Martin Welker
104
230,792
John Deere 1165 And 1175 Combines Operators Manual OMCQ34801
Format: HTML
Brand: John Deere
Type of Machine: Combines
Model: John Deere 1165 And 1175 Combines
Parts Number: OMCQ34801
Foreword
Section : 05 - Safety
Acknowledge the Safety Information
Follow Safety Instructions
Observe the Traffic Norms
Avoid Accidentally Starting the Machine.
Use the Lights and Other Safety Devices
Prepare for Emergencies
Wear Protective Clothing
Handle Fuel Carefully-Avoid Fires
Check the Safe Operation of the Combine
Transport on a Truck
Driving the Combine
Keep Riders and Children Away From the Machine
Wear Seat Belts
Stay Clear of Rotating Shafts.
Avoid Power Lines
Protection Device
Stay Clear of Harvesting Units
Care with the Cutter Blades
Safe Operation of the Straw Chopper
Cleaning the Grain Tank and Removal of Obstructions
Driving with the Cutting Platform Coupled
Use of Counterweights
Close the Grain Tank Unloading Auger
Stopping the Combine
Operation of the Engine
Maintenance Safety
Service Machines Safely
Remove Built-up Crop Debris
Support Machine Safely
Engine Maintenance
Tightening the Wheel Nuts
Avoid High-Pressure Fluids
Prevent Battery Explosions
Handle Batteries Safely
Service Tires Safely
Safe Maintenance of the Radiator
Observe the Environment Protection Laws
Emergency Exit
Section : 10 - Safety Stickers
Safety Decals
Operation Manual
Repairs and Maintenance
Left Side Combine Shields
Chopper
Chopper
Work Platform Access Ladder
Right Side Combine Shields
Section : 15 - Control and Instruments
General View Of Controls And Instruments
Instrument Panel
Clutch Pedal
Steering Column Lock Pedal
Work Brake Pedals
Shift Lever
Header Height Control Lever
Travel Speed Control Lever
Reel Height Control Lever
Throttle
Reel Speed Variator Knob
Grain Tank Unloading Auger Drive Lever
Grain Tank Unloading Drive Lever
Threshing Transmission Drive Lever
Header Transmission Drive Lever
Park Brake
Cylinder Speed Variator Lever (Machines with Posi-Torq Transmission)
Cylinder Speed Variator Knob (Machines without Posi-Torq)
Concave Clearance Adjustment Lever
Warning Light
Alternator Warning Light
Engine Oil Pressure Warning Light
Park Brake Warning Light
Transmission Oil Temperature Warning Light
Grain Tank 3/4 Full Warning Light
Neutral Warning Light
Engine Coolant Temperature Warning Light
Hydraulic Oil Filter Obstruction Warning Light
Air Filter Obstruction Warning Light
Full Beam Warning Light
Hazard Lights Warning Light
Main and Key Switch
Automatic Header Control (AHC) Selector
Speedometer or Tachometer Selector on the Cylinder Indicator
Cylinder Speedometer or Tachometer
Cooling System Temperature Gauge
Fuel Level Gauge
Hour Meter
Turn Indicator Lights Rotary Switch and Headlights
Rotary Switch for the Auxiliary Lights, the Internal Lighting for the Grain Tank, the Awning or Cab and Unloading Auger Lights.
