John Deere 360 370 390 Flail Mowers Operators Manual OMFH337667
- Download this document, you need 300 Gallons
Brand: John Deere
Type of Machine: Flail Mowers
Model: John Deere Heavy-Duty Flail Mowers
360 (Serial No. 002300- )
370 (Serial No. 002800- )
390 (Serial No. 004600- )
Part Number: OMFH337667
Number of Pages: 56 Pages
Introduction
Foreword
Identification View
A Message to Our Customers
Preliminary Checks
Regions and Country Versions
Machine Overview
Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Practice Safe Maintenance
Keep Riders Off Machine
Prepare for Emergencies
Wear Protective Clothing
Stay Clear of Rotating Drivelines
Use Safety Lights and Devices
Avoid High-Pressure Fluids
Protect Against Noise
Before Servicing the Mower
Safety Signs
Read Safety Signs Carefully
Rotating Driveline Danger Decal
Rotating Knife Danger Decal
Rotating Parts Danger Decal
Caution Decal
Drivelines Decals
Preparing the Tractor
Selecting Tractor Size
Positioning Tractor Drawbar
Adjusting Tractor Hitch
Checking Ballast, Wheel Spacing, and Tire Inflation
Tractor Brakes
Preparing the Machine
Introduction
Prestarting Checklist
Setting Cutting Height
Attaching and Detaching
Quick Coupler Hitch Compatibility Decals
Center Link Mounting Hardware - 360, 370 and 390
Draft Link Mounting Hardware - 370 and 390
Draft Link Mounting Hardware - 360
Attaching Mower to Tractor with Quick Coupler Hitch
Attaching Mower to Tractor with Three-Point Hitch
Assembling Main PTO Driveline Telescoping Members (If Necessary)
Attaching PTO Driveline
Detaching Mower from Tractor
Transporting
Use a Safety Chain
Tow Loads Safely
Observe Maximum Transport Speed
Preparing Mower for Transport
Follow Safe Transport Procedures
Operating the Machine
Break-In the New Mower
Preparing Mower for Operation
Adjusting Cutting Height
Follow Safe Operating Procedures
Operating the Mower for Best Performance
Maintaining Rotor Balance
Smooth-Cut Knives
Rear Rubber Safety Shield
Lubrication and Maintenance
Lubricating and Maintaining Machine Safely
Gear Oil
Grease for General Use
Mixing of Lubricants
Lubricant Storage
Perform Lubrication and Maintenance
Observe Lubrication Symbols
Lubrication Intervals
Checking Gear Case Oil Level
Keeping Mower Clean
Drive Pulley Bearing and Gauge Roller Bearings
Driveline Inner Shaft
Checking Driveline Shield
Troubleshooting
Knife Troubleshooting
General Troubleshooting
Operation Troubleshooting
Service
Practice Safe Service Procedures
Keep Service Area Clean
Inspecting Knives
Inspecting Knife Fasteners
Replacing Knives
Installing Anti-Wrap Bolts
Gear Case Service
Removing and Installing Gear Case
Adjusting Drive Belt
Aligning Pulleys
Belt Installation
Bearing Locking Collars
Storage
Store Attachments Safely
End of Season
Beginning of Season
Assembly
Install PTO Driveline
Install Rear Safety Deflector
Specifications
Specifications
Serial Number
John Deere Service Keeps You On Job
John Deere Is At Your Service
John Deere Parts
The Right Tools
Well-Trained Technicians
Prompt Service
Brand: John Deere
Introduction
Foreword
Identification View
Preliminary Checks
Machine Overview
Safety
Safety Signs
Caution Decal
Drivelines Decals
Tractor Brakes
Introduction
Transporting
Use a Safety Chain
Tow Loads Safely
Smooth-Cut Knives
Gear Oil
Lubricant Storage
Keeping Mower Clean
Troubleshooting
Service
Inspecting Knives
Replacing Knives
Gear Case Service
Aligning Pulleys
Belt Installation
Storage
End of Season
Beginning of Season
Assembly
Specifications
Specifications
Serial Number
John Deere Parts
The Right Tools
Prompt Service
- JOHN DEERE CODE DTC LIST
