Martin Welker
104
230,310
John Deere 310G Backhoe Loader Operators Manual OMT166698
Format: HTML
Brand: John Deere
Model: John Deere 310G Backhoe Loader
Serial Number: -910055
Parts Number: OMT166698
Foreword
310G
Technical Information Feedback Form
Section 05OM Safety and Operator Conveniences
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Avoid Injury From Rollover Accidents
Wear Your Seat Belt
Do Not Attempt to Jump Clear of Tipping Machine—Serious or Fatal Crushing Injuries Will Result
Machine Will Tip Over Faster Than You Can Jump Free
Avoid Injury From Backover Accidents
Before Moving Machine, Be Sure All Persons Are Clear of Area
Always Be Alert For Bystanders Moving Into the Work Area. Use Horn or Other Signal to Warn Bystanders Before Moving Machine
When Using a Signal Person, Keep Person in View At All Times. Be Sure Signal Person is Clear Before Backing Up
Avoid Injury From Rollaway Accidents
To Prevent Rollaway, Always Make Sure Machine Is Properly Secured Before Leaving Operator’s Seat
Death or Serious Injury May Result If You Attempt to Mount or Stop a Moving Machine
Inspect Machine
Use Handholds and Steps
Prevent Machine Runaway
Use Seat Belt Properly
Maintain Seat Belt
Secondary Exits
Drive Machine Safely
Travel Safely
Operate Backhoe Safely
Avoid Power Lines
Work In Ventilated Area
Keep Riders Off Machine
Handle Fuel Safely—Avoid Fires
Prepare for Emergencies
Handle Starting Fluid Safely
Clean Trash from Machine
Protect Against Flying Debris
Wear Protective Clothing
Protect Against Noise
Use Safety Lights and Devices
Keep ROPS Installed Properly
Warn Others of Service Work
Practice Safe Maintenance
Avoid HighPressure Fluids
Clean the Machine Regularly
Service Cooling System Safely
Store Attachments Safely
Dispose of Waste Properly
Section 06OM Safety Signs
Safety Signs
Section 10OM Operator’s Station
Monitor and Gauge Panel
Engine Coolant Temperature Gauge
Transmission and Torque Converter Oil Temperature Gauge
Fuel Level Gauge
STOP Indicator and Alarm
Engine Oil Pressure Indicator
Alternator Voltage Indicator
Engine Air Filter Restriction Indicator
Seat Belt Indicator
Park Brake Indicator
Hydraulic Oil Filter Restriction Indicator
Controls—RightSide Console
Park Brake Switch
Mechanical Front Wheel Drive (MFWD) Switch and Indicator—If Equipped
Ride Control Switch and Indicator—If Equipped
Air Suspension Seat Height Adjustment Switch—If Equipped
Backhoe Auxiliary Hydraulic Function Switch—If Equipped
Horn Button
Defroster, Heater, and Air Conditioner Controls—If Equipped
Controls—Steering Console
Lights
Windshield Wipers and Washer Reservoir—If Equipped
Adjusting Seat
Seat Belt
Seat Belt
Side Windows—Secondary Exits—Cab Machines
Rear Windows—Cab Machines
Dome Light and Radio—If Equipped
12Volt Accessory Outlets
Toolbox
Steering Wheel Tilt Lever—If Equipped
Operational Controls
Front Loader Controls
Stabilizer Control Levers
Backhoe Controls—John Deere TwoLever Style
Backhoe Controls—ISO Excavator TwoLever Style
Backhoe Controls—CASE® ThreeLever Style
Backhoe Controls—FORD® FourLever Style
Backhoe Auxiliary Hydraulic Function Controls—If Equipped
Boom Lock Control
Swing Locking Pin
Extendible Dipperstick Locking Pin—If Equipped
Document Holders
Section 20OM PreStart Inspection
Inspect Machine Daily Before Starting
Section 25OM Operating the Engine
Check Instruments Before Starting
Starting the Engine—With Manual Shift Transmission
Starting Fluid—Cold Weather Start Aid—If Equipped
Using Booster Batteries—12 Volt System
Using Coolant Heater—If Equipped
Check Instruments After Starting
WarmUp
Cold Weather WarmUp
Stalled Engine
Stopping the Engine—Normal Shutdown With Manual Shift Transmission
