John Deere 4055 4255 4455 Tractors Operators Manual OMAR110015
- Download this document, you need 300 Gallons
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 4055 4255 4455 Tractors
Serial Number: 003397-, 003934-, 006676-
Part Number: OMAR110015
Number of Pages: 296 Pages
Safety
Safety Signs
Controls and Instruments
Control Location
Instrument Identification
Indicators Description
Tachometer
Performance Monitor
Radar Sensor
Lighting and Signals
Switch
Lamps
Electrical Outlets
Operator’s Station
SOUND-GARD® Body Temperature
Controls
Window Wipers and Washers
Windows
Radio
Steering Wheel
Engine Break-in
Prestarting Checks
Operating the Engine
Start-up Procedure
Cold Weather Starting
Starting Aids
Warm-Up and Operation
Stopping the Engine
Operating the Tractor
Brakes
Differential Lock
Power Shift Transmission
Page
QUAD-RANGE™ Transmission
Mechanical Front-Wheel Drive (MFWD)
Rockshaft and 3-Point Hitch
Component Identification
Rockshaft Control Lever
Rockshaft Selector Lever
Rate-of-Drop
Sway Blocks
Hitch
Connecting Implement
Hi-Crop Hitch
Remote Hydraulic Cylinders
Hose Tips
Identifying SCV
Connecting Cylinder Hoses
Operating SCV
Setting Remote Cylinder Stroke
Disconnecting Cylinder Hoses
Adjusting SCV Linkage
Drawbar and PTO
Drawbar Adjustments
Power Take-Off (PTO)
Ballast
Importance of Ballast
Measuring Wheel Slip
Rear Ballast
Front Ballast
Installing QUICK-TATCH™ Weights
Wheels, Tires and Treads
Wheel Tightening
Front Wheel Spacing
Toe-in
Toe-in (MFWD)
Rear Wheel Spacing
Tire Pressures
MFWD Wheel Spacing
Front Fender Adjustment
Transporting
Driving
Carrier
Towing
Fuels, Lubricants and Coolants
Fuel
Engine Oil
Engine Coolant
Transmission-Hydraulic Oil
Lubricants
Lubrication and Maintenance
First 100 Hours
Lubrication and Maintenance/10 Hour
Lubrication and Maintenance/250 Hour
Lubrication and Maintenance/750 Hour
Lubrication and Maintenance/1500 Hour
Lubrication and Maintenance/Annual
Lubrication and Maintenance/2 Year
Lubrication and Maintenance/As
Required
Troubleshooting
Brakes
Rockshaft 3-Point Hitch
Electrical
SOUND-GARD Body
Service
Access
Air Cleaner
Belts
Fuel System
Page
Electrical
Fuses
Lighting
Brakes
Tires
Heating and Air Conditioner
ROPS
Storage
Placing Tractor in Long-Term Storage
Short-Term Idle Periods
Removing Tractor From Storage
Crime Prevention Tips
Specifications
General
Ground Speeds
Identification Numbers
Daily Maintenance
Lubrication and Maintenance Records
Index
Brand: John Deere
Safety
Safety Signs
Control Location
Tachometer
Performance Monitor
Radar Sensor
Switch
Lamps
Electrical Outlets
Operator’s Station
Controls
Windows
Radio
Steering Wheel
Engine Break-in
Prestarting Checks
Start-up Procedure
Starting Aids
Stopping the Engine
Brakes
Differential Lock
Page
Rate-of-Drop
Sway Blocks
Hitch
Hi-Crop Hitch
Hose Tips
Identifying SCV
Operating SCV
Drawbar and PTO
Drawbar Adjustments
Ballast
Rear Ballast
Front Ballast
Wheel Tightening
Front Wheel Spacing
Toe-in
Toe-in (MFWD)
Rear Wheel Spacing
Tire Pressures
MFWD Wheel Spacing
Transporting
Driving
Carrier
Towing
Fuel
Engine Oil
Engine Coolant
Lubricants
First 100 Hours
Required
Troubleshooting
Brakes
Electrical
SOUND-GARD Body
Service
Access
Air Cleaner
Belts
Fuel System
Page
Electrical
Fuses
Lighting
Brakes
Tires
ROPS
Storage
Specifications
General
Ground Speeds
Daily Maintenance
Index
- JOHN DEERE CODE DTC LIST
