Martin Welker
104
230,310
John Deere 3320 3520 3720 Compact Utility Tractor Technical Manual TM2365
Brand: John Deere
Type of Machine: Compact Utility Tractor
Type of Manual: Technical Manual
Model: John Deere 3320 3520 3720 Compact Utility Tractor
Part Number: TM2365
Publication Date: 2013
Number of Pages: 2101 Pages
FOREWORD
Section 10 - SAFETY
Group 05 - Safety
Recognize Safety Information
Understand Signal Words
Replace Safety Signs
Prepare for Emergencies
Prevent Battery Explosions
Prevent Acid Burns
Wear Protective Clothing
Avoid High-Pressure Fluids
Service Machines Safely
Use Proper Tools
Park Machine Safely
Support Machine Properly
Use Proper Lifting Equipment
Work in Clean Area
Protect Against High Pressure Spray
Illuminate Work Area Safely
Work In Ventilated Area
Avoid Harmful Asbestos Dust
Service Tires Safely
Stay Clear of Rotating Drivelines
Service Cooling System Safely
Dispose of Waste Properly
Live With Safety
Section 20 - SPECIFICATIONS AND INFORMATION
Group 05 - General Specifications
Metric Cap Screw Torque Values—Grade 7
Gasket Sealant Application
Service Recommendations For Flat Face O-Ring Seal Fittings
Service Recommendations for O-Ring Boss Fittings
Group 10 - Fuel and Lubricants
Diesel Fuel
Diesel Engine Oil
Diesel Engine Break-In Oil
Lubricant Storage
Mixing of Lubricants
Grease
Transmission and Hydraulic Oil
Heavy Duty Diesel Engine Coolant
Group 15 - Serial Number Locations
Serial Numbers
Machine Product Identification Number
Engine and Turbocharger Serial Numbers
Section 30 - ENGINE—DIESEL
Group 05 - Specifications
Repair Specifications
Tests and Adjustment Specifications
Operational Tests
Torque Values, Non-Standard Fasteners
Special Tools
Other Materials
Group 10 - Component Location
Air Cleaner and Intake Components
Turbocharge Components
Fuel Line Identification
Group 15 - Theory of Operation
Fuel System Operation
Cooling System Operation
Turbocharger Operation
Lubrication System Operation
Group 20 - Diagnostics
Engine Troubleshooting
Engine Oil Diagnostics
Excessive Fuel Consumption
Incorrect Manifold Pressure
Low Engine Compression
Engine Starting Problem
Engine Operation Poor
Engine Oil Pressure Low
Coolant Temperature Abnormal
Coolant in Oil or Oil in Coolant
Turbocharger Failure Analysis
Diagnostic Table
Check for Head Gasket Failures
Group 25 - Tests and Adjustments
Air Restriction Indicator Test
Check for Intake and Exhaust Restrictions
Fan/Alternator Drive Belt Adjustment
A/C Compressor Belt Adjustment
Throttle Cable Adjustment
Slow Idle Adjustment
Thermostat Opening Test
Cylinder Compression Test
Valve Clearance Adjustment
Valve Lift Check
Radiator Bubble Test
Radiator Pressure Cap Test
Cooling System Pressure Test
Engine Oil Pressure Test
Check for Excessive Engine Crankcase Pressure (Turbocharged Engines)
Engine Oil Consumption
Fuel System Leakage Test
Bleed Fuel System
Fuel Supply Pump Pressure Test
Injection Pump Timing (EPA Engines)
Fuel Injection Nozzle Test
Check for Exhaust Air Leaks (Turbocharger)
Turbocharger Oil Seal Leak Check
Turbocharger Waste Gate Test
Turbocharger Inspection
Crankshaft End Play Check
Timing Gear Backlash Check
Camshaft End Play Check
Connecting Rod Side Play Check
Connecting Rod Bearing Clearance Check
Crankshaft Main Bearing Clearance Check
Group 30 - Repair
Thermostat Removal and Installation
Water Pump Removal and Installation
