John Deere 328E 329E 332E 333E Loader Repair Technical Manual TM12808
Brand: John Deere
Type of Machine: Loader
Model: John Deere 328E 329E 332E 333E Loader
(PIN: 1T0328E_ _ _E236673— )
(PIN: 1T0329E_ _ _E236704— )
(PIN: 1T0332E_ _ _E236670— )
(PIN: 1T0333E_ _ _E236690—)
Part Number: TM12808
Publication Date: 2014
Number of Pages: 352 Pages
Safety
Recognize Safety Information
Follow Safety Instructions
Operate Only If Qualified
Wear Protective Equipment
Avoid Unauthorized Machine Modifications
Inspect Machine
Stay Clear of Moving Parts
Avoid High-Pressure Fluids
Avoid High-Pressure Oils
Work In Ventilated Area
Prevent Fires
Prevent Battery Explosions
Dispose of Waste Properly
Prepare for Emergencies
Clean Debris from Machine
Start Only From Operator's Seat
Use and Maintain Seat Belt
Prevent Unintended Machine Movement
Avoid Work Site Hazards
Keep Riders Off Machine
Avoid Backover Accidents
Avoid Machine Tip Over
Operating On Slopes
Operating or Traveling On Public Roads
Inspect and Maintain ROPS
Add and Operate Attachments Safely
Park and Prepare for Service Safely
Service Cooling System Safely
Make Welding Repairs Safely
Drive Metal Pins Safely
Handle Cab Door Safely
Clean Exhaust Filter Safely
Torque Values
Additional Metric Cap Screw Torque Values
Check Oil Lines And Fittings
Service Recommendations for O-Ring Boss Fittings
Service Recommendations for 37° Flare and 30° Cone Seat Connectors
Service Recommendations For Flared Connections—Straight or Tapered Threads
Inch Series Four Bolt Flange Fitting For High Pressure Service Recommendations
Service Recommendations For Inch Series Four Bolt Flange Fittings
O-Ring Face Seal Fittings With SAE Inch Hex Nut And Stud End For High Pressure Service Recommendations
O-Ring Face Seal Fittings With Metric Hex Nut And Stud End For Standard Pressure Service Recommendations
O-Ring Face Seal Fittings With Metric Hex Nut And Stud End For High Pressure Service Recommendations
Service Recommendations for Metric Series Four Bolt Flange Fitting
Wheels or Tracks
Powered Wheels and Fastenings
Wheel Remove and Install
Tire Remove and Install
Track System
Measure Rubber Track Height
Track Remove and Install
Track Roller Remove and Install
Drive Sprocket Remove and Install
Front or Rear Idler Remove and Install
Front Idler Yoke Assembly Remove and Install
Track Adjuster and Recoil Spring Assembly Remove and Install
Track Adjuster Recoil Spring Remove and Install
Track Adjuster Cylinder Disassemble and Assemble
Axles and Suspension Systems
Drive Axle Housing and Support
Axle Housing Remove and Install
Axle Housing Disassemble and Assemble
Axle Shaft, Bearings, and Reduction Gears
Chain Case Access Plate Remove and Install
Drive Chain and Sprocket Remove and Install
Controls Linkage
Left and Right Joystick Remove and Install
Joystick Disassemble and Assemble
Flywheel Coupler
Hub Coupler Remove and Install
Hydrostatic and Hydraulic Start-Up Procedure
Hydrostatic Motor and Park Brake Remove and Install
Hydrostatic Motor and Park Brake Disassemble and Assemble
Hydrostatic Motor and Park Brake Disassemble and Assemble—Two Speed
Hydrostatic Motor, Park Brake, and Gear Case Repair
Hydrostatic Motor, Park Brake, and Gear Case Remove and Install
Hydrostatic Motor, Park Brake, and Gear Case Disassemble
Hydrostatic Motor, Park Brake, and Gear Case Inspection
Hydrostatic Motor, Park Brake, and Gear Case Assemble
Inspect Metal Face Seals
Gear Case Leakage Test
Hydrostatic Pump Remove and Install
Hydrostatic Pump Disassemble and Assemble
Charge Pump Remove and Install
Hydrostatic Control Valve Remove and Install
Hydrostatic Control Valve Disassemble and Assemble
Park Brake Solenoid Valve Remove and Install
Return Manifold Screen Remove and Install
Removal and Installation
John Deere Engine
Engine Remove and Install
