John Deere 11 One-Row Mounted Cotton Picker Parts Catalog PC0638
- Download this document, you need 250 Gallons
Brand: John Deere
Type of Machine: Mounted Cotton Picker
Model: John Deere 11 One-Row Mounted Cotton Picker
Part Number: PC0638
Number of Pages: 92 Pages
ALPHABETICAL INDEX
A
Air Stack (3010 and 4010 Tractors)
Auxiliary Balance Spring (50 and 60 Tractors)
B
Basket
Basket Cylinder Oil Lines (50 and 60 Tractors)
Basket Cylinder Oil Lines (430, 420, 530, 520, 630, 620, 730, and 720 Tractors)
Basket Cylinder Oil Lines (2010, 3010, and 4010 Tractors)
Basket Lid
Basket Support
Bottom Frame (R.H. Only Shown)
C
Center Shield (For 11 Cotton Pickers Prior to Serial No. 11-351) (430 and 420 Tractors)
Center Shield (For 11 Cotton Pickers Prior to Serial No. 11-351) (530, 520, 630, and 620 Tractors)
Center Shield (For 11 Cotton Pickers Serial No. 11-351 and Up)
Cotton Door and Fan Suction Pipes, L.H.
Cotton Door and Fan Suction Pipes, R.H.
Decalcomania Set and Operator's Manual
Doffer
Drive Gears in Picking Unit Upper Housing
Drive Shaft for Picking Unit
Drive Shaft Shield (For Machines Prior to Serial No. 11-754 Without Pressure Trip Clutch)
Drive Shaft Shield (For Machines with Pressure Trip Clutch and Machines Serial No. 11-754 and Up Without Pressure Trip Clutch)
F
Fan Discharge Pipe
Fan Housing
Fan Shaft, Blade, and Drive
Frame for Fan Housing (430 and 420 Tractors)
Frame for Fan Housing and PTO Flipper Guard Chain (50, 60, 530, 520, 630, 620, 730, and 720 Tractors
Frame for Fan Housing, Main Frame Rear Mounting Bracket and R.H. Stabilizer Bracket (2010, 3010, and 4010 Tractors)
Front Wheel Shields (For 11 Cotton Pickers Prior to Serial No. 11-351) (430, 420, 530, 520, 630, and 620 Tractors)
Front Wheel Shields (For 11 Cotton Pickers Serial No. 11-351 and Up)
Hydraulic Cylinder for Basket
I
ID VIEW
L
Lift Bar and Balance Spring
Lighting Equipment
Lubricator
M
Main Drive (430, 420, 530, 520, 630, 620, 730, 720, 50, and 60 Tractors)
Main Drive (2010, 3010, and 4010 Tractors)
Main Drive Shields (430 and 420 Tractors)
Main Drive Shields (2010, 3010, 4010, 530, 520, 630, 620, 730, 720, 50, and 60 Tractors)
Main Frame and Mounting Brackets
Main Frame Front Mounting Brackets and Basket Supports (2010, 3010, and 4010 Tractors)
Muffler Shields (2010, 3010, and 4010 Tractors)
P
Picker Bar
Picker Drum
Picking Unit Drive Bevel Gear Housing with Pressure Trip Clutch
Picking Unit Drive Bevel Gear Housing Without Pressure Trip Clutch
Plant Shield (For 11 Cotton Picker Prior to Serial No. 11-351) (R.H.)
Plant Shield (For 11 Cotton Picker Serial No. 11-351 and Up)
Pressure Plates
Pressure Plates with Fingers
Pressure Trip Clutch Control
PTO Lever Extension (2010 Tractor)
S
Side Sheets and Panels, L.H.
Side Sheets and Panels, R.H.
Spindle Moisteners
Stabilizer Bars
Stalk Lifters and Front Shields
T
Tools, Wetting Agent, and Spindle Lubricant
Tractor Muffler Shield (430, 420, 530, 520, 630, 620, 730, 720, 50, and 60 Tractors)
Tractor Radiator Screen (530 and 520 Tractors)
Tractor Side Shield (430 and 420 Tractors)
Tractor Side Shield (530 and 520 Tractors)
Tractor Side Shield (630 and 620 Tractors)
Tractor Side Shield (2010 Tractors)
Tractor Side Shield (3010 and 4010 Tractors)
Tunnel Front Mounting and Rear Basket Support Brackets (R.H. Shown)
U
Unit Lift Arms (L.H. Shown) (50 and 60 Tractors)
Unit Lift Arms (L.H. Shown) (430, 420, 530, 520, 630, 620, 730, and 720 Tractors)
Unit Lift Arms (L.H. Shown) (2010, 3010, and 4010 Tractors)
Unit Lift Hydraulic Selector Valve (50 and 60 Tractors)
Unit Lift Stop
W
Water Filter
Water Lines from Supply Tank to Moisteners For Machines Before No. 11-351 Not Converted to Dual Line Selective Moisture Control
Water Lines from Supply Tank to Moisteners with Dual Line Selective Moisture Control
Water Metering Valve
Water Supply Tank
Brand: John Deere
Part Number: PC0638
ALPHABETICAL INDEX
A
B
Basket
Basket Lid
Basket Support
C
Doffer
F
Fan Discharge Pipe
Fan Housing
I
ID VIEW
L
Lighting Equipment
Lubricator
M
P
Picker Bar
Picker Drum
Pressure Plates
S
Spindle Moisteners
Stabilizer Bars
T
U
Unit Lift Stop
W
Water Filter
Water Supply Tank
- JOHN DEERE CODE DTC LIST