Fuel Filter/Water Separator 3TNV
Secondary Fuel Filter 3TNV
Fuel Injection Pump
Fuel Injection Nozzles
Intake Manifold
Turbocharger Removal and Installation
Exhaust Manifold
Starting Motor Removal and Installation
Rocker Arm Assembly
Cylinder Head and Valves Removal and Installation
Cylinder Head and Valves Disassembly and Assembly
Valve Seats
Valve Recession
Valve Guides
Valve Springs
Grind Valve Seats
Lap Valves
Measure Piston-To-Cylinder Head Clearance
Piston and Connecting Rod
Piston Inspection
Cylinder Bore
Crankshaft Front Oil Seal
Crankshaft Rear Oil Seal
Crankshaft and Main Bearings
Flywheel and Coupling
Camshaft
Camshaft Followers
Timing Gear Cover
Idler Gear
Timing Gear Cover Mounting Plate
Oil Pan and Crankcase Housing Extension
Oil Pump (Engines 3TNV8x-JT, -MJT)
Oil Pump (Engines 3TNV8x-BJT, -BMJT, -BXJT)
Section 40 - ELECTRICAL - NORTH AMERICA
Group 05 - General Information
Reading Electrical Schematics
Theory of Operation Information
Diagnostic Information
Wire Color Abbreviation Chart
Common Circuit Tests
Conductors for 12-Volt Circuits
Group 10 - Specifications
System Specifications
Essential or Recommended Tools
Other Materials
Group 15 - Component Location
W1 Chassis Wiring Harness
W1 Chassis Wiring Harness—MY13
W2 Lower Cab Wiring Harness
W2 Lower Cab Wiring Harness—MY13
W3 Upper Cab Wiring Harness
A1 Display Panel Signal Location
A1 Display Panel Signal Location—MY13
A2 HST Controller Signal Location
W1 Chassis Schematic and Wiring Harness Legend
W2 Lower Cab Schematic and Wiring Harness Legend
W3 Upper Cab Schematic and Wiring Harness Legend
Ground Circuit Legend
Group 20 - Schematics and Harnesses
Main Wiring Schematic
Main Wiring Schematic—MY13
W3 Upper Cab Electrical Schematic
W1, W2, and W3 Ground Circuits
W1, W2, and W3 Ground Circuits—MY13
W1 Chassis Wiring Harness Color Codes
W1 Chassis Wiring Harness Color Codes—MY13
W2 Lower Cab Wiring Harness Load Center
W2 Lower Cab Wiring Harness Color Codes
W2 Lower Cab Wiring Harness Load Center—MY13
W2 Lower Cab Wiring Harness Color Codes—MY13
W3 Upper Cab Wiring Harness Color Codes
W3 Upper Cab Wiring Harness Relay Block
W4 Headlight Wiring Harness
W4 Headlight Wiring Harness Color Codes
W5 Proportional Valve Wiring Harness
W5 Proportional Valve Wiring Harness Color Codes
W6 Cruise Control Wiring Harness (Standard)
W6 Cruise Control Wiring Harness Color Codes (Standard)
W7 Cruise Control Wiring Harness (Optional)
W7 Cruise Control Wiring Harness (Option) Color Codes
W8 Diverter Valve Wiring Harness (SN —740000)
W8 Diverter Valve Wiring Harness Color Codes (SN —740000)
W8 Diverter Valve Wiring Harness (SN 740001— )
W8 Diverter Valve Wiring Harness Color Codes (SN 740001— )
W9 Air Ride Seat Wiring Harness
W9 Air Ride Seat Wiring Harness (Option) Color Codes
W28 3rd SCV Function Wiring Harness (SN 740001— )
W28 3rd SCV Function Wiring Schematic (SN 740001— )
Group 25 - Troubleshooting
Display Panel Fault Codes
Display Panel Fault Code Chart
Connecting Service ADVISOR
Group 30 - Operation and Diagnostics
Power Circuit Operation
Power Circuit Operation—MY13
Power Circuit Electrical Schematic
Power Circuit Electrical Schematic—MY13
Power Circuit Diagnosis
Power Circuit Diagnosis—MY13
Ground Circuit Diagnosis
Ground Circuit Diagnosis—MY13
Cranking Circuit Operation
Cranking Circuit Operation—MY13
Cranking Circuit Electrical Schematic
