Martin Welker
104
230,310
John Deere 316 318 420 Lawn And Garden Tractor Operators Manual OMM79655
Download this document, you need 200 Gallons
Brand: John Deere
Type of Machine: Lawn And Garden Tractor
Model: John Deere 316 318 420 Lawn And Garden Tractor
Serial Number: 010001-
Part Number: OMM79655
Number of Pages: 80 Pages
Safety
Controls
Operating the Engine
Starting the Engine
Warming Engine
Engine Idling
Stopping the Engine
Driving the Tractor
Driving the Tractor
Using 2-Speed Axle Shift Lever—420
Tractors Only
Operating Differential Lock—420 Tractors
Using Turn Brake Pedals—318 and 420
Tractors
Using reserve Fuel System—318 and 420
Tractors
Stopping Tractor
Emergency Stopping
Operating the Lights
Oil Pressure Indicator
Battery Discharge Indicator
Connecting Front Attachment Hydraulic
Hoses
Using Rear Weights
Rear Wheel Weights—Cast Iron
Rear Wheel Weights—Plastic Shell
Rear Weights for 3-Point Hitch
Rear Weights for Tractor Without 3-Point
Hitch
Using Front Weight
Liquid Weight
Maximum Weights
Adjusting Rear Wheel Spacing
Transporting
Fuels and Lubricants
Page
Troubleshooting
Tractor
Brakes
Steering
Service
Hour Meter
Removing and Installing Engine Shields
Service Intervals
Engine Break-In
Checking
Engine Oil Level
Transmission Oil Level
Air Cleaner Elements
Air Intake Screens
Safety Interlock System Checkout
Procedure
Changing Engine Oil
Checking Tire Pressure
Checking Gear Case Oil Level for Tractor
with 2000 RPM Rear PTO
Lubricating
Front Wheel Spindles
Brake Pedal Shaft
Power Steering Cylinder Ball Joint
Drive Shaft
Clean Engine Cooling Fins
Changing Engine Oil Filter
Cleaning and Gapping Spark Plugs
Changing Transmission Oil and Filter
Changing Air Cleaner Element
Checking Battery Electrolyte Level
Changing Fuel Filter
Adjusting Seat
Lubricating Ball Joints on Tractors With
3-Point Hitch
Replacing
Headlight Bulbs
Taillight Bulb
Indicator Light Bulb
Lighting Circuit Fuse
Adjusting Transmission Shift Lever
Storage
Assembly
Specifications
Index
