John Deere 313 315 CT315 Skid Steer Compact Track Loader Operation Test Manual TM10605
- Download this document, you need 1600 Gallons
Type of Manual: Operation Test Manual
Type of Machine: Skid Steer Compact Track Loader
Model: 313 315 CT315
Part Number: TM10605
Publication Date: 2015
Number of Pages: 398 pages
FOREWORD
TECHNICAL INFORMATION FEEDBACK FORM
Section 9000 - GENERAL INFORMATION
FOREWORD
Group 01 - Safety
Safety and Operator Convenience Features
Recognize Safety Information
Follow Safety Instructions
Operate Only If Qualified
Wear Protective Equipment
Avoid Unauthorized Machine Modifications
Inspect Machine
Stay Clear of Moving Parts
Avoid High-Pressure Fluids
Avoid High-Pressure Oils
Beware of Exhaust Fumes
Prevent Fires
Prevent Battery Explosions
Dispose of Waste Properly
Prepare for Emergencies
Start Only From Operator′s Seat
Use and Maintain Seat Belt
Prevent Unintended Machine Movement
Avoid Work Site Hazards
Keep Riders Off Machine
Avoid Backover Accidents
Avoid Machine Tip Over
Operating or Traveling On Public Roads
Add and Operate Attachments Safely
Park and Prepare for Service Safely
Service Cooling System Safely
Service Tires Safely
Make Welding Repairs Safely
Drive Metal Pins Safely
Section 9001 - DIAGNOSTICSGroup 10 - Engagement and Monitor Unit Diagnostic Trouble Codes
Engagement and Monitor Unit (EMU) Diagnostic Trouble Codes
Coolant Temperature Sensor Input at 0 Volts Diagnostic Procedure
Coolant Temperature Sensor Input at 5 Volts Diagnostic Procedure
Fuel Level Sensor Input at 5 Volts Diagnostic Procedure
Alternator Voltage Out of Range High Diagnostic Procedure
Hydraulic Oil Temperature Sensor Input at 0 Volts Diagnostic Procedure
Hydraulic Oil Temperature Sensor Input at 5 Volts Diagnostic Procedure
Park Brake Output Open or Shorted to Power Diagnostic Procedure
Park Brake Output Shorted to Ground Diagnostic Procedure
Hydraulic Output Open or Hydraulic Output Shorted to Power Diagnostic Procedure
Hydraulic Output Shorted to Ground Diagnostic Procedure
Glow Plug Relay Output Open or Shorted to Power Diagnostic Procedure
Glow Plug Relay Output Shorted to Ground Diagnostic Procedure
Auto Shutdown Relay Output Open or Shorted to Power Diagnostic Procedure
Auto Shutdown Relay Output Shorted to Ground Diagnostic Procedure
Engagement and Monitor Unit (EMU) Warning Alarm Output Shorted to Ground Diagnostic Procedure
Section 9005 - OPERATIONAL CHECKOUT PROCEDUREGroup 10 - Operational Checkout Procedure
Key Switch ON, Engine ON Checks
Section 9010 - ENGINEGroup 05 - Theory Of Operation
POWERTECH POWERTECH is a trademark of Deere & Company 2.4 L & 3.0 L (4024 & 5030) John Deere Engines
Group 15 - Diagnostic Information
POWERTECH™ 2.4 L & 3.0 L (4024 & 5030) John Deere Engines
Engine Cooling System Component Location
Engine Fuel System Component Location
Engine Intake and Exhaust Component Location
Group 25 - Tests
Engine Speed Test and Adjustment
Intake Manifold Pressure—Turbocharger Boost
Section 9015 - ELECTRICAL SYSTEMGroup 05 - System Information
Electrical Diagram Information
Electrical Schematic Symbols
Group 10 - System Diagrams
Fuse Specifications
System Functional Schematic, Wiring Diagram, and Component Location Master Legend
System Functional Schematic and Section Legend
Engine Harness (W1) Component Location
Engine Harness (W1) Wiring Diagram
Cab Harness—Standard (W2) Component Location
Cab Harness—Standard (W2) Wiring Diagram
Front Chassis Harness—Standard (W3) Component Location
Front Chassis Harness—Standard (W3) Wiring Diagram
Backup Alarm Harness (W4) Component Location
Backup Alarm Harness (W4) Wiring Diagram
Dual Flasher Harness (W5) Component Location
Dual Flasher Harness (W5) Wiring Diagram
Horn Harness (W6) Component Location
Horn Harness (W6) Wiring Diagram
Heater Harness (W7) Component Location
