Martin Welker
104
230,310
John Deere 3033R 3039R 3046R Tractors Operation Manual OMTR130108
Download this document, you need 200 Gallons
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 3033R 3039R 3046R Tractors
Serial Number: NP000001-
Part Number: OMTR130108
Number of Pages: 184 Pages
Introduction
Foreword
Product View
Trademarks
Glossary of Terms
Regions and Country Versions
Machine Overview
Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Prepare for Emergencies
Wear Protective Clothing
Protect Against Noise
Handle Fuel Safely—Avoid Fires
Handle Starting Fluid Safely
Fire Prevention
In Case of Fire
Avoid Static Electricity Risk When Refueling
Keep ROPS Installed Properly
Use Foldable ROPS and Seat Belt Properly
Stay Clear of Rotating Drivelines
Read Operators’s Manuals for ISOBUS Controllers
Use Seat Belt Properly
Operating the Tractor Safely
Avoid Backover Accidents
Limited Use in Forestry Operation
Operating the Loader Tractor Safely
Keep Riders Off Machine
Instructional Seat
Use Safety Lights and Devices
Use a Safety Chain
Transport Towed Equipment at Safe Speeds
Use Caution on Slopes, Uneven Terrain, and Rough Ground
Freeing a Mired Machine
Avoid Contact with Agricultural Chemicals
Handling Batteries Safely
Handle Electronic Components and Brackets Safely
Practice Safe Maintenance
Avoid Hot Exhaust
Clean Exhaust Filter Safely
Work In Ventilated Area
Support Machine Properly
Prevent Machine Runaway
Park Machine Safely
Transport Tractor Safely
Service Cooling System Safely
Service Tires Safely
Service Front-Wheel Drive Tractor Safely
Tightening Wheel Retaining Bolts/Nuts
Avoid High-Pressure Fluids
Do Not Open High-Pressure Fuel System
Store Attachments Safely
Safety Signs
Replace Safety Signs
Starter
PTO Shield
Operators Manual - OOS
Folding ROPS
Canopy or Sunshade
Engine Coolant Heater
Use Seat Belt Properly - Cab
Operators Manual - Cab
Controls and Instruments
Operators Station Controls—OOS
Operators Station Controls—Cab
Floor Panel Operation—OOS
Floor Panel Operation—Cab
HVAC Controls
Instrument Cluster
Information Display Icons
Information Display and Display Mode Switch
Engine Operation
Use Key Switch
Use Throttle
Use eThrottle
Use Fuel Shut off Valve
Start the Engine - Hydrostatic Transmission
Start the Engine—PowrReverser Transmission
Stop Machine
Air Intake, Fuel, Coolant, and Exhaust Operation
Using Fuel Shutoff Valve
Fill Fuel Tank
Exhaust Filter System Overview
Aftertreatment Indicators Overview
Electrical and Lighting Operation
Use Lights and Turn Signals
Use Dome Light
Use Display Mode Switch
Drivetrain Operation
Drive Machine—Hydrostatic Transmission
Drive Machine—PowrReverser Transmission
Transmission Operation
Operate Hydrostatic Transmission
Operate PowrReverser Transmission
Use Cruise Control—If Equipped
Use LoadMatch
Use SpeedMatch
Use MotionMatch
MFWD and Front Axle Operation
Use Mechanical Front Wheel Drive (MFWD)
Differential and Rear Axle Operation
Use Differential Lock (Traction Assist)
PTO Operation
Use the PTO Safely
Use Rear and Mid PTO (Operators on Seat)
Use Rear PTO (Operators off Seat)
Steering and Brake Operation
Use Brake Pedals
Use Park Brake
Adjust Tilt Steering Wheel
Hydraulics Operation
Warm Hydraulic System Oil
Hydraulics Information
Hitch and Drawbar Operation
Use Attachments
Use 3-Point Hitch
Use Drawbar Hitch (If Equipped)
Use Optional iMatch Quick-Attach Hitch System
Use Front 3-Point Hitch (If equipped)
SCV Operation
Connect Implement Hydraulic Hoses
Use Dual SCV Lever
Use Dual SCV Lock Lever
Use Third SCV
Use Fourth and Fifth SCV (If Equipped)
Use Diverter Rear Outlets (If Equipped)
Wheels and Tires Operation
Tire Combinations
Ballast
Ballast Machine
Implement Codes
Use Optional Rear Cast Iron Wheel Weights
Use Optional Rear Ballast Box
Use Liquid Weight in Tires
Use Optional Front Weights
Additional Equipment Operation
Operators Station Operation
Entering and Exiting Machine
Adjust Seat
Use Seat Belt
Raising and Lowering Roll-Over Protective Structure (ROPS)
HVAC Temperature Control—Cab
Using Windshield Wiper and Washer—Cab
Defrost Windshield and Side Glass—Cab
Using Radio—Cab
Using Rear Window—Cab
Transport and Storage
Transport Machine on Trailer
Transport Machine
Push or Tow Machine
Store Safety
Prepare Machine for Storage
Prepare Fuel and Engine For Storage
