John Deere 4120 4320 4520 4720 Compact Utility Tractor Technical Manual TM2137
Brand: John Deere
Type of Machine: Compact Utility Tractor
Type of Manual: Technical Manual
Model: John Deere 4120 PIN (120101-610000), 4320 PIN (130101-620000), 4520 PIN (150101- 630000), 4720 PIN (170101-670000) (Without Cab)
Part Number: TM2137
Number of Pages: 1759 Pages
tm2137 - Compact Utility Tractors 4120 PIN (120101-610000), 4320 PIN (130101-620000), 4520 PIN (150101-630000), 4720 PIN (170101-670000) (Without Cab)
Table of Contents
Manual Description
Section : Safety
Group : Safety
Recognize Safety Information
Understand Signal Words
Replace Safety Signs
Handle Fluids Safely - Avoid Fires
Use Care In Handling and Servicing Batteries
Prevent Battery Explosions
Prevent Acid Burns
Wear Protective Clothing
Use Care Around High-pressure Fluid Lines
Service Machines Safely
Use Proper Tools
Park Machine Safely
Support Machine Properly and Use Proper Lifting Equipment
Work In Clean Area
Using High Pressure Washers
Illuminate Work Area Safely
Work In Ventilated Area
Warning: California Proposition 65 Warning
Avoid Harmful Asbestos Dust
Service Tires Safely
Avoid Injury From Rotating Blades, Augers and PTO Shafts
Service Cooling System Safely
Dispose Of Waste Properly
Live With Safety
Section : Specifications & Information
Group : General Specifications
Metric Fastener Torque Values
Metric Fastener Torque Values—Grade 7
Inch Fastener Torque Values
Gasket Sealant Application
Group : O-Ring Seal Service Recommendations
Face Seal Fittings with Inch Stud Ends Torque
Face Seal Fittings with Metric Stud Ends Torque
O-Ring Face Seal Fittings
O-Ring Boss Fittings
Group : Fuels and Lubricants
Diesel Fuel Specifications
Diesel Fuel Lubricity
Diesel Fuel Storage
Engine Oil
Engine Break–in Oil
Alternative Lubricants
Synthetic Lubricants
Lubricant Storage
Mixing Of Lubricants
Chassis Grease
Transaxle Oil
Group : Coolant Specifications
Engine Coolant
Engine Coolant Drain Interval
Group : Serial Number Locations
Machine Product Identification Number
Engine and Turbocharger Serial Numbers
Section : Engine - Diesel
Group : Specifications
Engine Specifications
Cylinder Head and Valves Specifications
Cylinder Block, Pistons, and Rods Specifications
Crankshaft, Main Bearings, and Flywheel Specifications
Camshaft, Balancer Shafts and Timing Gear Train Specifications
Lubrication System Specifications
Cooling System Specifications
Air Intake and Exhaust System Specifications
Starting and Charging Systems Specifications
Fuel System
Engine Mounting Specifications
Group : Tools and Materials
Engine Rebuild Essential Tools
Engine Rebuild Service Equipment and Tools
Cylinder Head and Valves Essential Tools
Cylinder Head and Valves Other Materials
Cylinder Block, Pistons, and Rods Essential Tools
Crankshaft, Main Bearings and Flywheel Essential Tools
Crankshaft, Main Bearings and Flywheel Service Equipment and Tools
Crankshaft, Main Bearings and Flywheel Other Materials
Camshaft and Timing Gear Train Essential Tools
Lubrication System Essential Tools
Base Engine Diagnostic Tools
Fuel System Observable Diagnostic Tools
Group : Theory of Operation
General Engine Operation
Lubrication System Operation
Coolant System Operation
Air Intake and Exhaust System Operation
Air Cleaner Operation
Turbocharger Operation
Turbocharger Lubrication
Group : Theory of Operation (Air and Fuel)
Fuel System Operation
Fuel Supply Pump
Fuel Filter/Water Separator Operation
Governor Operation
Integrated Fuel System (IFS) Operation
Light Load and Speed Advance Operation
Cold Start Advance Operation
Glow Plug Cold Start Aid Operation
Group : Diagnostics
About This Group of the Manual
Guideline for Acceptable Oil Consumption
L1 - Excessive Oil Consumption
L2 - Engine Oil Pressure Low
L3 - Engine Oil Pressure High
C1 - Coolant Temperature Above Normal
C2 - Coolant Temperature Below Normal
C3 - Coolant in Oil or Oil in Coolant
E1 - Engine Cranks/Won’t Start
E2 - Engine Misfires/Runs Irregularly
E3 - Engine Does Not Develop Full Power
E4 - Excessive White Exhaust Smoke
E5 - Excessive Black Or Gray Exhaust Smoke
E6 - Engine Will Not Crank
E7 - Engine Idles Poorly
E8 - Abnormal Engine Noise
F1 - Fuel Supply System Check
F2 - Excessive Fuel Consumption
F3 - Fuel in Oil
Group : Tests and Adjustments
Test Engine Compression Pressure
Test Engine Cranking Speed
Dynamometer Test
Engine Oil Consumption
Check Engine Oil Pressure
Check for Excessive Engine Crankcase Pressure (Blow-By)
Check for Turbocharger Oil Seal Leak
Inspect Thermostat and Test Opening Temperature
Pressure Test Cooling System and Radiator Cap
Check for Head Gasket Failures
Check and Service Cooling System
Check Air Intake System
Measure Intake Manifold Pressure (Turbocharger Boost)
Check for Intake and Exhaust Restrictions
Test for Intake Air Leaks
Check for Exhaust Air Leaks (Turbocharger)
Glow Plug Operation
Cylinder Misfire Test
Check Fuel Supply Quality
Test for Fuel Drain Back
Test Air in Fuel
Bleed Fuel System
Measure Fuel Transfer Pump Pressure
Bench Test Fuel Transfer Pump
Check Cold Start Advance Operation
Check Fuel Shut-Off Solenoid Operation
Check and Adjust Fast Idle Speed
Check and Adjust Slow Idle Speed
Group : Repair
Engine Removal and Installation
Engine Disassembly Sequence
Engine Assembly Sequence
Engine Break-In Guidelines
Perform Engine Break-In
Group : Cylinder Head and Valves
Cylinder Head - Exploded View
Remove Rocker Arm Cover
Remove Cylinder Head
Disassemble and Inspect Rocker Arm Assembly
Inspect, Remove, and Install Glow Plugs and Wire Harness
Measure Valve Recess in Cylinder Head
Preliminary Cylinder Head and Valve Checks
Remove Valve Assembly
