Martin Welker
104
230,310
John Deere 248 Series Power Unit Parts Catalog PC0668
Brand: John Deere
Type of Machine: Power Unit
Model: John Deere 248 Series Power Unit
Part Number: PC0668
Number of Pages: 164 Pages
ALPHABETICAL INDEX
A
Adapter, Converter (HB-L)
Adapter, Starting Motor
Air Cleaner, Dry-Type
Air Cleaner, Oil Baths
Air Ducts (HA-D, HA-G, HB-D, HB-G, HB-L)
Air Intake Manifold (HA-D, HB-D)
Air Intake Manifold (NA-D)
Air Pre-Cleaner
Air Scoop, Generator (HA-D, HA-G, HB-D, HB-G, HB-L)
Armature, Generator (HA-D, HA-G, HB-D, HB-G, HB-L)
Armature, Generator (BA-G, NA-D)
B
Battery Support (NA-D)
Bayonet Oil Gauge (BA-G, HA-G, HB-G, HB-L)
Bayonet Oil Gauge (HA-D, HB-D, NA-D)
Bearing, Camshaft (BA-G, HA-G, HB-G, HB-L)
Bearing, Camshaft (HA-D, HB-D, NA-D)
Bearing, Connecting Rod
Bearing, Crankshaft (BA-G, HA-G, HB-G, HB-L)
Bearing, Crankshaft (HA-D, HB-D, NA-D)
Bellcrank, Governor (BA-G, HB-G, HB-L)
Bellcrank, Governor (HA-G)
Belt, Fan
Belt, Fan, Generator, and Water Pump
Belt, Generator, and Water Pump
Belts, Pump Drive
Block, Cylinder (BA-G, HA-G, HB-G, HB-L)
Block, Cylinder (HA-D, HB-D, NA-D)
C
Cables, Battery (NA-D)
Cables, Spark Plug (BA-G, HA-G, HB-G, HB-L)
Camshaft Rear Cover (BA-G, HA-G, HB-G, HB-L)
Camshaft Rear Cover (HA-D, HB-D, NA-D)
Cap, Distributor
Cap, Main Bearing (BA-G, HA-G, HB-G, HB-L)
Cap, Main Bearing (HA-D, HB-D, NA-D)
Carburetor (BA-G, HA-G, HB-G)
Carburetor (HB-L)
Chamber, Turbulence (HA-D, HB-D, NA-D)
Coil
Condenser, Distributor
Connecting Rod
Connecting Rod Bearing
Converter, LP-Gas (HB-L)
Cover, Camshaft Rear (BA-G, HA-G, HB-G, HB-L)
Cover, Camshaft Rear (HA-D, HB-D, NA-D)
Cover, Engine Front Gear (BA-G, HA-G, HB-G, HB-L)
Cover, Engine Front Gear (HA-D, HB-D, NA-D)
Cover, Engine Rear
Cylinder Block (BA-G, HA-G, HB-G, HB-L)
Cylinder Block (HA-D, HB-D, NA-D)
Cylinder Head (BA-G, HA-G, HB-G, HB-L)
Cylinder Head (HA-D, HB-D, NA-D)
Distributor
E
Element, Fuel Filter (HA-D, HB-D, NA-D)
Element, Oil Filter
Engine, Front Gear Cover (BA-G, HA-G, HB-G, HB-L)
Engine, Front Gear Cover (HA-D, HB-D, NA-D)
Engine, Rear Cover
Engine Shield (NA-D)
Engine Support (HA-D, HA-G, HB-D, HB-G, HB-L)
Engine Support (HA-D, HB-D, HB-G, HB-L)
Engine Support (HA-G)
Engine Support (NA-D)
Engine Support, Front (BA-G)
Exhaust Manifold (HA-D, HB-D, NA-D)
Engine Valve (BA-G, HA-G, HB-G, HB-L)
Engine Valve Stem Lubricant
Exhaust Manifold (BA-G, HA-G, HB-G)
Exhaust Manifold (HB-L)
Exhaust Pipe (BA-G)
Exhaust Pipe (NA-D)
Exhaust Valve (HA-D, HB-D, NA-D)
F
Fan Belt
Fan Drive
Fan Hub (BA-G, HA-G, HB-G, HB-L)
Fan Hub (HA-D, HB-D, NA-D)
Filter, Fuel (HA-D, HB-D, NA-D)
Filter, Oil
Flywheel
Fuel LInes (BA-G, HA-G, HB-G)
Fuel Lines (HA-D, HB-D, NA-D)
Fuel Lines (HB-G)
Fuel Pump and Fuel Lines (BA-G, HA-G, HB-G)
Fuel Pump (BA-G, HA-B, HA-G, HB-D, HB-G, NA-D)
Fuel Strainer (HB-L)
Fuel Tank (NA-D)
G
Gauge, Bayonet Oil (BA-G, HA-G, HB-G, HB-L)
Gauge, Bayonet Oil (HA-D, HB-D, NA-D)
Gasket, Cylinder Head (BA-G, HA-G, HB-G, HB-L)
Gasket, Cylinder HEad (HA-D, HB-D, NA-D)
