Martin Welker
104
230,792
John Deere 22 122 Cotton Pickers Parts Catalog PC0571
Brand: John Deere
Type of Machine: Cotton Pickers
Model: John Deere 22 122 Cotton Pickers
Part Number: PC0571
Number of Pages: 201 Pages
ALPHABETICAL INDEX
A
Air Stack
Air Stack Screen
Arm, Stalk Lifters
Arms, Lift, Picking Unit
Angles, Picking Unit Bottom
Axle, Rear Drop, Tractor
B
Bar, Picker
Bars and Panels, Front Drum Grid
Bars and Panels, Rear Drum Grid
Bars, Grid, and Supports
Basket, Cotton
Basket Lid Control Linkage
Basket Lid Frame
Basket Lid Grate
Basket Lid Sheets
Basket Lift Hydraulic Selector Valve
Basket Lift Lever
Basket Lift Linkage
Basket Lift Oil Lines
Basket Support
Bearing Support, Rear Steering
Belts, Picking Unit Drive
Blades, Fan
Brackets, Idler, Main Frame
Brackets, Main Frame Tractor Axle Mounting
Brackets, Mounting, Main Frame
Brake Linkage
Brake Pedal
Brake Shaft
C
Cam Follower, Picker Bar
Cam, Picker Drum
Chain, Shield, Tractor Flipper
Clutch, Drum Release, Upper Housing
Clutch, Drum Slip, Upper Housing
Clutch Lever
Clutch Linkage
Clutch, Overrunning, Picking Unit
Clutch Pedal
Clutch, Pressure Trip, Control Linkage
Clutch, Pressure Trip Picking Unit
Clutch, PTO, Lever
Clutch, PTO, Linkage
Clutch Shaft
Cotton Door, Front Drum
Cotton Door, Rear Drum
Cushions, Seat
Cylinder, Hydraulic, Cotton Basket
Decalcomania Set
Doffer
Door,Cotton, Front Drum
Door, Cotton, Rear Drum
Drive, Fan
Drive Gears, Bevel
Drive Gears, Upper Housing
Drive, Picking, Unit
Drive Shaft, Picking, Unit
Drive, Tractor
Drum, Cotton Door, Front
Drum, Cotton Door, Rear
Drum Grate
Drum Grates (12-Bar)
Drum Grid Bars and Panels, Front
Drum Grid Bars and Panels, Rear
Drum Panels, Front
Drum Panels, Rear
Drum, Picker
Drum Pressure Plates, Front
Drum Pressure Plates, Rear
Drum Release Clutch, Upper Housing
Drum, Slip Clutch, Upper Housing
E
Engine Side Shields
Extensions, Stalk Lifter
F
Fan Blades
Fan Discharge Pipe
Fan Drive
Fan Drive Gear
Fan Gear Drive
Fan, Gear Drive Housing
Fan Housing
Fan, Platform
Fan Shafts
Fan Sheaves
Fan Suction Pipes
Fingers, Grid
Finger, Stalk Lifters
Filter, Water
Follower, Cam, Picker Bar
Frame, Basket Lid
Frame, Main
Frame, Main, Idler Brackets
Frame, Main, Mounting Brackets
Frame, Main, Tractor Axle Mounting Brackets
Frames, Picking Unit, Lower
Frame, Seat
Front Drum Cotton Door
Front Drum Grid Bars and Panels
Front Drum Panels
Front Drum Pressure Plates
Front Wheel
Front Yoke
G
Gauge, Master, Picker Bar
Gauge, Temperature, Tractor (2010)
Gears, Drive, Bevel
Gear, Drive Fan
Gear, Drive Housing, Fan
Gears, Drive Housing, Upper
Gear, Spindle Drive, Picker Bar
Gears, Rear Drop Axle , Tractor
Gearshift Lever
Gearshift Linkage
Grates, Basket Lid
Grate, Front Drum
Grates, Stalk Lifter
Grid Bars and Panels, Front Drum
Grid Bars and Panels, Rear Drum
Grid Bars and Supports
Grid Fingers
Guard, Wheel, L.H.
Guard, Wheel, R.H.
