John Deere 350C 350D Bulldozer 350C 355D Loader Technical Manual TM1115
Brand: John Deere
Type of Machine: Bulldozer, Loader
Type of Manual: Technical Manual
Model: John Deere 350C 350D Bulldozer 350C 355D Loader
Part Number: TM1115
Number of Pages: 857 Pages
SECTION I—GENERAL INFORMATION
Group I—lntroduction and Safety
Group Il—Specmcauons
Group III—Torque Values
Group IV—Fuels and Lubricants
Group V—lnspection Procedures
SECTION 1—TRACKS
Group 0130-Traclr. Systems
Group 0199—Specifications and Special Tools
SECTION 2—AXLES AND SUSPENSION SYSTEMS
Group 0201—Drive Axle Housing and Support
Group 0210—Difterential or Bevel Drive
Group 0225—Input Drive Shafts
Group 0250—Axle Shaft, Bearings and Reduction Gears
Group 0299—Specificalions and Special Tools
SECTION 3—TRANSMISSION
Group 0315—Controls
Group 0341—Housings and Covers
Group 0350—Gears, Shafts, Bearings and Power Shift Clutch
Group 0360—Tranemiue'mn HydrollIice
Group 0399—Specifications and Special Tools
SECTION 4—ENGINES
Group 0401—Crankshalt and Main Bearings
Group 0402—Camshalts and Valve Actuating Means
Group 0403—Connecting Rods and Pistons
Group 0404—Cyiinder Block (Liners)
SECTION 4—ENGINES—CONTINUED
Group 0405—Carburetor
Group 0406—Governor
Group 0407—Engirie Citing System
Group 0408-Ventilating System
Group 0409—Cylinder Head and Valves
Group 0410—Exhaust Manifold
Group 0411—lgnition System
Group 0413—Fuel Injection System
Group 0414-intake Manifold
Group OMS—Engine Baiancer
Group 0416—Turbocharger
Group 0417—Water Pump
Group 041 8—Thermostats, Housings and Piping
Group 041 Q—Engine Oil Cooler
Group 0420—Fuei Filter
Group O421-Fuel Transfer Pump
Group 0422—Startlng System
Group O433-Fly wheel, Housing and Fasteners
Group 0499—Specifications and Special Tools
SECTION 5—ENGINE AUXILIARY SYSTEMS
Group 0505—Coid Weather Starting Aids
Group 051O—Engine Cooling Systems
Group 0520—intake System
Group 0560—External Fuel Supply Systems
Group 0599—Specifications and Special Tools
SECTION 15—EQUIPMENT ATTACHING
Group 1511—Drawbar
Group 1520—Hitches and Hitch Pins
Group 1599—Specifications and Special Tools
SECTION 16—ELECTRICAL SYSTEMS
Group 1671—Batteries. Support and Cables
Group 1672-Alternaton Regulator and Charging System Wiring
Group 1673—Venicie Lighting System
Group 1674—Wiring Harness and Switches
Group 1699—Specifications and Special Tools
SECTION 17—CRAWLER MAIN FRAME
Group 1741—Crawier Main Frame
Group 1746—Frame Bottom Guard
Group 1749-Chassis Weights
Group 1799—Specifications and Special Tools
SECTION 18—OPERATOR'S STATION
Group 1806—Salety Equipment
Group 1808—Comfort and Convenience items
Group 1810—Operator Enclosure Group teat—Seat
Group 1823 instruments and indicators
Group 1824—Externai Engine Speed Controls
Group 1899—Specification: and Special Tools
SECTION 19—SHEET METAL
Group 1910-Hcod or Engine Enclosure
Group 1921—Grilie and Grille Housing
SECTION 21—MAIN HYDRAULIC SYSTEM
Group 2160—Hydrauiic System
Group 2199—Specifications and Special Tools
SECTION 30—WINCH
Group 3015—Controis Linkage
Group 3041—Housing and Mounting Structure
