Martin Welker
104
230,310
John Deere 190E Excavator Operation And Test Manual TM1539
Brand: John Deere
Type of Machine: Excavator
Type of Manual: Operation And Test Manual
Model: John Deere 190E Excavator
Part Number: TM1539
Publication Date: 2005
Number of Pages: 433 Pages
FOREWORD
Section 9000 - GENERAL INFORMATION
Group 01 - Safety
Follow Safe Procedures
Prepare for Emergencies
Prevent Acid Burns
Handle Fluids Safely-Avoid Fires
Avoid High-Pressure Fluids
Warn Others of Service Work
Support Machine Properly
Operate Only from Operator′s Seat
Park Machine Safely
Stay Clear of Moving Parts
Avoid Power Lines
Use Handholds and Steps
Keep Riders Off Machine
Move and Operate Machine Safely
Wear Protective Clothing
Protect Against Flying Debris
Protect Against Noise
Illuminate Work Area Safely
Service Machines Safely
Beware of Exhaust Fumes
Use Proper Lifting Equipment
Service Cooling System Safely
Dispose of Waste Properly
Work in a Clean Area
Use Tools Properly
Replace Safety Signs
Live With Safety
Group 02 - General Specifications
190E
190E Drain And Refill Capacities
Group 03 - Torque Values
Unified Inch Bolt and Cap Screw Torque Values
Metric Bolt and Cap Screw Torque Values
Additional Metric Cap Screw Torque Values
Service Recommendations for O-Ring Boss Fittings
Service Recommendations for Flat Face O-Ring Seal Fittings
Service Recommendations for 37° Flare and 30° Cone Seat Connectors
Service Recommendations For Flared Connections-Straight or Tapered Threads
Service Recommendations For Inch Series Four Bolt Flange Fittings
Service Recommendations for Metric Series Four Bolt Flange Fitting
Group 04 - Fuels And Lubricants
Fuel Specifications
Engine Oil
Hydraulic Oil
Swing Gearbox And Propel Gearbox Oils
Track Roller, Front Idler, And Carrier Roller Oil
Grease
Section 9005 - OPERATIONAL CHECKOUT
Group 10 - Operational Checkout Procedure
Operational Checkout Record Sheet
Cooling System Checks
KEY SWITCH ACCESSORY CHECK
GAUGES, MONITOR, BATTERY RELAY CHECKS
MONITOR CIRCUIT, GAUGES AND HOUR METER
POWER MODE SWITCHES
ENGINE SPEED CONTROL SWITCHES
HYDRAULIC OIL WARM-UP INDICATOR CIRCUIT CHECK
AUTO-IDLE CIRCUIT
START AID SYSTEM
PILOT SHUT-OFF VALVE
TRAVEL ALARM
TRAVEL ALARM STOP CIRCUIT
PILOT CONTROLLER PATTERN CHECK (SAE PATTERN)
PILOT CONTROLLER PATTERN CHECK (JOHN DEERE PATTERN)
DIG FUNCTION DRIFT CHECKS
DYNAMIC SWING BRAKE
MECHANICAL SWING BRAKE RELEASE
SWING CIRCUIT LEAKAGE
DIG AND PROPEL PILOT PRESSURE SWITCHES
CONTROL VALVE LIFT CHECK AND LOAD CHECK TEST
PROPEL SPEED CHECK
BOOM OFFSET FUNCTION CHECK-IF EQUIPPED
OFFSET PEDAL LOCK CHECK
BLADE FUNCTION CHECK
PROPEL SYSTEM TRACKING CHECKS (WHILE OPERATING A DIGGING FUNCTION)
PROPEL SYSTEM RELIEF VALVE CHECK
CYCLE TIME
TRACK SAG, ROLLER AND IDLER LEAKAGE CHECKS
SPROCKET WEAR CHECK
GROUSER WEAR, BENT TRACK SHOE, AND LOOSE HARDWARE CHECKS
TRACK LINK ROLLER AND FRONT IDLER WEAR CHECKS
LIGHT CIRCUIT
WINDSHIELD WIPER CIRCUIT
HORN CIRCUIT
HEATER CONTROLS
SEAT CONTROL
CAB DOOR LATCH
CAB DOOR LOCK
LEFT AND RIGHT ACCESS DOORS AND TOOL BOX LOCK CHECK
FUEL CAP LOCK CHECK
HOOD CHECKS
VISUAL INSPECTION
PRESSURIZED HYDRAULIC OIL TANK CHECK
RADIATOR CAP
FAN DIRECTION
POWER MODE SWITCHES
AUTO-IDLE CIRCUIT
START AID SYSTEM
TRAVEL ALARM
DYNAMIC SWING BRAKE
PROPEL SPEED CHECK
CYCLE TIME
SPROCKET WEAR CHECK
LIGHT CIRCUIT
HORN CIRCUIT
HEATER CONTROLS
SEAT CONTROL
CAB DOOR LATCH
CAB DOOR LOCK
FUEL CAP LOCK CHECK
HOOD CHECKS
VISUAL INSPECTION
RADIATOR CAP
FAN DIRECTION
Section 9010 - ENGINE