Heater Harness (W7) Wiring Diagram
Wiper Harness (W8) Component Location
Wiper Harness (W8) Wiring Diagram
12 Volt Auxiliary Power Harness (W9) Component Location
12 Volt Auxiliary Power Harness (W9) Wiring Diagram
Beacon Harness (W10) Component Location
Beacon Harness (W10) Wiring Diagram
Cab Harness—Deluxe (W12) Component Location
Cab Harness—Deluxe (W12) Wiring Diagram
Front Chassis Harness—Deluxe (W13) Component Location
Front Chassis Harness—Deluxe (W13) Wiring Diagram
8-Button Controller Harness (W15) Component Location
8-Button Controller Harness (W15) Wiring Diagram
Operator Convenience Package (W19) Component Location
Operator Convenience Package (W19) Wiring Diagram
Electric Quik-Tatch (W28) Component Location
Electric Quik-Tatch (W28) Wiring Diagram
Water-in-Fuel Indicator Harness (W37) and Water-in-Fuel Sensor Harness (W38) Component Location—If Equipped
Water-in-Fuel Indicator Harness (W37) Wiring Diagram—If Equipped
Water-in-Fuel Sensor Harness (W38) Wiring Diagram—If Equipped
License Plate Light Harness (W39) Component Location—If Equipped
License Plate Light Harness (W39) Wiring Diagram—If Equipped
Front Chassis Harness—Compact Track Loader (W40) Component Location
Front Chassis Harness—Compact Track Loader (W40) Wiring Diagram
Wiper Motor Harness (W41) Wiring Diagram
Wiper Motor Harness (W41) Component Location
Group 15 - Sub-System Diagnostics
Starting Circuit Theory of Operation
Engagement and Monitor Unit (EMU) Circuit Theory of Operation
Backup Alarm Circuit Theory of Operation
Electric Quik-Tatch Theory of Operation—If Equipped
Group 20 - References
Engagement and Monitor Unit Operation
Anti-Theft Security System Operation—If Equipped
Engagement and Monitor Unit Data Items
Reading Engagement and Monitor Unit Diagnostic Trouble Codes
Electrical Component Specifications
Fuse Test
Relay Test
Alternator Test
Solenoid Observable Symptom Check
Temperature Sensor Test
Electrical Component Checks
Battery Remove and Install
Instrument Panel, Engagement and Monitor Unit, and Key Switch Remove and Install
Engagement and Monitor Unit Initial Configuration
Backup Alarm Remove and Install
Replace (Pull Type) Metri-Pack™ Connectors
Replace (Push Type) Metri-Pack™ Connectors
Replace WEATHER PACK WEATHER PACK is a trademark of Packard Electric. Connector
Install WEATHER PACK WEATHER PACK is a trademark of Packard Electric. Contact
Replace DEUTSCH DEUTSCH is a trademark of Deutsch Co. Rectangular or Triangular Connectors
Replace DEUTSCH DEUTSCH is a trademark of the Deutsch Co. Connectors
Install DEUTSCH DEUTSCH is a trademark of the Deutsch Co. Contact
Section 9020 - POWER TRAINGroup 05 - Theory Of Operation
Power Train System Operation—Skid Steer Loader
Chain Case Operation
Drive Chain Operation
Drive Axle Operation
Power Train System Operation—Compact Track Loader
Hydrostatic Motor Gearbox Operation
Track Adjuster and Recoil Spring Operation
Diagnose Power Train Component Malfunctions—Skid Steer Loader
Oil Leak From Power Train Diagnostic Procedure
Excessive Axle Play Diagnostic Procedure
Drive Chain Noise Diagnostic Procedure
Grinding Noise Diagnostic Procedure
One Drive Wheel Not Powered Diagnostic Procedure
Both Wheels On One Side Not Powered
Diagnose Power Train Component Malfunctions—Compact Track Loader
Loose Track Diagnostic Procedure
Tight Track Diagnostic Procedure
Frequent Track Sag Adjustment Diagnostic Procedure
Excessive Oil Leakage From Idlers And Rollers Diagnostic Procedure
‘Popping” Of Track Diagnostic Procedure
Individual Undercarriage Component Wear Diagnostic Procedure
Group 25 - Tests
Drive Chain Tension Check and Adjustment
Check and Adjust Track Sag
Section 9025 - HYDRAULIC SYSTEMGroup 05 - Theory Of Operation
Hydraulic System Operation
Hydraulic Oil Filter and Park Brake Solenoid Valve Manifold Operation—Skid Steer Loader
