cylinder
Drives for, Grain Conveyor
Drives for, Grain Tank Loading Auger
Drives for, Grain Tank Loading Auger Drive for Hart ScourKleen
Drives for, Grain Tank Unloading Auger, Lower L.H.
Drives for, Grain Tank Unloading Auger, R.H.
Drives for, Grain Tank Unloading Auger, Upper L.H.
Drives for, Hart ScourKleen and Clean Grain Elevator Top Drive
Drives for, Knife and Auger on Feeder House Side
Drives for, Platform
Drives for, Platform Auger
Drives for, Reel
Drives for, Rotor for Hart ScourKleen
Drives for, Separator Drive Belt and Tightener
Drives for, Straw Chopper
Drives for, Straw Spreader
Drives for, Straw Walker, Shoe, and Fan
Drives for, Tailings Elevator
Drives for, Tailings Auger, Upper
Drives for, Weed Seed Auger for Hart ScourKleen
E
Elevator, Clean Grain and Tailings
End Sheets, Platform
Extension, Clean Grain Elevator (Special)
Extension, Concave, Cell - type
Extension, Divider
Extension, Grain Tank
Extension, Platform Auger Flight
F
Fan Housing and Shaft
Feeder House
Feeder House, Conveyor Chain
Finger, Grain Grate
Fingers, Platform Auger
Frame, Axle, and Tractor Hitch
G
Gear Housing
Grain Conveyor Bottoms
Grain Conveyor Chain
Grain Grate and Concaves
Grain Grate Fingers
Grain Tank
Grain Tank Hinged Unloading Auger
Grain Tank Unloading Auger Drive Countershaft, Lower
Grain Tank Unloading Auger Drive Countershaft, Upper
Grate and Concaves
Guard for Clean Grain and Tailings Auger Drive Belt
Guard, Straw Spreader
Guards and Knife
Hart ScourKleen
Hitch Jack
Hitch, Tractor, and Axle Frame
Hood, Rear
Hose, Support
Housings for, Clean Grain Hinged Unloading Auger
Housings for, Fan
Housings for, Grain Tank Loading Auger
Housings for, Upper Tailings Auger
Housings for, Weed Seed Auger (Hart ScourKleen)
Hydraulic Hoses and Lines
I
ID VIEW
J
Jack, Hitch
K
Knife
Knife and Auger Drive Shaft at Rear of Platform
Knife Pitman
Knife Sections (for Straw Chopper)
L
Lever, Gear Case
Lever, Grain Tank Unloading
Lift Parts, Platform
Lifting Guards
Lines, Oil
Lower Tailings Auger
O
Oil Lines
Operator's Manual
P
Paddles, Elevator
Parking Stand
Pickup Reel
Pickup Reel, Centershaft, Eccentric Crank, and Drive Parts
Pickup Reel Support Arms
Pipe, Reel
Pitman, Knife
Platform Auger
Platform Auger Flight Extensions
Platform, Cutting
Platform End Sheet
Platform Extension Divider
Platform Lift Parts
Platform Transport Block (Special)
Polygon, Spoke, Pickup Reel
Powershaft (On Hitch)
Powershaft (Tractor to Combine)
Powershaft Shields (On Hitch)
Powershaft Shields (Tractor to Combine)
Protective Plates, Platform
R
Rasp - bar
Rear Hood
Reel
Reel Arm, Pipe, and Slat
Reel End Shield (Special)
Reel, Pickup
Reel Support Arms
Reflective Tape, Safety
Rotor Drive (Hart ScourKleen)
S
Safety Clutch
Screen, Spinning Fan
Section, Knife
Separator Front Sheets
Separator Side Sheets
Separator Top Sheets
Shield, Cleaning Fan Housing
Shield, End, Reel Slats (Special)
Shield for Powershaft (Tractor to Combine)
Shield, Straw Chopper Drive
Shields for Powershaft (On Hitch)
Shields, Separator
Shoe
Shoe Pitman and Crank
Sieves, Chaffer, and Finger Bar
Slat, Reel
Spacer, Rear of Separator
Spike - tooth Concaves and Cylinder
Spindle, Wheel
Spinning Fan Screen (Special)
Spoke Polygon, Pickup Reel
Spreader, Straw
Sprockets, Cylinder
Stand, Adjustable Parking
Stand, Support, Cutting Platform (Special)
Stone Trap (Trough - type)
Straw Chopper
Straw Chopper Drive Shield
Straw Spreader
Straw Walker
Straw Walker Crankshafts
Support Arms, Pickup Reel
T
Tailings Auger Drive, Lower
Tailings Auger Drive, Upper
Tailings Elevator
Tank, Grain
Tire and Tube
Tooth, Concaves and Cylinder
Tractor Hitch and Axle Frame
Trap, Stone (Trough - type)
U
Unloading Auger, Grain Tank
Upper Tailings Auger and Housing
W
Walkers, Straw
Weed Bar (Special)
Weed Seed Spout (Hart ScourKleen)
Wheel and Spindle
Wrench, Wheel
Brand: John Deere
Part Number: PC0745
ALPHABETICAL INDEX
A
Arm, Reel
Arms, Reel Support
Auger, Clean Grain
Auger, Platform
B
Bar, Rasp
Bar, Weed (Special)
Beater
C
Chopper, Straw
Clean Grain Auger
Clutch, Safety
Concave Extension
Conveyor Bottoms
Crank, Shoe Pitman
Cylinder Sprockets
Cylinder Tooth
Decalcomania Set
Divider, Extension
Drives for, Reel
E
Extension, Divider
F
Feeder House
Finger, Grain Grate
G
Gear Housing
Grain Grate Fingers
Grain Tank
Grate and Concaves
Guards and Knife
Hart ScourKleen
Hitch Jack
Hood, Rear
Hose, Support
Housings for, Fan
I
ID VIEW
J
Jack, Hitch
K
Knife
Knife Pitman
L
Lever, Gear Case
Lifting Guards
Lines, Oil
O
Oil Lines
Operator's Manual
P
Paddles, Elevator
Parking Stand
Pickup Reel
Pipe, Reel
Pitman, Knife
Platform Auger
Platform, Cutting
Platform End Sheet
Platform Lift Parts
R
Rasp - bar
Rear Hood
Reel
Reel, Pickup
Reel Support Arms
S
Safety Clutch
Section, Knife
Shields, Separator
Shoe
Slat, Reel
Spindle, Wheel
Spreader, Straw
Sprockets, Cylinder
Straw Chopper
Straw Spreader
Straw Walker
T
Tailings Elevator
Tank, Grain
Tire and Tube
U
W
Walkers, Straw
Weed Bar (Special)
Wheel and Spindle
Wrench, Wheel
- JOHN DEERE CODE DTC LIST