Inspect and Measure Valve Springs
Clean Valves
Inspect and Measure Valves
Grind Valves
Head Gasket Inspection and Repair Sequence
Inspect and Clean Cylinder Head
Check Cylinder Head Flatness
Knurl Valve Guides
Clean and Inspect Valve Seats
Grind Valve Seats
Install Valves
Inspect and Clean Exhaust Manifold
Install Cylinder Head
Install Rocker Arm Assembly
Group : Cylinder Block, Pistons, and Rods
Connecting Rods - General Information
Preliminary Cylinder Block, Pistons, and Rod Checks
Remove Pistons and Connecting Rod Assembly
Disassemble Piston and Rod Assembly
Clean Pistons
Visually Inspect Pistons
Check Piston Ring Groove Wear
Measure Piston Pin Bore
Measure Piston Skirt
Determine Piston-to-Cylinder Bore Clearance
Deglaze Cylinder Bores
Inspect and Measure Connecting Rod Bearings (Rods Removed from Engine)
Inspect and Measure Connecting Rod Bearings (Rod & Crankshaft in Engine)
Inspect Rod and Cap
Inspect Piston Pins and Bushings
Measure Rod Center-to-Center Bores
Inspect and Clean Cylinder Block
Measure Cylinder Block Main Bearing Bore
Measure Camshaft Follower Machined Bore
Measure Camshaft Bushing Bores in Block
Inspect and Measure Cylinder Bore
Measure Cylinder Block Top Deck Flatness
Remove, Inspect, and Install Piston Cooling Orifices
Assemble Piston and Connecting Rod
Install Piston Rings
Install Piston and Connecting Rod Assembly
Torque-Turn Connecting Rod Cap Screws
Check Engine Rotation for Excessive Tightness
Measure Piston Protrusion
Complete Final Assembly
Group : Crankshaft, Main Bearings and Flywheel
Crankshaft and Main Bearing Failure Analysis
Remove Crankshaft Pulley
Inspect Pulley and Wear Sleeve
Replace Front Crankshaft Oil Seal (Without Removing Timing Gear Cover)
Install Crankshaft Pulley
Check Crankshaft End Play
Check Flywheel Face Flatness
Check Pilot Bearing Bore Concentricity
Remove Flywheel
Replace Flywheel Ring Gear
Remove Flywheel Housing
Remove Crankshaft Rear Oil Seal and Housing
Clean and Inspect Crankshaft Flange
Install Crankshaft Rear Oil Seal Housing
Remove Crankshaft Main Bearings
Check Main Bearing Oil Clearance
Remove Crankshaft
Inspect Crankshaft
Measure Crankshaft Journals and Main Bearing ID
Measure Main Thrust Journal Width and Thrust Washers
Measure Assembled ID of Main Bearing Caps
Install Main Bearings, Thrust Washers and Crankshaft
Install Flywheel Housing
Install Flywheel
Group : Camshaft, Balancer Shafts and Timing Gear Train
Remove Timing Gear Cover
Remove Balancer Shafts
Inspect and Measure Balancer Shaft Bushings and Journals
Inspect Balancer Shaft Gears and Thrust Plates
Remove, Inspect and Install Balancer Idler Gears and Shafts
Measure Idler Gear Bushing and Shaft
Remove Balancer Bushings
Install Balancer Bushings
Install Balancer Shafts
Remove Governor Assembly and Camshaft Drive Gear
Remove Camshaft
Visually Inspect Camshaft
Inspect and Measure Camshaft Bushing ID and Journal OD
Remove and Install Camshaft Bushings
Measure Camshaft Lobe Height
Inspect Camshaft Followers
Install Camshaft
Install and Time Camshaft Drive Gear
Install Governor Assembly
Clean and Inspect Timing Gear Cover
Install Timing Gear Cover
Group : Lubrication System
General Lubrication System Information
Remove Oil Cooler
Install Oil Cooler
Remove and Install Oil Pan
Remove and Install Oil Pressure Regulating Valve
Remove, Inspect, and Install Oil Pick-up Tube Assembly
Remove, Inspect and Install Oil Pump
Remove and Install Oil Dipstick Tube with Oil Pan Installed
Group : Cooling System
Remove and Install Thermostat
Test Thermostat
Replacing Fan and Alternator Belt
Remove and Install Automatic (Spring) Belt Tensioner
Checking Belt Tensioner Spring Tension and Belt Wear (Automatic Tensioner)
Remove Coolant Pump
Inspect and Clean Coolant Pump Parts
Install Coolant Pump
Cooling System Deaeration
Inspect and Install Fan Assembly
Remove Fan Bearing
Install Fan Bearing
Group : Air Intake and Exhaust System
Extending Turbocharger Life
Remove Turbocharger
Turbocharger Failure Analysis
Turbocharger Inspection
Repair Turbocharger
Prelube Turbocharger
Install Turbocharger
Remove, Inspect, and Install Exhaust Manifold
Remove, Inspect, and Install Intake Manifold
Group : Fuel System
Remove and Install Fuel Supply Pump
Remove and Inspect Integrated Fuel System (IFS)
Install Integrated Fuel System (IFS)
Remove and Install Fuel Rail Check Valve
Remove and Install Governor Lever Assembly
Remove and Install Throttle Control Assembly
Remove and Install Full Load Stop Screw
Remove and Install Idle Bias Adjustment Screw
Remove and Install Fuel Shut-Off Solenoid
Remove and Install Aneroid
Group : Starting and Charging Systems
Remove and Install Starter
Remove and Install Alternator
Section : Electrical
Group : General Information
Reading Electrical Schematics
Theory Of Operation Information
Diagnostic Information
Wire Color Abbreviation Chart
Common Circuit Tests
Conductors For 12 Volt Circuits
Tools
Other Materials
Group : Component Location
Main Machine
Load Center
Display Panel
Group : Schematics and Harnesses
Main Schematic and Wiring Harness Legend - PRT and eHydro
eHydro - Schematic and Wiring Harness Legend
W1 Main Electrical Schematic
W9 eHydro and Cruise Control Electrical Schematic (1 of 2)
W1 Main Wiring Harness
W1 Main Wiring Harness Color Codes
W2 Headlight Wiring Harness
W2 Headlight Wiring Harness Color Codes
W3 and W4 Jumper Plug
W7 Right Rear Lights Wiring Harness
W7 Right Rear Lights Wiring Harness Color Codes
W8 Left Rear Lights Wiring Harness
W8 Left Rear Lights Wiring Harness Color Codes
W9 eHydro Wiring Harness
W9 eHydro Wiring Harness Color Codes
W10 Proportional Valve Wiring Harness
W10 Proportional Valve Wiring Harness Color Codes
