John Deere 145 Series Power Unit Parts Catalog PC0537
Brand: John Deere
Type of Machine: Power Unit
Model: John Deere 145 Series Power Unit
Part Number: PC0537
Number of Pages: 149 Pages
ALPHABETICAL INDEX
A
Adapter, Starting Motor
Air Cleaner
Air Cleaner Cap
Air Cleaner Support
Air Pre-Cleaner Attachment
Air Scoop
Ammeter (TA-G, TA-L)
Armature, Generator
Armature, Starting Motor
B
Battery Tray
Bayonet Oil Gauge
Bearings, Connecting Rod
Bearing, Main
Bell Crank, Governor (TA-G, TA-L)
Belt, Fan
Belt, Fan and Generator
Belt, Water Pump
Block, Cylinder
Box, Battery (EA-G, EB-G, HD-G)
Bracket, Converter
Bracket, Fuel Strainer
Bracket, Idler (TA-G, TA-L Magneto)
Breather Cap, Oil
Brushes, Generator
Brushes, Starting Motor
C
Cable, Choke (TA-G, TA-L)
Cable, Engine Ground
Cable, Ground
Cable, Spark Plug
Cable, Starter
Camshaft
Camshaft Brushings
Camshaft Rear Cover
Cap, Air Cleaner
Cap, Fuel Tank (TA-G)
Cap, Main Bearing (EA-G, EB-G, HC-G, HC-L, HD-G)
Cap, Main Bearing (HA-G, HA-L, HB-G, HB-L, TA-G, TA-L)
Cap, Muffler Weather (TA-G, TA-L)
Cap, Oil Filler (TA-G, TA-L)
Cap, Radiator
Carburetor, Gasoline
Carburetor, LP-Gas
Choke Cable (TA-G, TA-L)
Coil
Condenser, Distributor
Connecting Rod Bearings
Connecting Rods
Converter Bracket
Converter, LP-Gas
Cover, Camshaft Rear
Cover, Engine (TA-G, TA-L)
Cover, Engine Gear (EA-G, EB-G, HC-G, HC-L, HD-G)
Cover, Engine Gear (HA-G, HA-L, HB-G, HB-L, TA-G, TA-L)
Cover, Rocker Arm
Cover, Tappet
Crank Guide (TA-G, TA-L)
Current-Voltage Regulator
Cut-Out Switch (TA-G, TA-L)
Cylinder Head Gasket
Cylinder Liner Plate
Decalcomania Kit
Distributor
Distributor Condenser
Distributor Points
E
Element, Oil Filter
Engine Cover (TA-G, TA-L)
Engine Gear Cover (EA-G, EB-G, HC-G, HC-L, HD-G)
Engine Ground Cable
Engine Hood (EA-G, EB-G, HD-G)
Engine Overhaul Gasket Set
Engine Rear Cover
Engine Support
Engine Tune-Up Gasket Set
Engine Valve Stem Lubricant
F
Fan Assembly (HB-G, HB-L, HC-G, HC-L)
Fan Belt
Fan and Generator Belt
Flywheel
Flywheel Housing
Front Cover, Engine
Front End Support (EA-G, EB-G, HD-G)
Front End Support (TA-G, TA-L)
Front Oil Seal
Fuel Lines (EA-G, EB-G, HA-G, HB-G, HC-G, HD-G)
Fuel Lines (TA-G)
Fuel Lines, LP-Gas (HA-L)
Fuel Lines, LP-Gas (HB-L, TA-L)
Fuel Lines, LP-Gas (HC-L)
Fuel Pump
Fuel Strainer Bracket
Fuel Strainer, LP-Gas
Fuel Tank (TA-G)
Fuel Tank Cap (TA-G)
Fuel Tank Support (TA-G)
G
Gasket, Cylinder Head
Gasket Set, Engine Overhaul
Gasket Set, Engine Tune-Up
Gasoline Carburetor
Gauge, Oil Safety (TA-G, TA-L)
Gauge, Water Safety (TA-G, TA-L)