Cranking Circuit Electrical Schematic—MY13
Cranking Circuit Diagnosis
Cranking Circuit Diagnosis—MY13
Manifold Heater and Indicator Light Circuit Operation
Manifold Heater and Indicator Light Circuit Operation—MY13
Manifold Heater Circuit Electrical Schematic
Manifold Heater Circuit Electrical Schematic—MY13
Manifold Heater Circuit Diagnosis
Manifold Heater Circuit Diagnosis—MY13
Fuel Supply/Engine Shutoff Circuit Operation
Fuel Supply/Engine Shutoff Circuit Operation—MY13
Fuel Supply/Engine Shutoff Circuit Schematic
Fuel Supply/Engine Shutoff Circuit Schematic—MY13
Fuel Supply/Engine Shutoff Circuit Diagnosis
Fuel Supply/Engine Shutoff Circuit Diagnosis—MY13
Charging Circuit Operation
Charging Circuit Operation—MY13
Tachometer Circuit Operation
Tachometer Circuit Operation—MY13
Hour Meter Circuit Operation
Speedometer Circuit Operation
Charging, Tachometer, Hour Meter, and Speedometer Circuit Electrical Schematic
Charging, Tachometer, Hour Meter, and Speedometer Circuit Electrical Schematic—MY13
Charging, Tachometer, Hour Meter, and Speedometer Circuit Diagnosis
Charging, Tachometer, Hour Meter, and Speedometer Circuit Diagnosis—MY13
Fuel Gauge Circuit Operation
Fuel Gauge Circuit Schematic
Fuel Gauge Circuit Schematic—MY13
Fuel Gauge Circuit Diagnosis
Fuel Gauge Circuit Diagnosis—MY13
Rear and Mid PTO Circuit Operation
Rear and Mid PTO Circuit Operation—MY13
Rear and Mid PTO Electrical Schematic
Rear and Mid PTO Electrical Schematic—MY13
Rear and Mid PTO Circuit Diagnosis
Rear and Mid PTO Circuit Diagnosis—MY13
MFWD Circuit Operation
MFWD Circuit Operation—MY13
MFWD Circuit Electrical Schematic
MFWD Circuit Electrical Schematic—MY13
MFWD Circuit Diagnosis
MFWD Circuit Diagnosis—MY13
Light Circuit Electrical Schematic (Overall Lighting System)
Light Circuit Electrical Schematic—MY13 (Overall Lighting System)
Light Circuit Electrical Schematic (Hazard Position)
Light Circuit Electrical Schematic—MY13 (Hazard Position)
Light Circuit Electrical Schematic (Road Position)
Light Circuit Electrical Schematic—MY13 (Road Position)
Light Circuit Electrical Schematic (Field Position)
Light Circuit Electrical Schematic—MY13 (Field Position)
Light Circuit Electrical Schematic (Turn Signal, Beacon, and Dome—Right Turn Shown)
Light Circuit Electrical Schematic—MY13 (Turn Signal, Beacon, and Dome—Right Turn Shown)
Light Circuit Diagnosis
Light Circuit Diagnosis—MY13
HVAC Circuit Operation
HVAC Electrical Schematic (Overall HVAC System)
HVAC Electrical Schematic—MY13 (Overall HVAC System)
HVAC Electrical Schematic (Blower Low Speed Operation with A/C On—Lowest Speed Shown)
HVAC Electrical Schematic—MY13 (Blower Low Speed Operation with A/C On—Lowest Speed Shown)
HVAC Electrical Schematic (Blower High Speed Operation with A/C On)
HVAC Electrical Schematic—MY13 (Blower High Speed Operation with A/C On)
HVAC Circuit Diagnosis
Wiper and Washer Circuit Operation
Wiper and Washer Circuit Operation—MY13
Wiper and Washer Circuit Electrical Schematic
Wiper and Washer Circuit Electrical Schematic—MY13
Wiper and Washer Circuit Diagnosis
Wiper and Washer Circuit Diagnosis—MY13
Radio Circuit Operation
Radio Circuit Electrical Schematic
Radio Circuit Electrical Schematic—MY13
Radio Circuit Diagnosis
Display Panel LCD Message
Display Mode Switch Circuit Operation
Display Mode Switch Circuit Operation—MY13
