Martin Welker
104
230,310
John Deere 210C 310C 315C Backhoe Loader Repair Technical Manual TM1420
Brand: John Deere
Model: John Deere 210C 310C 315C Backhoe Loader
Part Number: TM1420
Number of Pages: 804 Pages
SECTION I—GENERAL INFORMATION
Group I—introduction and Safety information
Group II—General Specifications
Group III—Torque Values
Group IV—Fuels and Lubricants
Group V—Inspection Procedure
SECTION 01—WHEELS
Group 0110—Powered Wheels and Fastenings
Group 0120—Non-Powered Wheels and Fastenings
SECTION 02—AXLES AND SUSPENSION SYSTEMS
Group 0230—Non-Powered Wheel Axles
Group 0240—Powered Wheel Axles
Group 0250—Axle Shafts, Bearings and Reduction Gears
Group 0260—Hydraulic System
SECTION 03—TFIANSMISSION
Group 0300—Removal and installation
Group 0315—Controls
Group 0325—Input Drive Shafts and U-Joints
Group 0350—Gears, Shafts, Housings, Bearings Differential Lock, Brake, and Park Brake
Group 0360—Hydraulic System Suction Screen, Oil Pump, and Control Valve
SECTION 04—ENGINE
Group 0400—Removal and Installation
SECTION 05—ENGINE AUXILIARY SYSTEMS
Group 0505—Cold Weather Starting Aids
Group 0510—Cooling Systems
Group 0515—Speed Controls
Group 0520—Intake System
Group 0560—External Fuel Supply Systems
SECTION 06—TORQUE CONVERTEFI
Group 0651—Turbine, Gears, and Shafts
SECTION 09—STEERING SYSTEM
Group 0960—Hydraulic System Steering Valve and Cylinder and Inlet Check Valve
SECTION 10—SERVICE BRAKES
Group 1011—Active Elements Brake Disks and Control Linkage
Group 1060—Hydraulic System Brake Valve
SECTION 11—PARK BRAKE
Group 1111—Active Elements
Group 1115—Controls (Linkage)
SECTION 15—EQUIPMENT ATTACHING
Group 1500—Removal and installation
Group 1520—Hitches and Hitch Pins
SECTION 16—ELECTRICAL SYSTEMS
Group 1671—Batteries, Support and Cables
Group 1672—Alternator, Regulator and Charging System Wiring
Group 1673—Lighting System
Group 1674—Wiring Harness and Switches
Group 1675—System Controls
Group 1676—instruments, Indicators, and Senders
Group 1677—M0tor3 and Actuators
SECTION 17—FRAME, CHASSIS, OR SUPPORTING STRUCTURE
Group 1740—Frame installation
Group 1749-Chassis Weights
SECTION 18—OPERATOR'S STATION
Group 1800—Removal and Installation
Group 1810—Operator Enclosure Wipe Motor and Windshield Washer
Group 1821—Seat and Seat Belt
Group 1830—Heating
SECTION 20—SAFETY, CONVENIENCE, MISCELLANEOUS
Group 2004—H0rn and Warning Devices
SECTION 21—MAIN HYDRAULIC SYSTEM
Group 2160—Hydraulic System Main Hydraulic Pump, Pump Drive, Main Hydraulic Filter, Hydraulic Reservoir, Reservoir Suction Screen, Oil Cooler, Oil Cooler Bypass Valve, and System Relief Valve
SECTION 31—LOADER
Group 3100—Removal and installation
Group 3102—Buckets
Group 3115—Controls Linkage
Group 3140—Frames
Group 3160—Hydraulic System
SECTION 33—BACKHOE
Group 3300—Removal and Installation
Group 3302—Buckets
Group 3315—Controls Linkage
Group 3340—Frames
Group 3360—Hydraulic System
SECTION 42—GROUND CONDITIONING TO0L
Group 4260—Hydraulic System
SECTION 99—DEALER FABRICATED TOOLS
