Martin Welker
104
230,310
John Deere 4000 Series Compact Utility Tractor Attachments Technical Manual TM1763
Brand: John Deere
Type of Machine: Compact Utility Tractor
Type of Manual: Attachments Technical Manual
Model: John Deere 4000 Series Compact Utility Tractor
47 and 48 Backhoes;
54, 60 and 72-Inch Mid Mount Rotary Mowers;
450, 550, 660, 670 and 680 Hydraulic Tillers;
31B Post Hole Digger;
74 and 84 Front Blades;
26 and 51-Inch Brooms;
47 and 59 Snowblowers;
261 and 271 Rear-Mounted Rotary Mowers
Part Number: TM1763
Number of Pages: 150 Pages
Safety
Specifications And Information
Backhoe Specifications
Mowers
Rotary Tiller Specifications
Post Hole Digger Specifications
Front Blade Specifications
Rotary Broom Specifications
Snowblower Specifications
Attachment Use
O-Ring Seal Service Recommendations
Face Seal Fittings With Inch Stud Ends Torque
Face Seal Fittings With Metric Stud Ends Torque
O-Ring Face Seal Fittings
O-Ring Boss Fittings
Inch Fastener Torque Values
Metric Fastener Torque Values
Lubricants
Hydrostatic Transmission & Hydraulic Oil
Alternative Lubricants
Lubricant Storage
Chassis Grease—North America
Chassis Grease—Europe
Backhoes
Specifications
Torque Specifications
Special Or Essential Tools
Other Materials
Backhoe Component Location
47 Boom
48 Boom
Theory Of Operation
Control Valves
Load Check Valves
Main System Relief Valve
Circuit Relief And Anti- Cavitation Check Valves
Restrictors
Backhoe Hydraulic System
Troubleshooting
Diagnostics
Tests And Adjustments
Circuit Relief Valve Tests
Main System Relief Valve Test
Restrictor Inspection
Rockshaft Height Adjustment (4200/4300/750)
Rockshaft Height Adjustment (4300/4600)
Repair
System Relief Valve Inspection
Spool Removal
Spool Assembly
Load Check Valves Inspection
Dipperstick Circuit Relief Valve Inspection
Anti-Cavitation Valve Inspection
Boom Circuit Relief Valve Inspection
Assemble Valve Housing
Valve Linkage Inspection
Valve Housing Installation
Cylinder Removal And Installation
Cylinder Repair
Boom And Dipperstick Cylinders Disassembly And Repair — 47 Backhoe
Bucket Cylinders Disassembly And Repair — 47 Backhoe
Stabilizer Cylinder Disassembly And Repair—47 Backhoe
Swing Cylinder Disassembly And Repair—47 Backhoe
Bucket, Boom, And Dipperstick Cylinders Disassembly And Repair—48 Backhoe
Stabilizer Cylinders Disassembly And Repair—48 Backhoe
Swing Cylinders Disassembly And Repair—48 Backhoe
Rotary Mowers
Specifications
Gear Case
Mid Mount Mowers
Model 261 And 272 Mowers
Spindles, Drive Belts And Powershafts
Spindles
Spindles Typical Cross-Section View
Drive Belts
Servicing Drive Belt 60 And 72 Inch Mowers
Powershafts
Rotary Tillers
Specifications
Lubricants
Other Materials
450 Side Drive Chain Adjustment
550, 660, 670 & 680 Side Drive Chain Adjustment
550, 660, 670 & 680 Pto Clutch Adjustment
Repair
450 Gear Case Removal And Installation
450 Pto Clutch
550 Gear Case Removal And Installation
660, 670 & 680 Gear Case Removal And Installation
Rotor Bearing Replacement
Post Hole Digger
Specifications
Model 31b Post Hole Digger
Other Materials
Repair
Gear Case Inspection
Gear Box Removal And Installation
Gear Box Disassembly
Gear Box Assembly
Blades
Specifications
Other Materials
Repair
74 And 84 Angle Cylinder
74 And 84 Lift Cylinder
Rotary Brooms
Specifications
Other Materials
Component Location
Mounting Components – 26 Broom
Brush Assembly – 26 Broom
Brush Assembly – 51 Broom
Gear Box – 51 Broom
26 Drive Chain Adjustment
Repair
26 Gear Box Removal And Installation
26 Gear Box Disassembly And Assembly
Brush Bearing Replacement
26 Pto Mounting Bracket Disassembly And Assembly
Snowblowers
Specifications
Lubricants
Other Materials
Component Location
47 Chute Control
59 Chute Control
Repair
47 Gear Case
59 Gear Case
59 Gear Assembly:
59 Main Gear Case Inspection
Rotor And Fan Removal And Installation
Fan Or Coupler Replacement
Rotor Assembly Installation
Miscellaneous
Hoses & Fittings
Selecting Hoses
Hose Failures
Hose Routing
Hose Installation
Index
