Martin Welker
104
230,310
John Deere 2040 2240 Tractor Technical Manual TM1221
Brand: John Deere
Type of Manual: Technical Manual
Model: John Deere 2040 2240 Tractor
Part Number: TM1221
Number of Pages: 586 Pages
SECTION 10 - GENERAL
Group 00 — Specifications and Special Tools
Group 05 — Pre-delivery, Delivery and After-Sales Inspections
Group 10 — Lubrication and Periodic Service
Group 15 — Engine and Tractor Tune-Up
Group 20 — Tractor Separation
SECTION 20 - ENGINE
Group 05 — General Information, Diagnosing Malfunctions
Group 10 — Cylinder Head and Camshaft
Group 15 — Cylinder Block, Liners, Pistons and Connecting Rods
Group 20 — Crankshaft, Main Bearings and Flywheel
Group 25 — Timing Gear Train
Group 30 — Engine Lubrication System
Group 35 —— Engine Cooling System
SECTION 30 — FUEL SYSTEM
Group 05 — Diagnosing Malfunctions
Group 10 — Fuel Tank, Fuel Transfer Pump and Fuel Filter
Group 15 — Roto Diesel Fuel Injection Pump
Group 20 — Fuel Injection Nozzles
Group 25 — Ether Starting Aid
Group 30 — Speed Control Linkage
Group 35 — Air Intake System
SECTION 40 - ELECTRICAL SYSTEM
Group 05 — Description and Diagnosing Malfunctions
Group 10 — Wiring Harnesses
Group 15 — Controls and Instruments
Group 20 — Lighting Systems
Group 25 — Wiring Diagram
Group 30 — Starting Motor
Group 35 — Alternator
SECTION 50 — POWER TRAIN
Group 05 — Engine Clutches and Clutch Linkages
Group 10 — Hi-Lo Shift Unit
Group 15 — Reverser Transmission ,
Group 20 — Synchronized Transmission and Transmission Oil Pump
Group 95 — Collar Shift Transmission and Transmission Oil Pump
Group 30 — Differential
Group 35 — Final Drives
Group 40 — Independent PTO Shaft
Group 45 — Continuous-Running PTO
Group 50 — Mechanical Front Wheel Drive
SECTION 60 — STEERING SYSTEM AND BRAKES
Group 05 - Power Steering
Group 10 — Brakes
SECTION 70 — HYDRAULIC SYSTEM
Group 05 — Hydraulic System Operation
Group 06 — Hydraulic System Tests
Group 10 — OII Reservoir, Filter, valves and Oil Comer
Group 15 — Hydraulic Pump
Group 20 — Rockshaft
Group 25 — Selective Control Valves and Breakaway Coupler
Group 30 — Remote Cylinder
SECTION 80 — MISCELLANEOUS
Group 05 — Front Axle
Group 10 — Belt Pulley
Group 15 — Front and Rear Wheels
Group 20 — ROLL-GARDP Protective Structure
Group 25 — Operator's Station
