Martin Welker
104
230,310
John Deere 325 And 328 Skid Steer Operators Manual OMT205051
Format: HTML
Brand: John Deere
Type of Machine: Skid Steer
Model: John Deere 325 And 328 Skid Steer
Parts Number: OMT205051
Section 1-1 - Safety—Safety and Operator Conveniences
Safety and Operator Convenience Features
Section 1-2 - Safety—General Precautions
Recognize Safety Information
Follow Safety Instructions
Operate Only If Qualified
Wear Protective Equipment
Avoid Unauthorized Machine Modifications
Inspect Machine
Stay Clear of Moving Parts
Avoid High-Pressure Fluids
Avoid High-Pressure Oils
Work In Ventilated Area
Prevent Fires
Prevent Battery Explosions
Dispose of Waste Properly
Prepare for Emergencies
Section 1-3 - Safety—Operating Precautions
Start Only From Operator's Seat
Use and Maintain Seat Belt
Prevent Unintended Machine Movement
Avoid Work Site Hazards
Keep Riders Off Machine
Avoid Backover Accidents
Avoid Machine Tip Over
Operating or Traveling On Public Roads
Add and Operate Attachments Safely
Section 1-4 - Safety—Maintenance Precautions
Park and Prepare for Service Safely
Service Tires Safely
Service Cooling System Safely
Make Welding Repairs Safely
Drive Metal Pins Safely
Section 1-5 - Safety—Safety Signs
Replace Safety Signs
Safety Signs
Section 2-1 - Operation—Operator’s Station
Pedals and Levers - Standard Controls
Pedal and Levers - EH Controls
Instrument Panel
Instrument Panel Functions
Engagement and Monitor Unit Operation — Standard Controls
Anti-Theft Security System Operation — Standard Controls
Engagement and Monitor Unit Data Items — Standard Controls
Engagement and Monitor Unit Operation — EH Controls
Anti-Theft Security System Operation—EH Controls
Engagement and Monitor Unit Data Items—EH Controls
Engagement and Monitor Unit Display Messages—EH Controls
Reading Diagnostic Trouble Codes
Gauges and Indicator Lights
Gauge and Indicator Light Functions
Auto Shutdown With Alarm
Horn Button—If Equipped
12-Volt Power Outlet
Dome Light
Heating/Defrosting Controls—If Equipped
Air Conditioning Controls—If Equipped
Rear Window (Secondary Exit)
Seat Adjustment
Suspension Seat Adjustment—If Equipped
Armrest Adjustment
Beacon—If Equipped
Section 2-2 - Operation—Operating the Machine
Before Starting Work
Operator's Daily Machine Check Before Starting
Entering Skid Steer
Starting the Engine
Engine Speed Control Devices
Cold Weather Starting
Engine Block Heater—If Equipped
Quick Coupler Pressure Release
Self-Leveling—If Equipped
Using Attachment Mounting System—Quik-Tatch™
Boom Lock
Boom Release—Standard Controls
Steering Levers—Standard Controls
Operating Auxiliary Hydraulics—Standard Controls (Hand-Foot Machines)
Operating Boom—Standard Controls (Hand-Foot Machines)
Operating Bucket—Standard Controls (Hand-Foot Machines)
Operating Auxiliary Hydraulics—Standard Controls (Hands-Only Machines)
Operating Boom and Bucket—Standard Controls (Hands-Only Machines)
Boom Release—EH Controls
Steering Controls—EH Controls
Operating Auxiliary Hydraulics—EH Controls
Operating Boom—EH Controls
Operating Bucket—EH Controls
Using Attachment Mounting System—Hydraulic Quik-Tatch (S.N. — 131876)
Using Attachment Mounting System—Electric Quik-Tatch (S.N. 131877 — )
Stopping the Engine—Standard Controls
Stopping the Engine—EH Controls
Loading Machine On a Trailer
Section 3-1 - Maintenance—Machine
Diesel Fuel
Lubricity of Diesel Fuel
BioDiesel Fuel
Testing Diesel Fuel
Minimizing the Effect of Cold Weather on Diesel Engines
