Martin Welker
104
230,792
John Deere 362 Series Power Units Parts Catalog PC1135
Download this document, you need 250 Gallons
Brand: John Deere
Type of Machine: Power Units
Model: John Deere 362 Series Power Units
Part Number: PC1135
Number of Pages: 80 Pages
ALPHABETICAL INDEX
A
Adapter, Air Restriction Indicator (Serial No. - 244429)
Adapter, Air Restriction Indicator (362GH - 01, 362GH - 02)
Air Cleaner (Serial No. - 244429)
Air Cleaner
Air Cleaner Element Cleaning Gun
Air Duct Deflector
Air Duct Screen
Air Duct, Radiator
Air Intake Pipe (Serial No. - 244429)
Air Intake Pipe (362GH - 01, 362GH - 02) (Pre - Cleaner to Air Cleaner)
Air Intake Pipe (362GH - 01) (Pre - Cleaner to Air Cleaner)
Air Intake Pipe (362GH - 01, 362GH - 02) (Air Cleaner to Carburetor)
Air Pre - Cleaner (362GH - 01, 362GH - 02)
Air Pre - Cleaner (Serial No. - 244429)
Air Restriction Indicator Adapter (Serial No. - 244429)
Air Restriction Indicator Adapter (362GH - 01, 362GH - 02)
Alternator (Serial No. - 244429) (12 - Volt, 35 - AMP)
Alternator (Serial No. - 244429) (12 - Volt) (Motorola)
Alternator (Serial No. 244430 - )
Arm, Rocker
B
Battery, Cables (Serial No. - 244429)
Battery, Cables (Serial No. 244430 - )
Battery, Clamps (Serial No. - 244429)
Battery, Clamps (Serial No. 244430 - )
Battery, Ground Strap (Serial No. - 244429)
Battery, Ground Strap (Serial No. 244430 - )
Battery, Tray (Serial No. - 244429)
Battery, Tray (Serial No. 244430 - )
Bearing, Main
Bearing, Main Thrust
Bearings, Connecting Rod
Belt, Fan and Alternator Drive
Block, Cylinder (Serial No. - 244429)
Block, Cylinder (Serial No. 244430 - )
Boot, Spark Plug
Bushing, Piston Pin
C
Cable, Battery (Serial No. - 244429)
Cable, Battery (Serial No. 244430 - )
Cables, Spark Plug
Cam Followers
Camshaft
Camshaft Gear
Cap, Radiator (Serial No. - 244429)
Cap, Radiator (Serial No. 244430 - )
Carburetor (Serial No. - 244429) (Lower)
Carburetor (Serial No. - 244429) (Upper)
Carburetor (Serial No. 244430 - ) (Lower)
Carburetor (Serial No. 244430 - ) (Upper)
Carburetor Heater
Clamp, Battery (Serial No. - 244429)
Clamp, Battery (Serial No. 244430 - )
Cool, Ignition
Connecting Rod
Connecting Rod Bearings
Cooler, Oil
Cover, Rocker Arm (Serial No. - 244429)
Cover, Rocker Arm (Serial No. 244430 - )
Cover, Timing Gear
Crankshaft (Serial No. - 244429)
Crankshaft (Serial No. 244430 - )
Crankshaft Pulley (Serial No. - 244429)
Crankshaft Pulley (Serial No. 244430 - )
Cylinder, Block (Serial No. - 244429)
Cylinder, Block (Serial No. 244430 - )
Cylinder, Liner (Serial No. - 244429)
Cylinder, Liner (Serial No. 244430 - )
Deflector, Air Duct
Distributor
Distributor Parts
E
Engine Oil Pump
Engine Powershaft
Engine Support (Serial No. - 244429)
Engine Support (Serial No. 244430 - )
Exhaust, Manifold (Serial No. 244430 - )
Exhaust, Manifold (Serial No. - 244429)
Exhaust, Valve
Exhaust, Valve Rotators
F
Fan (Serial No. - 244429)
Fan (Serial No. 244430 - )
Fan Belt
Fan Pulley (Serial No. - 244429)
Fan Pulley (Serial No. 244430 - 280000)
Fan Pulley (Serial No. 244430 - )
Filter, Oil (Serial No. 215000 - 244429)
Filter, Oil (Serial No. 244430 - )
Flywheel (Serial No. - 244429)
Flywheel (Serial No. 244430 - )
Flywheel Housing (Serial No. - 244429)
Follower, Cam
Fuel Pipe
G