Section 30OM Driving the Machine
Driving on Public Roads
Ride Control Operation—If Equipped
Driving the Machine—With Manual Shift Transmission
Ground Speeds—310G
Parking the Machine
Section 35OM Operating the Machine
Preparing to Operate Backhoe
Backhoe Valve Linkage Adjustment
Operating Stabilizers
Operating Boom Lock
Operating Swing Lock
Operating Extendible Dipperstick Lock—If Equipped
Operating Backhoe—John Deere TwoLever Controls
Operating Backhoe—ISO Excavator TwoLever Controls
Operating Backhoe—CASE ThreeLever Controls
Operating Backhoe—FORD FourLever Controls
Operating Extendible Dipperstick—If Equipped
Operating Backhoe Auxiliary Hydraulic Functions—If Equipped
Adjust Auxiliary Flow Control Valve—If Equipped
Backhoe Transport and Storage Position
Operating Front Loader
Adjusting Loader Bucket SelfLeveling Linkage and ReturntoDig Switch
Changing Loader Buckets
Operating Differential Lock
Operating Mechanical Front Wheel Drive (MFWD)—If Equipped
Reversing Stabilizer Feet
Adding Front Counterweights
Adding Liquid Ballast to Front Tires—310G
Operating Tips
Work at Proper Angles
Operating on a Slope
Positioning Spoil Piles
Leveling Machine
Moving With Backhoe
Using Backhoe Bucket
Using a Sight Gauge for Trenching
Trenching
Operating Extendible Dipperstick With Attachments
Using Loader Bucket
Excavating With Front Bucket
Dozing and Plowing
Excavating Banks or Stockpiles
Backdragging
Backfilling
Truck Loading
Benching
Lifting
Universal Bucket Couplers and Bucket Options
Section 40OM Transporting
Loading and Unloading Machine on a Trailer
Towing
Section 45OM Fuels and Lubricants
Diesel Fuel
Low Sulfur Diesel Fuel Conditioner
Diesel Fuel Storage
Diesel Engine Oil — NonEmissions Certified and Certified Tier 1 and Stage I
Transmission, Axles and Mechanical Front Wheel Drive Oil
Hydraulic Oil
Multipurpose Extreme Pressure (EP) Grease
Grease For Extendible Dipperstick, Sideshift Frame, And Stabilizer Leg Wear Strips
Lubricant Storage
Mixing of Lubricants
Section 50OM Periodic Maintenance
Attach Do Not Operate Tag
Service Your Machine at Specified Intervals
Check Hour Meter Regularly
Avoid Mud BuildUp
Use Correct Fuels and Lubricants
Prepare Machine for Maintenance
Loader Boom Service Lock
Opening and Closing Engine Hood
OILSCAN PLUS®, COOLSCAN PLUS®, Dieselscan, and 3Way Coolant Test Kit
Maintenance and Repair Record Keeping System
Section 55OM Maintenance—As Required
Inspect Belt
Check Tire Pressure
Tire Inflation Pressures
Checking Wheel Fasteners
Inspect Loader Boom Service Lock
Check and Adjust Boom Lock
Clean or Replace Cab Air Filters—If Equipped
Inspect and Clean Hydraulic Reservoir Fill Screen
Drain Fuel Tank Water and Sediment
Lubricate MFWD Drive Shaft Splines—If Equipped
Lubricate Extendible Dipperstick Side Rails—If Equipped
Lubricate Front Wheel Bearings—NonPowered
Section 60OM Maintenance—Every 10 Hours or Daily
Check Engine Oil Level
Lubricate Loader Pivots
Lubricate 4in1 Bucket Pivots—If Equipped
Lubricate Stabilizer Pivots and Cylinder Pins
Lubricate Backhoe Linkage, Pivots, and Cylinder Rod Ends
Lubricate NonPowered Front Axle and Steering Pivots
Lubricate MFWD Front Axle and Universal Joints—If Equipped
Section 65OM Maintenance—Weekly
Check Coolant Level
Section 75OM Maintenance—Every 250 Hours
Check MFWD Axle Oil Level—If Equipped
Check Battery Electrolyte Level and Terminals
Check Rear Axle Oil Level
Checking Hydraulic Reservoir Oil Level
Change Engine Oil and Replace Filter
Check Transmission Oil Level
Check MFWD Planetary Housing Oil—If Equipped
Section 80OM Maintenance—Every 500 Hours
Check Air Intake Hose
Replace Hydraulic Oil Filter
