John Deere 1640 1840 2040 2040S Tractor Technical Manual TM4363
Brand: John Deere
Type of Manual: Technical Manual
Model: John Deere 1640 1840 2040 2040S Tractor
Part Number: TM4363
Number of Pages: 1256 Pages
SECTION 10 — GENERAL
Group 00 — Specifications and special tools
Group 05 — Pre-delivery, delivery and after-sales inspections
Group 10 — Lubrication and periodic service
Group 15 — Engine and tractor tune~up
Group 20 — Tractor separation (tractors without increased lifting capacity)
Group 25 — Tractor separation (tractors with increased lifting capacity)
SECTION 20 — ENGINE
Group 00 - Specifications
Group 05 — Radiator
SECTION 30 — FUEL AND AIR INTAKE SYSTEM
Group 05 — Diagnosing malfunctions
Group 10 — Fuel tank and water trap
Group 15 - Cold weather starting aids
Group 20 — Speed control linkage
Group 25 — Air cleaner
SECTION 40 — ELECTRICAL SYSTEM _
Group 00 -- Specifications and special tools.
Group 05 — Description, diagnosing malfunctions and tests
Group 10 — Wiring harnesses
Group 15 -— Controls and instruments
Group 20 — Lighting system
Group 25 — Wiring diagrams
Group 30 —. Starting motor
Group 35 — Alternator
SECTION 50 — POWER TRAIN
Group 05 -- Description, operation and lubricating system
Group 10 - Clutch operating linkages
Group 15 — Engine clutches
Group 20 — Hi-Lo shift unit
Group 25 — Creeper transmission
Group 30 — Transmission shift linkage
Group 35 - Synchronized transmission and transmission oil pump
Group 40 — Collar shift transmission and-transmission oil pump
GrOUp 45 — Differential
Group 50 - Final drives
GrOUp 55 — independent PTO
Group 60 — Continuous-running PTO
Group 61 — Front PTO
Group 65 — Mechanical front wheel drive
SECTION 60 —— STEERING SYSTEM AND BRAKES
Group 05 - Hydrostatic steering (operating pressure: 12000 kPa; 120 bar; 1740 psi)
Group 06 — Hydrostatic steering {operating pressure: 13000 kPa; 150 bar; 2180 psi)
Group 10 — Power steering
Group 15 — Manual steering
Group20 - Brakes
SECTION 70 - HYDRAULIC SYSTEM
Group 05 — Description, diagnosing malfunctions and pressure tests
Group 10 — Oil reservoir, filter, valves and oil cooler
Group 15 — Hydraulic pumps
Group 20 - Rockshaft
Group 21 — Front hitch
Group 25 — Selective control valves (spool type)
Group 30 — Selective control valves (poppet valve type)
Group 35 — Hose couplers
Group 40 — Remote cylinder
Group 45 — Selective control valves (for tractors manufactured in Spain)
SECTION 80 — MISCELLANEOUS
Group 05 — Front axle
Group 10 — Belt pulley
Group 15 — Front and rear wheels
Group 20 — Axle trailer hitch
SECTION 90 - OPERATOR'S CAB
Group 05 — Air Conditioning system -
GrOup 10 — Cab ventilation and heating
Group 15 — Operator's seats
Group 20 — OPU cab
Group 25 — SG2 cab
Group 30 — Roll guard
Brand: John Deere
Part Number: TM4363
SECTION 20 — ENGINE
Group 05 — Radiator
Group20 - Brakes
Group 20 — OPU cab
Group 25 — SG2 cab
- JOHN DEERE CODE DTC LIST