Gasket Set
Gear, Camshaft
Gear, Crankshaft (Serial No. - 244429)
Gear, Crankshaft (Serial No. 244430 - )
Gear, Oil Pump Drive
Gear, Starter
Governor
Ground Strap, Battery (Serial No. - 244429)
Ground Strap, Battery (Serial No. 244430 - )
Gun, Air Cleaner Element Cleaning
Head, Cylinder
Heater, Carburetor
Hose, Air Intake (Serial No. - 244429)
Hose, Air Intake (362GH - 01) (Pre - Cleaner to Air Cleaner)
Hose, Air Intake (362GH - 01, 362GH - 02) (Pre - Cleaner to Air Cleaner)
Hose, Air Intake (362GH - 01, 362GH - 02) (Air Cleaner to Carburetor)
Hose, Crankcase Drain (Serial No. - 244429)
Hose, Crankcase Drain (Serial No. 244430 - )
Housing, Crankshaft Oil Seal
Housing, Governor
Housing, Oil Pump
Housing, Thermostat
I
ID VIEW
Intake Manifold (Serial No. - 244429)
Intake Manifold (Serial No. 244430 - )
Intake Valves
K
Kit, Carburetor Gasket
Kit, Carburetor Repair
Kit, Off - Season Storage
L
Lever, Governor
Liner, Cylinder (Serial No. - 244429)
Liner, Cylinder (Serial No. 244430 - )
M
Main Bearings
Main Thrust Bearing
Manifold
Manifold, Water Outlet
Manifolds (Serial No. - 244429)
Manifolds (Serial No. 244430 - )
Muffler (6602 Combine)
Muffler (Serial No. - 244429)
Muffler (Serial No. 244430 - )
O
Oil Filter (Serial No. 215000 - 244429)
Oil Filter (Serial No. 244430 - )
Oil Pan (Serial No. - 244429)
Oil Pan (Serial No. 244430 - )
Oil Pressure Sending Unit
Oil Pump
Oil, Torq - Gard
P
Pan, Oil (Serial No. - 244429)
Pan, Oil (Serial No. 244430 - )
Pin, Piston
Pipe, Air Intake (362GH - 01) (Pre - Cleaner to Air Cleaner)
Pipe, Air Intake (362GH - 01, 362GH - 02) (Air Cleaner to Carburetor)
Pipe, Air Intake (362GH - 01, 362GH - 02) (Pre - Cleaner to Air Cleaner)
Pipe, Air Intake (Serial No. - 244429)
Pipe, Air Intake (Serial No. - 244429) (Pre - Cleaner)
Pipe, Carburetor Heater
Pipe, Fuel
Pipe, Water Bypass
Piston, Engine
Piston, Pin Bushings
Piston, Pins
Piston, Rings
Powershaft, Engine
Pre - Cleaner, Air
Pulley, Crankshaft (Serial No. - 244429)
Pulley, Crankshaft (Serial No. 244430 - )
Pulley, Fan (Serial No. - 244429)
Pulley, Fan (Serial No. 244430 - )
Pulley, Fan (Serial No. 280001 - )
Pump, Oil
Pump, Water (Serial No. - 244429)
Pump, Water (Serial No. 244430 - 280000)
Pump, Water (Serial No. 280001 - )
Push Rod
R
Radiator Air Duct
Radiator Screen
Regulator, Alternator (Serial No. - 244429)
Regulator, Alternator (Serial No. 244430 - )
Rings, Piston
Rocker Arm Cover (Serial No. - 244429)
Rocker Arm Cover (Serial No. 244430 - )
Rocker Arms
Rod, Connecting
Rod, Push
Rotators, Exhaust Valve
S
Screen, Air Duct
Seal, Water Pump (Serial No. - 244429)
Seal, Water Pump (Serial No. 244430 - 280000)
Seal, Water Pump (Serial No. 280001 - )
Shaft, Rocker Arm
Solenoid Switch
Solenoid Switch (12 Volt)
Spark Plug Cables
Spark Plugs
Springs, Valve
Starter (Drive End Housing)
Starter (Main Frame)
Storage Kit, Off - Season
Strap, Battery Ground (Serial No. - 244429)
Strap, Battery Ground (Serial No. 244430 - )
Support, Engine (Serial No. - 244429)
Support, Engine (Serial No. 244430 - )
Switch, Solenoid
Switch, Solenoid (12 Volt)
T
Thermostat
Timing Gear Cover
Torq - Gard Oil
Tray, Battery (Serial No. - 244429)
Tray, Battery (Serial No. 244430 - )
V
Valve, Exhaust
Valve, Intake
Valve, Spring
W
Water Outlet Manifold
