John Deere 3100 3200 3300 3400 Tractors Operators Manual RT6005012380
- Download this document, you need 200 Gallons
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 3100 3200 3300 3400 Tractors
Part Number: RT6005012380
Number of Pages: 181 Pages
Identification Views
Safety
Safety Decals
Controls and Instruments
Dash panel
Operator’s station
Cab roof controls
Indicator lights
Instruments
Lights
Operator’s Cab/Platform
Roll-over protective structure
Operator’s seat
Passenger seat
Opening the doors and windows
Windshield wiper
Rear view mirrors
Heating and ventilation
Radio
Break-In Period
After the first 4 and 8 hours of operation
After the first 30 hours of operation
Within the first 100 hours of operation
After the first 100 hours of operation
After the first 250 hours of operation
Prestarting Checks
Operating the Engine
Starting the engine
Cold-weather starting aids
Booster battery
Engine warm-up period
Page
Parking the tractor
Towing the tractor
Operating the Tractor
Reduce fuel consumption
Warning concerning steering
Transmission controls
Transmission types
Changing gears
Changing ranges
Shifting gears from neutral
Reverse drive lever
Splitter
Front-wheel drive axle
Differential lock
Brakes
Ground travel speed
3100 and 3200
3300 and 3400
Rockshaft and Three-Point Hitch
Rockshaft control
Remote control
Position control
Load control
Mixed control
Float position
Three-point hitch
Center link adjustment
Lift links
Draft links
Stabilizers
Hitch configuration
Power Take-Off
PTO guard
Operating the rear PTO
Speed selector
Attaching PTO-driven equipment
Operating from stationary position
Front PTO
Ballast
Selecting ballast
Measuring rear wheel slip
Filling tires with liquid ballast
Front weights
Rear wheel weights
Wheel Tread, Tires
Tire maintenance
Tire pressures
Tire combinations with front-wheel drive
Front wheel tread adjustment
Without FWD axle
With FWD axle
Steering stops
Adjusting rear wheel tread
Dual rear wheels
Additional Equipment
Selective control valves
Couplers
Maximum permissible oil withdrawal
Hitches
Power outlet socket for electrical
equipment
Transport
Driving on public roads
Towing loads
Towing the tractor
Trailer brakes
Fuel, Lubricants, Hydraulic Oil and Coolant
Fuel
Engine oil
Transmission/hydraulic oil
FWD axle oil
Grease
Engine coolant
Lubrication and Periodic Service
Removing the side panels
Access to battery
Access to fuses
Service during break-in period
Page
Service intervals
Service - Daily or Every 10 Hours
Engine crankcase oil level
Fuel filter
Transmission/hydraulic oil level
Coolant level
Cleaning the dust unloading valve
Checking the lights
Service - Every 50 Hours
Lubricating the FWD axle
Checking oil level in front PTO housing
Service - Every 250 Hours
Changing engine oil
Replacing engine oil filter
Checking tension on alternator belt
Replacing the transmission oil filter
element
Bleeding the transmission/hydraulic circuit
Vehicle clutch — free travel at pedal
PTO clutch — free travel at lever
Lubricating the brakes
Checking hardware at front of tractor
Lubricating the front axle (not FWD)
Oil level at FWD axle housing
Oil level in final drives (FWD axle)
Lubricating the three-point hitch
Lubricating the pick-up hitch
Changing oil in front PTO
Service - Every 500 Hours
Replacing the fuel filter
Air intake hoses
Replacing the intake screen
Replacing the breather in the
Check free travel at brake pedals
Service - Every 750 Hours
Checking engine speeds
Replacing the cab air filter
Important note on transmission/hydraulic
oil
Changing the transmission/hydraulic oil
Service - Every 1000 Hours
Changing oil in FWD axle housing
Changing oil in final drives of FWD axle
Service - Every 1500 Hours or 2 Years
Replacing the coolant
Service - As Required
Air cleaner (engine)
Cleaning the front and side grilles
Cleaning the radiator
Battery service
Bleeding the fuel circuit
Cleaning the cab air filter
Lubricating points
Starting motor
Fuses
Replacing bulbs
Troubleshooting
Hydraulic circuit
Electrical system
Storage
Storage over lengthy period
Removing tractor from storage
Specifications
PTO power output
Hydraulic circuit
Electrical system
Capacities
Dimensions and weights
Tractors without FWD axle
Tractors with FWD axle
Sound level
Weights
Load capacity of tires
Serial Numbers
Lubrication and Maintenance Records
Index
Brand: John Deere
Safety
Safety Decals
Dash panel
Operator’s station
Cab roof controls
Indicator lights
Instruments
Lights
Operator’s seat
Passenger seat
Windshield wiper
Rear view mirrors
Radio
Break-In Period
Prestarting Checks
Starting the engine
Booster battery
Page
Parking the tractor
Towing the tractor
Transmission types
Changing gears
Changing ranges
Reverse drive lever
Splitter
Differential lock
Brakes
Ground travel speed
3100 and 3200
3300 and 3400
Rockshaft control
Remote control
Position control
Load control
Mixed control
Float position
Three-point hitch
Lift links
Draft links
Stabilizers
Hitch configuration
Power Take-Off
PTO guard
Speed selector
Front PTO
Ballast
Selecting ballast
Front weights
Rear wheel weights
Wheel Tread, Tires
Tire maintenance
Tire pressures
Without FWD axle
With FWD axle
Steering stops
Dual rear wheels
Couplers
Hitches
equipment
Transport
Towing loads
Towing the tractor
Trailer brakes
Fuel
Engine oil
FWD axle oil
Grease
Engine coolant
Access to battery
Access to fuses
Page
Service intervals
Fuel filter
Coolant level
Checking the lights
Changing engine oil
element
Air intake hoses
oil
Battery service
Lubricating points
Starting motor
Fuses
Replacing bulbs
Troubleshooting
Hydraulic circuit
Electrical system
Storage
Specifications
PTO power output
Hydraulic circuit
Electrical system
Capacities
Sound level
Weights
Serial Numbers
Index
- JOHN DEERE CODE DTC LIST
