John Deere 2130 Tractor Parts Catalog PC4128
Brand: John Deere
Model: John Deere 2130 Tractor
Part Number: PC4128
Number of Pages: 275 Pages
ALPHABETICAL INDEX
A
Accessory Parts
Air Pre-Cleaner (for Dry Air Cleaner)
Alternator / Voltage Regulator
B
Battery
Belt Pulley (with PTO 1000 RPM)
Brake Disk
Brake Pedal
Brake Valve / Brake Oil Lines
Brake Valve for Hydraulic Trailer Brake
C
Camshaft / Valves / Rocker Arm Shaft
Cast Rear Wheels / Weights
Cast Rear Wheels for Pinion Adjusted Axle / Weights
Center Link / Draft Links
Center Link / Telescoping Draft Links
Chock Block
Clutch Control Valve
Clutch Control Valve - Cover / Arm
Clutch Housing
Clutch Oil Manifold / Oil Lines (with High-Low Shift Unit, with Independent PTO)
Clutch Oil Manifold / Oil Lines (with Independent PTO, without High-Low Shift Unit)
Clutch Pedal
Clutch Shafts (without High-Low Shift Unit)
Cold Weather Starting Aid
Cold Weather Starting Aid (Thermostart)
Connecting Parts for Hydraulic Motor
Countershaft / Bearing Support
Couplers Disconnect Quick
Crankshaft / Timing Gears / Main Bearings
Cylinder Head / Rocker Arm Cover
Dash / Cowl
Deluxe Seat Assembly
Downward Exhaust
Drawbar
Drawbar
Dry Air Cleaner
Dual Stage Fuel Filter (Roto Diesel)
E
Electrical Instruments
Electrical Wiring System (with Shell Type Fenders) (Bilux)
Electrical Wiring System (with Shell Type Fenders) (Sealed Beam)
Electrical Wiring System with Flasher Warning Lights (with Wide Fenders)
Electrical Wiring System (with Wide Fenders)
Engine Balancer Shafts
Engine Clutch
Engine Gasket Set
Engine Oil Cooler
F
Final Drive / Axle Rear
Flow Control Valve (with Power Steering)
Flywheel / Flywheel Housing
Frame Weights
Front Axle (Heavy-Duty)
Front Axle Knee / Spindle Knuckle / Tie Rod (Heavy-Duty)
Front Fenders
Front Support / Front Hitch
Front Wheel / Assembly
Fuel Injection Nozzle
Fuel Injection Pump (Roto Diesel)
Fuel Pump
G
Gear Shifting Parts
Handbrake
High-Low Clutch
High-Low Shift Control Lever
Hinged Trailer Hitch
Hood / Front Plate / Grille
Horn / Socket / Stop Light Switch
Hydraulic Oil Lines
Hydraulic Oil Lines for Selective Control Valves
Hydraulic Oil Reservoir
Hydraulic Pump (1.38 Cubic Inch)
Hydraulic Pump (69 Cubic Inch)
Hydraulic Pump Drive
I
ID VIEW
Implement Quick Coupler
Independent Power Take-Off (540 RPM)
Independent Power Take-Off, Rear (540 - 1000 RPM)
L
Lateral Stabilizing Strut (with Reversible Draft Links)
Lift Links
Lights
Lights, Sealed Beam
M
Manual Steering
N
Name Plates / Decalcomanias
O
Oil Pump / Oil Pan
Operator Seat (Standard)
P
PTO Clutch
PTO Countershaft, Gear (with Independent PTO 540 - 1000 RPM)
Parts for Air Cleaner Restriction Indicator
Parts for Load Control
Parts for Parking Light in Headlights
Parts for Rigid Position of Draft Links
Passenger Seat
Pinion Shaft
Piston / Connecting Rod
Power Take-Off Guard
Power Shaft Brake Band
Power Steering
R
Radiator / Water Hoses / Oil Cooler
Rear Fenders (Shell Type) / Step Plates
Rear Fenders (Wide) / Step Plates
Rear View Mirror / Reflectors / Bracket (with Wide Fenders)
Rear Work Light
Rear Work Light
Reflectors / Brackets (with Shell Type Fenders)
Remote Control Cylinder
Rockshaft / Piston / Lift Arms
Rockshaft Control Lever
Rockshaft Cylinder and Valve Housing Linkage
Rockshaft Housing
Roll-Guard
S
Safety Belt
Seat Support Base (without Rockshaft)
Short Engine
Side Frames
Side Lamps / Turn Lights / Tail Lights
Starting Motor
Steel Disk Rear Wheels / Weights
Step Plate / Bracket
Support for Selective Control Valve
Sway Blocks and Supports
T
Thermostat / Thermostat Housing
Throttle Linkage
Timing Gear Cover / Oil Filler Inlet
Tools
Tool Box
Tractormeter
Trailer Hitch, Fixed
Transmission Case
Transmission Input Shaft
Transmission Input Shaft / Oil Pump (High-Low)
Transmission Oil Filter / Oil Cup / Lubricating Oil Lines
Transmission Oil Pump / Oil Lines (with High-Low Shift Unit)
Transmission Oil Pump / Oil Lines (without High-Low Shift Unit)
U
Upright Exhaust
W
Warning Light
Water Pump / Fan
Water Trap
Brand: John Deere
Part Number: PC4128
ALPHABETICAL INDEX
A
Accessory Parts
B
Battery
Brake Disk
Brake Pedal
C
Chock Block
Clutch Housing
Clutch Pedal
Dash / Cowl
Downward Exhaust
Drawbar
Drawbar
Dry Air Cleaner
E
Engine Clutch
Engine Gasket Set
Engine Oil Cooler
F
Frame Weights
Front Fenders
Fuel Pump
G
Gear Shifting Parts
Handbrake
High-Low Clutch
Hydraulic Oil Lines
I
ID VIEW
L
Lift Links
Lights
Lights, Sealed Beam
M
Manual Steering
N
O
Oil Pump / Oil Pan
P
PTO Clutch
Passenger Seat
Pinion Shaft
Power Steering
R
Rear Work Light
Rear Work Light
Rockshaft Housing
Roll-Guard
S
Safety Belt
Short Engine
Side Frames
Starting Motor
T
Throttle Linkage
Tools
Tool Box
Tractormeter
Transmission Case
U
Upright Exhaust
W
Warning Light
Water Pump / Fan
Water Trap
- JOHN DEERE CODE DTC LIST