Display Mode Switch Circuit Electrical Schematic
Display Mode Switch Circuit Electrical Schematic—MY13
Electronic Drive Controller
Electronic Drive Controller—MY13
Forward Drive Circuit Operation
Forward Drive Circuit Operation—MY13
Forward Drive Circuit Electrical Schematic
Forward Drive Circuit Electrical Schematic—MY13
Forward Drive Circuit Diagnosis
Forward Drive Circuit Diagnosis—MY13
Reverse Drive Circuit Operation
Reverse Drive Circuit Operation—MY13
Reverse Drive Circuit Electrical Schematic
Reverse Drive Circuit Electrical Schematic—MY13
Reverse Drive Circuit Diagnosis
Reverse Drive Circuit Diagnosis—MY13
Cruise Control Circuit Operation (Standard)
Cruise Control Circuit Operation (Standard)—MY13
Cruise Control Circuit Electrical Schematic (Standard)
Cruise Control Circuit Electrical Schematic (Standard)—MY13
Cruise Control Circuit Diagnosis (Standard)
Cruise Control Circuit Diagnosis (Standard)—MY13
Cruise Control Circuit Operation (Optional)
Cruise Control Circuit Operation (Option)—MY13
Cruise Control Circuit Wiring Schematic (Optional)
Cruise Control Circuit Wiring Schematic (Option)—MY13
Cruise Control Circuit Diagnosis (Optional)
Cruise Control Circuit Diagnosis (Optional)—MY13
Load Match and MotionMatch (Option) Circuit Operation
LoadMatch and MotionMatch (Option) Circuit Operation—MY13
Load Match and MotionMatch (Option) Circuit Electrical Schematic
LoadMatch and MotionMatch (Option) Circuit Electrical Schematic—MY13
Load Match and MotionMatch (Option) Circuit Diagnosis
LoadMatch and MotionMatch (Option) Circuit Diagnosis—MY13
Diverter Valve Circuit Operation (Option)
Diverter Valve (Option) Circuit Electrical Schematic (Latch or On Position)
Diverter Valve (Option) Circuit Electrical Schematic—MY13 (Latch or On Position)
Diverter Valve Circuit Electrical Schematic (Activate Position)
Diverter Valve Circuit Electrical Schematic—MY13 (Activate Position)
Diverter Valve Circuit Diagnosis (Option)
Air Ride Seat Circuit Operation (Option)
Air Ride Seat Circuit Schematic (Option)
Air Ride Seat Circuit Schematic—MY13 (Option)
Air Ride Seat Circuit Diagnosis (Option)
Group 35 - Tests and Adjustments
Ground Circuit Test
Battery Voltage and Specific Gravity Test
Battery—Charge
Battery—Load Test
Starting Motor Solenoid Test
Starting Motor Amperage Draw Test
Starting Motor No-Load Amperage Draw and RPM Test
Fuse Test
Manifold Heater Test
Engine Coolant Temperature Sensor Test
Engine Oil Pressure Switch Test
Relay Test
Key Switch Test
Light Switch Test
Sensing Switch Test
Turn Signal Switch Test
Rear PTO Switch Test
Rear PTO Switch Test—MY13
Rear PTO Solenoid Test
Seat Switch Test
Cruise/Max Speed Switch Test (Option)
Res/+, Set/- Switch Test (Option)
Wiper/Washer Switch Test
Beacon Lamp Switch Test
Door Switch Test
Fan Speed Switch Test
Air Ride Seat Switch Test (Option)
Diverter Valve Switch Test
A/C Temperature Control Switch Test
Brake and Park Brake Switch Test
Air Filter Restriction Switch Test
Fuel Gauge Sensor Test
Fuel Shutoff Solenoid Test
LoadMatch Switch Test
MotionMatch Switch Test (Option)
Display Mode Switch Test
A/C (HVAC) Switch Test
Rear Work Light Switch Test
Diode Test
Proportional Drive Solenoid Test
Horn Switch Test
Configure the Display
Editing Tire Size Value
Editing MotionMatch Settings
Editing LoadMatch Settings
HST Proportional Solenoid Test
Entering Diagnostic and Calibration Modes