Check BoomtoDipperstick Pin Bolt Torque
Replace Hydraulic Reservoir Breather
Replace Fuel Filter
Check Coolant and Add Conditioner
Section 85OM Maintenance—Every 1000 Hours
Change MFWD Front Axle Housing Oil—If Equipped
Change MFWD Front Wheel Planetary Housing Oil—If Equipped
Clean, Pack, and Adjust Front Wheel Bearings—NonPowered
Check Engine Speeds
Check and Adjust Engine Speed Control Linkage
Change Rear Axle Oil
Change Transmission Oil Filter
Change Hydraulic Reservoir Oil
Clean Engine Crankcase Ventilation Tube
Change Transmission and Torque Converter Oil and Filter
Replace Engine Air Cleaner Elements
Section 86OM Maintenance—Every 2000 Hours
Adjust Engine Valve Lash (Clearance)
Section 90OM Maintenance
External Service Brake Inspection
Clean Engine Air Cleaner Dust Unloader Valve
Inspect Air Cleaner Elements
Clean Air Cleaner Primary Element
Check ReceiverDryer—If Equipped
Test the Coolant FreezeProtection Level
Servicing the Cooling System
Checking Coolant Hoses and Radiator
Draining the Cooling System
Diesel Engine Coolant (engine with wet sleeve cylinder liners)
Filling the Cooling System
Do Not Service Injection Nozzles
Do Not Adjust Injection Pump
Replace Engine Crankshaft Dampener
Draining Fuel Filter Sediment
Precautions for Alternator and Regulator
Prevent Acid Burns
Handling Batteries Safely
Service Batteries Carefully
Checking Electrolyte Specific Gravity
Using Battery Charger
Replacing Batteries
Removing Batteries
Replacing Fuses
Remove and Install Halogen Bulb
Changing Reverse Warning Alarm Volume
Checking Neutral Start System
Adding Attachments/Accessories to RollOver Protective Structure (ROPS)
Welding on Machine
Checking Ride Control Accumulator—If Equipped
Discharge Ride Control System Hydraulic Pressure—If Equipped
Check Park Brake
Checking Machine Cycle Times—310G
Brake Bleeding Procedure
Service Recommendations For STC® Fittings
Adjusting Speed Control Lever Tension
Checking and Adjusting ToeIn
Installing Teeth on Backhoe Bucket
Do Not Service Control Valves, Cylinders, Pumps or Motors
Hardware Torque Specifications
Service Recommendations for Metric Series Four Bolt Flange Fitting
Additional Metric Cap Screw Torque Values
Check Oil Lines And Fittings
Service Recommendations for ORing Boss Fittings
Service Recommendations For Flat Face ORing Seal Fittings
Service Recommendations For Inch Series Four Bolt Flange Fittings
Section 95OM Operational Checkout
Operational Checkout Procedure
Section 100OM Troubleshooting
Troubleshooting Procedure
Gauges and Indicators
MFWD
Rear Axle
Section 105OM Storage
Prepare Machine for Storage
Monthly Storage Procedure
Section 110OM Crime Prevention Tips
Help Prevent Crime
Record Construction Identification Numbers
Keep Proof of Ownership
Park Indoors Out of Sight
When Parking Outdoors
Reduce Vandalism
Report Thefts Immediately
Section 115OM Specifications
310G Specifications
310G Backhoe Loader
310G Backhoe Loader
Other Information—310G Backhoe Loader
310G Backhoe Loader Weight
Buckets
310G Backhoe Loader Drain and Refill Capacities
310G Backhoe Loader Lifting Capacities—Standard Dipperstick
310G Backhoe Loader Lifting Capacities—Extendible Dipperstick (Retracted)
310G Backhoe Loader Lifting Capacities—Extendible Dipperstick (Extended)
Section 120OM Machine Numbers
Record Product Identification Number (PIN)
Record Engine Serial Number
Record Transmission Serial Number—Manual Shift
Record Rear Axle Housing Serial Number
Record (MFWD) Front Axle Housing Serial Number—If Equipped
Section CLISOM Checklists
Section SLITOM John Deere Service Literature
Section IBCOM John Deere Service Keeps You On the Job
AT YOUR SERVICE WHEN YOU NEED IT