Group 05 - Theory Of Operation
4039 John Deere Engine-Use CTM8
General Engine Description
Engine-Sectional View
Engine Speed Control System Operation
Group 10 - System Operational Checks
Engine Speed And Performance Checks
RADIATOR CAP CHECKS
COOLANT LEVEL AND COOLANT CONDITION IN OVERFLOW TANK CHECKS
COOLANT LEVEL AND COOLANT CONDITION IN RADIATOR CHECKS
RADIATOR OUTSIDE AIR FLOW CHECK
RADIATOR INTERNAL CORE CHECK
RADIATOR BUBBLE CHECK
HOSES, CLAMPS, AND WATER PUMP CHECKS
FAN CHECKS
FAN SHROUD AND FAN GUARD CHECKS
FAN BELT CHECKS
AIR FILTER RESTRICTION INDICATOR SWITCH CHECK
STARTING AID CHECKS
EXHAUST SMOKE CHECK
OIL LEVEL CHECK
WATER TRAP CHECK
FUEL CAP AND FUEL STRAINER
INSIDE FUEL TANK CHECK
FUEL PUMP CHECK
FUEL SYSTEM CHECK
ENGINE SPEED CHECK
ENGINE BLOW-BY CHECK
LOOSE OR WORN ENGINE PARTS
RADIATOR CAP CHECKS
FAN CHECKS
FAN BELT CHECKS
STARTING AID CHECKS
EXHAUST SMOKE CHECK
OIL LEVEL CHECK
WATER TRAP CHECK
FUEL PUMP CHECK
FUEL SYSTEM CHECK
ENGINE SPEED CHECK
Group 15 - Diagnostic Information
Diagnose Engine Malfunctions
Group 20 - Adjustments
JT05801 Clamp-On Electronic Tachometer Installation
Fan Belt Tension Adjustment
Engine Speed And Control Linkage Adjustment
Group 25 - Tests
Fuel Line Leakage Test
Air Filter Restriction Indicator Switch Test
Air Intake System Leakage Test
Radiator Air Flow Test
Section 9015 - ELECTRICAL SYSTEM
Group 05 - System Information
Battery Specifications
Battery Operation
Diagnose Battery Malfunctions
Check Battery Electrolyte Level And Terminals
Procedure For Testing Batteries
Using Booster Batteries-24 Volt System
Visually Inspect Electrical System
Electrical Circuit Malfunctions
High Resistance Circuit
Open Circuit
Grounded Circuit
Shorted Circuit
Multimeter
Seven Step Electrical Test Procedure
Wiring Diagram And Schematic Information
Reading A System Functional Schematic
Reading A Wiring Diagram
Electrical Schematic Symbols
Group 10 - System Diagrams
Component Identification Table
Replacing Fuses
Fuse (Blade-Type) Color Codes
Fuse Specifications
Wiring And Schematic Diagrams Legend
System Functional Schematic Section Legend
190E System Functional Schematic
Cab Harness (W6) Wiring Diagram
Cab Harness (W6) Component Location
Engine Harness (W5) Wiring Diagram
Engine Harness (W5) Component Location
Group 15 - Sub-System Diagnostics
Power Circuit Operational Information
Power Circuit Theory Of Operation
Power Circuit Diagnostic Procedures
BATTERY STATE OF CHARGE
BATTERY VOLTAGE CHECK
FUSIBLE LINK CHECK
KEY SWITCH CHECK
BATTERY RELAY CHECK
FUSE CHECK
FUSIBLE LINK CHECK
KEY SWITCH CHECK
BATTERY RELAY CHECK
FUSE CHECK
Charging Circuit Operational Information
Charging Circuit Theory Of Operation
Charging Circuit Diagnostic Procedures
CHARGE INDICATOR LIGHT CHECK
ALTERNATOR OUTPUT
ALTERNATOR CHECK
BATTERY RELAY CHECK
LOAD DUMP RELAY CHECK
SAFETY RELAY CHECK
ALTERNATOR OUTPUT
ALTERNATOR CHECK
BATTERY RELAY CHECK
SAFETY RELAY CHECK
Starting Circuit Operational Information
Starting Circuit Theory Of Operation
Starting Circuit Diagnostic Procedures
KEY SWITCH CHECK
START RELAY CHECK
SAFETY RELAY CHECK
FUEL SHUT-OFF SOLENOID CHECK
FUEL SHUT-OFF SOLENOID DIODE CHECK
KEY SWITCH CHECK
START RELAY CHECK
SAFETY RELAY CHECK
Windshield Wiper Circuit Operational Information
Windshield Wiper Circuit Theory Of Operation
Windshield Wiper Circuit Diagnostic Procedures
WINDSHIELD WIPER RELAY CHECK
WINDSHIELD WIPER SWITCH CHECK
WINDSHIELD WIPER MOTOR CHECK
WINDSHIELD WIPER MOTOR PARK CIRCUIT CHECK