Electronic Drive Controller System Calibration
Single Sensor Calibration
Test Kit
Throttle Position Sensor Test and Adjustment
Forward and Reverse Pedal Sensor Test and Adjustment
MFWD Speed Sensor Test
Group 40 - Service ADVISOR Test and Adjustments
Service ADVISOR Diagnostic Application
Retrieving Diagnostic Trouble Codes with Service ADVISOR Diagnostic Application
Adding and Removing Data Points
Service ADVISOR Connection Procedure
HST Troubleshooting Flowchart
eHydro—eMatchOS Electronic Drive Controller Circuit Operation
HST Sensor Calibration Using Service ADVISOR
eHydro Control System Complete Calibration Using Service ADVISOR
Forward and Reverse Threshold Calibration
Controller Reprogramming
Section 50 - ELECTRICAL - EEC
Group 05 - European Electrical Section
European Electrical Theory
Other Material
A1 Electronic Drive Controller Signal Location
A2 Display Panel Signal Location
A2 Display Panel Signal Location—MY13
W1 Chassis Schematic Wiring Harness Legend
W2 Lower Cab Schematic Wiring Harness Legend
W3 Upper Cab Schematic Wiring Harness Legend
W4 Proportional Valve Wiring Harness
W5 Cruise Control Wiring Harness (Standard)
W6 Cruise Control Wiring Harness (Optional)
W7 Diverter Valve Wiring Harness
W8 Air Ride Seat Wiring Harness
W9 Headlight/Horn Wiring Harness
W4 Proportional Valve Wiring Harness Color Codes
W5 Cruise Control Wiring Harness Color Codes (Standard)
W6 Cruise Control Wiring Harness (Option) Color Codes
W7 Diverter Valve Wiring Harness Color Codes
W8 Air Ride Seat Wiring Harness (Option) Color Codes
W9 Headlight/Horn Wiring Harness Color Codes
Power Circuit Electrical Schematic—Unswitched
Power Circuit Electrical Schematic—Unswitched—MY13
Power Circuit Diagnosis—Unswitched
Power Circuit Diagnosis—Unswitched—MY13
Power Circuit Electrical Schematic—Switched
Power Circuit Electrical Schematic—Switched—MY13
Power Circuit Diagnosis—Switched
Power Circuit Diagnosis—Switched—MY13
Power Circuit Diagnosis—Secondary Switched
Power Circuit Diagnosis—Secondary Switched—MY13
Speedometer Circuit Operation—MY13
Front PTO Circuit Operation
Front PTO Circuit Operation—MY13
Front PTO Circuit Electrical Schematic
Front PTO Circuit Electrical Schematic—MY13
Front PTO Circuit Diagnosis
Front PTO Circuit Diagnosis—MY13
Light Switch Circuit Operation
Light Switch Circuit Operation—MY13
Lights Circuit Electrical Schematic
Lights Circuit Electrical Schematic—MY13
Lights Circuit Diagnosis
Lights Circuit Diagnosis—MY13
Hazard Lights Circuit Operation
Hazard Lights Circuit Operation—MY13
Hazard Lights Circuit Electrical Schematic
Hazard Lights Circuit Electrical Schematic—MY13
Hazard Lights Circuit Diagnosis
Hazard Lights Circuit Diagnosis—MY13
Turn Signal Lights Circuit Operation
Turn Signal Lights Circuit Operation—MY13
Turn Signal Circuit Electrical Schematic
Turn Signal Circuit Electrical Schematic—MY13
Turn Signal Lights Circuit Diagnosis
Dome Light Circuit Operation
Dome Lights Circuit Electrical Schematic
Dome Light Circuit Diagnosis
Beacon Light Circuit Operation (option)
Beacon Light Circuit Operation (option)—MY13
Beacon Lights Circuit Electrical Schematic
Beacon Lights Circuit Electrical Schematic—MY13
Beacon Light Circuit Diagnosis
Beacon Light Circuit Diagnosis—MY13
Brake Switch Circuit Operation
Brake Switch Circuit Operation—MY13
Brake Switch Circuit Electrical Schematic
