John Deere 1350 1360 1460 1470 Mower-Conditioners Technical Manual TM3268
- Download this document, you need 300 Gallons
Brand: John Deere
Type of Machine: Mower-Conditioners
Type of Manual: Technical Manual
Model: John Deere 1350 1360 1460 1470 Mower-Conditioners
Part Number: TM3268
Publication Date: 2003
Number of Pages: 195 Pages
Safety
PREPARE FOR EMERGENCIES
AVOID HIGH-PRESSURE FLUIDS
PARK MACHINE SAFELY
SUPPORT MACHINE PROPERLY
WEAR PROTECTIVE CLOTHING
WORK IN CLEAN AREA
SERVICE MACHINES SAFELY
ILLUMINATE WORK AREA SAFELY
REPLACE SAFETY SIGNS
USE PROPER LIFTING EQUIPMENT
REMOVE PAINT BEFORE WELDING OR HEATING
AVOID HEATING NEAR PRESSURIZED FLUID LINES
SERVICE TIRES SAFELY
PRACTICE SAFE MAINTENANCE
USE PROPER TOOLS
DISPOSE OF WASTE PROPERLY
LIVE WITH SAFETY
General Specifications
1350 MOWER-CONDITIONER
1360 MOWER-CONDITIONER
1460 MOWER-CONDITIONER
1470 MOWER-CONDITIONER
UNIFIED INCH BOLT AND CAP SCREW TORQUE VALUES
METRIC BOLT AND CAP SCREW TORQUE VALUES
LOCKING COLLARS FOR SHAFT BEARINGS
LUBRICATION
Power Train
Powerline Specifications
SPECIAL OR ESSENTIAL TOOLS
TORQUES FOR HARDWARE
Front and Rear Powerlines
REMOVE FRONT POWERLINE
FRONT POWERLINE — EXPLODED VIEW (NORTH AMERICA)
FRONT POWERLINE — EXPLODED VIEW (EXCEPT NORTH AMERICA)
INSTALL FRONT POWERLINE
REMOVE REAR POWERLINE
REAR POWERLINE — EXPLODED VIEW (EXCEPT NORTH AMERICA)
INSTALL REAR POWERLINE
REMOVE HALF GUARD
INSTALL HALF GUARD
DISASSEMBLE HOOK-UP
ASSEMBLE HOOK-UP
DISASSEMBLE COUPLER (NORTH AMERICA)
DISASSEMBLE COUPLER (EXCEPT NORTH AMERICA)
Rear Powerline (North America)
DISASSEMBLE WIDE ANGLE CV JOINT SHIELD
REAR POWERLINE — EXPLODED VIEW (NORTH AMERICA)
Slip Clutch
SPECIFICATIONS
DESCRIPTION
REMOVE SLIP CLUTCH
DISASSEMBLE SLIP CLUTCH
SLIP CLUTCH — EXPLODED VIEW
SLIP CLUTCH INSPECTION
ASSEMBLE AND INSTALL SLIP CLUTCH
ADJUST SLIP CLUTCH
Main Gear Case
SELF-MANUFACTURED TOOLS
MATERIAL REQUIRED
SPECIFICATIONS
SPECIFICATIONS (CONTINUED)
MAIN GEAR CASE DESCRIPTION
REMOVE GEAR CASE
INSTALL GEAR CASE
REMOVE CUTTERBAR DRIVE
DISASSEMBLE CUTTERBAR DRIVE
CUTTERBAR DRIVE — EXPLODED VIEW
INSTALL CUTTERBAR DRIVE
REMOVE CONDITIONER DRIVE
DISASSEMBLE CONDITIONER DRIVE
CONDITIONER DRIVE — EXPLODED VIEW
INSTALL CONDITIONER DRIVE
REMOVE PRIMARY DRIVE
DISASSEMBLE PRIMARY DRIVE
PRIMARY DRIVE — EXPLODED VIEW
INSTALL PRIMARY DRIVE
ADJUST SPIRAL BEVEL GEAR
ADJUST CONDITIONER BEVEL GEAR
ADJUST TOOTH CONTACT
Swivel Gear Case
MATERIAL REQUIRED
SPECIFICATIONS
REMOVE SWIVEL GEAR CASE
SWIVEL HITCH — EXPLODED VIEW
SWIVEL TONGUE — EXPLODED VIEW
INSTALL SWIVEL GEAR CASE
DISASSEMBLE SWIVEL GEAR CASE
SWIVEL GEAR CASE — EXPLODED VIEW
Lift Cylinder
MATERIAL REQUIRED
TORQUES FOR HYDRAULIC FITTINGS
DESCRIPTION OF LIFT CYLINDER
RECOMMENDATIONS FOR DISASSEMBLY AND INSPECTION OF LIFT CYLINDER
REMOVE LIFT CYLINDER (RIGHT AND LEFT)
DISASSEMBLE LIFT CYLINDER (RIGHT AND LEFT)
LEFT-HAND LIFT CYLINDER, EXPLODED VIEW
RIGHT-HAND LIFT CYLINDER, EXPLODED VIEW
