Martin Welker
104
230,310
John Deere 4050 4250 4450 4650 4850 Tractor Technical Manual TM1259
Brand: John Deere
Type of Manual: Technical Manual
Model: John Deere 4050 4250 4450 4650 4850 Tractor
Part Number: TM1259
Number of Pages: 1086 Pages
SECTION 210—GENERAL
Introduction and Safety Information
SECTION 220—ENGINE OPERATION AND TESTS
Group 05—System Operation
Group 10—System Tests and Diagnosis
SECTION 230—FUEL/AIR OPERATION AND TESTS
Group 05—Air Intake System _
Group 10—Diesel Fuel System
Group 15—Control Linkage
SECTION 240—ELECTRICAL SYSTEM
Group 05—Electrical System Information
Group 06—Phase I Electrical Wiring Diagrams
Group 07—Phase II Electrical Wiring Diagrams
Group 10—Electrical System Diagnosis
Group 15—Delcotron Charging Circuit
Group 16—John Deere Charging Circuit
Group 220—Starting Circuit
Group 25—Lighting Circuit
Group 30—INVESTIGATORTM II and Digital Tachometer
Group 31—Gauge Cluster Instrumentation
Group 32—Analog Tachometer
Group 35—Accessories Circuit
Group 40—PERFORMANCE TRAKTM I Radar Sensor System (Tachometer Version)
Group 41—PERFORMANCE TRAKTM II Radar Sensor System (Mini-Monitor)
Group 42—PERFORMANCE TRAKTM III Radar Sensor System (Multi-Function Monitor)
SECTION 250—POWER TRAIN (PERMA-CLUTCH TRANSMISSION)
Group 05—QUAD-RANGETM System Operation
Group 10—PERMA-CLUTCHTM Operation
Group 15—QUAD-RANGETM Planetary
Group 20-QUAD-RANGETM Eight-Speed
Group 25—Transmission Oil Pump
Group 30—Transmission Lubrication Valve
Group 35—Transmission Control Valves
Group 40—Differential and Final Drive
Group 45—SYNCRO-RANGETM Transmission
Group 55—PTO
Group 60—QUAD RANGETM Transmissions Diagnosis
SECTION 255—POWER SHIFT TRANSMISSION
Group 05—Mechanical Operation
Group 10—Hydraulic Controls
Group 15—PTO, Differential and Final Drives
Group 16—Power Shift Transmission Diagnosis
Group 20—Mechanical Front Wheel Drive
SECTION 260—STEERING/BRAKES OPERATION AND TESTS
Group 05—4050, 4250, and 4450 Power Steering
Group 06—4650 and 4850 Power Steering
Group 10—Power Brakes
SECTION 270—HYDRAULIC OPERATION AND TESTS
Group 05-PERMA-CLUTCHTM Transmission Operation
Group 10—Power Shift Transmission Hydraulic System Operation and Tests
Group 15—Main Hydraulic Pump
Group 20—QUAD-RANGETM Transmission Hydraulic Valves
Group 25—Power Shift Transmission Hydraulic Valves
Group 30—Pressure Control Valve
Group 35—HYDRACUSHIONEDTM Seat
Group 40—Rockshaft Operation (4050, 4250, 4450)
Group 45—Rockshaft Operation (4650 and 4850)
Group 50—Selective Control Valve
Group 55—Remote Cylinder
Group 60—OUAD-RANGE Hydraulic Diagnosis
Group 65—Power Shift Transmission Hydraulic Diagnosis
SECTION 290—0PERATOR STATION OPERATIONS AND TESTS
Group 05—Air Conditioning System
Group 10—Air Conditioning System Tests Introduction
Group 11—System Tests Without Timer Relay Warning Lamps
Group 12—System Tests With Timer Relay Warning Lamps
Group 15—Heating System Operation Tests
Group 20—HYDRACUSHIONEDTM Seat
SECTION 299—SPECIAL TOOLS
Group 05—Purchased Tools
Group 10—Fabricated Tools
Group 15—Test Equipment Calibration
