Martin Welker
104
230,792
John Deere 4040 4240 Series Tractor Technical Manual TM1181
Brand: John Deere
Type of Manual: Technical Manual
Model: John Deere 4040 4240 Series Tractor
Part Number: TM1181
Number of Pages: 1108 Pages
SECTION lO—GENERAL
Group 00—Specifications and Special Tools
Group 05—Predelivery, Delivery, and After Sale Services
Group 10—Tune Up
Group 15—Lubrication
Group 20—Separation
SECTION 20—ENGINE REPAIR
GrOUp 00—Specifications and Special Tools
Group OS—Cylinder Head, Valves, and Camshaft
Group 10—Cylinder Block, Liners, Pistons, and Rods
Group 15—Crankshaft, Main Bearings, and Flywheel
Group 20—Lubricating System
Group 25—Cooling System
SECTION 30—FUEL AND AIR REPAIR
Group 05—Air Intake System
Group 1 O—Diesel Fuel System
Group 15—Control Linkage
SECTION 40—ELECTRICAL REPAIR
Group 05—Harness Replacement
Group 10—Charging Circuit
Group 15—Starting Circuit
Group 20—Lighting Circuits
Group 25—Instrument and Accessory Circuits
Group 30—Power Front-Wheel Drive
SECTION 50—POWER TRAIN REPAIR
Group 05—Perma-Clutch®
Group 10—Syncro Range Transmission (Also BQSpeed Portion of Quad-Range and Creeper)
SECTION 50—POWER TRAIN REPAIR (Continued)
Group 15—Creeper Planetary
Group 20—Quad-Range Planetary and Shifter Assembly
Group 25—Power Shift Transmission
Group 30—Dual—Speed PTO
Group 35—Differential
Group 40—Final Drive
Group 45—Power Front-Wheel Drive
SECTION 60—STEERING/BRAKES REPAIR
Group 05—Power Steering
Group 10—Power Brakes
SECTION 70—HYDRAULIC REPAIR
Group 05—Miscellaneous Hydraulic Components
Group 10—Hydraulic Pumps
Group 15—Rockshaft and Implement Hitches
Group 20—Selective Control Valve and Remote Cylinder
SECTION 80—MISCELLANEOUS
Group 05—Front Axles
Group 10 Wheels
SECTION 90 STATION REPAIR
Group 05—Air Conditioning System
Group 10—Heating System
Group 15—Seat
Group 20—Miscellaneous Components (Continued on page 2)
SECTION 220-ENGINE OPERATION AND TESTS
Group 00-Specifications and Special Tools
Group 05—System Operation
Group 10—System Tests and Diagnosis
SECTION 230—FUELIAIR OPERATION AND TESTS
GrOUp 10—Diesel Fuel System
Group 15-—Control Linkage
SECTION 240—ELECTRICAL OPERATION AND TESTS
Group 05—General Information and Diagrams
Group 35—Electrical Remote Control and Outlet Socket
SECTION 250—POWER TRAIN OPERATION AND TESTS
Group 05-Perma-Clutch Systems Operation
Group 10—Perma-Clutch Systems Tests
Group IS—Power Shilt Transmission Operation
Group 20—Power Shift Transmission Tests
Group 25—Diferential and Final Drive
SECTION 260-STEERING/BRAKES OPERATION AND TESTS
SECTION 270—HYDRAULIC OPERATION AND TESTS
Group 05—Hydraulic System Operation
Group 10—Hydraulic System Tests
Group 15—Miscellaneous Hydraulic Components
Group 20—Hydraulic Pumps
Group 25—Rockshaft and Implement Hitches
Group 30—Selective Control Valve and Remote Cylinder
SECTION 290—OPERATOR STATION OPERATION AND TESTS
GrOUp 05—Air Conditioning System