W11 Cruise Control Wiring Harness (standard)
W11 eHydro Cruise Control Wiring Harness Color Codes (standard)
W12 Cruise Control Wiring Harness (optional)
W12 eHydro Cruise Control Wiring Harness Color Codes (optional)
Group : Troubleshooting
Display Panel Fault Codes
Display Panel Fault Code Chart
Group : Operation and Diagnostics
Power Circuit Operation
Power Circuit Electrical Schematic - W1 PRT and eHydro
Power Circuit Electrical Schematic - W9 eHydro
Power Circuit Diagnosis
Cranking Circuit Operation
Cranking Circuit Electrical Schematic
Cranking Circuit Diagnosis
Glow Plug and Light Circuit Operation
Glow Plug and Light Circuit Electrical Schematic
Glow Plug and Light Circuit Diagnosis
Fuel Supply/Engine Shutoff Circuit Operation
Fuel Supply/Engine Shutoff Circuit Electrical Schematic
Fuel Supply/Engine Shutoff Circuit Diagnosis
Charging Circuit Operation
Tachometer Circuit Operation
Hour Meter Circuit Operation
Charging, Tachometer and Hour Meter Circuit Electrical Schematic
Charging, Tachometer and Hour Meter Circuit Diagnosis
Rear PTO Circuit Operation
Rear PTO Circuit Electrical Schematic
Rear PTO Circuit Diagnosis
MFWD Circuit Operation
MFWD Circuit Electrical Schematic
MFWD Circuit Diagnosis
Lights Circuit Electrical Schematic
Lights Circuit Diagnosis
Turn Signal Lights Circuit Operation
Turn Signal Lights Circuit Electrical Schematic
Turn Signal Lights Circuit Diagnosis
Display Panel Operation
Display Panel Diagnosis
Display Mode Switch Circuit Operation
Display Mode Switch Circuit Electrical Schematic
Display Mode Switch Circuit Diagnosis
eHydro - eMatchOS Electronic Drive Controller
eHydro - Forward Drive Circuit Operation
eHydro - Forward Drive Circuit Electrical Schematic
eHydro - Forward Drive Circuit Diagnosis
eHydro - Reverse Drive Circuit Operation
eHydro - Reverse Drive Circuit Electrical Schematic
eHydro - Reverse Drive Circuit Diagnosis
eHydro - Cruise Control Circuit Operation (standard)
eHydro - Cruise Control Circuit Electrical Schematic (standard)
eHydro - Cruise Control Circuit Diagnosis (standard)
eHydro - Cruise Control Circuit Operation (optional)
eHydro - Cruise Control Circuit Electrical Schematic (optional)
eHydro - Cruise Control Circuit Diagnosis (optional)
eHydro - Load Match and Motion Match Circuit Operation
eHydro - Load Match and Motion Match Circuit Electrical Schematic
eHydro - Load Match and Motion Match Control Circuit Diagnosis
Ground Circuit Test
Battery Voltage and Specific Gravity Test
Battery - Charge
Battery - Load Test
Alternator Regulated Voltage Test
Alternator Test and Inspection
Regulated Amperage and Voltage Test
Starting Motor Solenoid Test
Starting Motor Amperage Draw Test
Starting Motor No-Load Amperage Draw and RPM Test
Fuse Test
Glow Plug Test
Engine Coolant Temperature Sensor Test
Engine Oil Pressure Switch Test
Relay Test
Key Switch Test
Light Switch Test
Sensing Switch Test
Turn Signal Switch Test
Hazard Switch Test
Rear PTO Switch Test
Rear PTO Solenoid Test
Seat Switch Test
Cruise/Max Speed Switch Test - eHydro
Res/+, Set/- Switch Test - eHydro
Brake and Park Brake Switch Test
Air Filter Restriction Switch Test
Fuel Gauge Sensor Test
Fuel Shutoff Solenoid Test
Load Match Switch Test - eHydro
Motion Match Switch Test - eHydro
Display Mode Switch Test
Proportional Drive Solenoid Test - eHydro
Horn Switch Test
Configure the Display
Editing Tire Size Value
Editing Motion Match Settings - eHydro
Editing Load Match Settings - eHydro
Entering Diagnostic and Calibration Modes
eHydro - Electronic Drive Controller System Calibration
eHydro - Single Sensor Calibration
Test Kit
eHydro - Throttle Position Sensor Test and Adjustment
eHydro - Forward and Reverse Pedal Sensor Test and Adjustment
eHydro - MFWD Speed Sensor Test
Group : Repair
Throttle Position Sensor Removal and Installation
Electronic Drive Controller Removal and Installation
Alternator Removal and Installation
Alternator Disassembly and Assembly
Fuel Gauge Sensor Removal and Installation
Section : Electrical - European
Tools
Other Materials
Main Machine
Load Center
Display Panel
W1 Main Electrical Schematic (1 of 4)
W2 Headlight/Horn Wiring Harness
W2 Headlight/Horn Wiring Harness Color Codes
W7 Left Rear Lights Wiring Harness
W7 Left Rear Lights Wiring Harness Color Codes
W8 Right Rear Lights Wiring Harness
W8 Right Rear Lights Wiring Harness Color Codes
Charge Circuit Operation
Charge, Tachometer and Hour Meter Circuit Electrical Schematic
Charge, Tachometer and Hour Meter Circuit Diagnosis
Brake Lights Operation
Hazard Lights Circuit Operation
Hazard Lights Circuit Electrical Schematic
Hazard Lights Circuit Diagnosis
Turn Signal Circuit Electrical Schematic
Section : Power Train - PRT
Repair Specifications
Torque Specifications
Special or Essential Tools
Other Materials
Clutch Housing
PowrReverser Clutch
Main Shaft
Driven Shaft
Main Gear Shift
PRT Pedal and Shift Linkage
PRT Valve
PRT Control Valve Operation
PRT Clutch Operation - Forward
PRT Clutch Operation - Reverse
4 Speed Transmission Operation
Range Transmission Power Flow
PRT Clutch Adjustment
PRT Hydraulic Pressure Tests
Group : Repair
Machine Splitting (Front)
Machine Splitting (Rear)
Reverse Case Seal Replacement
PowrReverser Traction Clutch
PowrReverser Clutch Valve
4-Speed Transmission
Section : Power Train - Hydrostatic
Hydrostatic Power Train Specifications
Other Materials
eHydro Machines Component Location
eHydro Transmission Components
eHydro Center Plate Components
Drive Shaft
Front Drive
Group : Schematics
Steering/Charge Pump Circuit Schematic, eHydro Transmission
eHydro Transmission Operation
Group : Diagnostics
Troubleshooting Table
Hydrostatic High Pressure Relief Test
Charge Pump Pressure Test
