Martin Welker
104
230,310
John Deere 2140 Tractor Technical Manual TM4373
Brand: John Deere
Type of Manual: Technical Manual
Model: John Deere 2140 Tractor
Part Number: TM4373
Number of Pages: 1236 Pages
SECTION 10 — GENERAL
Group 00 _ Specifications and special tools
Group 05 - Pre-delivery, delivery and after-sales inspections
Group 10 - Lubrication and periodic service
Group 15 — Engine and tractor tune-up
Group 20 — Tractor separation (tractors without increased lift capacity)
Group 25 — Tractor separation (tractors with increased lift capacity)
SECTlON 20 — ENGINE
Group 00 — Specifications
Group 05 - Radiator
SECTION 30 — FUEL AND AIR INTAKE SYSTEM
Group 00 - Specifications and special tools
Group 05 — General information, diagnosing malfunctions
Group 10 - Fuel tank and water trap
Group 15 — Cold weather starting aids
Group 20 — Speed control linkage
Group 25 — Air cleaner
SECTION 40 — ELECTRICAL SYSTEM
Group 00 — Specifications and special tools
Group 05 —- Description, diagnosing malfunctions and tests
Group 10 — Wiring harnesses
Group 15 — Controls and instruments
Group 20 — Lighting systems
Group 25 — Wiring diagrams
Group 30 —— Starting motor
Group 35 — Alternator
SECTION 50 — POWER TRAIN
Group 05 - Description, operation and lubricating system
Group 10 — Clutch operating linkages
Group 15 — Engine clutches
Group 20 — Hi-Lo shift unit
Group 25 — Creeper transmission
Group 30 - Transmission shift linkage
Group 35 — Synchronized transmission and transmission oil pump
Group 40 — Collar shift transmission and transmission oil pump
Group 45 — Differential
Group 50 — Final drives
Group 55 - Independent PTO
Group 56 — Front PTO
Group 60 - Mechanical front wheel drive
SECTION 60 — STEERING SYSTEM AND BRAKES
Group 05 — Hydrostatic steering (operating pressure: 12000 kPa; 120 bar; 1740 psi)
Group 06 — Hydrostatic steering (operating pressure: 13000 kPa; 150 bar; 2180 psi)
Group 10 - Power steering
Group 15 - Manual steering
Group 20 - Brakes
SECTION 70 - HYDRAULIC SYSTEM
Group 05 — Description, diagnosing malfunctions and pressure tests
Group 10 — Oil reservoir, filter, valves and oil cooler
GrOUp 15 — Hydraulic pumps
Group 20 — Rockshaft
GrOUp 21 — Front hitch
Group 25 — Selective control valves (Spool type)
Group 30 — Selective control valves (poppet valve type)
Group 35 — Hose couplers
Group 40 — Remote cylinder
Group 45 — Selective control valves (Tractors manufactured in Spain)
SECTION 80 — MISCELLANEOUS
Group 00 — Specifications and Special tools
Group 05 — Front axle
Group 10 — Belt pulley
Group 15 — Front and rear wheels
Group 20 — Axle trailer hitch
SECTION 90 — OPERATOR'S CABS
Group 05 - Air conditioning system
Group 10 — Ventilation and heating
Group 15 — Operator's seats
Group 20 — OPU cab
Group 25 — SGZ cab
Group 30 — Roll guard