Hazard Lights Switch
Horn
Alert Sound Emitter
Other Controls-Off the Operating Platform
Operating Platform Access Ladder
Operator Seat
Useful Compartments
Accessing the cab
Cab Controls and Items
Section : 20 - Lights and Lighting System
Headlights
Auxiliary Lights
Awning Lights
Internal Grain Tank Lighting
Turn Indicator Lights, Hazard Lights and Brake Lights
Section : 25 - Combine Operation
Check daily-Before Starting the Engine
Engine Oil
Radiator Fluid
Hydraulic Oil
Combine Lubrication
Starting the Engine
Turning Off the Engine
Driving on Public Roads
Moving the Combine
Shifting the Gears
Engine-Break in Period
Servicing-Break In Period
Section : 30 - Basic Fundamentals
Basic Fundamentals of the Combine
Cutting and Pickup Unit
Cutting Platform
Side Tilt Master System (Optional item for 1175 only)
Feeder House
Threshing Unit
Cylinder and Bar Concave
Special Small Grain Bar Concave (Accessory)
Cylinder and Tooth Concave
Threshing Evaluation
Separation Unit
Curtain Over the Straw Walker
Separation Evaluation
Cleaning Units
Chaffer
Chaffer Extension
Sieve
Fan
Cleaning Evaluation
Grain Transport and Storage Unit
How to Avoid Grain Losses-Limiting Losses
Determining Losses
Source of Losses
Ways of Measuring Losses
1° Step: Harvest Yield
2° Step: Pre-Harvest Losses
3° Step: Cutting Platform Losses
4° Step: Threshing, Straw Walker and Shoe Losses
5° Step: Total Combine Loss
6° Step: See the Guidance Chart
7° Step: Loss Percentage
Loss Calculation
Section : 35 - Basic Adjustments
Basic Adjustment Table
Cutting Height
Adjusting Automatic Header Control (AHC) and/or Cutting Platform Side Tilt Master System
Floating Roll Height
Tension of the Conveyor Belt Chains
Separation Unit-Adjustable Concave Extension
Straw Walker Curtain
Type of Straw Walker
Straw Walker Risers
Cleaning Unit-Shoes
Chaffer Extension Tilt
Grain Saver System ("Grain Saver" System for Sloping Terrains)
Chaffer and Extension for Corn
Catch Plate
Air Direction
Lower Auger Cover
Straw Chopper-Placing in Working Position
Stake
Assembling the Straw Distributor
Adjusting the Guides
Position of Counterblades
To Reduce the Straw Chopper Speed
To Turn Off the Straw Chopper
Straw Chopper Alarms
Shield Openings-Right Hand Side Shield
Left Hand Side Shields
Ground Speed Variator Shield Opening
Drive Belt Shield Opening
Feeder Transmission Shield Opening
Section : 40 - Fuel, Lubricant, and Coolant
Fuel
Replenishing the Fuel Tank
JD 15W-40 Oil for Diesel Engines
Capacities
Engine Coolant
Cooling System Capacity
Changing Transmission Oil
Final Drives
Hydraulic System Oil
Hydraulic System Oil-Level
Oil Deposit for the Brake and Clutch System
Grease
Storage of Lubricants
Use Only Original Parts
Section : 45 - Maintenance
Periodic Service Table
Lubrication Points-Daily or Every 10 Hours (Left Hand Side)
Lubrication Points-Daily or Every 10 Hours (Right Hand Side)
Lubrication Points-Every 50 Hours (Left Hand Side)
Lubrication Points-Every 50 Hours (Right Hand Side)
Service During the First 100 Hours of Operation
Every 10 Hours
After the First 100 Hours
Every 250 Hours
Every 500 Hours
Every 1000 Hours
Every 1500 Hours
Engine-Work Platform
Inspecting the Crankshaft Dampener
Adjusting the Engine Valves
Crankcase Oil Level
Changing the Engine Oil
Do Not Alter the Fuel System
Fuel System
Fuel Tank Decanter
Cleaning the Pre-Filter with Water Separator
Draining Water From Fuel Pre-Filter
Fuel Pump
Bleeding Engine Filter Fuel
Checking the Injection Nozzles
Purging Fuel from the Injection Nozzles
Review the Injection Nozzles'
Changing the Fuel Filter
Engine Coolant
Coolant Level
Rotating Radiator Filter
Cleaning the Radiator Externally