Hydraulic Oil Filter Manifold Operation—Compact Track Loader
High Flow Hydraulic Pump Operation
Self-Level Valve Operation
Counterbalance Valve Operation—Skid Steer Loader
Control Valve Operation
Hydraulic System Circuit Symbols
Hydraulic System Schematic—Skid Steer Loader
Hydraulic System Schematic—Compact Track Loader
Diagnose Hydraulic System Malfunctions
No Hydraulic Functions Diagnostic Procedure
Boom Will Not Raise Diagnostic Procedure
Boom Will Not Lower Diagnostic Procedure
Bucket Will Not Dump Diagnostic Procedure
Bucket Will Not Roll Back Diagnostic Procedure
Bucket Will Not Self-Level When Boom Is Raised Diagnostic Procedure
Bucket Dumps During Self-Leveling Cycle Diagnostic Procedure
Boom Drifts Down Diagnostic Procedure
Boom Drifts Up Diagnostic Procedure
Bucket Drifts Down Diagnostic Procedure
Bucket Drifts Up Diagnostic Procedure
Hydraulic Functions Slow Or No Power Diagnostic Procedure
Hydraulic Functions ‘Jerky” Or ‘Spongy” Diagnostic Procedure
Hydraulic System Noise Diagnostic Procedure
Pedals Will Not Move Diagnostic Procedure
Hydraulic Oil Overheats Diagnostic Procedure
Group 25 - Tests
JT05800 Digital Thermometer Installation
JT02156A Digital Pressure/Temperature Analyzer Installation
Remote Start Box Installation
Hydraulic System Pressure Release
Hydraulic System Pressure Release Cable Adjustment
Port Lock Solenoid Valve and Port Lock Spool Test
Boom and Bucket Spool Lock Solenoid Test
System Relief Valve Test
Charge Pressure Relief Valve Test
Circuit Relief Valve Test
Hydraulic Pump Flow Test
Section 9026 - HYDROSTATIC SYSTEMGroup 05 - Theory Of Operation
Hydrostatic System Operation
Hydrostatic Pump Operation
Hydrostatic Motor Operation—Skid Steer Loader
Hydrostatic Motor Operation—Compact Track Loader
Park Brake Solenoid Valve Manifold Operation—Compact Track Loader
Park Brake System Operation
Steering Control Operation
Diagnose Hydrostatic System Malfunctions
Machine Does Not Move In Either Direction Diagnostic Procedure
Hydrostatic Pump Or Hydrostatic Motor Noise Diagnostic Procedure
Slow Response To Changes In Speed Diagnostic Procedure
Low Power Diagnostic Procedure
Wheels Powered On One Side, Not The Other Diagnostic Procedure
Machine Creeps With Steering Levers In Neutral Diagnostic Procedure
Hydrostatic System Noise While In Neutral Diagnostic Procedure
Steering Levers Hard To Move Diagnostic Procedure
Steering Levers Feel Loose Or ‘Sloppy” Diagnostic Procedure
Machine Tracks To One Side With Steering Levers In Full Forward Or Reverse Position Diagnostic Procedure
Steering Levers Pulse Or Vibrate Excessively Diagnostic Procedure
Park Brake Does Not Hold Diagnostic Procedure
Park Brakes Do Not Release Diagnostic Procedure
Grinding Noise While Operating Machine Diagnostic Procedure
Group 25 - Tests
Hydrostatic Pump System Pressure Relief Test
Hydrostatic Pump Case Drain Test
Wheel Speed Test and Tracking Adjustment—Skid Steer Loader
Track Speed Test and Tracking Adjustment—Compact Track Loader
Hydrostatic Pump Flow Test
Centering Plate Adjustment—Skid Steer Loader
Centering Plate Adjustment—Compact Track Loader
Steering Lever Adjustment
Auxiliary Hydraulic Control Handle Adjustment
Hydraulic Control Handle Adjustment—Hands Only Machine
Park Brake Release Pressure Test
Section 9031 - HEATING SYSTEMGroup 05 - Theory Of Operation
Heater Blower Circuit Theory Of Operation
Temperature Control Theory of Operation
Heater Core Theory of Operation
Heater System Component Location
Heater System Diagnostic Information
Heater System Does Not Operate Diagnostic Procedure
Heater Does Not Warm Interior of Cab Diagnostic Procedure
Interior Windows Continue to Fog Diagnostic Procedure
Group 25 - Tests
Visual Inspection Of Components
Blower Switch Test
Blower Motor Resistor Test
Heater Blower Motor Test
- JOHN DEERE CODE DTC LIST