Brake Switch Circuit Electrical Schematic—MY13
Brake Switch Circuit Diagnosis
Brake Switch Circuit Diagnosis—MY13
Display Panel Operation
Display Panel Operation—MY13
Display Panel Diagnosis
Display Mode Switch Circuit Diagnosis
Display Mode Switch Circuit Diagnosis—MY13
Cruise Control Circuit Operation—MY13 (Standard)
Cruise Control Circuit Operation—MY13 (Optional)
Cruise Control Circuit Wiring Schematic—(Optional)—MY13
Cruise Control Circuit Diagnosis—MY13 (Optional)
Load Match and Motion Match (Option) Circuit Operation
Load Match and Motion Match (option) Circuit Electrical Schematic
Load Match and Motion Match (option) Circuit Electrical Schematic—MY13
Load Match and Motion Match (Option) Circuit Diagnosis
Diverter Valve Circuit Electrical Schematic (Activate Position) MY13
Diverter Valve (Option) Circuit Electrical Schematic (Latch Position)
Diverter Valve (Option) Circuit Electrical Schematic (Latch Position) MY13
Air Ride Seat Circuit Schematic (Option)—MY13
Section 60 - POWER TRAIN—HYDROSTATIC
General
Hydrostatic Pump
Hydrostatic Motor
Torque Specifications
Special or Essential Tools
Other Materials
Transmission (eHydro™)
eHydro™ Transmission Components
eHydro™ Center Plate Components
Drive Shaft
Front Drive
Group 15 - Schematics
Steering/Charge Pump Circuit Schematic, eHydro™ Transmission
Group 20 - Theory of Operation
eHydro Transmission Operation
Range Transmission Power Flow
Group 25 - Diagnostics
Hydrostatic (HST) Power Train
Group 30 - Troubleshooting
Troubleshooting
Hydrostatic High Pressure Relief Test
Charge Pump Pressure Test and Adjustment
Hydraulic System Bleed Procedure
Group 40 - Repair
Charge Pressure Relief Valve Inspection/Replacement
Forward and Reverse Position Sensors
Forward and Reverse Pedals Assembly
Section 70 - POWER TRAIN—FINAL DRIVE
Other Material
Main and Driven Shafts
Drive/Pinion Shaft
Range Shift
Differential Assembly
Rear Axle and Final Drive
Brake Assembly
PTO Clutch/Brake Assembly
Rear PTO Shaft
Rear and Mid PTO Shafts
Rear and Mid PTO Shift Assembly
Transmission Housing
Front Drive (For MFWD)
MFWD Front Axle Housing and Differential
MFWD Final Drive
Range Transmission—eHydro
Differential Power Flow and Lock
MFWD Power Operation
MFWD Power Flow
PTO Diagnostics Table
Final Drive Diagnosis
Troubleshooting Table
Group 30 - Final Drive Troubleshooting
Final Drive Symptom Diagnosis
Differential Lock
Specifications
Differential Pinion Shaft Adjustment
Differential Backlash Adjustment
Transmission Range Cable Adjustment
PTO Selector Cable Adjustment
Differential Lock Cable Adjustment
MFWD Cable Adjustment
Group 40 - Repair
Specifications
MFWD Output Shaft
Speed Range Transmission—eHydro™
Main Gear Disassembly/Assembly
Assemble Range Transmission—eHydro™
Final Drive Removal
Final Drive Installation
Final Drive Disassembly, Inspection, and Assembly
Differential Lock Fork
Differential Removal and Installation
MFWD Drive Shaft Removal and Installation
MFWD Removal and Installation
MFWD Final Drive Cover
MFWD Spindle Shaft
MFWD Final Drive Housing
Spindle Housing
MFWD Differential
Pinion Depth Setup and Adjustment
Group 45 - PTO Theory of Operation
PTO Clutch and Brake Theory of Operation
Power Transmission—Rear PTO
Power Transmission—Mid PTO
Group 50 - PTO Repair
PTO Drive Shaft and Gears
Rear and Mid PTO Shifter
Mid PTO
Section 80 - HYDRAULICS
Hydraulic Specifications
Hydraulic Gear Pump