Remove Machine from Storage
Maintenance Intervals
Service Machine
Maintenance Interval Chart—Daily to Every 400 Hours
Maintenance Interval Chart—Every 600 Hours to Every 6000 Hours
Test Safety Systems
Test the Neutral Start Switch (PowrReverser Only)
Test the Seat Switch
Avoid Damage to Plastic and Painted Surfaces
Clean Plastic Surfaces
Clean and Repair Metal Surfaces
Fuel, Lubricants, and Coolant
Carbon Dioxide Emissions (CO₂)
Emissions Performance and Tampering
Diesel Fuel
Testing Diesel Fuel
Minimizing the Effect of Cold Weather on Diesel Engines
Engine Oil
Diesel Engine Coolant
Operating in Warm Temperature Climates
Additional Information About Diesel Engine Coolants and John Deere COOL-GARD™ II Coolant Extender
Testing Diesel Engine Coolant
Testing Coolant Freeze Point
Transmission and Hydraulic Oil
Front Axle and MFWD Oil
Grease
Maintenance—As Required
Service—As Required
Controls and Instruments Maintenance
Engine Maintenance
Required Emission-Related Information
Daily Operation Checklist
Exhaust Filter Maintenance and Service
Avoid Fumes
Check Engine Oil Level
Change Engine Oil and Filter
Clean Dust Unloading Valve
Service the Alternator Belt
Clean Front Grille Screens
Air, Fuel, Coolant and Exhaust Maintenance
Service Air Filter Elements
Check Air Filter Intake Hose
Automatic (AUTO) Exhaust Filter Cleaning
Disabled Exhaust Filter Cleaning
Parked Exhaust Filter Cleaning
Service Exhaust Filter Cleaning
Check and Clean Fuel Filter Sediment Bowl and Replace Filter
Fuel Injection Pump
Fuel Injection Nozzles
Check Radiator Hoses and Clamps
Clean Radiator Cooling Fins
Service the Air Conditioner Belt—Cab
Clean Hood Vents
Service Air Conditioner
Clean Cab Air Filter
Electrical and Lighting Maintenance
Service Electrical
Service the Battery Safely
Remove and Install Battery
Clean Battery and Terminals
Use Booster Battery
Replace Headlight Bulbs
Replace Tail Light, Turn Signal Light, and Warning Light Bulbs
Replace Light Bulbs (Tractor with Cab)
Replace Fuses and Relays
Drivetrain Maintenance
Transmission Maintenance
Check Transmission Oil Level
Change Transmission Oil and Hydraulic Suction Oil Filter
MFWD and Front Axle Maintenance
Check Front Axle Oil Level
Change Front Axle Oil
Adjust Front Axle Thrust Bolt Torque
Lubricate Axle Trunnion
Differential and Rear Axle Maintenance
Rear Axle
PTO Maintenance
PTO Maintenance
Steering and Brake Maintenance
Check and Adjust Toe-In
Steering Maintenance
Lubricate Brake Linkage
Brake Maintenance
Hydraulics Maintenance
Hydraulic Maintenance
Hitch and Drawbar Maintenance
Lubricate 3-Point Hitch
Lubricate Front Hitch
SCV Maintenance
Check SCV
Wheels and Tires Maintenance
Check Wheel Bolts and Hardware
Remove and Install Wheels
Check Tire Pressure
Tire Inflation Pressures (Maximum)
Select Front Tire Rolling Direction
Change Wheel Spacing and Tread Width
Lifting Points for Jacking up the Tractor
Ballast Maintenance
Match Ballast to Work Load
Additional Equipment Maintenance
Operators Station Maintenance
Raise and Lower Hood
Remove and Install Side Panels
Hood Cowl Removal and Installation
Checking Cab Roll-Over Protection System Installation
Troubleshooting
Use Troubleshooting Chart
Heater and Air Conditioning System
Machine
Brakes
Steering
On Board Diagnostics
Service Alert and Information Display
On Board Diagnostic Display
On-Board Diagnostic (OBD) Tool
Diagnostic Trouble Code (DTC)
Come Home Mode
Specifications
How to Calculate Maximum Permissible Download on Trailer Hitch
How to Calculate Permissible Mass
Drivetrain
Fluid Capacities
Ground Speeds
Dimensions
Track Width
Height From Ground
Ground Clearance
Turning Radius
Weight
3-Point Hitch
Identification Numbers
Product Identification Information
Record Identification Numbers
Certification and Warranty
Product Warranty
Emission System Warranty
Tire Warranty
Limited Battery Warranty
Service Records
After first 10 Hours
Every 10 Hours or Daily
Every 50 Hour Service
Every 100 Hour Service
Every 200 Hour Service or Annually
Every 400 Hour Service
Every 600 Hour Service
Annually
Every 1000 Hour Service
Every 2000 Hour Service or Every Two Years
Every 6000 Hour Service or Every Six Years
Change of Ownership
Change of Ownership
Change of Ownership
Index
John Deere Service
John Deere Is At Your Service
Technical Information