Hand Rail, Operator's Platform
Headlight, Picker
Headlight Extensions, Tractor
Housing, Drive Gear, Fan
Housing, Drive Gears, Upper
Housing, Drum Release Clutch, Upper
Housing, Drum Slip Clutch, Upper
Housing, Fan
Housing, Lubricator
Housing, Picking Unit, Upper
Housing, Sprockets, Upper
Hydraulic Oil Lines
I
ID VIEW
Idler Brackets, Main Frame
L
Levers, Basket Lift
Lever, Clutch
Lever, Gearshift
Lever, Lubricator
Lever, Picking Unit
Lever, PTO Clutch
Lever, Throttle
Lever, Water Cut-Off
Lift Arms, Picking Unit
Lifter Arms, Stalk
Lifter Extensions, Stalk
Lifter Fingers, Stalk
Lifter Grates, Stalk
Lifter Shoes, Stalk
Lifters, Stalk
Lines, Oil, Basket Lift
Lines, Oil, Hydraulic
Lines, Oil, Lubricator
Lines, Water, Water Tank to Moisteners
Link, Lift, Picking Unit Lift Arms
Linkage, Basket Lift
Linkage, Brake
Linkage, Clutch
Linkage, Control, Basket Lid
Linkage, Control, Pressure Trip Clutch
Linkage, Control, Rear Rockshaft
Linkage, Gearshift
Linkage, Picking Unit
Linkage, PTO Clutch
Linkage, Throttle
Linkage, Water Cut-Off
Lubricant, Spindle
Lubricator
M
Main Frame
Main Frame Idler Brackets
Main Frame Mounting Brackets
Main Frame Tractor Axle Mounting Brackets
Manual, Operator's
Metering, Water, Valve
Moistener, Spindle
Muffler Shield
O
Oil Lines, Hydraulic
Oil Lines, Lubricator
Operator's Manual
Operator's Platform
Operator's Platform Hand Rail
Operator's Platform Seat
P
Panels, Drum, Front
Panels, Drum, Front Grid Bar
Panels, Drum, Rear
Panels, Drum, Rear Grid Bar
Panels, Picking Unit (12-Bar)
Panels, Brake
Panels, Clutch
Picker Bar
Picker Bar Master Gauge
Picker Drum and Cam
Picker Head Light and Wires
Picker Unit Bevel Drive Gears and Shafts
Picking Unit Bottom Angles
Picking Unit Bottom Plates
Picking Unit Drive Belts
Picking Unit Drive Housing
Picking Unit Drive Shaft
Picking Unit Drive Shaft Shield
Picking Unit Drive Sheaves
Picking Unit Housing
Picking Unit Levers
Picking Unit Lift Arms Lifting Link
Picking Unit Lift Arms Spring
Picking Unit Linkage
Picking Unit Lower Frames
Picking Unit Overrunning Clutch
Picking Unit Panels (12-Bar)
Picking Unit Pressure Trip Clutch
Picking Unit Side Sheets (12-Bar)
Picking Unit Universal Joint
Picking Unit Upper Housing
Pipe, Fan, Discharge
Pipes, Fan Suction
Plant Shield, L.H.
Plant Shield, R.H.
Plates, Bottom, Picking Unit
Plates, Pressure, 12 and 16-Bar
Plates, Pressure, Front Drum
Plates, Pressure, Rear Drum
Platform, Fan
Platform, Operator's
Platfrom, Operator's Rest
Post, Steerig Wheel
PTO Clutch Lever
PTO Clutch Linkage
Pre-Cleaner
Pre-Screener
Pressure Plates, 12 and 16-Bar
Pressure Plates, Front Drum
Pressure Plates, Rear Drum
Pressure Trip Control Linkage
Pump, Lubricator
R
Rail, Hand, Operator's Platform
Radiator Screen
Rear Drum Cotton Door
Rear Drum Panels
Rear Drum Grid Bars and Panels
Rear Drum Pressure Plates
Rockshaft, Rear
Rockshaft, Rear, Control Linkage
S
Sheaves, Fan
Sheaves, Picking Unit Drive
Sheets, Basket Lid
Sheets, Side, Picking Unit (12-Bar)
Screen, Air Stack
Screen, Radiator
Seat Cushions
Seat, Economy
Seat Frame
Seat Frame and Support
Seat, Tractor and Operator's Platform
Shaft, Bevel Drive Gear
Shaft, Brake
Shaft, Clutch
Shaft, Drive, Picking Unit
Shaft, Drive Shield
Shaft, Fan
Shaft, Picker Bar
Shaft, Rear Drop Axle, Tractor
Shaft, Steering, Rear
Shaft, Steering Wheel
Shaft, Steering Front
Shield Chain, Tractor Flipper
Shield, Drive Shaft
Shield, Engine Side
Shield, Muffler
Shield, Picking Unit Drive Shaft
Shield, Tractor Side
Shield, Plant, L.H.
Shield, Plant, R.H.
Shoe, Stalk Lifters
Spindle Lubricant
Spindle Moistener
Spindle, Picker Bar
Spring, Picking Unit Lift Arms
Sprocket, Doffer
Steering Post
Sprockets, Steering Wheel
Sprockets, Upper Housing
Stabilizer Bars
Stack, Air
Stalk Lifter
Stalk Lifter Arms
Stalk Lifter Extensions
Stalk Lifter Fingers
Stalk Lifter Grates
Stalk Lifter Shoes
Steering Shaft
Steering Shaft, Front
Steering Shaft, Rear
Steering Sprockets
Steering Universal Joint, Rear
Steering Wheel
Support, Basket
Support, Bearig, Rear Steering
Support, Grid Bars
Support, Seat
T
Tank, Water Supply
Temperature Gauge, Tractor (2010)
Throttle Lever
Throttle Linkage
Tools
Tractor Drive
Tractor Flipper Shield Chain
Tractor Headlight Extensions and Wires
Tractor Seat
Tractor Side Shields
Tractor Temperature Gauge (2010)
U
Unit, Picking - See Picking Unit
Universal Joint, Picking Unit
Universal Joint, Steering, Front
Universal Joint, Steering, Rear
Upper Housing Drive Gears
Upper Housing Sprockets
Upper Housing Drum Release Clutch
Upper Housing Drum Slip Clutch
V
Valve, Selector, Basket Lift
Valve, Water Metering
W
Water Cut-Off Lever
Water Lines, Water Tank to Moisteners
Water Metering Valve
Water Supply Tank
Wetting Agent
Wheel, Front
Wheel Guard, L.H.
Wheel Guard, R.H.
Wires, Picker Headlight
Wires, Tractor Headlight Extensions
Y
Yoke, Front
