Martin Welker
104
230,310
John Deere 400G Crawler Bulldozer Repair Technical Manual TM1412
Download this document, you need 350 Gallons
Brand: John Deere
Type of Machine: Crawler Bulldozer
Model: John Deere 400G Crawler Bulldozer
Part Number: TM1412
Number of Pages: 386 Pages
SECTION I—GENERAL INFORMATION
Group I—Introduction and Safety Information
Group II—General Specifications
Group III—Torque Values
Group IV—Fuels and Lubrication
Group V—Inspection Procedures
SECTION 01—TRACKS
Group 0130—Track Systems Track Chain, Track Frame, Carrier Roller, Front Idler, Track Roller and Track Adjuster
SECTION 02—AXLES AND SUSPENSION SYSTEMS
Group 0250—Axle Shaft, Bearings, and Reduction Gears Final Drive, Steering Brakes, Steering Clutch, Linkage, and Adjustments
SECTION 03—TRANSMISSION
Group 0315—Controls
Group OSSO—Gears, Shafts, Bearings and Power Shift Clutches Transmission, Clutch Oil Pump, H—L—R Clutches, Valves, Oil Filter, Winch Drive, Drive Shaft, Ring Gear, Linkages and Adjustments
Group 0360—Hydraulic System Transmission Oil Filter and Transmission Oil Cooler
SECTION 04—ENGINE
Group 0400—Removal and Installation Engine, Oil Pan, Fuel Injection Pump, Injection Nozzles, Thermo, stats, Fuel Transfer Pump and Water Pump
SECTION 05—ENGINE AUXILIARY SYSTEMS
Group 0505—COId Weather Starting Aid Starting Aid (Solenoid and Nozzles)
Group 0510—Cooling System Fan Belt, BIoWer Fan, Radiator, Oil Cooler, Pump and Radiator Support
Group 0515—Speed Controls
Group 0560—External Fuel Supply Systems Fuel Tank
SECTION 07—CLUTCH
Group 0715 Controls Clutch Pedal Linkage and Adjustment
Group 0752—Elements Engine Clutch Assembly and Clutch Housing
SECTION 09—STEERING SYSTEM
Group 0960—Hydraulic System Steering Valve Spools
SECTION 15—EQUIPMENT ATTACHING
Group 1511—Fairlead
SECTION 16—ELECTRICAL SYSTEM
Group 1671—Batteries, Support, and Cables
Group 1672—Alternator, Regulator, and Charging System Wiring
Group 1673—Lighting System
Group 1674—Wiring Harness and Switches
Group 1676—Instruments and Indicators Logic Module, Relay, Circuit Breakers, and Switches
Group 1677——.Motors and Actuators Starting Motor
SECTION 17—FRAME, CHASSIS, OR SUPPORTING STRUCTURE
Group 1740—Frames Side Frames
SECTION 18—OPERATOR'S STATION
Group 1810—Operator Enclosure Roll—Over Protective Structure (ROPS)
Group 1821-Scat and Seat Belt
SECTION 19—SHEET METAL AND STYLING
Group 1910—Hood or Engine Enclosure Grille Housing and Cowl
SECTION 30—WINCH
Group 3015—Controls Linkage
Group 3050—Winch Drive and Clutches
Group 3060—Winch Hydraulic System
SECTION 32—BULLDOZER
Group 3201—Blade
Group 3215-Contro| Linkage
Group 3240—Framres
Group 3260—Hydraulic System
Hydraulic Oil Filter, Reservoir, Hydraulic Pump, Pump Drive, Dozer Valve, Relief Valves and Cylinders
SECTION 40—PTO OR WINCH DRIVE
Group 4051—Gears, Shafts and Bearings Powershaft and Winch Drive
SECTION 42—GROUND CONDITIONING TOOLS
Group 4201—Teeth and Shanks
Group 4240—Frame
Group 4260—Hydraulic System Ripper Cylinder
SECTION 99—DEALER FABRICATED TOOLS