Switch Panel 1 Circuit Operational Information
Switch Panel 1 Theory Of Operation
Switch Panel 1 Circuit Diagnostic Procedures
SWITCH PANEL 1 HARNESS CHECK
Switch Panel 2 Circuit Operational Information
Switch Panel 2 Theory Of Operation
Switch Panel 2 Circuit Diagnostic Procedures
SWITCH PANEL 2 HARNESS CHECK
SWITCH PANEL 2 CHECK
Light Circuit Operational Information
Light Circuit Theory Of Operation
Light Circuit Diagnostic Procedures
DRIVE LIGHT RELAY CHECK
WORK LIGHT RELAY CHECK
DRIVE LIGHT SWITCH CHECK
WORK LIGHT SWITCH CHECK
Horn, Dome Light, Optional Equipment And Heater Circuits Operational Information
Horn, Dome Light, Optional Equipment And Heater Circuits Theory Of Operation
Horn, Dome Light, Optional Equipment And Heater Circuits Diagnostic Procedures
HORN RELAY CHECK
HORN SWITCH CHECK
HORN CHECK
HEATER BLOWER SWITCH CHECK
HEATER BLOWER MOTOR CHECK
DOME LIGHT CHECK
HORN RELAY CHECK
HORN SWITCH CHECK
HORN CHECK
DOME LIGHT CHECK
Monitor Circuit Operational Information
Monitor Circuit Theory Of Operation
Monitor Circuit Diagnostic Procedures
ENGINE TEMPERATURE INDICATOR AND SWITCH CHECK
ENGINE OIL PRESSURE INDICATOR AND SWITCH CHECK
AIR FILTER RESTRICTION INDICATOR AND SWITCH CHECK
FUEL GAUGE CHECK
FUEL GAUGE SENDER CHECK
ENGINE TEMPERATURE GAUGE CHECK
COOLANT TEMPERATURE GAUGE SENDER CHECK
HOURMETER CHECK
FUEL GAUGE CHECK
HOURMETER CHECK
Auto Idle Circuit Operational Information
Auto Idle Circuit Theory Of Operation
Auto Idle Circuit Diagnostic Procedures
AUTO IDLE SWITCH TO EPC HARNESS CHECK
MODE SWITCH HARNESS FROM SWITCH PANEL 2 TO EPC CHECK
EC MOTOR HARNESS CHECK
EC SENSOR HARNESS CHECK
EC SENSOR CHECK
DIG PILOT PRESSURE SWITCH CHECK
DIG PILOT PRESSURE SWITCH HARNESS CHECK
PROPEL PILOT PRESSURE SWITCH CHECK
PROPEL PILOT PRESSURE SWITCH HARNESS CHECK
EC SENSOR CHECK
Warm-Up Circuit Operational Information
Warm-Up Circuit Theory Of Operation
Hydraulic Warm-Up Circuit Diagnostic Procedures
Engine And Pump Controller Circuit Operational Information
Engine And Pump Controller Circuit Theory Of Operation
Engine And Pump Controller Circuit Diagnostic Procedures
EC MOTOR RELAY CHECK
EC MOTOR CHECK
EC SENSOR CHECK
HYDRAULIC PUMP MAXIMUM DISPLACEMENT SOLENOID CHECK
HYDRAULIC PUMP MAXIMUM DISPLACEMENT SOLENOID HARNESS CHECK
EC MOTOR CHECK
EC SENSOR CHECK
Starting Aid And Propel Alarm Circuit Operational Information
Starting Aid And Propel Alarm Circuit Theory Of Operation
Starting Aid And Travel Alarm Circuit Diagnostic Procedures
STARTING AID RELAY CHECK
STARTING AID SWITCH CHECK
STARTING AID SWITCH TO RELAY HARNESS CHECK
STARTING AID SOLENOID CHECK
STARTING AID SOLENOID TO STARTING AID RELAY HARNESS CHECK
PROPEL ALARM FUSE TO PROPEL ALARM HARNESS CHECK
TRAVEL ALARM PRESSURE SWITCH CHECK
TRAVEL ALARM PRESSURE SWITCH TO TRAVEL ALARM HARNESS CHECK
TRAVEL ALARM CANCEL SWITCH CHECK
TRAVEL ALARM TO TRAVEL ALARM CANCEL SWITCH HARNESS CHECK
TRAVEL ALARM CANCEL SWITCH HARNESS GROUND CONNECTION CHECK
TRAVEL ALARM CHECK
TRAVEL ALARM CHECK
Group 20 - Adjustments And Additional Information
Connecting Engine And Pump Controller (EPC) Harness Connector
Disconnect Tab Retainer Connectors
Connector Pin Location And Numbers
Monitor Panel And Switch Panels
Monitor Panel
Switch Panel 1
Switch Panel 2
Switch Specifications
Section 9020 - POWER TRAIN
Track Adjuster Operation
Propel Gearbox Operation
Diagnose Undercarriage Components Malfunctions
Measure Track Chain Bushing Wear
Measure Track Chain Link Wear
Measure Lower Track Roller Wear
