Martin Welker
104
230,310
John Deere 2025R Compact Utility Tractors Operators Manual OMTR117530
Brand: John Deere
Type of Machine: Compact Utility Tractors
Model: John Deere 2025R Compact Utility Tractors
Part Number: OMTR117530
Publication Date: 2020
Number of Pages: 148 Pages
Introduction
Foreword
Product View
Trademarks
Glossary of Terms
Regions and Country Versions
Machine Overview
Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Prepare for Emergencies
Wear Protective Clothing
Protect Against Noise
Handle Fuel Safely—Avoid Fires
Handle Starting Fluid Safely
Fire Prevention
In Case of Fire
Avoid Static Electricity Risk When Refueling
Keep ROPS Installed Properly
Use Foldable ROPS and Seat Belt Properly
Stay Clear of Rotating Drivelines
Read Operators’s Manuals for ISOBUS Controllers
Use Seat Belt Properly
Operating the Tractor Safely
Avoid Backover Accidents
Limited Use in Forestry Operation
Operating the Loader Tractor Safely
Keep Riders Off Machine
Instructional Seat
Use Safety Lights and Devices
Transport Towed Equipment at Safe Speeds
Use Caution on Slopes, Uneven Terrain, and Rough Ground
Freeing a Mired Machine
Avoid Contact with Agricultural Chemicals
Handling Batteries Safely
Handle Electronic Components and Brackets Safely
Practice Safe Maintenance
Avoid Hot Exhaust
Clean Exhaust Filter Safely
Work In Ventilated Area
Support Machine Properly
Prevent Machine Runaway
Park Machine Safely
Transport Tractor Safely
Service Cooling System Safely
Service Tires Safely
Service Front-Wheel Drive Tractor Safely
Tightening Wheel Retaining Bolts/Nuts
Avoid High-Pressure Fluids
Do Not Open High-Pressure Fuel System
Store Attachments Safely
Safety Signs
Replace Safety Signs
Folding ROPS
Use Seat Belt
ROPS in Normal Position, Riders, and Operators’s Manual
Noise
Controls and Instruments
Front Console Controls
Foot-Operated Controls
Right-Hand Console Controls
Left-Hand Console Controls
Differential, MFWD, Rate-of-Drop, and Seat Controls
Instrument Control Panel
Engine Operation
Operate Key Switch
Operate Hand Throttle
Operate Auto-Throttle (If Equipped)
Operate Fuel Shutoff Valve
Start the Engine
Cold Weather Starting Aids
Warm and Idle the Engine
To Start a Stalled Engine
Stop Engine
Air Intake, Fuel, Coolant, and Exhaust Operation
Fill the Fuel Tank
Use Fuel Gauge
Electrical and Lighting Operation
Use Light Switch
Use Turn Signal Switch
Use Power Port Outlet
Drivetrain Operation
Drive Machine
Transmission Operation
Operate the Hydrostatic Transmission
Use Cruise Control
MFWD and Front Axle Operation
Use Mechanical Front Wheel Drive (MFWD)
Differential and Rear Axle Operation
Use Differential Lock (Traction Assist)
Power Take Off (PTO) Operation
Use the PTO Safely
Check PTO Driveshaft Length
Operate Rear and Mid PTO (Operators on Seat)
Operate Rear PTO (Operators off Seat)
Operate Reverse Implement Option (RIO)
Adjust Height-of-Cut (If Equipped)
Steering and Brake Operation
Operate Brake Pedal
Operate Park Brake
Adjust Tilt Steering Wheel
Hydraulics Operation
Warm Hydraulic System Oil
Hydraulics Information
Hitch and Drawbar Operation
Operate Attachments
Operate 3-Point Hitch
Operate Rate-of-Drop
Use Draft Link and Center Link
Level Implement Front-to-Rear
Level Implement Side-to-Side
Adjust Implement Side-to-Side Sway
Operate Rear Hitch
Operate Optional iMatch Quick-Attach Hitch System
Use Front Quick Hitch
Front Quick Hitch Compatibility
Selective Control Valve Operation
Connect Implement Hydraulic Hoses
Operate Hydraulic Dual Selective Control Valve (SCV)
Operate Selective Control Valve (SCV) Lock Lever
Wheels and Tires Operation
Tire Labeling, Ascertain the Load Capacity of Tires
Select Tire Inflation Pressure
Tire Combinations
Front and Rear Tire Capacity
Ballast
Ballast Machine
Implement Codes
Use Optional Rear Cast Iron Wheel Weights
Use Optional Rear Ballast Box
Use Liquid Weight in Tires
Use Optional Front Weights
Additional Equipment Operation
Operators Station Operation
Enter and Exit Machine
Adjust Seat
Use Seat Belt