INSTALL LIFT CYLINDER
BLEED HYDRAULIC LINE
Cutting Components
Disks
DISKS — EXPLODED VIEW
REMOVE INNER DISKS
INSTALL INNER DISKS
REMOVE OUTER DISKS
INSTALL OUTER DISKS
Cutterbar
MATERIAL REQUIRED
REMOVE CUTTERBAR
SEPARATE CUTTERBAR
1350 CUTTERBAR — EXPLODED VIEW
1360-1460 CUTTERBAR — EXPLODED VIEW
1470 CUTTERBAR — EXPLODED VIEW
ASSEMBLE CUTTERBAR
INSTALL CUTTERBAR
DISASSEMBLE INNER QUILL BEARING
DISASSEMBLE OUTER QUILL BEARING
Knives
REMOVE KNIVES
INSTALL KNIVES
DIRECTION OF KNIFE ROTATION
Rotor
Impeller (1350, 1360)
MATERIAL REQUIRED
SPECIFICATIONS
REMOVE IMPELLER
IMPELLER — EXPLODED VIEW
INSTALL IMPELLER
Roll Drive Gear Case (1460, 1470)
MATERIAL REQUIRED
SPECIFICATIONS
REMOVE ROLL DRIVE GEAR CASE
DISASSEMBLE ROLL DRIVE GEAR CASE
ROLL DRIVE GEAR CASE — EXPLODED VIEW
INSTALL ROLL DRIVE GEAR CASE
Roll Drive Shafts (1460, 1470)
MATERIAL REQUIRED
SPECIFICATIONS
REMOVE ROLL DRIVE SHAFTS
DISASSEMBLE ROLL DRIVE SHAFTS
ROLL DRIVE SHAFTS — EXPLODED VIEW
INSTALL ROLL DRIVE SHAFTS
Rolls (1460, 1470)
MATERIAL REQUIRED
REMOVE ROLLS
ROLLS — EXPLODED VIEW
INSTALL ROLLS
REMOVE AND INSTALL ROLL ENDS
Rotor Housing
Torsion Bar (1460, 1470)
SPECIFICATIONS
REMOVE TORSION BAR
TORSION BAR — EXPLODED VIEW (RIGHT-HAND)
TORSION BAR — EXPLODED VIEW (LEFT-HAND)
INSTALL TORSION BAR
Index
A
Adjustments
Conditioner bevel gear
Spiral bevel gear
Tooth contact
B
Bearing locking collars
C
Adjustment
Conditioner drive
Assembly
Disassemble
Exploded view
Installation
Removal
Coupler (Except North America)
Assembly
Disassembly
Coupler (North America)
Assembly
Disassembly
Cutterbar
Assembly
Exploded View 1350
Exploded View 1360-1460
Exploded View 1470
Installation
Removal
Separation
Cutterbar drive
Assembly
Disassembly
Exploded view
Installation
Removal
D
Disks
Exploded view
Inner disk installation
Inner disk removal
Outer disk installation
Outer disk removal
F
Front powerline
Exploded view (North America)
Exploded view (Not North America)
Installation
Removal
G
Gear case
Description
Installation
Removal
H
Half guard
Installation
Removal
Hook-up
Assembly
Disassembly
I
Impeller
Exploded view
Installation
Removal
Inch torque values
Inner quill bearing
Assembly
Disassembly
K
Knives
Direction of rotation
Installation
Removal
L
Lift cylinder
Assembly
Bleeding
Description
Disassembly
Exploded view
Installation
Removal
Locking collars for bearings
Lubrication
M
Main gear case
Description
Metric torque values
O
Outer quill bearing
Assembly
Disassembly
P
Primary drive
Assembly
Disassembly
Exploded view
Installation
Removal
R
Rear powerline
Installation
Removal
Roll drive gear case
Assembly
Disassembly
Exploded view
Installation
Removal
Roll drive shafts
Assembly
Disassembly
Exploded view
Installation
Removal
Roll ends
Installation
Removal
Removal/installation information
Rolls
Exploded view
Installation
Removal
S
Slip clutch
Adjustment
Assembly and installation
Description
Disassembly
Inspection
Removal
Specifications