Measure Upper Track Roller Wear
Measure Front Idler Wear
Measure Track Chain Pitch
Measure Track Shoe Grouser Wear
Swing Bearing Wobble Test
Adjust Track Sag
Section 9025 - HYDRAULIC SYSTEM
Pilot System Operation
Pilot Pump And Pilot Filter Operation
Pump Displacement Solenoid Valve Operation
Pilot Shut-Off Valve Operation
Pilot Controller Operation-Neutral
Pilot Controller Operation-Metering
Flow Regulator Valve Operation
Pilot Pressure Regulating Valve Operation
Main Control Valve Operation
Control Valve Passages
System Relief Valve Circuit Operation
System Relief Valve Operation
Circuit Relief Valve Operation
Flow Combiner And Swing Brake Release Valve Circuit Operation
Bucket And Auxiliary Work Circuits Operation
Boom Up Work Circuit Operation
Boom Down Work Circuit Operation
Arm In Work Circuit Operation
Arm Out Work Circuit Operation
Swing Work Circuit Operation
Combined Functions Operation
Combined Swing And Boom Operations
Combined Boom And Propel Operations
Swing Motor Cover Operation
Swing Motor Relief Valve Operation
Swing Motor
Swing Brake Release Circuit Operation
Swing Gearbox Operation
Hydraulic Cylinder Operation
Engine And Pump Control Operation
Main Hydraulic Pump Operation
Main Hydraulic Pump Regulator Operation-High Maximum Displacement
Main Hydraulic Pump Regulator Operation-Low Maximum Displacement
Constant Horsepower System
Propel Circuit Operation
Propel Control Valve Operation
Rotary Manifold Operation
Propel Motor Construction
Propel Motor Operation
Counterbalance Valve Neutral Operation
Counterbalance Valve Operation
Propel Relief Valve Operation
Propel Brake Operation
Suction, Supply And Return Circuits Operation
Hydraulic Oil Tank Operation
Pilot And Blade Pump Operation
Blade Control Valve Operation
Blade Hydraulic System Operation
Diagnose Hydraulic System Malfunctions
Diagnose Pilot Circuit Malfunctions
Diagnose Dig Circuit Malfunctions
Diagnose Swing Circuit Malfunctions
Diagnose Propel System Malfunctions
Hydraulic Circuit Symbols
Propel Circuit Component Location
Pilot Circuit Component Location
Main Hydraulic Circuit Component Location
Offset Boom And Blade Circuit Component Location
Pilot Control Lever Pattern Information
Pilot Shut-Off Valve Linkage Adjustment
Group 25 - Tests
Self Diagnosing Function Fault Codes-Engine And Pump Controller (EPC)
Component Abbreviations
Outline Of The Control System
Monitor Function Display List And Description
Cross Reference To Display Symbols And List, Unit Of Measure
Retry Procedure A
Retry Procedure B
JT05800 Digital Thermometer Installation
Hydraulic System Warm-Up Procedure
Hydraulic Pump Start-Up Procedure
Swing Motor Start-Up Procedure
Swing Gearbox Start-Up Procedure
Propel Motor Start-Up Procedure
Hydraulic Oil Filter Inspection Procedure
Hydraulic Oil Cleanup Procedure Using Portable Filter Caddy
Cycle Time Test
Pilot Pressure Regulating Valve Test And Adjustment
Dig And Propel System Relief Valve Test And Adjustment
Circuit Relief Valve Test And Adjustment
Swing Motor Crossover Relief Valve Test And Adjustment
Main Hydraulic Pump Performance Test (Cycle Time Method)
Hydraulic Pump Regulator Test And Adjustment (Engine Pulldown)
Pilot Pump Flow Test
Hydraulic Pump Flow Test
Propel Motor Operating Leakage Test
Swing Motor Leakage Test
Arm, Boom, And Bucket Cylinder Drift Test
Blade System Relief Valve Test And Adjustment
Blade Circuit Relief Valve Test And Adjustment
Blade Hydraulic Pump Flow Test
TM Worksheet 190E
