Martin Welker
104
230,310
John Deere 2040 Tractor Technical Manual TM4300
Brand: John Deere
Type of Manual: Technical Manual
Model: John Deere 2040 Tractor
Part Number: TM4300
Number of Pages: 338 Pages
SECTION 10 - GENERAL
Group 05 - Specifications
Group 10 - Predelivery, Delivery, and After-Sales Inspections
Group 15 - Lubrication and Periodic Service
Group 20 - Engine and Tractor Tune-Up
Group 25 - Tractor Separation (Open Center System)
Group 26 - Tractor Separation (Closed Center System)
SECTION 20 — ENGINE
Group 05 — General Information, Diagnosing Malfunctions
Group 10 - Cylinder Head and Camshaft
Group 15 — Cylinder Block, Liners, Pistons, and Connecting Rods
Group 20 - Crankshaft, Main Bearings, and Flywheel
Group 25 - Timing Gear Train
Group 30 — Engine Lubrication System
Group 35 - Cooling System
Group 40 - Speed Control Linkage
SECTION 30 - FUEL SYSTEM
Group 05 — Diagnosing Malfunctions
Group 10 - Fuel Tank, Fuel Transfer Pump, and Air Cleaner
Group 15 — Roto Diesel
Group 20 - Injection Nozzles
Group 25 - Cold Weather Starting Aid
SECTION 40 - ELECTRICAL SYSTEM
Group 10 - Components and Wiring Diagram
Group 15 - Starting Motor
Group 20 - Alternator and Regulator
SECTION 50 — POWER TRAIN
Group 05 - Engine Dual-Stage Clutch and Clutch Linkage
Group 10 - Collar-Shift Transmission
Group 15 - Differential Assembly
Group 20 - Final Drives
Group 25 — Continuous Running PTO
SECTION 60 - FRONT AXLE, POWER STEERING, AND BRAKES
Group 05 - Front Axle
Group 10 - Power Steering (Open Center System)
Group 11 - Power Steering (Closed Center System)
Group 15 - Hydraulic Brakes
SECTION 70 - HYDRAULIC SYSTEM
Group 05 - General Information. Diagnosing
Malfunctions and Tests (Open Center System)
Group 06 - General Information, Diagnosing Malfunctions and Tests (Closed Center System)
Group 10 - Oil Reservoir, Filter and Valves (Open Center System)
Group 11 - Oil Reservoir, Filter and Valves (Closed Center System)
Group 16 Hydraulic Pump (Open Control System)
Group 16 - Hydraulic Pump (Closed Center System)
Group 20 - Rockshaft (Open Center System)
Group 21 - Rockshaft (Closed Center System)
Group 25 — Selective Control Valves (Spool Type; Open Center System)
Group 26 - Selective Control Valves (Poppet Type; Closed Center System) and Breakaway Coupler
Group 30 - Remote Cylinder
SECTION 80 - MISCELLANEOUS
Group 05 - Belt Pulley
Group 10 - Seat
Group 15 - Front Wheels