Group 3050—Winch Drive and Clutches
Group 3060—Winch Hydraulic System
Group 3099-pecifications and Special Tools
SECTION 31—LOADER
Group 3102—Buckets
Group 3103—Forks
Group 3115—Controls Linkage
Group 3140—Loader Frames
Group 3160-Loader Hydraulics
Group 3199—Speciiications and Special Tools
SECTION 32—DOZER
Group 3201—Biade
Group 3215—Controls Linkage
Group 3241—Main Frame
Group 3243—Moveabie Frames
Group 3399—Speciiications and Special Tools
SECTION 33—9250 BACKHOE
Group 3302—Bucket
Group 3315—-Controls Linkage
Group 3340—Frames
Group 3360—Hydraulic System
Group 3399—Specitications and Special Tools
SECTION 33A—9300 BACKHOE
Group 3302—Bucket
Group 3315—Controls Linkage
Group 3340—Frames
Group 3360—Hydrauiic System
Group 3399—Specifications and Special Tools
SECTION 33B—9550 BACKHOE
Group 3302-Bucket
Group 3315—Controis Linkage
Group 3340—Frames
SECTION 37—LOG ARCH
Group 3740—Frames
SECTION 40-WINCH DRIVE
Group 4015—PTO Control
Group dost—Gears, Shafts and Bearings
SECTION 41—MISCELLANEOUS FUNCTION MECHANICAL DRIVES
Group 4158—Output Shaft or Pulley
Group 4199—Specifications and Special Tools
SECTION 42—GROUND CONDITIONING TOOL
Group 4201—Teeth and Shanks
Group 4240—Frame
Group 4260—Hydraulic System
Group 4299—Speciiications and Special Tools
SECTION 90—SYSTEM TESTING
Group 9005—Operationai Checkout Procedure
Group 9010—Engine
Group 9015-Electrical System
Group 9020—Power Train
Group 9025-Hydraulic System
Group 9025A—Hydraulic System (Analyzer)
Group 9030—Miscelianeous Components
Group 9035—Specifications and Special Tools
Brand: John Deere
Part Number: TM1115
SECTION 1—TRACKS
Group 0315—Controls
SECTION 4—ENGINES
Group 0406—Governor
Group 1511—Drawbar
SECTION 30—WINCH
SECTION 31—LOADER
Group 3102—Buckets
Group 3103—Forks
SECTION 32—DOZER
Group 3201—Biade
Group 3302—Bucket
Group 3340—Frames
Group 3302—Bucket
Group 3340—Frames
Group 3302-Bucket
Group 3340—Frames
SECTION 37—LOG ARCH
Group 3740—Frames
Group 4240—Frame
Group 9010—Engine
- John Deere 3800 Telescopic Handler Service Manuals
- John Deere Tractors 3030, 3130 Technical Manual_EN
- John Deere ZTrak Mower Z910A, Z920A, Z925A, Z930A, Z950A, Z960A, Z970A Technical Manual_TM109119 2012
- John Deere 9540 9560 9580 9640 9660 9680 WTS CWS Combines Repair Technical Manual EN TM4697
- John Deere Powershift Transmission DF180 Repair Technical Manual_EN
- John Deere 9540 9560 9580 9640 9660 9680 WTS CWS Combines Operator Manual_EN
- John Deere Sugarcane Harvester 3520 Parts Catalog_EN
- John Deere Backhoe Loader JD410 Maintenance Manual_EN
- John Deere 310SL HL, 410L Repair Technical Manual & Parts Catalog(2019)
- John Deere Tractors 1640, 1840, 2040, 2040 S Specifications & Special Tools Manual_EN
- John Deere Tractors 7600, 7700, 7800 Repair Manual_EN
- John Deere Powertech 4.5L-4045DFM50/TFM50-Marine Engines Part Catalog_EN
- John Deere Premium Tractors 6230, 6330, 6430, 6530 and 6630 Premium (European) Service Repair Manual
- John Deere 6090 Diesel Engine Component Technical Manual_CTM117719
- John Deere 3520 Sugar Cane Harvester Parts Catalog_EN