Cleaning the Cooling System Internally
Engine Coolant Drain Tap
Engine Coolant Drain Tap on the Engine Block
Changing Thermostats
Fan Belt and Water Pump
Aspiration System
Pre-Filter
Engine Filtering Element
Changing the Engine Filtering Elements
Compressed Air Deposit
Draining the Air Deposit
Air-Conditioning System-Adjusting the Compressor Belt Tension
Air-Conditioning System-Coolant Level
Cleaning Condenser
Pre-Filter Screens
Disassembling the Paper Filtering Element (Main Filter)
Disassembling the Air Circulator Filter
Cleaning the Paper Filtering Element
Reinstalling the Paper Filtering Element (Main Filter)
Cleaning the Evaporator
"Posi-Torq" Variator
Top Unit of the "Posi-Torq" Variator
Lower Unit of the "Posi-Torq" Variator
Lubricating the Top Unit
Lubricating the Lower Unit
Replacing the Drive Posi-Torq Belts
Adjusting the Work Brakes
Park Brake Adjustment
Adjusting the Clutch
Gear Box and Differential
Final Drives
Adjusting the Play on the Bearings on the Final Drive Shaft End
Front Axle
Rear Wheel Alignment
Air Inlet
Inflating the Tires and Cleaning
Recommended Inflation Pressures
Batteries
Fuse and Relay Box
Replacing Fuses
Description of Fuses and Relays
Hydraulic Pump Belt Tensioning
Hydraulic System Oil Level
Hydraulic System Oil Filter
Changing the Oil
Replenishing the System
Transmission from the Beater to the Feeder House
Adjusting the Feeder House Slip Clutch
Transmission from the Feeder to the Cutting Platform
Replacing the Feeder House Drive Belt
Cylinder Deflector Front Inspection Cover
Cylinder Side Inspection Covers
Stone Trap
Cylinder Rasp Bars
Cylinder Reversal
Threshing Drive-Belt Tension
Adjusting the Mechanical Variator
Replacing the Threshing Drive Belt
Adjusting the Hydraulic Variator
Parallelism Between the Concave and the Cylinder
Adjusting the Opening Between the Concave and the Cylinder
Replacing the Cylinder Variator Belt
Special Anti-Wear Plates for the Beater
Cylinder Deflector
Bar Concave Closure Plates
Toothed Concave Closure Plates
Straw Walker Transmission
Slip Clutch
Cleaning Unit-Cleaning System Arms and Bell Cranks
Removing the Chaffer Extension
Removing the Sieve
Cleaning the Shoes
Opening the Large Pan
Fan Variator Transmission
Replacing the Fan Speed Variator Belt
Elevators
Chain Tension
Lower Elevator Augers
Tailings Elevator
Clean Grain Elevator
Grain Tank Cover
Top Auger Drive
Unloading Auger Feeder
Automatic Unloading Device
Unloading System Transmission
Straw Spreader and Chopper
Section : 50 - Storage
At the End of Each Season
At the End of Each Season-Engine
At the End of Each Season-Air-Conditioner
At the Start of Each Season-Combine
At the Start of Each Season-Engine
At the Start of Each Season-Air-Conditioning System
Chains
Section : 55 - Accessories
Bar Cylinder Closure Plates
Chain Transmission to the Cylinder
Cover for the Stone Trap
Straw Walker Riser Kit
Second Straw Walker Curtain
Chaffer Extension
Special Corn Kit
Straw Spreader
Counterweights
John Deere Corn and Cutting Platforms Transport Car
Multiple Calibrator
Crawler Track-Components
Preparing the Combine
Fastening the Crawler Track
Combine Ladder Adaptation
Checking the Drive Wheel Alignment
Checking the Parallelism Between Crawler Tracks
Tensioning the Crawler Track
Maintenance and Precautions
Support Axle Maintenance
Checking Crawler Track Component Wear
Section : 60 - Specifications
Combines
Drive Track Specifications
Dimensions
Dimensions
Metric Bolt Torque Values
Bolt Torque Values in Inches
Serial Number
Combine
Section : IBC - John Deere keeps you on the job
John Deere Parts
The Right Tools
Well-Trained Technicians
Prompt Assistance