Gasket Set, Engine Oerhaul
Gasket Set, Engine Tune-Up
Gear, Camshaft (BA-G, HA-G, HB-G, HB-L)
Gear, Camshaft (HA-D, HB-D, NA-D)
Gear Cover, Front (BA-G, HA-G, HB-G, HB-L)
Gear Cover, Front (HA-D, HB-D, NA-D)
Gear, Crankshaft (BA-G, HA-G, HB-G, HB-L)
Gear, Crankshaft (HA-D, HB-D, NA-D)
Gear, Flywheel
Gear, Oil Pump
Generator
Glow Plug (HA-D, HB-D, NA-D)
Governor (HA-G)
Governor Linkage (NA-D)
Head, Cylinder (BA-G, HA-G, HB-G, HB-L)
Head, Cylinder (HA-D, HB-D, NA-D)
Hose, Crankcase Drain (HA-D, HB-D, NA-D)
Hose, Crankcase Drain (HA-G, HB-L)
Housing, Flywheel
Hub, Fan (BA-G, HA-G, HB-G, HB-L)
Hub, Fan (HA-D, HB-D, NA-D)
I
Injection Nozzle (HA-D, HB-D, NA-D)
Injection Pump (HA-D, HB-D, NA-D)
Intake Valve (BA-G, HA-G, HB-G, HB-L)
Intake Valve (HA-D, HB-D, NA-D)
K
Kit, Drain, Fuel Filter (HA-D, HB-D, NA-D)
Kit, Fuel Pump Overhaul (BA-G, HA-D, HA-G, HB-D, HB-G, NA-D)
Kit, Lead Wire
Kit, Storage
L
Line, Fuel (BA-G, HA-G, HB-G)
Line, Fuel (HA-D, HB-D, NA-D)
Line, Fuel (HB-L)
LP-Gas Carburetor (HB-L)
LP-Gas Fuel Strainer (HB-L)
M
Manifold, Air Intake (HA-D, HB-D)
Manifold, Air Intake (NA-D)
Manifold, Exhaust (BA-G, HA-G, HB-G)
Manifold, Exhaust (HA-D, HB-D, NA-D)
Manifold, Exhaust (HB-L)
Manifold, Water (BA-G, HA-G, HB-G, HB-L)
Manifold, Water (HA-D, HB-D)
Manifold, Water (NA-D)
Muffler (BA-G)
Muffler (NA-D)
Mufflers and Clamps (HA-D, HA-G, HB-D, HB-G, HB-L)
N
Nozzle, Injection (HA-D, HB-D, NA-D)
O
Oil Filter
Oil Pan
Oil Pressure Sending Unit (HA-D, HB-D, NA-D)
Oil Pump
P
Pan, Oil
Pistons
Plug, Glow (HA-D, HB-D, NA-D)
Plugs, Spark (BA-G, HA-G, HB-G, HB-L)
Points, Distributor
Powder, Engine Break-In (HA-D, HB-D, NA-D)
Pre-Cleaner (HA-D, HA-G, HB-D, HB-G, HB-L)
Pre-Cleaner and Pre-Screener (NA-D)
Primer Aid (HA-D, HB-D)
Pulley, Fan Drive
Pump, Fuel, and Fuel Lines (BA-G, HA-G, HB-G)
Pump, Fuel Injection (Diesel)
Pump, Oil
Pump, Primer, Starting Aid
Pump, Water
R
Radiator (BA-G)
Radiator (HA-D)
Radiator (HA-G, HB-G)
Radiator (HB-D, HB-L)
Radiator (NA-D)
Radiator Screen (NA-D)
Regulator, Voltage (NA-D)
Relay, Glow Plug and Starter (HA-D, HB-D, NA-D)
Rings, Piston
Rocker Arm Cover
Rod, Connecting
Rod, Push
S
Series Parallel Switch
Solenoid Switch
Spark Plug Wires and Cables (BA-G, HA-G, HB-G, HB-L)
Starting Aid Primer Pump (HA-D, HB-D)
Starting Motor (BA-G, HA-G, HB-G, HB-L)
Starting Motor, 12-Volt (HA-D, HB-D, NA-D)
Starting Motor, 24-Volt (HA-D, HB-D, NA-D)
Starting System Wiring (HA-D, HB-D, NA-D)
Storage Kit
Strainer, LP-Gas (HB-L)
Support, Engine Front (BA-G)
Support, Engine Rear
T
Tank, Fuel (NA-D)
Tappets (BA-G, HA-G, HB-G, HB-L)
Tappets (HA-D, HB-D, NA-D)
Temperature Sending Unit (BA-G, HA-G, HB-G, HB-L)
Temperature Sending Unit (HA-D, HB-D)
Temperature Sending Unit (NA-D)
Turbulence Chamber (HA-D, HB-D, NA-D)
V
Valves (BA-G, HA-G, HB-G, HB-L)
Valves (HA-D, HB-D, NA-D)
Valve Stem Lubricant, Engine
Voltage Regulator (NA-D)
W
Water Manifold (BA-G, HA-G, HB-G, and HB-L)
Water Manifold (HA-D, HB-D)
Water Manifold (NA-D)
Wire Kit, Lead
Wiring, Starting System (HA-D, HB-D)
