John Deere 115 118 And 120 Series Flail Shredders Operators Manual OMP63099
Format: HTML
Brand: John Deere
Type of Machine: Shredders
Model: John Deere 115 118 And 120 Series Flail Shredders
Parts Number: OMP63099
Foreword
Identification View
A Message to Our Customers
Preliminary Checks
Regions and Country Versions
Section 05 - Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Keep Riders Off Machine
Prepare for Emergencies
Wear Protective Clothing
Use Seat Belt Properly
Use Safety Lights and Devices
Practice Safe Maintenance
Avoid High-Pressure Fluids
Store Attachments Safely
Protect Against Noise
Stay Clear of Rotating Drivelines
Section 10 - Safety signs
Rotor Drive Shield label
Flail Shredder Front Side Labels
Rotor Drive label
Flail Shredder Rear Side label
Gear Case Shield Label
Hitch label
Section 15 - Preparing the Tractor
Tractor Size
Positioning Tractor Drawbar
Adjusting Tractor Drawbar and Hitch
Checking Ballast, Wheel Spacing, and Tire Inflation
Tractor Brakes
Section 20 - Preparing the Machine
Adjusting Wheel Spacing on Drawn Flail Shredders
Before You Start
Jack stand
Place jack stand in vertical position
Section 25 - Operating the Machine
Brake-in the Shredder
Follow Safe Operating Procedures
Operating Shredder for Best Performance
Maintaining Rotor Balance
Adjusting Rotor Drive Belts
Adjusting Cutting Height on Flail Shredders
Skid plates
Support stand
Section 30 - Attaching and Detaching
Attaching Shredder to Tractor
Detaching Shredder from Tractor
Use Correct Hose Tips
Attaching PTO Driveline
Checking operation of depth control hydraulic cylinder
Section 35 - Transporting
Use a Safety Chain
Tow Loads Safely
Observe Maximum Transport Speed
Transporting Flail Shredder using regular supports
Transporting Flail Shredder Using Easy-End Transport
Installing transport lockup
Preparing the Shredder for Transport
Follow Safe Transport Procedures
Section 40 - Attachments
Disk Hitch
Center Crop Divider
Safety chain
Crop Deflectors
Rubber deflectors
Easy-End Transport
PTO Driveline used on Flail Shredders
Section 45 - Assembly
Set-Up Time
Assembling Shredder Safely
Assembling Flail Shredder
Installing Warning Lights
Section 50 - Trouble Shooting
Knife Troubleshooting
General Troubleshooting
Operation Troubleshooting
Section 55 - Lubrication and Maintenance
Lubricating and Maintaining Machine Safely
Gear Case Lubricant
Grease for General Use
Perform Lubrication and Maintenance
Lubrication Intervals
PTO Driveline
Wheel Support
Drive Pulley
Wheel Support Bar
Adding Oil to Gear Case
Wheel Bearing
Section 60 - Service
Practice Safe Service Procedures
Rotor Knives
Inspecting Knives
Inspecting Knife Fasteners
(Standard, 68º and Hard Surfaced Knives)
(Cupped Knives)
Replacing Knives
(Standard, 68º and Hard Surfaced)
Gear Case Service
Bearing Guards
Rubber deflectors (Optional)
Bearing Locking Collars
Rotor Drive Belts
Wheel Bearings
Adjusting the Pulleys
Section 65 - Storage
End of Season
Beginning of Season
Belts
Operator's manual container
Section 70 - Specifications
Specifications
Serial Number
Section IBC - John Deere Service Keeps You On Job
John Deere Is At Your Service
John Deere Parts
The Right Tools
Well-Trained Technicians
Prompt Service
Format: HTML
Brand: John Deere
Foreword
Identification View
Preliminary Checks
Section 05 - Safety
Rotor Drive label
Hitch label
Tractor Size
Tractor Brakes
Before You Start
Jack stand
Skid plates
Support stand
Use a Safety Chain
Tow Loads Safely
Disk Hitch
Center Crop Divider
Safety chain
Crop Deflectors
Rubber deflectors
Easy-End Transport
Set-Up Time
Gear Case Lubricant
PTO Driveline
Wheel Support
Drive Pulley
Wheel Support Bar
Wheel Bearing
Rotor Knives
Inspecting Knives
(Cupped Knives)
Replacing Knives
Gear Case Service
Bearing Guards
Rotor Drive Belts
Wheel Bearings
End of Season
Beginning of Season
Belts
Specifications
Serial Number
John Deere Parts
The Right Tools
Prompt Service
- JOHN DEERE CODE DTC LIST