Raise and Lower ROPS
Transport and Storage
Transport Machine on Trailer
Transport Machine
Push or Tow Machine
Tow Loads
Use Safety Chain
Store Safety
Prepare Machine for Storage
Prepare Fuel and Engine for Storage
Remove Machine from Storage
Maintenance Intervals
Service Your Machine
Maintenance Interval Chart—Daily to Every 400 Hours
Maintenance Interval Chart—Every 600 Hours to Every 6000 Hours
Test the Safety Interlock System Before Startup
Avoid Damage to Plastic and Painted Surfaces
Clean Plastic Surfaces
Clean and Repair Metal Surfaces
Fuel, Lubricants, and Coolant
Diesel Fuel
Testing Diesel Fuel
Minimizing the Effect of Cold Weather on Diesel Engines
Engine Oil
Diesel Engine Coolant
Operating in Warm Temperature Climates
Additional Information About Diesel Engine Coolants and John Deere COOL-GARD™ II Coolant Extender
Testing Diesel Engine Coolant
Transmission and Hydraulic Oil
Front Axle and MFWD Oil
Grease
Maintenance—As Required
Service—As Required
Controls and Instruments Maintenance
Engine Maintenance
Daily Startup Procedure
Required Emission-Related Information
Avoid Fumes
Check Engine Oil Level
Change Engine Oil and Filter
Clean Dust Unloading Valve
Service the Alternator Belt
Clean Front and Side Grille Screens
Clean Engine Compartment
Air, Fuel, Coolant and Exhaust Maintenance
Service Air Filter Elements (S.N. J103921—)
Check Air Restriction Indicator
Check Air Filter Hose
Check and Drain Water Separator
Replace Fuel Filter
Fuel Injection Pump
Fuel Injection Nozzles
Drain and Flush Fuel Tank
Check Coolant Level
Drain and Flush Cooling System
Fill Cooling System
Check Radiator Hoses and Clamps
Clean Radiator, Fuel, and Transmission Cooling Fins
Electrical and Lighting Maintenance
Service Electrical
Service the Battery Safely
Remove and Install Battery
Clean Battery and Terminals
Use Booster Battery
Replace Headlight Bulb
Replace Tail/Turn Light Bulb
Replace Warning Light Bulb
Replace Fuses and Relays
Drivetrain Maintenance
Transmission Maintenance
Check Transmission Oil Level
Change Transmission Oil and Filter
Remove and Install Oil Suction Screen
MFWD and Front Axle Maintenance
Check Front Axle Oil Level
Change Front Axle Oil
Lubricate MFWD Driveshaft
Lubricate Main Driveline
Differential and Rear Axle Maintenance
Rear Axle
Power Take Off (PTO) Maintenance
PTO Maintenance
Steering and Brake Maintenance
Steering Maintenance
Brake Maintenance
Hydraulics Maintenance
Hydraulic Maintenance
Hitch and Drawbar Maintenance
Lubricate 3-Point Hitch
Selective Control Valve Maintenance
Check Selective Control Valve
Wheels and Tires Maintenance
Check Wheel Bolts and Hardware
Remove and Install Wheels
Check Tire Pressure
Tire Inflation Pressure Chart
Select Front Tire Rolling Direction
Lift Points for Jacking up the Tractor
Ballast Maintenance
Match Ballast to Work Load
Additional Equipment Maintenance
Operators Station Maintenance
Raise and Lower Hood
Remove and Install Side Panels
Inspect ROPS for Loose Hardware
Troubleshooting
Machine
Brakes
Steering
On-Board Diagnostics
Service Alert and Information Display
Specifications
Engine Specifications
Drivetrain Specifications
Hydraulic System Specifications
Electrical System Specifications
Fluid Capacities
Ground Speeds
Dimensions
Height from Ground
Ground Clearance
Turning Radius
Machine Weight
3-Point Hitch Specification
Sound Level
Coupling Devices
How to Calculate Maximum Permissible Download on Trailer Hitch
How to Calculate Permissible Mass
Identification Numbers
Product Identification Information
Record Identification Numbers
Certification and Warranty
Warranty
Service Records
Every 10 Hour or Daily Service
Every 50 Hour Service
Every 200 Hour Service
Every 400 Hour Service
Every 600 Hour Service
Yearly Service
Every 1000 Hour Service
Every 2000 Hour Service or Every Two Years
Every 6000 Hour Service or Every Six Years
Service as Required
Change of Ownership
Change of Ownership
Change of Ownership
Index
John Deere Service
John Deere Is At Your Service
Technical Information