1350 Mower-Conditioner
1360 Mower-Conditioner
1460 Mower-Conditioner
Spiral bevel gear
Adjustment
Swivel gear case
Assembly
Disassembly
Exploded view
Installation
Removal
T
Tooth contact
Adjustment
Torque values
Inch
Metric
Torsion bar
Exploded view (left-hand)
Exploded view (right-hand)
Installation
Removal
W
Wide angle CV joint
Assembly
Disassembly
Wide angle CV joint shield
Assembly
Disassembly
PAGE NUMBERS
Brand: John Deere
Part Number: TM3268
Safety
PARK MACHINE SAFELY
WORK IN CLEAN AREA
USE PROPER TOOLS
LIVE WITH SAFETY
LUBRICATION
Power Train
REMOVE HALF GUARD
INSTALL HALF GUARD
DISASSEMBLE HOOK-UP
ASSEMBLE HOOK-UP
Slip Clutch
SPECIFICATIONS
DESCRIPTION
REMOVE SLIP CLUTCH
ADJUST SLIP CLUTCH
Main Gear Case
MATERIAL REQUIRED
SPECIFICATIONS
REMOVE GEAR CASE
INSTALL GEAR CASE
Swivel Gear Case
MATERIAL REQUIRED
SPECIFICATIONS
Lift Cylinder
MATERIAL REQUIRED
Cutting Components
Disks
REMOVE INNER DISKS
INSTALL INNER DISKS
REMOVE OUTER DISKS
INSTALL OUTER DISKS
Cutterbar
MATERIAL REQUIRED
REMOVE CUTTERBAR
SEPARATE CUTTERBAR
ASSEMBLE CUTTERBAR
INSTALL CUTTERBAR
Knives
REMOVE KNIVES
INSTALL KNIVES
Rotor
MATERIAL REQUIRED
SPECIFICATIONS
REMOVE IMPELLER
INSTALL IMPELLER
MATERIAL REQUIRED
SPECIFICATIONS
MATERIAL REQUIRED
SPECIFICATIONS
Rolls (1460, 1470)
MATERIAL REQUIRED
REMOVE ROLLS
INSTALL ROLLS
Rotor Housing
SPECIFICATIONS
REMOVE TORSION BAR
INSTALL TORSION BAR
Index
A
Adjustments
Spiral bevel gear
Tooth contact
B
C
Adjustment
Conditioner drive
Assembly
Disassemble
Exploded view
Installation
Removal
Assembly
Disassembly
Assembly
Disassembly
Cutterbar
Assembly
Exploded View 1350
Exploded View 1470
Installation
Removal
Separation
Cutterbar drive
Assembly
Disassembly
Exploded view
Installation
Removal
D
Disks
Exploded view
Inner disk removal
Outer disk removal
F
Front powerline
Installation
Removal
G
Gear case
Description
Installation
Removal
H
Half guard
Installation
Removal
Hook-up
Assembly
Disassembly
I
Impeller
Exploded view
Installation
Removal
Inch torque values
Inner quill bearing
Assembly
Disassembly
K
Knives
Installation
Removal
L
Lift cylinder
Assembly
Bleeding
Description
Disassembly
Exploded view
Installation
Removal
Lubrication
M
Main gear case
Description
O
Outer quill bearing
Assembly
Disassembly
P
Primary drive
Assembly
Disassembly
Exploded view
Installation
Removal
R
Rear powerline
Installation
Removal
Assembly
Disassembly
Exploded view
Installation
Removal
Roll drive shafts
Assembly
Disassembly
Exploded view
Installation
Removal
Roll ends
Installation
Removal
Rolls
Exploded view
Installation
Removal
S
Slip clutch
Adjustment
Description
Disassembly
Inspection
Removal
Specifications
Spiral bevel gear
Adjustment
Swivel gear case
Assembly
Disassembly
Exploded view
Installation
Removal
T
Tooth contact
Adjustment
Torque values
Inch
Metric
Torsion bar
Installation
Removal
W
Wide angle CV joint
Assembly
Disassembly
Assembly
Disassembly
PAGE NUMBERS
- JOHN DEERE CODE DTC LIST