Hydraulic System Bleed Procedure
Group : Repair
Forward and Reverse Position Sensors
Forward and Reverse Pedals Assembly
Hydrostatic Transmission Removal and Installation
Hydrostatic Transmission Disassembly
Section : Power Train - Final Drive
Other Materials
Rear Axle and Final Drive
Differential Pinion Shaft (eHydro)
Differential Pinion Shaft (PRT)
Range Shift
Front Drive (For MFWD)
Differential Gear
Differential Lock
Brake
PTO Clutch/Brake Assembly
Rear PTO Shafts
Mid PTO Assembly
2-Speed Rear PTO
Transmission Housing (eHydro)
Transmission Housing - PRT
MFWD Front Axle Housing and Differential
MFWD Final Drive
Range Transmission
MFWD Power Operation
Differential Power Flow and Lock
MFWD Power Flow
Group : Diagnostics
PTO Diagnostics Table
Differential Pinion Shaft Adjustment
Differential Backlash Adjustment
Group : Repair
MFWD Output Shaft
Speed Range Transmission
Final Drive Removal
Final Drive Installation
Final Drive Disassembly, Inspection, and Assembly
Differential Lock Fork
Differential Removal and Installation
MFWD Drive Shaft Removal and Installation
MFWD Removal and Installation
MFWD Final Drive Cover
MFWD Spindle Shaft
MFWD Final Drive Housing
Spindle Housing
MFWD Differential
Pinion Depth Setup and Adjustment
Group : PTO Theory of Operation
PTO Clutch and Brake Theory of Operation
Power Transmission - Rear PTO
Power Transmission - 2 Speed Rear PTO
Power Transmission - Mid PTO
Group : PTO Repair
Rear PTO Drive Shaft and Gears
2-Speed Rear PTO Drive Shaft and Gears
Mid PTO
Section : Hydraulics
Hydraulic Specifications
Other Materials
PRT Machines Component Location
Rockshaft Component Location
Dual SCV Components
Dual SCV Hydraulic Lines
Third SCV Components
Power Beyond Components
Hydraulic Pump Component Location
Rockshaft Piston, Rod, and Rate of Drop Valve
Rockshaft Control Valve, Plunger Assembly and Controls
Rockshaft and Lift Arms (Exploded View)
PTO Clutch Valve Component Location
SCV Valve Component Location
Diverter Assembly Front
Diverter 4th and 5th SCV Assembly Rear
Group : Schematics & Harnesses
Steering/Charge Pump Circuit Schematics, PRT Transmission
Implement Pump Circuit Schematic, eHydro and PRT
Diverter Valve Schematic
Hydraulics (General)
Hydraulics (SCV) (Option)
Hydraulics (Rockshaft)
Diverter Valve (Option)
Group : Diagnostics
Diagnostic Table
Hydraulic Pump Flow Test
System Relief Pressure Test
PTO Valve Pressure Test
Steering Pressure Check
Rockshaft Lift Cycle Test
Rate of Drop/Stop Valve Adjustment
Rockshaft Leakage Test
Rockshaft Position Feedback Linkage Adjustment
Group : Repair
Hydraulic Gear Pump
Rockshaft Removal and Installation
Lift Arms
Lift Control Lever
Rockshaft Feedback Shaft
Rockshaft Piston
PTO Clutch Valve
Selective Control Valve (SCV)
Section : Steering
Steering
Steering Component Location
Steering System Schematic
All Models:
eHydro Model:
PowrReverser Model:
Group : Diagnostics
Steering Operation
Diagnosis Table
Steering System Test
Toe-in Adjustment MFWD
Group : Repair
Steering Cylinder
Steering Wheel Removal and Installation
Tilt Steering Mechanism Removal and Installation
Steering Control Unit (SCU) Removal and Installation
Tie Rod Removal and Installation - MFWD
Section : Brakes
Brakes
Transaxle Oil
Brake Housing
Park Brake
Park Brake Components
Brake Pedals and Linkage - eHydro
Brake Pedals and Linkage - eHydro (Exploded View)
Brake Pedals and Linkage - PRT
Brake Pedals and Linkage - PRT (Exploded View)
Brakes
Group : Diagnostics
Brakes
Diagnosis
Brake Pedal Adjustment
Parking Brake Adjustment
Group : Repair
Brake Disassembly and Inspection
Brake Assembly
Brake Pedal Assembly Removal and Installation - eHydro
Brake Pedal Assembly Removal and Installation - PRT
Parking Brake Linkage Removal and Installation
Section : Miscellaneous
Group : Repair
Three Point Hitch Removal and Installation
Center Link Bracket Removal and Installation
Seat and Seat Support Removal and Installation
Seat Closeout Removal and Installation
Rear Fenders Removal and Installation
Roll Over Protection System (ROPS)
Front Wheel Removal and Installation
Rear Wheel Removal and Installation
Operator’s Platform Removal and Installation
Fuse Panel Cover Removal and Installation
Battery Removal and Installation
Hood Removal and Installation
Cowl Panel Removal and Installation
Control Panel and Removal and Installation
Fuel Tank Removal and Installation
Manual Description
Be Prepared For Emergencies
Prevent Acid Burns
Avoid acid burns by:
If you spill acid on yourself:
If acid is swallowed:
Avoid High-Pressure Fluids
Use Proper Tools
Park Machine Safely
Before working on the machine:
Work In Clean Area
Before starting a job:
Live With Safety
Cleaning:
How to Dispense/Apply/Assemble Gasket Sealants:
Disassembly:
Diesel Fuel Storage
Engine Oil
Engine Break–in Oil
Lubricant Storage
Chassis Grease
Transaxle Oil
Engine Coolant
Engine Coolant
Fuel System
Fuel Supply Pump
Governor Operation
Pistons, Rings, Cylinder Bore Check
E1 - Preliminary Check
E2 - Preliminary Check
Piston Ring Check
E3 - Preliminary Check
E4 - Preliminary Check
E5 - Preliminary Check
E7 - Preliminary Check
Fuel Transfer Pump Check
Return Fuel Check
F3 - Fuel in Oil
Compression Test
Compression Test
Dynamometer Test
Test Radiator Cap:
Test Cooling System:
Glow Plug Operation
Test Air in Fuel
Bleed Fuel System
Vacuum/Pressure Test
Leakage Test
Special or Required Tools:
Prepare the Machine:
Remove Engine:
Installation and Assembly:
Remove Engine:
Clean Valves
Grind Valves
Knurl Valve Guides
Grind Valve Seats
Install Valves
Scuffed or Scored Pistons:
Worn or Broken Compression Rings:
Clogged Oil Control Ring:
Stuck Rings:
Mottled, Grayish or Pitted Compression Rings:
Dull Satin Finish and Fine Vertical Scratches on Rings:
Piston Pin and Snap Ring Failure:
Broken Connecting Rod:
Cylinder Wear and Distortion:
Warped Cylinder Block:
Clean Pistons
Inspect Rod and Cap
Using Engine Axis Method to Torque-Turn Connecting Rod Cap Screws:
Using JT05993 Torque Angle Gauge to Torque-Turn Connecting Rod Cap Screws:
Remove Front Crankshaft Oil Seal
Install Front Crankshaft Oil Seal
Remove Flywheel
Remove Rear Oil Seal Using JDG698A
Remove Rear Oil Seal Housing
Handling Rear Oil Seal
Oil Seal Installation
Remove Crankshaft
Inspect Crankshaft
Install Flywheel
Remove Camshaft
Remove Camshaft Bushings
Install Camshaft
Remove Oil Cooler
Install Oil Cooler
Removal
Installation
To Remove Thermostat
To Install Thermostat
Test Thermostat
Testing Thermostats Opening Temperature
Checking Belt Wear:
Checking Tensioner Spring Tension
Remove Coolant Pump
Remove Fan Bearing
Install Fan Bearing
Lack of Lube Oil
Oil Contamination
Ingestion of Foreign Objects
Restricted Oil Drainage
Abnormally High Exhaust Temperatures
Lack of Lube Oil
Oil Contamination
Remove Turbocharger
Compressor Housing Inlet and Compressor Wheel
Compressor Housing Outlet
Turbine Housing Inlet
Turbine Housing Outlet and Turbine Wheel
External Center Housing and Joints
Perform Axial Bearing End Play Test
Repair Turbocharger
Remove Governor Lever Assembly
Remove Throttle Assembly
Install Throttle Assembly
Throttle Assembly Adjustments
Remove Full Load Stop Screw
Shorted Circuit:
High Resistance or Open Circuit:
Grounded Circuit:
Tools
Other Materials
Main Machine
Main Machine
Load Center
Display Panel
Connectors:
Wiring Harnesses:
Connectors:
Wiring Harnesses:
Connectors:
Wiring Harnesses:
W1 Main Electrical Schematic (2 of 3)
W1 Main Electrical Schematic (3 of 3)
W9 eHydro and Cruise Control Electrical Schematic (2 of 2)
Purpose:
Operation:
Purpose:
Operation:
Function:
Unswitched Power:
Switched Power:
Switched Power - eHydro specific Circuits:
Secondary Switched Power:
Secondary Switched Power - eHydro specific Circuits:
Function:
Unswitched Power:
Switched Power:
Test Procedure A:
Test Procedure B:
Test Procedure C:
Function:
Operating Conditions:
Theory of Operation:
Test Conditions:
Function:
Test Conditions:
Function:
Operating Conditions (Cranking):
Operating Conditions (Engine on, Operator ON Seat):
Operating Conditions (Engine On, Operator OFF Seat):
Operating Conditions (Engine On, Operator OFF Seat, Rear PTO Engaged):
Engine MUST STOP when:
Theory of Operation - Fuel Supply Logic:
Theory of Operation - Engine Shutoff:
Engine on, Operator ON Seat Logic:
Engine On, Operator OFF Seat Logic:
Engine On, Operator OFF Seat, Rear PTO Engaged Logic (Off Seat PTO Logic):
Test Procedure A:
Test Procedure B:
Function:
Function:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Light Switch Hazard Position:
Light Switch Road Position:
Light Switch Field Position:
Test Procedure A:
Test Procedure B:
Test Procedure C:
Turn Signal Switch Function:
Operating Condition:
Turn Signal Switch Left Position:
Turn Signal Switch Right Position:
Test Procedure A:
Test Procedure B:
Function:
Inputs:
Outputs:
Ground:
eHydro Communication:
Function:
Test Conditions:
Function:
General Theory:
Cruise Control - Standard:
Cruise Control - Optional:
Max Speed:
Motion Match Switch:
Load Match Switch:
Drive Controller Inputs and Outputs
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Conditions:
Function, Load Match:
Operating Conditions, Load Match:
Theory of Operation, Load Match:
Function, Motion Match:
Operating Conditions, Motion Match:
Theory of Operation, Motion Match:
Diagnosis - Load Match:
Diagnosis - Motion Match:
Ground Circuit Test
Reason:
Equipment:
Ohmmeter Procedure:
Voltmeter Procedure:
Results:
Ground Circuit Test
Reason:
Equipment:
Ohmmeter Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Battery - Charge
Reason:
Equipment:
Procedure:
Battery - Load Test
Reason:
Equipment:
1/2 CCA Load Test Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Inspection:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Fuse Test
Reason:
Equipment:
Procedure:
Results:
Glow Plug Test
Reason:
Equipment:
Procedure:
Results:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Reason:
Equipment:
Procedure:
Results:
Results:
Relay Test
Results:
Equipment:
Procedure:
Results:
Results:
Key Switch Test
Reason:
Equipment:
Procedure:
Results:
Light Switch Test
Reason:
Equipment:
Procedure:
Results:
Sensing Switch Test
Reason:
Equipment:
Procedure:
Reason:
Equipment:
Procedure:
Results:
Hazard Switch Test
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Seat Switch Test
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Test Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Test Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Horn Switch Test
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Reason:
Equipment:
Procedure:
Option 1 (without switch):
Option 2 (with switch):
Diagnostic Mode 1:
Diagnostic Mode 2 (eHydro only):
Diagnostic Mode 3 - System Calibration (eHydro only):
Reason:
Test Conditions:
Procedure:
Reason:
Test Conditions:
Procedure:
Test Kit
Function:
Equipment:
Theory:
Purpose:
Procedure - Diagnostic Mode 2:
Procedure - Test Kit:
Throttle Sensor Adjustment:
Purpose:
Drive Pedal Sensor Adjustment:
Purpose:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Disassembly:
Assembly:
Removal:
Installation:
Tools
Other Materials
Main Machine
Main Machine
Load Center
Display Panel
Connectors:
Wiring Harnesses:
Connectors:
Wiring Harnesses:
Connectors:
Wiring Harnesses:
W1 Main Electrical Schematic (2 of 4)
W1 Main Electrical Schematic (3 of 4)
W1 Main Electrical Schematic (4 of 4)
Purpose:
Operation:
Purpose:
Operation:
Function:
Unswitched Power:
Switched Power:
Function:
Unswitched Power:
Switched Power:
Test Procedure A:
Test Procedure B:
Test Procedure C:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Procedure A:
Test Procedure B:
Function:
Function:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Function:
Test Procedure A:
Test Procedure B:
Test Procedure C:
Function:
Test Conditions:
Test Procedure A:
Test Procedure B:
Function:
Inputs:
Outputs:
Ground:
Function:
Test Conditions:
Function:
General Theory:
Max Speed:
Load Match Switch:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Conditions:
PowrReverser Hydraulic Clutch:
PowrReverser Valve Block
Other Materials
Clutch Housing
Clutch Housing
PowrReverser Clutch
Main Shaft
Driven Shaft
Main Gear Shift
PRT Valve
PRT Control ValveOperation
Lever In Neutral, Clutch Pedal Up
Lever In Forward, Clutch Pedal Down
Lever In Forward, Clutch Pedal Up
Lever In Reverse, Clutch Pedal Up
Function:
Function:
Function:
Function:
PRT ClutchAdjustment
Reason:
Procedure:
Reason:
Procedure:
Reason:
Procedure (Forward and Reverse Pressure):
Results:
Procedure (Lubrication Pressure):
Results:
Machine Splitting(Front)
Split the Machine:
Assemble Machine Sections:
Split the Machine:
Machine Splitting(Rear)
Procedure:
Split the Machine:
Reverse Case SealReplacement
Procedure:
PowrReverser TractionClutch
Removal:
TractionClutch Idler Gear Removal:
Traction Clutch Disassembly:
Transfer Shaft Disassembly:
Installation:
Removal:
Disassembly:
Installation:
Removal and Disassembly:
Transmission Top Shaft Removal:
Fork Shaft Detent Inspection:
Mid Shaft Disassembly, Inspect and Assembly:
Gear Shaft Disassembly and Inspection:
Synchromesh Gear Disassembly, Inspection and Reassembly:
4-Speed Transmission Assembly / Installation:
Other Materials
Drive Shaft
Front Drive
Steering/Charge Pump Schematics, eHydro
Function:
Principles of Operation:
Charge Pump
Hydrostatic Pump
Hydrostatic Motor
Function:
Charge Pump
Hydrostatic Pump
Hydrostatic Motor
Function:
Reason:
Equipment:
Procedure:
Specifications:
Results:
Reason:
Equipment:
Procedure:
Specifications:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Procedure:
Removal:
Installation:
Removal:
Installation:
Disassembly:
Assembly:
Forward and Reverse Pedals Components Explode
Split the Machine:
Split the Machine:
Special or Essential Tools:
Removal:
Installation:
Disassembly:
Front Seal Replacement:
Transaxle Oil:
Capacity:
PTO Speeds (At 2396 Engine rpm):
MFWD Oil:
Transaxle Oil:
Capacity:
MFWD Oil:
Transaxle Oil:
Capacity:
MFWD Oil:
PTO Clutch/Brake Specifications:
Pinion and Ring Gear Specifications:
Front Wheel Alignment:
Steering Angle:
Front Axle MFWD:
Other Materials
Range Shift
Differential Gear
Differential Lock
Brake
Rear PTO Shafts
Mid PTO Assembly
2-Speed Rear PTO
MFWD Final Drive
Range Transmission
Operation:
MFWD Drive:
Range Transmission
Operation:
MFWD Drive:
Operation:
Function:
Power Flow Operation:
Differential Operation:
MFWD Power Flow
Reason:
Procedure:
Reason:
Procedure:
Reason:
Procedure:
To Adjust Backlash:
MFWD Output Shaft
Removal:
Disassembly:
Installation:
MFWD Output Shaft
Removal:
Disassembly:
Installation:
Removal:
Disassembly:
Assembly:
Differential Pinion Shaft Removal & Disassembly:
Assembly:
Final Drive Removal
Left-Hand Final Drive Removal:
Right-Hand Final Drive Removal:
Left-Hand Final Drive Installation:
Right-Hand Final Drive Installation:
Disassemble:
Planetary Pinions:
Assembly:
Removal:
Installation:
Removal:
Disassembly:
Assembly:
Removal:
Installation:
Removal and Inspection:
Installation:
MFWD Spindle Shaft
Assembly and Installation:
Disassembly:
Assembly:
Spindle Housing
MFWD Differential
Specification:
Tools Required:
Procedure:
Determining Differential Bearing Preload:
Differential Backlash Adjustment:
Results:
Function:
Theory:
Function:
Theory:
Function:
Theory:
Function:
Theory:
Power Transmission -Mid PTO
Function:
Theory:
Removal:
Installation:
Disassembly:
Assembly:
Removal:
Installation:
Disassembly:
Assembly:
Removal:
Installation:
Disassembly:
Assembly:
Removal andInstallation:
Installation:
Disassembly:
Assembly:
Mid PTO
Removal:
Installation:
Assembly:
Hydraulic Oil:
All Machines (Unless Noted):
Hydraulic Oil:
Hydraulic Oil:
Rockshaft Specifications:
Lift Arms:
SCV:
Rockshaft:
Other Materials
Dual SCV Components
Steering System Schematics, PRT (continued)
Function:
Function:
Function:
Theory:
Operation:
Function:
Theory:
Operation:
Function:
Theory:
Diagnostic Table
Diagnostic Table
Reason:
Procedure:
Reason:
Procedure:
Reason:
Equipment:
Procedure:
Test Rockshaft/Hydraulic Pump (B) on machines without SCVs:
Machines with SCVS:
Reason:
Procedure:
Machines without SCV:
Machines with SCV:
Reason:
Equipment:
Procedure:
Hydraulic Oil Pressure Specification ±10%
Reason:
Equipment:
Procedure:
Specifications:
Results:
Reason:
Equipment:
Procedure:
Specifications
Results:
Reason:
Equipment:
Procedure:
Specifications:
Results:
Reason:
Equipment:
Procedure:
Specifications
Results:
Reason:
Procedure:
Hydraulic Gear Pump
Gear Pump Disassembly and Inspection:
Assembly:
Hydraulic Gear Pump
Assembly:
Removal:
Installation:
Lift Arms
Removal:
Specifications:
Installation:
Specifications:
Lift Control Lever
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Rockshaft Piston
Removal:
Installation:
PTO Clutch Valve
Removal:
Installation:
Disassembly and Assembly:
Inspection:
Assembly:
Removal:
Installation:
Dual SCV Linkage Disassembly:
Dual SCV Linkage Assembly:
SCV Disassembly:
Valve Spools Assembly:
Load Check Valves:
Installation:
Relief Valve:
Steering
Steering
Steering
All Models:
All Models:
eHydro Model:
PowrReverser Model:
Steering Operation
Steering Operation
Diagnosis Table
Reason:
Tools:
Procedure:
Results:
Procedure:
Results:
Reason:
Tools:
Procedure:
Results:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Steering Cylinder
Removal:
Installation:
Steering Cylinder
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Tie Rod Removal and Installation- MFWD
Removal:
Installation:
Brakes
Brakes
Brakes
Transaxle Oil
Brake Housing
Brake Housing
Park Brake
Brakes
Brakes
Brakes
Brakes
Diagnosis
Reason:
Tools:
Procedure:
Results:
Reason:
Tools:
Procedure:
Results:
Brake Actuator Inspection:
Brake Assembly
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Center Lift Link Removal:
Installation:
Draft Arm & Adjustable Sway Bar Removal:
Installation:
Adjustable (Right Side) and Fixed (Left Side) Lift Link Removal:
Installation:
Installation:
Installation:
Installation:
CenterLink Bracket Removal and Installation
Removal:
Installation:
Seatand Seat Support Removal and Installation
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
ControlPanel and Removal and Installation
Removal:
Installation:
FuelTank Removal and Installation
Removal:
Installation:
Brand: John Deere
Part Number: TM2137
Table of Contents
Manual Description
Section : Safety
Group : Safety
Prevent Acid Burns
Use Proper Tools
Park Machine Safely
Work In Clean Area
Live With Safety
Diesel Fuel Storage
Engine Oil
Engine Break–in Oil
Lubricant Storage
Chassis Grease
Transaxle Oil
Engine Coolant
Fuel System
Fuel Supply Pump
Governor Operation
Group : Diagnostics
F3 - Fuel in Oil
Dynamometer Test
Glow Plug Operation
Test Air in Fuel
Bleed Fuel System
Group : Repair
Clean Valves
Grind Valves
Knurl Valve Guides
Grind Valve Seats
Install Valves
Clean Pistons
Inspect Rod and Cap
Remove Flywheel
Remove Crankshaft
Inspect Crankshaft
Install Flywheel
Remove Camshaft
Install Camshaft
Remove Oil Cooler
Install Oil Cooler
Test Thermostat
Remove Coolant Pump
Remove Fan Bearing
Install Fan Bearing
Remove Turbocharger
Repair Turbocharger
Group : Fuel System
Tools
Other Materials
Main Machine
Load Center
Display Panel
Ground Circuit Test
Battery - Charge
Battery - Load Test
Fuse Test
Glow Plug Test
Relay Test
Key Switch Test
Light Switch Test
Sensing Switch Test
Hazard Switch Test
Seat Switch Test
Horn Switch Test
Test Kit
Group : Repair
Tools
Other Materials
Main Machine
Load Center
Display Panel
Other Materials
Clutch Housing
PowrReverser Clutch
Main Shaft
Driven Shaft
Main Gear Shift
PRT Valve
Group : Repair
Other Materials
Drive Shaft
Front Drive
Group : Schematics
Group : Diagnostics
Group : Repair
Other Materials
Range Shift
Differential Gear
Differential Lock
Brake
Rear PTO Shafts
Mid PTO Assembly
2-Speed Rear PTO
MFWD Final Drive
Range Transmission
MFWD Power Flow
Group : Diagnostics
Group : Repair
MFWD Output Shaft
Final Drive Removal
MFWD Spindle Shaft
Spindle Housing
MFWD Differential
Group : PTO Repair
Mid PTO
Other Materials
Dual SCV Components
Group : Diagnostics
Diagnostic Table
Group : Repair
Hydraulic Gear Pump
Lift Arms
Lift Control Lever
Rockshaft Piston
PTO Clutch Valve
Section : Steering
Steering
All Models:
eHydro Model:
PowrReverser Model:
Group : Diagnostics
Steering Operation
Diagnosis Table
Group : Repair
Steering Cylinder
Section : Brakes
Brakes
Transaxle Oil
Brake Housing
Park Brake
Brakes
Group : Diagnostics
Brakes
Diagnosis
Group : Repair
Brake Assembly
Group : Repair
Manual Description
Prevent Acid Burns
Use Proper Tools
Park Machine Safely
Work In Clean Area
Live With Safety
Cleaning:
Disassembly:
Diesel Fuel Storage
Engine Oil
Engine Break–in Oil
Lubricant Storage
Chassis Grease
Transaxle Oil
Engine Coolant
Engine Coolant
Fuel System
Fuel Supply Pump
Governor Operation
Piston Ring Check
Return Fuel Check
F3 - Fuel in Oil
Compression Test
Compression Test
Dynamometer Test
Test Radiator Cap:
Glow Plug Operation
Test Air in Fuel
Bleed Fuel System
Leakage Test
Remove Engine:
Remove Engine:
Clean Valves
Grind Valves
Knurl Valve Guides
Grind Valve Seats
Install Valves
Stuck Rings:
Clean Pistons
Inspect Rod and Cap
Remove Flywheel
Remove Crankshaft
Inspect Crankshaft
Install Flywheel
Remove Camshaft
Install Camshaft
Remove Oil Cooler
Install Oil Cooler
Removal
Installation
Test Thermostat
Checking Belt Wear:
Remove Coolant Pump
Remove Fan Bearing
Install Fan Bearing
Lack of Lube Oil
Oil Contamination
Lack of Lube Oil
Oil Contamination
Remove Turbocharger
Repair Turbocharger
Shorted Circuit:
Grounded Circuit:
Tools
Other Materials
Main Machine
Main Machine
Load Center
Display Panel
Connectors:
Wiring Harnesses:
Connectors:
Wiring Harnesses:
Connectors:
Wiring Harnesses:
Purpose:
Operation:
Purpose:
Operation:
Function:
Unswitched Power:
Switched Power:
Function:
Unswitched Power:
Switched Power:
Test Procedure A:
Test Procedure B:
Test Procedure C:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Procedure A:
Test Procedure B:
Function:
Function:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Procedure A:
Test Procedure B:
Test Procedure C:
Test Procedure A:
Test Procedure B:
Function:
Inputs:
Outputs:
Ground:
Function:
Test Conditions:
Function:
General Theory:
Max Speed:
Load Match Switch:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Conditions:
Ground Circuit Test
Reason:
Equipment:
Ohmmeter Procedure:
Results:
Ground Circuit Test
Reason:
Equipment:
Ohmmeter Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Battery - Charge
Reason:
Equipment:
Procedure:
Battery - Load Test
Reason:
Equipment:
Results:
Reason:
Equipment:
Procedure:
Results:
Inspection:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Fuse Test
Reason:
Equipment:
Procedure:
Results:
Glow Plug Test
Reason:
Equipment:
Procedure:
Results:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Reason:
Equipment:
Procedure:
Results:
Results:
Relay Test
Results:
Equipment:
Procedure:
Results:
Results:
Key Switch Test
Reason:
Equipment:
Procedure:
Results:
Light Switch Test
Reason:
Equipment:
Procedure:
Results:
Sensing Switch Test
Reason:
Equipment:
Procedure:
Reason:
Equipment:
Procedure:
Results:
Hazard Switch Test
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Seat Switch Test
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Test Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Test Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Horn Switch Test
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Reason:
Equipment:
Procedure:
Diagnostic Mode 1:
Reason:
Test Conditions:
Procedure:
Reason:
Test Conditions:
Procedure:
Test Kit
Function:
Equipment:
Theory:
Purpose:
Purpose:
Purpose:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Disassembly:
Assembly:
Removal:
Installation:
Tools
Other Materials
Main Machine
Main Machine
Load Center
Display Panel
Connectors:
Wiring Harnesses:
Connectors:
Wiring Harnesses:
Connectors:
Wiring Harnesses:
Purpose:
Operation:
Purpose:
Operation:
Function:
Unswitched Power:
Switched Power:
Function:
Unswitched Power:
Switched Power:
Test Procedure A:
Test Procedure B:
Test Procedure C:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Procedure A:
Test Procedure B:
Function:
Function:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Function:
Test Procedure A:
Test Procedure B:
Test Procedure C:
Function:
Test Conditions:
Test Procedure A:
Test Procedure B:
Function:
Inputs:
Outputs:
Ground:
Function:
Test Conditions:
Function:
General Theory:
Max Speed:
Load Match Switch:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Conditions:
Other Materials
Clutch Housing
Clutch Housing
PowrReverser Clutch
Main Shaft
Driven Shaft
Main Gear Shift
PRT Valve
Function:
Function:
Function:
Function:
Reason:
Procedure:
Reason:
Procedure:
Reason:
Results:
Results:
Split the Machine:
Split the Machine:
Procedure:
Split the Machine:
Procedure:
Removal:
Installation:
Removal:
Disassembly:
Installation:
Other Materials
Drive Shaft
Front Drive
Function:
Charge Pump
Hydrostatic Pump
Hydrostatic Motor
Function:
Charge Pump
Hydrostatic Pump
Hydrostatic Motor
Function:
Reason:
Equipment:
Procedure:
Specifications:
Results:
Reason:
Equipment:
Procedure:
Specifications:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Procedure:
Removal:
Installation:
Removal:
Installation:
Disassembly:
Assembly:
Split the Machine:
Split the Machine:
Removal:
Installation:
Disassembly:
Transaxle Oil:
Capacity:
MFWD Oil:
Transaxle Oil:
Capacity:
MFWD Oil:
Transaxle Oil:
Capacity:
MFWD Oil:
Steering Angle:
Front Axle MFWD:
Other Materials
Range Shift
Differential Gear
Differential Lock
Brake
Rear PTO Shafts
Mid PTO Assembly
2-Speed Rear PTO
MFWD Final Drive
Range Transmission
Operation:
MFWD Drive:
Range Transmission
Operation:
MFWD Drive:
Operation:
Function:
MFWD Power Flow
Reason:
Procedure:
Reason:
Procedure:
Reason:
Procedure:
To Adjust Backlash:
MFWD Output Shaft
Removal:
Disassembly:
Installation:
MFWD Output Shaft
Removal:
Disassembly:
Installation:
Removal:
Disassembly:
Assembly:
Assembly:
Final Drive Removal
Disassemble:
Planetary Pinions:
Assembly:
Removal:
Installation:
Removal:
Disassembly:
Assembly:
Removal:
Installation:
Installation:
MFWD Spindle Shaft
Disassembly:
Assembly:
Spindle Housing
MFWD Differential
Specification:
Tools Required:
Procedure:
Results:
Function:
Theory:
Function:
Theory:
Function:
Theory:
Function:
Theory:
Function:
Theory:
Removal:
Installation:
Disassembly:
Assembly:
Removal:
Installation:
Disassembly:
Assembly:
Removal:
Installation:
Disassembly:
Assembly:
Installation:
Disassembly:
Assembly:
Mid PTO
Removal:
Installation:
Assembly:
Hydraulic Oil:
Hydraulic Oil:
Hydraulic Oil:
Lift Arms:
SCV:
Rockshaft:
Other Materials
Dual SCV Components
Function:
Function:
Function:
Theory:
Operation:
Function:
Theory:
Operation:
Function:
Theory:
Diagnostic Table
Diagnostic Table
Reason:
Procedure:
Reason:
Procedure:
Reason:
Equipment:
Procedure:
Machines with SCVS:
Reason:
Procedure:
Machines with SCV:
Reason:
Equipment:
Procedure:
Reason:
Equipment:
Procedure:
Specifications:
Results:
Reason:
Equipment:
Procedure:
Specifications
Results:
Reason:
Equipment:
Procedure:
Specifications:
Results:
Reason:
Equipment:
Procedure:
Specifications
Results:
Reason:
Procedure:
Hydraulic Gear Pump
Assembly:
Hydraulic Gear Pump
Assembly:
Removal:
Installation:
Lift Arms
Removal:
Specifications:
Installation:
Specifications:
Lift Control Lever
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Rockshaft Piston
Removal:
Installation:
PTO Clutch Valve
Removal:
Installation:
Inspection:
Assembly:
Removal:
Installation:
SCV Disassembly:
Load Check Valves:
Installation:
Relief Valve:
Steering
Steering
Steering
All Models:
All Models:
eHydro Model:
PowrReverser Model:
Steering Operation
Steering Operation
Diagnosis Table
Reason:
Tools:
Procedure:
Results:
Procedure:
Results:
Reason:
Tools:
Procedure:
Results:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Steering Cylinder
Removal:
Installation:
Steering Cylinder
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Brakes
Brakes
Brakes
Transaxle Oil
Brake Housing
Brake Housing
Park Brake
Brakes
Brakes
Brakes
Brakes
Diagnosis
Reason:
Tools:
Procedure:
Results:
Reason:
Tools:
Procedure:
Results:
Brake Assembly
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Installation:
Installation:
Installation:
Installation:
Installation:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
- JOHN DEERE CODE DTC LIST