Starter Motor Remove and Install
Accessory Drive Belt Tensioner Remove and Install
Damper Plate Remove and Install
Compressor Bracket Remove and Install
Engine Oil Dipstick Tube Remove and Install
Engine Auxiliary System
Cooling Systems
Fan Remove and Install
Charge Air Cooler Remove and Install
Radiator Remove and Install
Cooling Package Remove and Install
Intake System
Air Cleaner Remove and Install
External Exhaust Systems
Exhaust Tube Remove and Install
Diesel Particulate Filter (DPF) Remove and Install
Exhaust Filter Remove and Install
External Fuel Supply Systems
Fuel Tank Remove and Install
Low-Pressure Fuel Pump Remove and Install
Primary Fuel Filter and Water Separator Assembly Remove and Install
Final Fuel Filter Assembly Remove and Install
Frame or Supporting Structure
Frame Installation
Welding On Machine
Welding Repair of Major Structure
Counterweight Remove and Install
Raising and Blocking Machine
Operator's Station
Operator's Station Remove and Install
Operator Enclosure
Cab Door Remove and Install
Top Window Remove and Install
Rear Window Remove and Install
Side Window Remove and Install
Raising Operator's Station
Seat and Seat Belt
Seat Remove and Install
Seat Belt Remove and Install
Interlocking Seat Bar Remove and Install
Seat Air Spring Remove and Install
Heating and Air Conditioning
Refrigerant Cautions and Proper Handling
Flush and Purge Air Conditioner System
R134a Refrigerant Oil Information
R134a Refrigerant Recovery, Recycling, and Charging Station Installation Procedure
Recover R134a Refrigerant
Evacuate R134a System
Charge R134a System
Air Conditioner Compressor Remove and Install
Expansion Valve Remove and Install
Receiver-Dryer Remove and Install
Condenser Remove and Install
Air Conditioner and Heater Remove and Install
Sheet Metal and Styling
Hood or Engine Enclosure
Footwell Remove and Install
Side Panel Remove and Install
Engine Cover Remove and Install
Safety and Convenience
Radio
Radio Antenna Remove and Install
Main Hydraulic System
General Oil Cleanup Procedure
Hydraulic/Hydrostatic Component Failure Cleanup Procedure
Vacuum Pump Installation
Hydraulic Fan Motor Remove and Install
Hydraulic Oil Cooler Remove and Install
Hydraulic Oil Reservoir Remove and Install
Hydraulic Pump Remove and Install
Hydraulic Pump Disassemble and Assemble
High Flow Hydraulic Pump Disassemble and Assemble
Loader
Attachment Coupler
Quik-Tatch™ Coupler Remove and Install
Quik-Tatch™ Actuator Remove and Install
Frame
Upper Boom Link Remove and Install
Lower Boom Link Remove and Install
Boom Remove and Install
Boom Lock Remove and Install
Boom Lock Disassemble and Assemble
Boom Lock
Self Leveling Valve Remove and Install
Ride Control Accumulator Remove and Install
Ride Control Valve Remove and Install
Ride Control Valve Disassemble and Assemble
Boom Cylinder Remove and Install
Bucket Cylinder Remove and Install
Hydraulic Cylinder Disassemble and Assemble
Hydraulic Oil Filter Manifold Remove and Install
Hydraulic Cylinder Bleed Procedure
Dealer Fabricated Tools
DFT1101 Boom Lifting Bracket
ST4920 Track Recoil Spring Disassembly and Assembly Tool
DFT1087 Track Recoil Spring Disassembly and Assembly Guard Tool
DFT1325 Solenoid Power Harness
DFT1333 Lock Nut Wrench
DFT1334 Gear Case Turning Tool
DFT1335 Park Brake Spring Compressor
DFT1336 Bias Spring Compressor
DFT1358 Engine Lifting Bracket
DFT1359 Engine Lifting Bracket
Page Number
Brand: John Deere
Safety
Inspect Machine
Prevent Fires
Operating On Slopes
Torque Values
Wheels or Tracks
Track System
Controls Linkage
Flywheel Coupler
John Deere Engine
Cooling Systems
Intake System
Frame Installation
Welding On Machine
Operator's Station
Operator Enclosure
Seat and Seat Belt
Charge R134a System
Radio
Loader
Attachment Coupler
Frame
Boom Lock
Page Number