Diesel Engine Oil — Tier 2 and Stage II
Diesel Engine Oil and Filter Service Intervals
Hydraulic and Hydrostatic Oil
Chain Case Oil
Grease
Diesel Engine Coolant (engine without wet sleeve cylinder liners)
Drain Intervals for Diesel Engine Coolant
John Deere COOL-GARD™ II Coolant Extender
Supplemental Coolant Additives
Operating in Warm Temperature Climates
Additional Information About Diesel Engine Coolants and John Deere COOL-GARD™ II Coolant Extender
Testing Diesel Engine Coolant
Section 3-2 - Maintenance—Periodic Maintenance
Service Machine at Specified Intervals
Raising and Blocking Machine
Opening and Closing Rear Service Door
Opening and Closing Engine Cover
Removing Side Panels
Raising Operator's Station
Removing Cover Plates
Fluid Analysis Program Test Kits and 3-Way Coolant Test Kit
Service Intervals
Required Parts
Section 3-3 - Maintenance—As Required
Check Coolant
Section 3-4 - Maintenance—Every 10 Hours or Daily
Check Engine Oil Level
Check Hydraulic Tank Oil Level
Clean Radiator and Oil Cooler
Check Radiator Coolant Level
Drain Fuel Water Separator Filter
Check Auxiliary Water Separator Fuel Filter—If Equipped
Section 3-5 - Maintenance—Every 50 Hours
Lubricate Boom Linkage, Cylinder Pivots, and Quik-Tatch™
Check Tire Pressure
Section 3-6 - Maintenance—Every 250 Hours
Check Wheel Lug Nut Torque
Change Engine Oil and Replace Filter
Take Engine Oil Sample
Section 3-7 - Maintenance—Every 500 Hours
Replace In-Line Fuel Filter
Replace Fuel Filter and Water Separator
Replace Primary Air Cleaner Element
Replace Hydraulic Oil Tank Breather Element
Replace Hydraulic Oil Filter
Check Chain Case Oil Level
Check Battery Electrolyte Level and Terminals
Replace Auxiliary Water Separator Fuel Filter—If Equipped
Lubricate Steering Linkage
Lubricate Foot Pedal
Take Fluid Samples
Section 3-8 - Maintenance—Every 1000 Hours
Replace Secondary Air Cleaner Element
Change Chain Case Oil
Check Coolant
Change Hydraulic Tank Oil
Replace In-Line Hydrostatic Case Drain Filters—1 Speed Only
Section 3-9 - Maintenance—Every 6000 Hours
Drain Cooling System
Flush Cooling System
Fill Cooling System
Section 4-1 - Miscellaneous—Machine
Bleed Fuel System
Checking Radiator, Air Conditioning Condenser
Replacing Fan and Alternator Belt
Adjusting Auxiliary Hydraulic Linkage—Standard Controls (Hand-Foot Machines)
Adjusting Boom and Bucket Linkage—Standard Controls (Hands-Only Machines)
Adjusting Pedal Angle
Cleaning and Replacing Air Conditioner and Heater/Defroster Air Filters (If Equipped)
Checking Battery Electrolyte Level (Maintenance Type Batteries Only)
Using Battery Charger
Cleaning or Replacing Battery
Using Booster Batteries—12-Volt System
Replacing Fuses—Standard Controls
Replacing Fuses—EH Controls
Replacing Blower Motor Fuse
Replacing Glow Plug Fuse
Unified Inch Bolt and Cap Screw Torque Values
Metric Bolt and Cap Screw Torque Values
Section 4-2 - Miscellaneous—Operational Checkout
Section 4-3 - Miscellaneous—Troubleshooting
Troubleshooting Procedure
Section 4-4 - Miscellaneous—Storage
Prepare Machine for Storage
Monthly Storage Procedure
Section 4-5 - Miscellaneous—Machine Numbers
Record Product Identification Number (PIN)
Record Engine Serial Number
Record Hydrostatic Motor Serial Numbers
Keep Proof of Ownership
Keep Machines Secure
Section 4-6 - Miscellaneous—Specifications
325 Engine Specifications
328 Engine Specifications
Drain and Refill Capacities
325 Machine Dimensions
328 Machine Dimensions
325 and 328 Tire Options and Pressures
Pallet Fork Lift Chart