Rockshaft Piston, Rod, and Rate of Drop Valve
Rockshaft Control Valve, Plunger Assembly and Controls
Rockshaft and Lift Arms (Exploded View)
SCV Components
SCV Cable Control Components
SCV and Rockshaft System Components
Diverter Valve Components (SN —740000)
Diverter Valve Components (SN 740001— )
Steering System Schematics
SCV and Rockshaft System Schematics (SN —740000)
2-Spool SCV Schematics (SN 740001— )
3rd, 4th, and 5th SCV Schematics (SN 740001— )
Diverter Valve Schematic (SN —740000)
Diverter Valve Schematic (SN 740001— )
eHydro™ Hydraulic Operation
PTO Clutch Operation
PTO Valve Operation
Rockshaft Operation
Hydrostatic (eHydro) Troubleshooting
Rockshaft Hydraulics
Group 30 - Tests and Adjustments
SCV Joystick Cable Adjustment
Rate of Drop/Stop Valve Adjustment
Lift Arms Adjustment
System Pressure/Flow Test
System Pressure Adjustment
Steering Pressure Test
PTO Clutch Pressure Test
Rockshaft Cable Adjustment
Rockshaft Lift Cycle Test
Rockshaft Leakage Test
Rockshaft Position Feedback Linkage Adjustment
Group 35 - Repair
Hydraulic Gear Pump
Rockshaft Disassembly and Assembly
Rockshaft Lift Arms Removal and Installation
Section 90 - STEERING
Steering
Steering Components
Steering
Steering System Check
Steering Operation
Steering Pressure Check
Steering System Test
Toe-in Adjustment MFWD
Group 30 - Repair
Steering Cylinder Removal and Installation MFWD
Steering Wheel Removal and Installation
Tilt Steering Mechanism Removal and Installation
Steering Control Unit (SCU) Removal and Installation
Tie Rod Removal and Installation MFWD
Section 100 - BRAKES
Brakes
Transaxle Oil
Brake Pedals and Linkage—eHydro™
Brake Assembly
Brake Housing
Park Brake Linkage—North America
Park Brake Linkage—Export
Brakes
Brake Pedals and Linkage Checks
Brake Operation Problems
Internal Components
Brake Pedal Adjustment
Group 30 - Repair
Brake Pedal and Linkage Removal and Installation
Brake Shaft Removal and Installation
Brake Disassembly and Inspection
Brake Assembly
Section 110 - HVAC
Air Conditioner Specifications
Group 10 - Tools and Materials
Other Material
Service Parts Kits
Group 15 - General Information
System Information
Refrigerant Oil Information
Determine Correct Refrigerant Oil Charge
Group 20 - Tests and Adjustments
Heater Temperature Control Cable Adjustment
A/C Temperature Control Switch Cable Adjustment
Compressor Shaft Seal Leakage Test
Compressor Clutch Hub Clearance Check
Evaporator/Heater Core Leak Test
Compressor Oil Charge Check
Add Refrigerant Oil to System
Recover/Recycle Refrigerant
Air Conditioning Receiver/Dryer
Section 120 - MISCELLANEOUS
Cab Specifications
Other Material
Group 10 - Repair
Front Wheel Removal and Installation
Rear Wheel Removal and Installation
Battery Removal and Installation
Fuse Panel Cover Removal and Installation
Seat and Support Removal and Installation—Standard Seat
Seat and Support Removal and Installation—Air Seat
Right-Side Control Console Removal and Installation
Left-Side Control Console Removal and Installation
Cowl Panel Removal and Installation
Control Panel Removal and Installation
Hood Removal and Installation
Headliner Removal and Installation
Cab Outer Roof Removal and Installation
Cab Door Removal and Installation
Cab Removal and Installation
Three Point Hitch Removal and Installation
Center Link Bracket Removal and Installation
Cleaning Cab Air Filter