Gauges (TA-G, TA-L)
Generator
Generator Armature
Generator Brushes
Generator and Fan Belt
Generator and Water Pump Belt
Governor
Governor, Bell Crank (TA-G, TA-L)
Governor Weight
Grille (TA-G, TA-L)
Ground Cable
Guide, Crank (TA-G, TA-L)
Hood, Engine (EA-G, EB-G, HD-G)
Hose, Radiator
Housing, Flywheel
I
ID VIEW
Idler Bracket (TA-G, TA-L Magneto)
Idler Pulley (TA-G, TA-L Magneto)
Ignition Switch (TA-G, TA-L)
Instrument Panel (TA-G, TA-L)
J
"John Deere" Name Plate (TA-G, TA-L)
K
Kit, Carburetor
Kit, Converter, LP-Gas
Kit, Manifold Gasket
Kit, Storage
Kit, Wire, Lead
L
Lever, Speed Control (TA-G, TA-L)
Lines, Fuel (EA-G, EB-G, HA-G, HB-G, HC-G, HD-G)
Lines, Fuel (TA-G)
LP-Gas Carburetor
LP-Gas Converter
LP-Gas Fuel Lines (HA-L)
LP-Gas Fuel Lines (HB-L, TA-L)
LP-Gas Fuel Lines (HC-L)
LP-Gas Fuel Strainer
LP-Gas Sump
M
Magneto (TA-G, TA-L)
Main Bearing Caps (EA-G, EB-G, HC-G, HC-L, HD-G)
Main Bearing Caps (HA-G, HA-L, HB-G, HB-L, TA-G, TA-L)
Main Bearings (EA-G, EB-G, HC-G, HC-L, HD-G)
Main Bearings (HA-G, HA-L, HB-G, HB-L, TA-G, TA-L)
Manifold and Muffler
Manifold Gasket Kit
Manifold, Water
Muffler and Manifold
Muffler Weather Cap (TA-G, TA-L)
N
Name Plate, "John Deere" (TA-G, TA-L)
O
Oil Breather Cap
Oil Filler Cap (TA-G, TA-L)
Oil Filter
Oil Filter Element
Oil Gauge, Bayonet
Oil Pan
Oil Pressure Sensing Unit (HA-G, HA-L, HB-G, HB-L, HC-G, HC-L)
Oil Pump
Oil Safety Gauge (TA-G, TA-L)
Oil Seal, Front
Oil Seal, Rear
P
Pan, Oil
Panel, Instrument (TA-G, TA-L)
Panel, Side (TA-G, TA-L)
Piston Rings
Piston Rods
Pistons
Plate, Cylinder Liner
Points, Distributor
Pre-Cleaner
Pulley
Pulley, Idler (TA-G, TA-L Magneto)
Pump, Fuel
Pump, Oil
Pump, Water
R
Radiator Cap
Radiator Hose
Radiator Screen
Radiator Support
Rear Cover, Engine
Rear Generator Support
Rear Oil Seal
Regulator, Current-Voltage
Rocker Arm Cover
Rocker Arm Cover Gasket
Rocker Arms
S
Scoop, Air
Screen, Radiator
Side Panel (TA-G, TA-L)
Skid, Transport Attachment (TA-G, TA-L)
Sleeve Plate Gasket
Solenoid, Starting Motor
Spark Plug Cables
Spark Plug Wires
Spark Plugs
Speed Control Lever (TA-G, TA-L)
Stand, Transport Attachment (TA-G, TA-L)
Starter Cable
Starter Switch (TA-G, TA-L)
Starting Magnetic Switch
Starting Motor
Starting Motor Adapter
Starting Motor Armature
Starting Motor Brushes
Starting Motor Solenoid
Sump, LP-Gas
Support, Air Cleaner
Support, Engine
Support, Front End (EA-G, EB-G, HD-G)
Support, Front End (TA-G, TA-L)
Support, Fuel Tank (TA-G)
Support, Generator, Rear
Suport, Radiator
Switch, Cut-Out (TA-G, TA-L)
Switch, Ignition (TA-G, TA-L)
