Martin Welker
104
230,310
John Deere 3020 Tractor Technical Manual TM1005
Brand: John Deere
Type of Manual: Technical Manual
Model: John Deere 3020 Tractor
Serial Number: 123000-
Part Number: TM1005
Number of Pages: 358 Pages
SECTION 10 - GENERAL
Group 5 - Specifications
Group 10 - Predelivery, Delivery, and After—Sale Services
Group 15 - Tune-up
Group 20 - Lubrication
Group 25 - Separation
SECTION 20 - ENGINE
Group 5 - General Information and Diagnosis
Group 10 - Cylinder Head and Camshaft
Group 15 - Cylinder Block, Liners, Pistons, and Rods
Group 20 - Crankshaft, Main Bearings, Flywheel, and Balancer
Group 25 — Lubrication System
Group 30 - Cooling System
Group 35 - Governor and Speed Control Linkage
SECTION 30 - FUEL SYSTEMS
Group 5 - Diagnosing Malfunctions
Group 10 — Diesel Fuel System
Group 15 - Gasoline Fuel System
Group 20 - LP—Gas Fuel System
SECTION 40 - ELECTRICAL SYSTEM
Group 5 - Information and Wiring Diagrams
Group 10 - Charging Circuit
Group 15 - Starting Circuit
Group 20 - Ignition System
Group 25 — Lighting and Accessory Circuits
SECTION 50 - POWER TRAIN
Group 5 - Syncro-Range Transmission and PTO Clutches
Group 10 - Syncro-Range Transmission
Group 15 - Engine Disconnect Clutch
Group 20 - Power Shift Transmission
Group 25 - Differential
Group 30 - Final Drive
Group 35 - Hi-Crop Final Drive
Group 40 - Syncro-Range PTO
Group 45 - Power Shift PTO
Group 50 - Belt Pulley '
Group 55 - Power Front Wheel Drive
SECTION 60 - STEERING AND BRAKES
SECTION 70 - HYDRAULIC SYSTEM
Group 5 - General Information, Diagnosis, and Tests
Group 10 - Main Reservoir, Filters, Valves, Oil Cooler, and Oil Reservoir
Group 15 ~ Hydraulic Pumps
Group 20 - Power Steering
Group 25 - Power Brakes
Group 30 - Rockshaft and Implement Hitches
Group 35 - Selective Control Valve, Breakaway Couplers, and Remote Cylinders
SECTION 80 - MISCELLANEOUS
Group 5 - Conventional Front Axle
Group 10 - Power Front Wheel Drive Axle
