Martin Welker
104
230,310
John Deere 4055 4255 4455 4755 4955 Tractor Operation Manual OMAR110280
Brand: John Deere
Model: John Deere 4055(P.I.N. 003397- ) 4055(P.I.N. 003934- )
4455(P.I.N. 006676- ) 4755(P.I.N. 003767- ) and 4955(P.I.N. 004650- ) Tractor
Part Number: OMAR110280
Number of Pages: 276 Pages
Identification View
Safety
Safety Signs
Controls and Instruments
Controls
SOUND-GARD Body
Tractor
Shift Console
Instrument Identification
Signals Description
Indicators Description
Tachometer Functions
Performance Monitor Functions
Lighting and Signals
Switch
Lamps
Electrical Outlets
Operator’s Station
SOUND-GARD Body Temperature
Controls
Window Wipers and Washer
Rear Window
Steering Wheel
Engine Break-in
Prestarting Checks
Operating the Engine
Start-up Procedure
Cold Weather Starting
Starting Aids
Warm-up and Operation
Stopping the Engine
Page
Operating the Tractor
Emergency Steering
Brakes
Secondary Brake
Differential Lock
Transmission Operation
Mechanical Front-Wheel Drive (MFWD)
Rockshaft and Three-Point Hitch
Component Identification
Rockshaft Controls
4055, 4255 and 4455 Tractors
4755 and 4955 Tractors
Rockshaft Troubleshooting—4755 and
4955 Tractors
Sway Blocks
Hitch Conversion—4055, 4255 and 4455
Tractors
Attaching Implement—4055, 4255 and
4455 Tractors
Adjusting Implement—4055, 4255 and
4455 Tractors
Removing Implement—4055, 4255 and
4455 Tractors
Implement Hitch—Hook Type Draft Links
Attaching—4755 and 4955 Tractors
Removing—4755 and 4955 Tractors
Attaching Implement to Quick
Coupler—4755 and 4955 Tractors
Adjusting Level with Quick Coupler—4755
and 4955 Tractors
Adjusting Level with Walterscheid
Hitch—4755 and 4955 Tractors
Removing Implement—4755 and 4955
Tractors
Trailer Hitch
Remote Hydraulic Cylinders
Hose Tips
Identifying SCV
Connecting Cylinder Hoses
Operating SCV
Lever Locks and Lockouts
Remote Cylinder Adjustments
Disconnecting Cylinder Hoses
Adjusting SCV Linkage
Drawbar and PTO
Drawbar Loads
Drawbar Adjustments
Clevis Assembly
Power Take-Off (PTO) Master Shield
PTO Stub Shaft—4055, 4255 and 4455
Tractors
PTO Adapter
Attaching PTO Driven Implement
Operating PTO
Ballast
Importance of Ballast
Measuring Wheel Slip
Rear Ballast
Front Ballast
Installing QUIK-TATCH Weights
Wheels, Tires and Treads
Wheel Tightening
Axle Cover
Rear Wheel Tread Settings
Adjusting Rear Wheels
Reversing Wheels
Inflation Pressures
MFWD Toe-In
MFWD Wheel Spacing
MFWD Steering Stops
Front Fender Adjustment
Tire Combinations
Transporting
Driving
Hauling
Towing
Fuels, Lubricants and Coolant
Fuel
Engine Oil
Engine Coolant
Transmission-Hydraulic Oil
Lubricants
Page
Lubrication and Maintenance
Break-In Service
Service Intervals Chart
Lubrication and Maintenance/10 Hour
Lubrication and Maintenance/250 Hour
Lubrication and Maintenance/750 Hour
Lubrication and Maintenance/1500 Hour
Lubrication and Maintenance/Annual
Lubrication and Maintenance/2 Year
Lubrication and Maintenance/As
Required
Troubleshooting
Hydraulic
Brakes
Rockshaft 3-Point Hitch
Electrical
SOUND-GARD Body
Service
Access
Air Cleaner
Belts
Fuel System
Electrical
Fuses
Lighting
Brakes
Tires
Heating and Air Conditioning
Roll-Over Protective Structure (ROPS)
Storage
Specifications
General
Ground Speed Charts
Torque Chart
Identification Numbers
Serial Number Plates
Daily Maintenance
Lubrication and Maintenance Records
Index
