John Deere 410B 410C 415B 510B 510C Backhoe Loaders Repair Technical Manual TM1469
- Download this document, you need 350 Gallons
Brand: John Deere
Type of Machine: Backhoe Loaders
Model: John Deere 410B 410C 415B 510B 510C Backhoe Loaders
Part Number: TM1469
Number of Pages: 1056 Pages
SECTION I—GENERAL INFORMATION
Group I—Introduction and Safety Information
Group Il—General Specifications
Group III—Torque Values
Group lV—Lubrication
Group V—Inspection Procedures
SECTION 01—WHEELS
Group 0110—Powered Wheels and Fastenings
Group 0120—Non—Powered Wheels and Fastenings
SECTION 02—AXLES AND SUSPENSION SYSTEMS
Group 0230—Non-Powered Wheel Axles
Group 0250—Axle Shafts, Bearings and Reduction Gears
SECTION 03—TRANSMISSION
Group 0300—Removal and Installation
Group 0315—Controls
Group 0325—Input Drive Shafts and U-Joints
Group O350—Gears, Shafts, Housings, Bearings, Differential Lock, Brake and Park Brake Group 0360—Hydraulic System, Control Valve, Suction Screen, Oil Pump, and Lubrication System
SECTION 04—ENGINE
Group 0400—Removal and Installation
Group 0413—Fuel Injection System
Group 0414—Intake Manifold
Group OMS—Turbocharger
Group 0417—Water Pump
Group 0418——Thermostats, Housing and Water Piping
Group O419—Oil Cooler
Group 0420—Fuel Filter
Group O421—Fuel Transfer Pump
Group 0422—Starting Motor and Fastenings
SECTION 05—ENGINE AUXILIARY SYSTEMS
Group 0505—Cold Weather Starting Aids
Group 0510—Cooling Systems
Group 0515—Speed Controls
Group 0520—Intake System
Group 0560—External Fuel Supply Systems
SECTION 09—STEERING SYSTEM
Group 0960—Hydraulic System Steering Valve and Cylinder
SECTION 10—SERVICE BRAKES
Group 1011—Active Elements, Brake Disks and Control Linkage
Group 1060—Hydraulic System Brake Valve
SECTION 11—PARK BRAKES
Group 1111—Active Elements
Group 1115—Controls Linkage
SECTION 16—ELECTRICAL SYSTEMS
Group 1671—Batteries, Support and Cables
Group 1672—Alternator, Regulator and Charging System Wiring
Group 1673—Lighting System
Group 1674—Wiring Harness and Switches
Group 1675—System Controls
Group 1676—Instruments, Indicators and Senders
Group 1677—Motors and Actuators
SECTION 17—FRAME, CHASSIS, OR
SUPPORTING STRUCTURE
Group 1740—Frame Installation
Group I749—Chassis Weights
SECTION 18—0PERATOR'S STATION
Group 1800—Removal and Installation
Group 1810—Operator Enclosure Wiper Motor and Windshield Washer
Group 1821-Seat and Seat Belt
Group 1830—Heating and Air Conditioning
SECTION 20—SAFETY, CONVENIENCE AND MISCELLANEOUS
Group 2004—Horn and Warning Devices
SECTION 21-MAIN HYDRAULIC SYSTEM
Group 2160—Hydraulic System Main Hydraulic Pump, Pump Drive, Main Hydraulic Filter, Oil Cooler, Oil Cooler Bypass Valve, and System Relief Valve
SECTION 31—LOADER
Group 3100—Removal and Installation
Group 3102—Buckets
Group 3115—Controls Linkage
Group 3140—Frames
Group 3160—Hydraulic System Control Valve and Cylinders
SECTION 33—BACKHOE
Group 3302—Buckets
Group 3315—Controls Linkage
Group 3340—Frames
Group 3360—Hydraulic System Control Valve and Cylinders
Brand: John Deere
Part Number: TM1469
SECTION 01—WHEELS
Group 0315—Controls
SECTION 04—ENGINE
SECTION 31—LOADER
Group 3102—Buckets
Group 3140—Frames
SECTION 33—BACKHOE
Group 3302—Buckets
Group 3340—Frames