Switch, Starter (TA-G, TA-L)
Switch, Starting Magnetic
Switches (TA-G, TA-L)
T
Tank, Fuel (TA-G)
Tapper Cover
Temperature Sensing Unit
Thermostat]
Tongue, Transport Attachment (TA-G, TA-L)
Transport Attachment Skid (TA-G, TA-L)
Transport Attachment Stand (TA-G, TA-L)
Transport Attachment Tongue (TA-G, TA-L)
Transport Attachment Wheel Hub (TA-G, TA-L)
Tray, Battery
U
Unit, Oil Pressure Sending (HA-G, HA-L, HB-G, HB-L, HC-G, HC-L)
Unit, Temperature Sensing
V
Valves
Valve Stem Lubricant, Engine
W
Water Manifold
Water Manifold Gasket
Water Pump Belt
Water Safety Gauge (TA-G, TA-L)
Weight, Governor
Wheel Hub, Transport Attachment (TA-G, TA-L)
Wire Kit, Lead
Wiring, Spark Plug
Wiring, Harness (TA-G, TA-L)
Brand: John Deere
Part Number: PC0537
ALPHABETICAL INDEX
A
Air Cleaner
Air Cleaner Cap
Air Cleaner Support
Air Scoop
Armature, Generator
B
Battery Tray
Bayonet Oil Gauge
Bearing, Main
Belt, Fan
Belt, Water Pump
Block, Cylinder
Bracket, Converter
Breather Cap, Oil
Brushes, Generator
C
Cable, Ground
Cable, Spark Plug
Cable, Starter
Camshaft
Camshaft Brushings
Camshaft Rear Cover
Cap, Air Cleaner
Cap, Radiator
Carburetor, LP-Gas
Coil
Connecting Rods
Converter Bracket
Converter, LP-Gas
Cover, Rocker Arm
Cover, Tappet
Decalcomania Kit
Distributor
Distributor Points
E
Element, Oil Filter
Engine Ground Cable
Engine Rear Cover
Engine Support
F
Fan Belt
Flywheel
Flywheel Housing
Front Cover, Engine
Front Oil Seal
Fuel Lines (TA-G)
Fuel Pump
Fuel Tank (TA-G)
G
Gasoline Carburetor
Gauges (TA-G, TA-L)
Generator
Generator Armature
Generator Brushes
Governor
Governor Weight
Grille (TA-G, TA-L)
Ground Cable
Hose, Radiator
Housing, Flywheel
I
ID VIEW
J
K
Kit, Carburetor
Kit, Storage
Kit, Wire, Lead
L
Lines, Fuel (TA-G)
LP-Gas Carburetor
LP-Gas Converter
LP-Gas Sump
M
Manifold Gasket Kit
Manifold, Water
N
O
Oil Breather Cap
Oil Filter
Oil Filter Element
Oil Gauge, Bayonet
Oil Pan
Oil Pump
Oil Seal, Front
Oil Seal, Rear
P
Pan, Oil
Piston Rings
Piston Rods
Pistons
Points, Distributor
Pre-Cleaner
Pulley
Pump, Fuel
Pump, Oil
Pump, Water
R
Radiator Cap
Radiator Hose
Radiator Screen
Radiator Support
Rear Cover, Engine
Rear Oil Seal
Rocker Arm Cover
Rocker Arms
S
Scoop, Air
Screen, Radiator
Sleeve Plate Gasket
Spark Plug Cables
Spark Plug Wires
Spark Plugs
Starter Cable
Starting Motor
Sump, LP-Gas
Support, Engine
Suport, Radiator
T
Tank, Fuel (TA-G)
Tapper Cover
Thermostat]
Tray, Battery
U
V
Valves
W
Water Manifold
Water Pump Belt
Weight, Governor
Wire Kit, Lead
Wiring, Spark Plug
- JOHN DEERE CODE DTC LIST
