Martin Welker
104
230,310
John Deere 360 330 430 530 630 730 Combines Technical Manual TM4222
Brand: John Deere
Type of Machine: Combines
Type of Manual: Technical Manual
Model: John Deere 360 330 430 530 630 730 Combines
Part Number: TM4222
Number of Pages: 544 Pages
SECTION 10 - GENERAL INFORMATION
Group 5 - Specifications
Group 10 - Pre-Delivery, Delivery and After-Sales Inspections
Group 15 - Service and Lubrication
Group 20 - Engine and Combine Tune-Up
Group 25 - Separation
SECTION 20 — ENGINE
Group 5 - General Information, Diagnosing Malfunctions
Group 10 - Cylinder Head and Camshaft
Group 15 - Cylinder Block, Liners, Pistons and Connecting Rods
Group 16 - Installation of 3-Sea1 Cylinder Liners
Group 20 - Crankshaft, Main Bearings and Flywheel
Group 25 - Timing Gear Train
Group 30 - Oil Pump, Pressure Regulating Valve and Oil Filter
Group 35 - Cooling System
Group 40 - Speed Control Linkage
SECTION 30 - FUEL SYSTEM
Group 5 - Diagnosing Malfunctions
Group 10 - Fuel Tank, Transfer Pump, Fuel Filters, Air Cleaner
Group 15 — Roto Diesel Fuel Injection Pump
Group 20 - Roosa Master Model DB Fuel Injection Pump
Group 25 - Roosa Master Model CB Fuel Injection Pump
Group 30 - Roosa Master Injection Nozzles
Group 35 - CAV Injection Nozzles
Group 40 - Cold Weather Starting Aid
SECTION 40 — ELECTRICAL SYSTEM
Group 10 - Individual Parts and Wiring Diagram
Group 11 - Reverser Clutch, Linkage and Control
Group 15 - Bosch Helical-Spline Sliding Gear Starting Motor
Group 20 - Delco Remy Helical-Spline Sliding Gear Starting Motor
Group 25 - Generator
Group 30 - Enclosed-Type Alternator
SECTION 50 — POWER TRAIN
Group 5 - Clutch and Clutch Linkage - Combines 330/430
Group 10 - Clutch and Clutch Linkage - Combines 530/630/730
Group 15 - Front Axle - Combines 330/430 up to Serial No. 303995 and 402960
Group 20 - Front Axle - Combines 330/430, Serial No. 303996 and 402961 - Up
Group 25 - Front Axle - Combines 530/630/730
Group 30 - Track System for Combines 630/730
Group 35 — Separator Drive
Group 40 - Variable Drives
Group 45 - Power Drive Gear - Combine 360
SECTION 60 - REAR AXLE, MANUAL STEERING AND MECHANICAL BRAKES
Group 5 - Foot Brakes - Combines 530/630/730
Group 10 - Foot Brakes ~ Combines 330/430
Group 15 - Manual Steering .
Group 20 - Parking Brake - Combines 530/630/730
Group 25 - Parking Brake - Combines 33 0/430
Group 30 - Rear Axle — Combines 330/430/530/630/730
SECTION 70 — HYDRAULIC SYSTEM
Group 5 - General Information, Pressure Tests, Diagnosing Malfunctions
Group 10 - Hydraulic Oil Reservoir, Filter and Oil Lines
Group 15 - Hydraulic Pumps and Flow Divider
Group 20 - Three-Spool Control Valve
Group 25 - Hydraulic Cylinders
Group 30 - Steering Cylinder (Power Assisted)
Group 35 - Hydrostatic Steering
Group 40 - Hydraulic System of 360 Combine
Group 45 ~ Hydraulic Brakes
Group 50 - Reverser Clutch Control
SECTION 80 — MISCELLANEOUS
Group 5 - Cutting Platform and Cutter Bar Drive
Group 10 - Cylinder, Concave and Rotary Deflector
Group 15 - Separating and Cleaning Units
Group 20 - Bearings
Group 25 - Fundamentals about V-Belts, Flat Belts and Chain Drives
